    t113 由256MB flash更换flash 为512MB,启动出现如下错误??? 有知道的大佬吗?
    • Q
      quanzhi111 LV 5 最后由 q1215200171 编辑
      [159]HELLO! BOOT0 is starting!
      [161]BOOT0 commit : 069ed30b88
      [164]set pll start
      [166]fix vccio detect value:0xc0
      [173]periph0 has been enabled
      [176]set pll end
      [178][pmu]: bus read error
      [180]board init ok
      [182]enable_jtag
      [184]get_pmu_exist() = -1
      [186]DRAM BOOT DRIVE INFO: V0.34
      [189]DRAM CLK = 792 MHz
      [192]DRAM Type = 3 (2:DDR2,3:DDR3)
      [195]DRAMC ZQ value: 0x7b7bfb
      [198]DRAM ODT value: 0x42.
      [200]ddr_efuse_type: 0x0
      [204]DRAM SIZE = 1024 MB
      [211]DRAM simple test OK.
      [213]rtc standby flag is 0x0, super standby flag is 0x0
      [218]dram size =1024
      [221]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [226]block from 8 to 32
      [332]Check is correct. Find a good uboot copy at block 8
      [337]dma 0x2b3c4 int is not used yet
      [340]dma 0x2b3c4 int is free, you do not need to free it again
      [346]Entry_name        = u-boot
      [353]Entry_name        = optee
      [358]Entry_name        = dtb
      [361]Jump to second Boot.
      M/TC: OP-TEE version: 2a99a16f (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Thu Aug 17 11:13:02 UTC 2023 arm
      E/TC:0 0 platform_standby_fdt_parse:126 no pmu0 node
      E/TC:0 0 sunxi_twi_parse_from_dt:121 no pmu node
      U-Boot 2018.07-g7962ea9-dirty (Nov 06 2025 - 16:04:31 +0800) Allwinner Technology
      [00.431]CPU:   Allwinner Family
      [00.434]Model: sun8iw20
      [00.436]DRAM:  1 GiB
      [00.440]Relocation Offset is: 3ceb6000
      [00.468]secure enable bit: 0
      E/TC:0   fdt_getprop_u32:336 prop trace_level not found
      [00.482]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.488]gic: sec monitor mode
      SPI ALL:   ready
      [00.493]line:703 init_clocks
      [00.496]flash init start
      [00.498]workmode = 0,storage type = 0
      [00.505]sunxi-spinand-phy: spinand sample_mode:1 sample_delay:1d
       0: boot0               0x00200000      0x00000000      1
       1: uboot               0x00600000      0x00200000      1
       2: secure_storage      0x00200000      0x00800000      1
       3: sys                 0x1f600000      0x00a00000      0
      active partition: nand0,0 - (boot0) 0x00200000 @ 0x00000000
      defaults:
      mtdids  : nand0=nand
      mtdparts: mtdparts=nand:2048k@0(boot0)ro,6144k@2097152(uboot)ro,2048k@8388608(secure_storage)ro,-(sys)
      [00.647]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      [00.750]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      [00.952]ubi0: attaching mtd4
      [01.321]ubi0: scanning is finished
      [01.327]ubi0: attached mtd4 (name "sys", size 502 MiB)
      [01.332]ubi0: PEB size: 524288 bytes (512 KiB), LEB size: 516096 bytes
      [01.338]ubi0: min./max. I/O unit sizes: 8192/8192, sub-page size 4096
      [01.344]ubi0: VID header offset: 4096 (aligned 4096), data offset: 8192
      [01.351]ubi0: good PEBs: 1002, bad PEBs: 2, corrupted PEBs: 0
      [01.356]ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
      [01.363]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [01.370]ubi0: available PEBs: 0, total reserved PEBs: 1002, PEBs reserved for bad PEB handling: 38
      [01.379]sunxi flash init ok
      [01.382]drv_disp_init
      ** Unable to read file lcd_compatible_index.txt **
      [01.485]disp_fat_load for lcd config failed
      [01.514]drv_disp_init finish
      [01.584]Loading Environment from SUNXI_FLASH... OK
      [01.604]boot_gui_init:start
      bad fb1_cfg[w=0,h=0,bpp=32,format=0]
      [01.981]boot_gui_init:finish
      [01.998]bmp_name=bootlogo.bmp size 3072054
      [02.088]LCD open finish
      [02.216]Item0 (Map) magic is bad
      [02.246]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [02.257]usb prepare ok
      [02.560]overtime
      [02.563]do_burn_from_boot usb : no usb exist
      [02.643]update bootcmd
      [02.658]change working_fdt 0x7c875e68 to 0x7c855e68
      [02.702]disp_fat_load for lcd config failed
      writing lcd_compatible_index.txt
      [02.723]offset should be 0 but 0x199d when write to new volume boot-resource
      Error: writing contents
      ** Unable to write "lcd_compatible_index.txt" from sunxi_flash 0:1 **
      [02.738]do_fat_fswrite for lcd config failed
      [02.760]disp_fat_load for lcd config failed
      [02.765]update dts
      [03.274]no vendor_boot partition is found
      The loading address of the kernel is not in the boot image
      ERROR: reserving fdt memory region failed (addr=41b00000 size=100000)
      ERROR: reserving fdt memory region failed (addr=7c955000 size=3e8000)
      [03.324]Starting kernel ...
      [    0.000000] Linux version 5.4.61 (root@alientek) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #98 SMP PREEMPT Fri Oct 31 11:38:17 CST 2025
      [    0.000000] OF: fdt: Machine model: ATK-DLT113IS,sun8iw20
      [    0.000000] earlycon: uart8250 at MMIO32 0x02500000 (options '')
      [    0.000000] printk: bootconsole [uart8250] enabled
      [    0.000000] Reserved memory: created DMA memory pool at 0x42200000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node vdev0buffer@42200000, compatible id shared-dma-pool
      [    0.000000] Reserved memory: created DMA memory pool at 0x42244000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node dsp0_rpbuf@42244000, compatible id shared-dma-pool
      [    0.000000] Reserved memory: created DMA memory pool at 0x42900000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node vdev0buffer@42900000, compatible id shared-dma-pool
      [    0.000000] Reserved memory: created DMA memory pool at 0x42944000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node c906_rpbuf@42980000, compatible id shared-dma-pool
      [    0.000000] cma: Reserved 8 MiB at 0x7f800000
      [    0.000000] On node 0 totalpages: 260184
      [    0.000000]   Normal zone: 1536 pages used for memmap
      [    0.000000]   Normal zone: 194648 pages, LIFO batch:63
      [    0.000000]   HighMem zone: 65536 pages, LIFO batch:15
      [    0.000000] percpu: Embedded 15 pages/cpu s30976 r8192 d22272 u61440
      [    0.000000] pcpu-alloc: s30976 r8192 d22272 u61440 alloc=15*4096
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258648
      [    0.000000] Kernel command line: ubi.mtd=sys earlycon=uart8250,mmio32,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyAS0,115200 loglevel=8 root=ubi0_5 rootfstype=ubifs,rw init=/init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:UDISK@ubi0_6: cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.07-g7962ea9-dirty(11/06/2025-16:04:31) mbr_offset=1032192 disp_reserve=4096000,0x7c955000 aw-ubi-spinand.ubootblks=24 androidboot.dramfreq=792 androidboot.dramsize=1024 mtdparts=nand:2048k@0(boot0)ro,6144k@2097152(uboot)ro,2048k@8388608(secure_storage)ro,-(sys) uboot_backup=ubootA
      [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [    0.000000] Memory: 994920K/1040736K available (7168K kernel code, 446K rwdata, 2604K rodata, 1024K init, 198K bss, 37624K reserved, 8192K cma-reserved, 249952K highmem)
      [    0.000000] random: get_random_bytes called from start_kernel+0x250/0x3d0 with crng_init=0
      [    0.008390] Switching to timer-based delay loop, resolution 41ns
      [    0.014840] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.025131] Console: colour dummy device 80x30
      [    0.029830] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.040707] pid_max: default: 32768 minimum: 301
      [    0.045711] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [    0.053392] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [    0.062176] CPU: Testing write buffer coherency: ok
      [    0.067659] /cpus/cpu@0 missing clock-frequency property
      [    0.073239] /cpus/cpu@1 missing clock-frequency property
      [    0.078827] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.085367] Setting up static identity map for 0x40100000 - 0x40100060
      [    0.092381] rcu: Hierarchical SRCU implementation.
      [    0.097884] smp: Bringing up secondary CPUs ...
      [    0.103950] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.104105] smp: Brought up 1 node, 2 CPUs
      [    0.114353] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.120818] CPU: All CPU(s) started in SVC mode.
      [    0.126236] devtmpfs: initialized
      [    0.143182] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.151740] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.162095] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [    0.169721] pinctrl core: initialized pinctrl subsystem
      [    0.176728] NET: Registered protocol family 16
      [    0.183263] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.236724] rtc_ccu: sunxi ccu init OK
      [    0.243314] ccu: sunxi ccu init OK
      [    0.247439] r_ccu: sunxi ccu init OK
      [    0.293080] sun6i-dma 3002000.dma-controller: sunxi dma probed
      [    0.303917] iommu: Default domain type: Translated
      [    0.309243] sunxi iommu: irq = 24
      [    0.314281] SCSI subsystem initialized
      [    0.318586] usbcore: registered new interface driver usbfs
      [    0.324351] usbcore: registered new interface driver hub
      [    0.330059] usbcore: registered new device driver usb
      [    0.336221] mc: Linux media interface: v0.10
      [    0.340780] videodev: Linux video capture interface: v2.00
      [    0.347940] Advanced Linux Sound Architecture Driver Initialized.
      [    0.355007] Bluetooth: Core ver 2.22
      [    0.358880] NET: Registered protocol family 31
      [    0.363529] Bluetooth: HCI device and connection manager initialized
      [    0.370203] Bluetooth: HCI socket layer initialized
      [    0.375305] Bluetooth: L2CAP socket layer initialized
      [    0.380611] Bluetooth: SCO socket layer initialized
      [    0.386033] pwm module init!
      [    0.399931] g2d 5410000.g2d: Adding to iommu group 0
      [    0.405839] G2D: rcq version initialized.major:249
      [    0.412438] clocksource: Switched to clocksource arch_sys_counter
      [    0.428158] sun8iw20-pinctrl pio: initialized sunXi PIO driver
      [    0.448291] thermal_sys: Registered thermal governor 'step_wise'
      [    0.448299] thermal_sys: Registered thermal governor 'user_space'
      [    0.454677] thermal_sys: Registered thermal governor 'power_allocator'
      [    0.461636] NET: Registered protocol family 2
      [    0.473769] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    0.482588] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
      [    0.490774] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.498397] TCP: Hash tables configured (established 8192 bind 8192)
      [    0.505205] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    0.512194] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    0.519815] NET: Registered protocol family 1
      [    0.525589] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
      [    0.534307] spi spi0: spi0 supply spi not found, using dummy regulator
      [    0.541392] sunxi_spi_resource_get()2480 - sample_mode:1 sample_delay:29
      [    0.548474] sunxi_spi_request_dma()966 - [spi0] Request DMA channel dma0chan0 (tx) and dma0chan1 (rx) for DMA transfers
      [    0.559854] sunxi_spi_clk_init()2530 - [spi0] mclk 100000000
      [    0.566712] sunxi_spi_probe()3001 - [spi0]: driver probe succeed, base f0860000, irq 43
      [    0.577226] Initialise system trusted keyrings
      [    0.582069] workingset: timestamp_bits=30 max_order=18 bucket_order=0
      [    0.596323] ntfs: driver 2.1.32 [Flags: R/W].
      [    0.601207] fuse: init (API version 7.31)
      [    0.634129] NET: Registered protocol family 38
      [    0.638811] Key type asymmetric registered
      [    0.643231] Asymmetric key parser 'x509' registered
      [    0.648397] bounce: pool size: 64 pages
      [    0.652533] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
      [    0.660286] io scheduler mq-deadline registered
      [    0.665033] io scheduler kyber registered
      [    0.669341] atomic64_test: passed
      [    0.675520] pwm-backlight backlight: backlight supply power not found, using dummy regulator
      [    0.685318] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
      [    0.693860] [DISP]disp_module_init
      [    0.698090] disp 5000000.disp: Adding to iommu group 0
      [    0.704154] [DISP] disp_init,line:2372:
      [    0.704160] smooth display screen:0 type:1 mode:4
      [    0.730006] [pq_init]+++
      [    0.733056] display_fb_request,fb_id:0
      [    0.757955] disp_al_manager_apply ouput_type:1
      [    0.762862] [DISP] lcd_clk_config,line:777:
      [    0.762875] disp 0, clk: pll(402000000),clk(402000000),dclk(67000000) dsi_rate(67000000)
      [    0.762875]      clk real:pll(396000000),clk(396000000),dclk(99000000) dsi_rate(150000000)
      [    0.763108] [DISP]disp_module_init finish
      [    0.790949] sunxi_sid_init()783 - insmod ok
      [    0.796141] pwm-regulator: supplied by regulator-dummy
      [    0.805602] Freeing logo buffer memory: 4000K
      [    0.889538] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
      [    0.898280] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
      [    0.906937] uart uart0: uart0 supply uart not found, using dummy regulator
      [    0.914824] uart0: ttyAS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
      [    0.923398] sw_console_setup()1831 - console setup baud 115200 parity n bits 8, flow n
      [    0.931758] printk: console [ttyAS0] enabled
      [    0.941039] printk: bootconsole [uart8250] disabled
      [    0.952667] uart uart1: uart1 supply uart not found, using dummy regulator
      [    0.960748] uart1: ttyAS1 at MMIO 0x2500400 (irq = 35, base_baud = 1500000) is a SUNXI
      [    0.970357] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
      [    0.979513] uart uart2: uart2 supply uart not found, using dummy regulator
      [    0.987623] uart2: ttyAS2 at MMIO 0x2500800 (irq = 36, base_baud = 1500000) is a SUNXI
      [    0.997414] uart uart3: uart3 supply uart not found, using dummy regulator
      [    1.005532] uart3: ttyAS3 at MMIO 0x2500c00 (irq = 37, base_baud = 1500000) is a SUNXI
      [    1.015621] misc dump reg init
      [    1.019613] deinterlace 5400000.deinterlace: Adding to iommu group 0
      [    1.027355] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110
      [    1.036383] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [    1.043705] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    1.051039] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    1.058499] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [    1.065058] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [    1.072010] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [    1.079771] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=207 assert=1
      [    1.087642] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [    1.095798] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [    1.103530] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [    1.110314] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [    1.117910] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=206 assert=0
      [    1.127204] sunxi-spinand: AW SPINand MTD Layer Version: 2.5 20231129
      [    1.134479] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.15 20231114
      [    1.142365] sunxi-spinand-phy: not detect any munufacture from id table
      [    1.149841] sunxi-spinand-phy: get spi-nand Model from fdt fail
      [    1.156558] sunxi-spinand-phy: get phy info from fdt fail
      [    1.162654] sunxi-spinand-phy: not detect munufacture from fdt
      [    1.169300] sunxi-spinand-phy: detect munufacture from id table: Mxic
      [    1.176563] sunxi-spinand-phy: detect spinand id: ff0337c2 ffffffff
      [    1.183605] sunxi-spinand-phy: ========== arch info ==========
      [    1.190155] sunxi-spinand-phy: Model:               MX35LF4GE4AD
      [    1.196909] sunxi-spinand-phy: Munufacture:         Mxic
      [    1.202875] sunxi-spinand-phy: DieCntPerChip:       1
      [    1.208546] sunxi-spinand-phy: BlkCntPerDie:        2048
      [    1.214512] sunxi-spinand-phy: PageCntPerBlk:       64
      [    1.220271] sunxi-spinand-phy: SectCntPerPage:      8
      [    1.225952] sunxi-spinand-phy: OobSizePerPage:      128
      [    1.231809] sunxi-spinand-phy: BadBlockFlag:        0x1
      [    1.237677] sunxi-spinand-phy: OperationOpt:        0x7
      [    1.243552] sunxi-spinand-phy: MaxEraseTimes:       100000
      [    1.249702] sunxi-spinand-phy: EccFlag:             0x2
      [    1.255570] sunxi-spinand-phy: EccType:             10
      [    1.261338] sunxi-spinand-phy: EccProtectedType:    3
      [    1.267011] sunxi-spinand-phy: ========================================
      [    1.274444] sunxi-spinand-phy:
      [    1.277963] sunxi-spinand-phy: ========== physical info ==========
      [    1.284903] sunxi-spinand-phy: TotalSize:    512 M
      [    1.290282] sunxi-spinand-phy: SectorSize:   512 B
      [    1.295672] sunxi-spinand-phy: PageSize:     4 K
      [    1.300847] sunxi-spinand-phy: BlockSize:    256 K
      [    1.306236] sunxi-spinand-phy: OOBSize:      128 B
      [    1.311614] sunxi-spinand-phy: ========================================
      [    1.319043] sunxi-spinand-phy:
      [    1.322572] sunxi-spinand-phy: ========== logical info ==========
      [    1.329413] sunxi-spinand-phy: TotalSize:    512 M
      [    1.334793] sunxi-spinand-phy: SectorSize:   512 B
      [    1.340172] sunxi-spinand-phy: PageSize:     8 K
      [    1.345357] sunxi-spinand-phy: BlockSize:    512 K
      [    1.350727] sunxi-spinand-phy: OOBSize:      256 B
      [    1.356107] sunxi-spinand-phy: ========================================
      [    1.363601] sunxi-spinand-phy: block lock register: 0x00
      [    1.369642] sunxi-spinand-phy: feature register: 0x11
      [    1.375344] sunxi-spinand-phy: sunxi physic nand init end
      [    1.381879] Creating 4 MTD partitions on "sunxi_mtd_nand":
      [    1.388067] 0x000000000000-0x000000200000 : "boot0"
      [    1.403560] 0x000000200000-0x000000800000 : "uboot"
      [    1.412394] random: fast init done
      [    1.433626] 0x000000800000-0x000000a00000 : "secure_storage"
      [    1.453559] 0x000000a00000-0x000020000000 : "sys"
      [    1.685673] sunxi-spinand-phy: ecc error 0xf
      [    1.690468] sunxi-spinand-phy: phy blk 512 is bad
      [    1.952109] sunxi-spinand-phy: ecc error 0xf
      [    1.956920] sunxi-spinand-phy: phy blk 1025 is bad
      [    1.988236] random: crng init done
      [    2.484215] libphy: Fixed MDIO Bus: probed
      [    2.488822] CAN device driver interface
      [    2.493559] sun8iw20-pinctrl pio: unsupported function can0 on pin PB2
      [    2.500925] sun8iw20-pinctrl pio: unsupported function can0 on pin PB3
      [    2.509190] sunxi-awlink can@0x0: awlink driver probe ok ...
      [    2.515743] sun8iw20-pinctrl pio: unsupported function can1 on pin PB4
      [    2.523098] sun8iw20-pinctrl pio: unsupported function can1 on pin PB5
      [    2.531283] sunxi-awlink can@0x1: awlink driver probe ok ...
      [    2.538177] PPP generic driver version 2.4.2
      [    2.543278] PPP BSD Compression module registered
      [    2.548591] PPP Deflate Compression module registered
      [    2.554314] PPP MPPE Compression module registered
      [    2.559690] NET: Registered protocol family 24
      [    2.564838] usbcore: registered new interface driver asix
      [    2.570993] usbcore: registered new interface driver ax88179_178a
      [    2.577916] usbcore: registered new interface driver cdc_ether
      [    2.584564] usbcore: registered new interface driver net1080
      [    2.590968] usbcore: registered new interface driver cdc_subset
      [    2.597699] usbcore: registered new interface driver zaurus
      [    2.604056] usbcore: registered new interface driver cdc_ncm
      [    2.610485] usbcore: registered new interface driver qmi_wwan_q
      [    2.617237] usbcore: registered new interface driver qmi_wwan
      [    2.623701] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    2.631036] sunxi-ehci: EHCI SUNXI driver
      [    2.636082] get drvvbus-en is fail, 22
      [    2.640290] get ehci0-controller wakeup-source is fail.
      [    2.646289] sunxi ehci0-controller don't init wakeup source
      [    2.652595] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c97058, 0x:f0876000, irq_no:3c
      [    2.664885] sunxi-ehci 4101000.ehci0-controller: 4101000.ehci0-controller supply hci not found, using dummy regulator
      [    2.677253] sunxi-ehci 4101000.ehci0-controller: EHCI Host Controller
      [    2.684598] sunxi-ehci 4101000.ehci0-controller: new USB bus registered, assigned bus number 1
      [    2.694701] sunxi-ehci 4101000.ehci0-controller: irq 60, io mem 0x04101000
      [    2.742457] sunxi-ehci 4101000.ehci0-controller: USB 2.0 started, EHCI 1.00
      [    2.751261] hub 1-0:1.0: USB hub found
      [    2.755556] hub 1-0:1.0: 1 port detected
      [    2.760827] get drvvbus-en is fail, 22
      [    2.765098] get ehci1-controller wakeup-source is fail.
      [    2.771075] sunxi ehci1-controller don't init wakeup source
      [    2.777350] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c975b8, 0x:f08c3000, irq_no:3e
      [    2.789681] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [    2.802067] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    2.809368] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 2
      [    2.819320] sunxi-ehci 4200000.ehci1-controller: irq 62, io mem 0x04200000
      [    2.852471] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    2.861232] hub 2-0:1.0: USB hub found
      [    2.866527] hub 2-0:1.0: 1 port detected
      [    2.871737] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    2.878731] sunxi-ohci: OHCI SUNXI driver
      [    2.883818] get drvvbus-en is fail, 22
      [    2.888025] get ohci0-controller wakeup-source is fail.
      [    2.894034] sunxi ohci0-controller don't init wakeup source
      [    2.900313] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c97308
      [    2.910275] sunxi-ohci 4101400.ohci0-controller: 4101400.ohci0-controller supply hci not found, using dummy regulator
      [    2.922698] sunxi-ohci 4101400.ohci0-controller: OHCI Host Controller
      [    2.929963] sunxi-ohci 4101400.ohci0-controller: new USB bus registered, assigned bus number 3
      [    2.939909] sunxi-ohci 4101400.ohci0-controller: irq 61, io mem 0x04101400
      [    3.017438] hub 3-0:1.0: USB hub found
      [    3.021696] hub 3-0:1.0: 1 port detected
      [    3.026999] get drvvbus-en is fail, 22
      [    3.031210] get ohci1-controller wakeup-source is fail.
      [    3.037266] sunxi ohci1-controller don't init wakeup source
      [    3.043542] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c97868
      [    3.053493] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [    3.065890] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    3.073181] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 4
      [    3.082978] debugfs: Directory 'sunxi-ohci' with parent 'ohci' already present!
      [    3.091252] sunxi-ohci 4200400.ohci1-controller: irq 63, io mem 0x04200400
      [    3.167477] hub 4-0:1.0: USB hub found
      [    3.171736] hub 4-0:1.0: 1 port detected
      [    3.177110] usbcore: registered new interface driver cdc_acm
      [    3.183510] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
      [    3.192623] usbcore: registered new interface driver cdc_wdm
      [    3.199228] usbcore: registered new interface driver uas
      [    3.205377] usbcore: registered new interface driver usb-storage
      [    3.212182] usbcore: registered new interface driver ums-alauda
      [    3.218923] usbcore: registered new interface driver ums-cypress
      [    3.225751] usbcore: registered new interface driver ums-datafab
      [    3.232581] usbcore: registered new interface driver ums_eneub6250
      [    3.239577] usbcore: registered new interface driver ums-freecom
      [    3.246400] usbcore: registered new interface driver ums-isd200
      [    3.253140] usbcore: registered new interface driver ums-jumpshot
      [    3.260044] usbcore: registered new interface driver ums-karma
      [    3.266674] usbcore: registered new interface driver ums-onetouch
      [    3.273611] usbcore: registered new interface driver ums-realtek
      [    3.280414] usbcore: registered new interface driver ums-sddr09
      [    3.287316] usbcore: registered new interface driver ums-sddr55
      [    3.294065] usbcore: registered new interface driver ums-usbat
      [    3.300769] usbcore: registered new interface driver option
      [    3.307114] usbserial: USB Serial support registered for GSM modem (1-port)
      [    3.315873] ts probe start
      [    3.316329] input: 2009c00.rtp as /devices/platform/soc@3000000/2009c00.rtp/input/input0
      [    3.328761] ts probe success
      [    3.329447] sunxi-light-sensor 2009800.light-sensor: Sunxi Light Sensor Probe
      [    3.340813] sunxi-light-sensor 2009800.light-sensor: Configuring LRADC for light sensing
      [    3.350146] input: sunxi-light-sensor as /devices/platform/soc@3000000/2009800.light-sensor/input/input1
      [    3.361196] sunxi-light-sensor 2009800.light-sensor: Sunxi Light Sensor initialized successfully
      [    3.362530] sunxi-light-sensor 2009800.light-sensor: Light sensor thread started
      [    3.371404] sunxi_gpadc_init,2121, success
      [    3.384336] sunxi_gpadc_setup: get channel compare select failed
      [    3.391078] sunxi_gpadc_setup: get channel compare low data select failed
      [    3.398711] sunxi_gpadc_setup: get channel compare hig data select failed
      [    3.406346] sunxi_gpadc_setup: get channel scan data failed
      [    3.412610] sunxi_gpadc_setup:get channel0_compare_lowdata err!
      [    3.419250] sunxi_gpadc_setup:get channel0_compare_higdata err!
      [    3.425901] sunxi_gpadc_setup:get channel1_compare_lowdata err!
      [    3.432552] sunxi_gpadc_setup:get channel1_compare_higdata err!
      [    3.439457] input: sunxi-gpadc0 as /devices/virtual/input/input2
      [    3.446638] input: sunxi-gpadc1 as /devices/virtual/input/input3
      [    3.454734] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
      [    3.466935] sunxi-rtc 7090000.rtc: registered as rtc0
      [    3.472781] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:07 UTC (7)
      [    3.481673] sunxi-rtc 7090000.rtc: Fail to read dts property 'gpr_bootcount_pos'
      [    3.490009] reasonbase NULL
      [    3.493155] reason large than max, fix to hot reboot, save boot reason
      [    3.500476] invalid reason or reasonbase NULL
      [    3.505391] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [    3.511483] i2c /dev entries driver
      [    3.515605] IR NEC protocol handler initialized
      [    3.520689] IR RC5(x/sz) protocol handler initialized
      [    3.527050] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
      [    3.537237] [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
      [    3.547016] [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
      [    3.556697] [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
      [    3.568603] usbcore: registered new interface driver uvcvideo
      [    3.575086] USB Video Class driver (1.1.1)
      [    3.579680] sunxi cedar version 1.1
      [    3.583837] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    3.590170] VE: sunxi_cedar_probe power-domain init!!!
      [    3.595959] VE: install start!!!
      [    3.595959]
      [    3.601535] VE: cedar-ve the get irq is 44
      [    3.601535]
      [    3.608070] VE: ve_debug_proc_info:22d772d6, data:2f0b60ac, lock:5f97e52b
      [    3.608070]
      [    3.617366] VE: install end!!!
      [    3.617366]
      [    3.622459] VE: sunxi_cedar_probe
      [    3.627717] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    3.637036] Bluetooth: HCI UART driver ver 2.3
      [    3.642026] Bluetooth: HCI UART protocol H4 registered
      [    3.648115] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
      [    3.655480] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
      [    3.661879] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
      [    3.668487] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
      [    3.668487]
      [    3.677270] [XR_BT_LPM] bluesleep_probe: uart_index(1)
      [    3.686753] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [    3.696717] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    3.703036] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    3.709387] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    3.715864] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    3.722325] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    3.728886] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    3.735464] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    3.742008] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    3.749070] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    3.754709] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.765924] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    3.786111] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.810371] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
      [    3.816489] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    3.828194] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [    3.838140] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    3.844385] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    3.850735] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    3.857207] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    3.863666] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    3.870210] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    3.876764] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    3.883317] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    3.889880] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    3.899360] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.910564] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    3.930743] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.955026] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    3.962705] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    3.963376] usbcore: registered new interface driver usbhid
      [    3.975844] usbhid: USB HID core driver
      [    3.976652] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    3.980148] exFAT: Version 1.3.0
      [    3.990640] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.993049] sunxi-msgbox 3003000.msgbox: sunxi_msgbox_probe(): sunxi msgbox start probe
      [    4.011703] sunxi-msgbox 3003000.msgbox: sunxi_msgbox_probe(): sunxi msgbox probe success
      [    4.012477] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.021792] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver 2.2.1
      [    4.039563] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    4.046365] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    4.053138] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    4.059892] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    4.059923] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    4.066682] sunxi-rproc 3000008.dsp_rproc: failed to get firmware-name
      [    4.085638] remoteproc remoteproc0: dsp_rproc is available
      [    4.091889] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver probe ok
      [    4.099442] sunxi-rproc 6010000.c906_rproc: sunxi rproc driver 2.2.1
      [    4.107108] remoteproc remoteproc1: c906_rproc is available
      [    4.113520] sunxi-rproc 6010000.c906_rproc: sunxi rproc driver probe ok
      [    4.121134] rpmsg_tty_init: Sunxi rpmsg tty driver will init
      [    4.127572] rpmsg_tty_init: Sunxi rpmsg tty driver init ok
      [    4.134729] sunxi-rpbuf-controller rpbuf_controller@0: assigned reserved memory node c906_rpbuf@42980000
      [    4.145954] sunxi-rpbuf-controller rpbuf_controller@1: assigned reserved memory node dsp0_rpbuf@42244000
      [    4.160266] [AUDIOCODEC][sunxi_codec_parse_params][2441]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    4.160266]
      [    4.177523] [AUDIOCODEC][sunxi_codec_parse_params][2477]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [    4.188995] [AUDIOCODEC][sunxi_internal_codec_probe][2638]:codec probe finished
      [    4.198451] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    4.208325] [SNDCODEC][sunxi_card_init][598]:card init finished
      [    4.215600] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    4.226750] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input4
      [    4.238928] [SNDCODEC][sunxi_card_dev_probe][851]:register card finished
      [    4.247633] NET: Registered protocol family 10
      [    4.253686] Segment Routing with IPv6
      [    4.257921] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [    4.266198] NET: Registered protocol family 17
      [    4.271248] NET: Registered protocol family 15
      [    4.276253] can: controller area network core (rev 20170425 abi 9)
      [    4.283299] NET: Registered protocol family 29
      [    4.288304] can: raw protocol (rev 20170425)
      [    4.293109] can: broadcast manager protocol (rev 20170425 t)
      [    4.299464] can: netlink gateway (rev 20190810) max_hops=1
      [    4.305958] Bluetooth: RFCOMM TTY layer initialized
      [    4.311447] Bluetooth: RFCOMM socket layer initialized
      [    4.317274] Bluetooth: RFCOMM ver 1.11
      [    4.322380] Registering SWP/SWPB emulation handler
      [    4.328172] Loading compiled-in X.509 certificates
      [    4.336211] tv_probe()1540 - of_property_read_string tv_power failed!
      [    4.344035] get_key_map_info()210 - Failed to find "tvout" in dts.
      [    4.351108] tv probe finished!
      [    4.373556] sunxi-twi 2502c00.twi: 2502c00.twi supply twi not found, using dummy regulator
      [    4.384632] rtc-pcf8563 3-0051: low voltage detected, date/time is not reliable.
      [    4.393247] rtc-pcf8563 3-0051: registered as rtc1
      [    4.399254] sunxi:i2c_sunxi@2502c00.twi[INFO]: v2.6.5 probe success
      [    4.407638] sunxi-thermal 2009400.ths: sun8iw20 chip id: 13312
      [    4.414219] sunxi-thermal 2009400.ths: sun8iw20 t1: 3000
      [    4.420302] sunxi-thermal 2009400.ths: sun8iw20 cp version:24
      [    4.428013] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
      [    4.436920] gpio-145 (soc@3000000:i2c-gpio): enforced open drain please flag it properly in DT/ACPI DSDT/board file
      [    4.448750] gpio-144 (soc@3000000:i2c-gpio): enforced open drain please flag it properly in DT/ACPI DSDT/board file
      [    4.461494] Goodix-TS 0-0014: 0-0014 supply AVDD28 not found, using dummy regulator
      [    4.470348] Goodix-TS 0-0014: 0-0014 supply VDDIO not found, using dummy regulator
      [    4.595102] Goodix-TS 0-0014: ID 911, version: 1060
      [    4.600705] i2c-gpio soc@3000000:i2c-gpio: using lines 145 (SDA) and 144 (SCL)
      [    4.616401] Goodix-TS 0-0014: Direct firmware load for goodix_911_cfg.bin failed with error -2
      [    4.643867] ubi0: attaching mtd3
      [    4.663095] input: Goodix Capacitive TouchScreen as /devices/platform/soc@3000000/soc@3000000:i2c-gpio/i2c-0/0-0014/input/input5
      [    4.872511] [SNDCODEC][sunxi_check_hs_detect_status][192]:plugin --> switch:1
      [    5.321737] ubi0: scanning is finished
      [    5.333373] ubi0: attached mtd3 (name "sys", size 502 MiB)
      [    5.339529] ubi0: PEB size: 524288 bytes (512 KiB), LEB size: 516096 bytes
      [    5.347265] ubi0: min./max. I/O unit sizes: 8192/8192, sub-page size 4096
      [    5.354885] ubi0: VID header offset: 4096 (aligned 4096), data offset: 8192
      [    5.362696] ubi0: good PEBs: 1002, bad PEBs: 2, corrupted PEBs: 0
      [    5.369524] ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
      [    5.377628] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [    5.386997] ubi0: available PEBs: 0, total reserved PEBs: 1002, PEBs reserved for bad PEB handling: 38
      [    5.397451] ubi0: background thread "ubi_bgt0d" started, PID 1738
      [    5.417877] get det_vbus is fail, -84
      [    5.422014] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
      [    5.434489] input: soc@3000000:gpio-keys as /devices/platform/soc@3000000/soc@3000000:gpio-keys/input/input6
      [    5.446756] vin_csi 5801000.csi: Adding to iommu group 0
      [    5.455825] sunxi-vin-core 5809000.vinc: Adding to iommu group 0
      [    5.463036] sunxi-vin-core 5809200.vinc: Adding to iommu group 0
      [    5.471005] [VIN_WARN]get csi isp clk fail
      [    5.475652] [VIN_WARN]get csi isp src clk fail
      [    5.480660] [VIN_WARN]get csi mipi clk fail
      [    5.485378] [VIN_WARN]get csi mipi src clk fail
      [    5.490484] [VIN_WARN]get csi isp mbus clk fail
      [    5.495600] [VIN_WARN]Get isp reset control fail
      [    5.546325] find n5 csi camera sensor now.
      [    5.552055] [VIN_WARN]Pipe line  sensor subdev is NULL!
      [    5.558005] [VIN_WARN]Pipe line  sensor subdev is NULL!
      [    5.566923] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    5.578063] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    5.585583] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    5.592651] clk: Not disabling unused clocks
      [    5.595268] cfg80211: failed to load regulatory.db
      [    5.600038] ALSA device list:
      [    5.608766]   #0: audiocodec
      [    5.612015] alloc_fd: slot 0 not NULL!
      [    5.618307] VFS: Cannot open root device "ubi0_5" or unknown-block(0,0): error -19
      [    5.626867] Please append a correct "root=" boot option; here are the available partitions:
      [    5.636258] 1f00            2048 mtdblock0
      [    5.636261]  (driver?)
      [    5.643597] 1f01            6144 mtdblock1
      [    5.643600]  (driver?)
      [    5.650921] 1f02            2048 mtdblock2
      [    5.650923]  (driver?)
      [    5.658270] 1f03          514048 mtdblock3
      [    5.658273]  (driver?)
      [    5.665609] 1f04           16384 mtdblock4
      [    5.665611]  (driver?)
      [    5.672945] 1f05           17640 mtdblock5
      [    5.672948]  (driver?)
      [    5.680269] 1f06            1512 mtdblock6
      [    5.680271]  (driver?)
      [    5.687611] 1f07            1512 mtdblock7
      [    5.687613]  (driver?)
      [    5.694948] 1f08           17640 mtdblock8
      [    5.694950]  (driver?)
      [    5.702270] 1f09          172368 mtdblock9
      [    5.702272]  (driver?)
      [    5.709606] 1f0a          256536 mtdblock10
      [    5.709608]  (driver?)
      [    5.717039] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [    5.726303] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #98
      [    5.733030] Hardware name: Generic DT based system
      [    5.738421] [<c010e2d8>] (unwind_backtrace) from [<c010a894>] (show_stack+0x10/0x14)
      [    5.747105] [<c010a894>] (show_stack) from [<c075cb90>] (dump_stack+0x7c/0x98)
      [    5.755205] [<c075cb90>] (dump_stack) from [<c0119d20>] (panic+0x104/0x3dc)
      [    5.763014] [<c0119d20>] (panic) from [<c0b01278>] (mount_block_root+0x258/0x300)
      [    5.771405] [<c0b01278>] (mount_block_root) from [<c0b01428>] (prepare_namespace+0x84/0x178)
      [    5.780866] [<c0b01428>] (prepare_namespace) from [<c0771274>] (kernel_init+0x8/0x10c)
      [    5.789743] [<c0771274>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
      [    5.798225] Exception stack(0xef079fb0 to 0xef079ff8)
      [    5.803884] 9fa0:                                     00000000 00000000 00000000 00000000
      [    5.813050] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      [    5.822215] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
      [    5.829632] CPU0: stopping
      [    5.832665] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.61 #98
      [    5.839392] Hardware name: Generic DT based system
      [    5.844765] [<c010e2d8>] (unwind_backtrace) from [<c010a894>] (show_stack+0x10/0x14)
      [    5.853446] [<c010a894>] (show_stack) from [<c075cb90>] (dump_stack+0x7c/0x98)
      [    5.861544] [<c075cb90>] (dump_stack) from [<c010c690>] (handle_IPI+0xc0/0x168)
      [    5.869741] [<c010c690>] (handle_IPI) from [<c0341860>] (gic_handle_irq+0x70/0x78)
      [    5.878228] [<c0341860>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
      [    5.886612] Exception stack(0xc0c01f40 to 0xc0c01f88)
      [    5.892273] 1f40: 00038cb0 ef7b7574 00000000 c0115260 00000001 c0c00000 c0c03e28 c0c03e64
      [    5.901440] 1f60: 00000000 efffe2c0 c0b300c0 00000000 c0c7a8b0 c0c01f90 c0107fb0 c0107fb4
      [    5.910603] 1f80: 60000113 ffffffff
      [    5.914514] [<c01021cc>] (__irq_svc) from [<c0107fb4>] (arch_cpu_idle+0x2c/0x38)
      [    5.922808] [<c0107fb4>] (arch_cpu_idle) from [<c013e950>] (do_idle+0xb8/0x120)
      [    5.931002] [<c013e950>] (do_idle) from [<c013ec54>] (cpu_startup_entry+0x18/0x1c)
      [    5.939488] [<c013ec54>] (cpu_startup_entry) from [<c0b00c68>] (start_kernel+0x340/0x3d0)
      [    5.948656] [<c0b00c68>] (start_kernel) from [<00000000>] (0x0)
      [    5.955289] invalid reason or reasonbase NULL
      [    5.960178] rtc set bootreason panic reboot fail
      [    5.965369] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
      Q 1 条回复 最后回复 回复 引用 分享 0
      • Q
        quanzhi111 LV 5 @quanzhi111 最后由 编辑
        @quanzhi111 为啥系统会挂载不上呢?
