    T113S3 sd卡烧录emmc失败,请问这是什么原因
      jonhon25 LV 2 最后由 awwwwa 编辑
      烧录日志
      [176]HELLO! BOOT0 is starting!
      [179]BOOT0 commit : 09b36272
      [182]set pll start
      [184]fix vccio detect value:0xc0
      [191]periph0 has been enabled
      [194]set pll end
      [196][pmu]: bus read error
      [199]board init ok
      [201]enable_jtag
      [202]key press :
      [204]ZQ value = 0x2f
      [206]get_pmu_exist() = -1
      [209]ddr_efuse_type: 0xa
      [211]mark_id: 0x60
      [213]trefi:7.8ms
      [215][AUTO DEBUG] single rank and full DQ!
      [220]ddr_efuse_type: 0xa
      [222]mark_id: 0x60
      [224]trefi:7.8ms
      [226][AUTO DEBUG] rank 0 row = 13
      [229][AUTO DEBUG] rank 0 bank = 8
      [233][AUTO DEBUG] rank 0 page size = 2 KB
      [237]DRAM BOOT DRIVE INFO: V0.32
      [240]DRAM CLK = 792 MHz
      [242]DRAM Type = 3 (2:DDR2,3:DDR3)
      [246]DRAMC read ODT  off.
      [248]DRAM ODT value: 0x42.
      [251]ddr_efuse_type: 0xa
      [253]mark_id: 0x60
      [256]DRAM SIZE =128 M
      [258]PLL_DDR_CTRL_REG:0xf8004100
      [261]DRAM_CLK_REG:0xc0000000
      [264][TIMING DEBUG] MR2= 0x18
      [272]DRAM simple test OK.
      [274]rtc standby flag is 0x0, super standby flag is 0x0
      [279]dram size =128
      [282]card no is 0
      [284]sdcard 0 line count 4
      [286][mmc]: mmc driver ver 2021-05-21 14:47
      [296][mmc]: Wrong media type 0x0
      [299][mmc]: ***Try SD card 0***
      [319][mmc]: HSSDR52/SDR25 4 bit
      [322][mmc]: 50000000 Hz
      [324][mmc]: 30436 MB
      [326][mmc]: ***SD/MMC 0 init OK!!!***
      [420]Loading boot-pkg Succeed(index=0).
      [424]Entry_name        = u-boot
      [431]Entry_name        = optee
      [435]Entry_name        = dtb
      [438]mmc not para
      [439]Jump to second Boot.
      M/TC: OP-TEE version: e9372c9c-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #2 Sat Mar 19 11:09:45 UTC 2022 arm
      U-Boot 2018.05-g512bff9-dirty (Jul 13 2023 - 07:52:56 +0000) Allwinner Technology
      [00.497]CPU:   Allwinner Family
      [00.500]Model: sun8iw20
      [00.502]DRAM:  128 MiB
      [00.505]Relocation Offset is: 04ec1000
      [00.542]secure enable bit: 0
      [00.554]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.560]gic: sec monitor mode
      [00.563]flash init start
      [00.565]workmode = 0,storage type = 1
      [00.568][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
      [00.574][mmc]: get sdc_type fail and use default host:tm1.
      [00.580][mmc]: can't find node "mmc0",will add new node
      [00.585][mmc]: fdt err returned <no error>
      [00.589][mmc]: Using default timing para
      [00.592][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.620][mmc]: card_caps:0x3000000a
      [00.624][mmc]: host_caps:0x3000003f
      [00.629]sunxi flash init ok
      [00.631]line:717 init_clocks
      [00.634]drv_disp_init
      [00.645]drv_disp_init finish
      [00.647]boot_gui_init:start
      [00.650]set disp.dev0_output_type fail. using defval=0
      [00.666]Get Reserve0 partition number fail!
      no cfs of display devices.
        jonhon25 LV 2 最后由 编辑
        已解决,烧录为量产卡,不修改文件即可解决
