    aw869a wifi模块没有调通,insmod 报错。请教各位大佬,我是芯片是t113s3
      andy123 LV 3 最后由 编辑
      设备树代码
      &soc {
      	leds {
                      compatible = "gpio-leds";
                      gpio_pb6 {
                              label = "GPIO_PB6";
                              gpios = <&pio PB 6 GPIO_ACTIVE_HIGH>; /* PB6 */
      						        // 初始状态:设为on(触发模式需要LED先开启)
             					default-state = "on";
             					// 核心:指定默认触发模式为heartbeat
             					linux,default-trigger = "heartbeat";
      	card0_boot_para@2 {
      		reg = <0x0 0x2 0x0 0x0>;
      		card_ctrl = <0x0>;
      		card_high_speed = <0x1>;
      		card_line = <0x4>;
      		pinctrl-0 = <&sdc0_pins_a>;
      	card2_boot_para@3 {
      		reg = <0x0 0x3 0x0 0x0>;
      		card_ctrl = <0x2>;
      		card_line = <0x4>;
      		pinctrl-0 = <&sdc2_pins_a>;
      		/*sdc_ex_dly_used = <0x2>;*/
      		sdc_io_1v8 = <0x1>;
      		/*sdc_type = "tm4";*/
      		sdc_ex_dly_used = <2>;
      		/*sdc_tm4_win_th = <8>;*/
      	rfkill: rfkill@0 {
      		chip_en;
      		power_en;
      		pinctrl-0 ;
      		pinctrl-names;
      		status        = "okay";
      		wlan: wlan@0 {
      			clock-names ;
      			clocks;
      			wlan_power = "axp2202‑aldo3", "axp2202‑bldo1"; /* vcc‑pl/vcc‑pg/vcc‑pm */
          	 	// wlan_power_vol= <3300000>, <1800000>;
      			wlan_busnum    = <0x1>;
      			// wlan_regon    = <&pio PE 3 GPIO_ACTIVE_HIGH>;
      			wlan_power_vol = <3300000>;
      			/*interrupt-parent = <&pio>;
      			chip_en;                              /*启用模块*/
          		power_en;                             /*启用 Wi-Fi 电源*/
          		status        = "okay";               /*启用这个节点*/
      			wakeup-source;
      		bt: bt@0 {
      			clock-names ;
      			clocks ;
      			/*bt_power_num = <0x01>;*/
      			/*bt_io_vol = <3300000>;*/
      			bt_power_vol = <3300000>;
      			bt_power = "axp2202‑aldo3", "axp2202‑bldo1"; /* vcc‑pl/vcc‑pg/vcc‑pm */
      			// bt_power_vol= <3300000>, <1800000>;
      			// bt_rst_n      = <&pio PE 2 GPIO_ACTIVE_LOW>;
      			status        = "okay";
      	btlpm: btlpm@0 {
      		uart_index  = <0x1>;
      		// bt_wake     = <&pio PE 1 GPIO_ACTIVE_HIGH>;
      		bt_hostwake = <&pio PG 11 GPIO_ACTIVE_HIGH>;
      		wakeup-source;
      		status      = "okay";
      	addr_mgt: addr_mgt@0 {
      		type_addr_wifi = <0x0>;
      		type_addr_bt   = <0x0>;
      		type_addr_eth  = <0x0>;
      		status         = "okay";
