    T507 lcd和hdmi双屏异显问题
      leon_l LV 2 最后由 编辑
      现在lcd部分已经能正常显示了,但是hdmi一直调不通,下面是我的设备树配置
      disp init configuration
      set fbX_height to lcd_x)
                         in display.
      		disp: disp@01000000 {
      			fb0_width                = <480>;
      			fb0_height               = <854>;
      			/* VCC-LCD */
      			dc1sw-supply = <&reg_sw>;
      			/* VCC-LVDS and VCC-HDMI */
      			bldo1-supply = <&reg_bldo1>;
      			/* VCC-TV */
      			cldo4-supply = <&reg_cldo4>;
      		hdmi: hdmi@06000000 {
      			hdmi_used = <1>;
      			hdmi_power_cnt = <1>;
      			hdmi_power0 = "bldo1";
      			hdmi_hdcp_enable = <1>;
      			hdmi_hdcp22_enable = <1>;
      			hdmi_cec_support = <1>;
      			hdmi_cec_super_standby = <0>;
      			ddc_en_io_ctrl = <0>;
      			power_io_ctrl = <0>;
      ;lcd0 configuration
      ;Pin setting for gpio:
      ;fsync setting, pulse to csi
      		lcd0: lcd0@01c0c000 {
      			lcd_used            = <1>;
      		lcd_driver_name     = "st7701_lcd";
      		lcd_backlight       = <250>;
      		lcd_if              = <0>;
      		lcd_x               = <480>;
      		lcd_y               = <854>;
      		lcd_width           = <62>;
      		lcd_height          = <110>;
      		lcd_dclk_freq       = <28>;
      		lcd_pwm_used        = <1>;
      		lcd_pwm_ch          = <0>;
      		lcd_pwm_pol         = <0>;
      		lcd_pwm_max_limit   = <255>;
      		lcd_hbp             = <10>;
      		lcd_ht              = <510>;
      		lcd_hspw            = <10>;
      		lcd_vbp             = <16>;
      		lcd_vt              = <890>;
      		lcd_vspw            = <4>;
      		lcd_lvds_if         = <0>;
      		lcd_lvds_colordepth = <0>;
      		lcd_lvds_mode       = <0>;
      		lcd_frm             = <0>;
      		lcd_hv_clk_phase    = <1>;
      		lcd_hv_sync_polarity= <0>;
      		lcd_gamma_en        = <0>;
      		lcd_bright_curve_en = <0>;
      		lcd_cmap_en         = <0>;
      		lcd_fsync_en        = <0>;
      		lcd_fsync_act_time  = <1000>;
      		lcd_fsync_dis_time  = <1000>;
      		lcd_fsync_pol       = <0>;
      		deu_mode            = <0>;
      		lcdgamma4iep        = <22>;
      		smart_color         = <90>;
      		lcd_pin_power = "bldo1";
      		lcd_power = "dc1sw";
      		lcd_bl_en        = <&pio PH 3 1 0 3 1>;
      		lcd_gpio_0 = <&pio PH 5 1 1 3 1>;
      		lcd_gpio_1 = <&pio PH 6 1 1 3 1>;
      		lcd_gpio_2 = <&pio PH 7 1 1 3 1>;
      		lcd_gpio_3 = <&pio PH 8 1 1 3 1>;
      		/* LED */
      		lcd_gpio_4 = <&pio PI 8 1 1 3 1>;
      		pinctrl-0 = <&rgb24_pins_a>;
      		pinctrl-1 = <&rgb24_pins_b>;
      		lcd1: lcd1@01c0c001 {
      			lcd_used            = <0>;
      			lcd_driver_name     = "bp101wx1";
      			lcd_backlight       = <50>;
      			lcd_if              = <3>;
      			lcd_x               = <1280>;
      			lcd_y               = <800>;
      			lcd_width           = <150>;
      			lcd_height          = <94>;
      			lcd_dclk_freq       = <70>;
      			lcd_pwm_used        = <0>;
      			lcd_pwm_ch          = <0>;
      			lcd_pwm_pol         = <1>;
      			lcd_hbp             = <20>;
      			lcd_ht              = <1418>;
      			lcd_hspw            = <10>;
      			lcd_vbp             = <10>;
      			lcd_vt              = <814>;
      			lcd_vspw            = <5>;
      			lcd_lvds_if         = <0>;
      			lcd_frm             = <0>;
      			lcd_hv_clk_phase    = <0>;
      			lcd_gamma_en        = <0>;
      			lcd_cmap_en         = <0>;
      			lcd_fsync_en        = <0>;
      			deu_mode            = <0>;
      			smart_color         = <90>;
      			pinctrl-0 = <&lvds1_pins_a>;
      			pinctrl-1 = <&lvds1_pins_b>;
      ;tv configuration
      ;dac_src            (dac no,support dac_src0~dac_src3,dac num max is 4)
      ;interface          (interface type,1<->cvbs,2<->YPBPR,4<->SVIDEO)
      ;dac_type           (0<->composite,1<->luma,2<->chroma,3<->reserved,4<->y/green,
      ;                    5<->u/pb/blue,6<->v/pr/red)
      ;NOTE:              tv0,tv1 can not use the same dac_src.
      		tv0: tv0@01c94000 {
      			status =  "disabled";
      			dac_src0        = <0>;
      			dac_type0       = <0>;
      			interface       = <1>;
      			tv_power = "cldo4";
      		ctp {
      			device_type = "ctp";
      			ctp_twi_id = <2>;
      			ctp_twi_addr = <0x14>;
      			ctp_screen_max_x = <480>;
      			ctp_screen_max_y = <854>;
      			ctp_revert_x_flag = <0>;
      			ctp_revert_y_flag = <0>;
      			ctp_exchange_x_y_flag = <0>;
      			ctp_int_port = <&pio PI 11 6 0xffffffff 0xffffffff 0>;
      			ctp_wakeup = <&pio PI 12 1 0xffffffff 0xffffffff 1>;
      			ctp-supply = <&reg_dcdc1>;
      			ctp_power_ldo_vol = <3300>;
      			compatible = "goodix,gt911";
      	gpu: gpu@0x01800000 {
      		gpu_idle = <0>;
      		dvfs_status = <1>;
      		independent_power = <1>;
      		operating-points = <
                              /* KHz   uV */
      			648000 960000
      			600000 900000
      			552000 900000
      			504000 900000
      			456000 900000
      			420000 900000
      		gpu-supply = <&reg_dcdc4>;
      报错如下
      这是串口上面的报错
      [    3.268448] Registered cp15_barrier emulation handler
      [    3.273840] Registered setend emulation handler
      [    3.274635] registered taskstats version 1
      [    3.275266] HDMI 2.0 driver init start!
      [    3.275276] boot_hdmi=false
      [    3.275334] ERROR: can not get hdmi_cts_compatibility
      [    3.275972] Can not find the node of esm
      [    3.275981] ERROR: pinctrl_get for HDMI2.0 DDC fail
      [    3.276073] Get hdmi_power0:bldo1
      [    3.278120] hdmi_cec_init
      [    3.278784] HDMI2.0 module init end
      然后拔插能正常检测,也有报错
       [  580.403437] hdmi_hpd_sys_config_release
      [  583.230131] HDMI cable is connected
      [  583.300129] error: invalid cea_vic code:0
      [  583.304620] [HDMI2 error]: sink do not support this mode:0
      [  577.066792] HDMI cable is disconnected
      这是什么原因,求大佬帮帮忙
