    T113-i emmc EXT4-fs (mmcblk0p5): error loading journal
    • X
      xiandaozhang LV 3 最后由 编辑
      采用全志T113-i芯片与江波龙emmc 运行一段时间后rootfs无法挂载了是什么情况,刚开始是好的现场跑了两个月就挂了
      [ 11.094820] alloc_fd: slot 0 not NULL!
      [ 11.099554] Waiting 5 sec before mounting root device...
      [ 16.307111] JBD2: Invalid checksum recovering block 1611 in log
      [ 16.316364] JBD2: recovery failed
      [ 16.320100] EXT4-fs (mmcblk0p5): error loading journal
      [ 16.332142] VFS: Cannot open root device "mmcblk0p5" or unknown-block(179,5): error -5
      [ 16.341102] Please append a correct "root=" boot option; here are the available partitions:
      [ 16.350505] b300 7634944 mmcblk0
      [ 16.350508] driver: mmcblk
      [ 16.358208] b301 17219 mmcblk0p1 a0085546-4166-744a-a353-fca9272b8e45
      [ 16.358211]
      [ 16.368310] b302 1024 mmcblk0p2 a0085546-4166-744a-a353-fca9272b8e46
      [ 16.368312]
      [ 16.378497] b303 1024 mmcblk0p3 a0085546-4166-744a-a353-fca9272b8e47
      [ 16.378500]
      [ 16.388609] b304 65536 mmcblk0p4 a0085546-4166-744a-a353-fca9272b8e48
      [ 16.388611]
      [ 16.398680] b305 7302848 mmcblk0p5 a0085546-4166-744a-a353-fca9272b8e49
      [ 16.398682]
      [ 16.408803] b306 1024 mmcblk0p6 a0085546-4166-744a-a353-fca9272b8e4a
      [ 16.408806]
      [ 16.418881] b307 16384 mmcblk0p7 a0085546-4166-744a-a353-fca9272b8e4b
      [ 16.418883]
      [ 16.428954] 103:00000 193004 mmcblk0p8 a0085546-4166-744a-a353-fca9272b8e4c
      [ 16.428956]
      [ 16.439036] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5)
      [ 16.448499] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #30
      [ 16.455229] Hardware name: Generic DT based system
      [ 16.460621] [<c010e388>] (unwind_backtrace) from [<c010a92c>] (show_stack+0x10/0x14)
      [ 16.469305] [<c010a92c>] (show_stack) from [<c0d1c7d8>] (dump_stack+0x7c/0x98)
      [ 16.477409] [<c0d1c7d8>] (dump_stack) from [<c011c5cc>] (panic+0x100/0x3d4)
      [ 16.485221] [<c011c5cc>] (panic) from [<c130134c>] (mount_block_root+0x260/0x304)
      [ 16.493616] [<c130134c>] (mount_block_root) from [<c130158c>] (prepare_namespace+0x118/0x178)
      [ 16.503180] [<c130158c>] (prepare_namespace) from [<c0d315b8>] (kernel_init+0x8/0x118)
      [ 16.512062] [<c0d315b8>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
      [ 16.520547] Exception stack(0xef079fb0 to 0xef079ff8)
      [ 16.526209] 9fa0: 00000000 00000000 00000000 00000000
      [ 16.535374] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      [ 16.544539] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
      [ 16.551960] CPU1: stopping
      [ 16.554993] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #30
      [ 16.561723] Hardware name: Generic DT based system
      [ 16.567099] [<c010e388>] (unwind_backtrace) from [<c010a92c>] (show_stack+0x10/0x14)
      [ 16.575780] [<c010a92c>] (show_stack) from [<c0d1c7d8>] (dump_stack+0x7c/0x98)
      [ 16.583877] [<c0d1c7d8>] (dump_stack) from [<c010c710>] (handle_IPI+0xc0/0x168)
      [ 16.592073] [<c010c710>] (handle_IPI) from [<c063ff38>] (gic_handle_irq+0x70/0x78)
      [ 16.600560] [<c063ff38>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
      [ 16.608944] Exception stack(0xef09bf80 to 0xef09bfc8)
      [ 16.614605] bf80: 0000111c ef6c99f4 00000000 c0115440 00000002 ef09a000 c1405b64 c1405ba4
      [ 16.623772] bfa0: 4000406a 410fc075 00000000 00000000 00000000 ef09bfd0 c0108020 c0108024
      [ 16.632935] bfc0: 60000113 ffffffff
      [ 16.636847] [<c01021cc>] (__irq_svc) from [<c0108024>] (arch_cpu_idle+0x2c/0x38)
      [ 16.645141] [<c0108024>] (arch_cpu_idle) from [<c0142de0>] (do_idle+0xb8/0x120)
      [ 16.653336] [<c0142de0>] (do_idle) from [<c01430dc>] (cpu_startup_entry+0x18/0x1c)
      [ 16.661824] [<c01430dc>] (cpu_startup_entry) from [<40102c0c>] (0x40102c0c)
      [ 16.669643] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5) ]---
