    全志H618芯片的SDK资料获取以及Ubuntu适配源码编译产品
    • X
      Xuloy LV 3 最后由 编辑
      想编译手上的两个机顶盒,配置都是h618+4GB+64GB+螃蟹rtl8211f千兆网口+USB2.0+TF卡槽。GitHub上有t95zplus型号的armbian系统的说明。需要h618的SDK源码资料
      J 1 条回复 最后回复 回复 引用 分享 1
        Johnohhh1 LV 3 @Xuloy 最后由 编辑
        @xuloy Depends how experienced you are, you can use Dangku repo https://github.com/BPI-SINOVOIP/BPI-H618-Android12 use apollo/p2 and H618/p2 drop your dts in the longan/device/chips/h618/p2 but as with all of them if you dont have experience with the common folder you will end up with a lot of stock system settings that will make you hate that chip
