    a133的mipi屏幕点不亮
      ZZZZ_ LV 4 最后由 编辑
      uboot的驱动代码:
       * drivers/video/sunxi/disp2/disp/lcd/K080_IM2HYL802R_800X1280.c
       * Copyright (c) 2007-2018 Allwinnertech Co., Ltd.
       * This software is licensed under the terms of the GNU General Public
       * License version 2, as published by the Free Software Foundation, and
       * may be copied, distributed, and modified under those terms.
       * This program is distributed in the hope that it will be useful,
       * but WITHOUT ANY WARRANTY; without even the implied warranty of
       * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
       * GNU General Public License for more details.
      #include "K080_IM2HYL802R_800X1280.h"
      //#include <mach/sys_config.h>
      #include "panels.h"
      &lcd0 {
      	lcd_used            = <1>;
      	status              = "okay";
      	lcd_driver_name     = "K080_IM2HYL802R_800X1280";
      	lcd_backlight       = <50>;
      	lcd_if              = <4>;
      	lcd_x               = <800>;
      	lcd_y               = <1280>;
      	lcd_width           = <135>;
      	lcd_height          = <216>;
      	lcd_dclk_freq       = <75>;
      	lcd_pwm_used        = <1>;
      	lcd_pwm_ch          = <0>;
      	lcd_pwm_pol         = <1>;
      	lcd_pwm_max_limit   = <255>;
      	lcd_hbp             = <88>;
      	lcd_ht              = <960>;
      	lcd_hspw            = <4>;
      	lcd_vbp             = <12>;
      	lcd_vt              = <1300>;
      	lcd_vspw            = <4>;
      	lcd_frm             = <0>;
      	lcd_gamma_en        = <0>;
      	lcd_bright_curve_en = <0>;
      	lcd_cmap_en         = <0>;
      	deu_mode            = <0>;
      	lcdgamma4iep        = <22>;
      	smart_color         = <90>;
      	lcd_dsi_if          = <0>;
      	lcd_dsi_lane        = <4>;
      	lcd_dsi_format      = <0>;
      	lcd_dsi_te          = <0>;
      	lcd_dsi_eotp        = <0>;
      	lcd_pin_power = "dcdc1";
      	lcd_pin_power1 = "eldo3";
      	lcd_power = "eldo3";
      	lcd_power1 = "dcdc1";
      	lcd_power2 = "dc1sw";
      	lcd_gpio_1 = <&pio PD 22 1 0 3 1>;
      	lcd_bl_en = <&pio PB 8 1 0 3 1>;
      	lcd_bl_0_percent	= <15>;
      	lcd_bl_100_percent  = <100>;
      extern s32 bsp_disp_get_panel_info(u32 screen_id, disp_panel_para *info);
      //static void LCD_panel_try_switch(u32 sel);
      //static u8 const mipi_dcs_pixel_format[4] = {0x77,0x66,0x66,0x55};
      #define panel_reset(val) sunxi_lcd_gpio_set_value(sel, 1, val)
      #define power_en(val) sunxi_lcd_gpio_set_value(sel, 0, val)
      static void LCD_cfg_panel_info(panel_extend_para *info)
      	u32 i = 0, j = 0;
      	u32 items;
      	u8 lcd_gamma_tbl[][2] = {
      		//{input value, corrected value}
      		{0, 0},
      		{15, 15},
      		{30, 30},
      		{45, 45},
      		{60, 60},
      		{75, 75},
      		{90, 90},
      		{105, 105},
      		{120, 120},
      		{135, 135},
      		{150, 150},
      		{165, 165},
      		{180, 180},
      		{195, 195},
      		{210, 210},
      		{225, 225},
      		{240, 240},
      		{255, 255},
      	u32 lcd_cmap_tbl[2][3][4] = {
      		for (j = 0; j < num; j++) {
      			u32 value = 0;
      			value = lcd_gamma_tbl[i][1] + ((lcd_gamma_tbl[i + 1][1] - lcd_gamma_tbl[i][1]) * j) / num;
      			info->lcd_gamma_tbl[lcd_gamma_tbl[i][0] + j] = (value << 16) + (value << 8) + value;
      	info->lcd_gamma_tbl[255] = (lcd_gamma_tbl[items - 1][1] << 16) + (lcd_gamma_tbl[items - 1][1] << 8) + lcd_gamma_tbl[items - 1][1];
          pr_info("[LCD] %s: screen %u\n", __func__, sel);
      	LCD_OPEN_FUNC(sel, LCD_power_on, 100);   //open lcd power, and delay 100ms
      	LCD_OPEN_FUNC(sel, LCD_panel_init, 200); //open lcd power, than delay 200ms
      	LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 50); //open lcd controller, and delay 50ms
      	LCD_OPEN_FUNC(sel, LCD_bl_open, 0);     //open lcd backlight, and delay 0ms
      	LCD_CLOSE_FUNC(sel, LCD_bl_close, 200);       //close lcd backlight, and delay 0ms
      	LCD_CLOSE_FUNC(sel, sunxi_lcd_tcon_disable, 20);         //close lcd controller, and delay 0ms
      	LCD_CLOSE_FUNC(sel, LCD_panel_exit,	10);   //open lcd power, than delay 200ms
      	LCD_CLOSE_FUNC(sel, LCD_power_off, 500);   //close lcd power, and delay 500ms
          pr_info("[LCD] %s: start, screen %u\n", __func__, sel);
      	// 1. 复位引脚拉低(复位触发)
      	panel_reset(0);
      	sunxi_lcd_delay_ms(20);
          // 2. 电源开启(严格按联发科顺序:3.3V → 1.8V → AVDD)
          sunxi_lcd_power_enable(sel, 0);
          sunxi_lcd_power_enable(sel, 1);
          sunxi_lcd_delay_ms(10);
          sunxi_lcd_power_enable(sel, 2);
          sunxi_lcd_delay_ms(5);
          // 3. 电源使能GPIO置高
          power_en(1);
          // 4. 复位引脚拉高(释放复位)
          panel_reset(1);
          sunxi_lcd_delay_ms(50);
          sunxi_lcd_pin_cfg(sel, 1);
      	pr_info("[LCD] %s: finish, screen %u\n", __func__, sel);
      	sunxi_lcd_pin_cfg(sel, 0);
      	power_en(0);
      	panel_reset(0);
      	// 电源关闭顺序:反向关闭(AVDD → 1.8V → 3.3V),匹配上电顺序
      	sunxi_lcd_power_disable(sel, 2);
      	sunxi_lcd_power_disable(sel, 1);
      	sunxi_lcd_power_disable(sel, 0);
      	sunxi_lcd_pwm_enable(sel);
      	sunxi_lcd_backlight_enable(sel);//config lcd_bl_en pin to open lcd backlight
      	sunxi_lcd_backlight_disable(sel);//config lcd_bl_en pin to close lcd backlight
      	sunxi_lcd_pwm_disable(sel);
      #define REGFLAG_DELAY             						0XFE
      #define REGFLAG_END_OF_TABLE      						0xFD   // END OF REGISTERS MARKER
      struct LCM_setting_table {
          u8 cmd;
          u32 count;
          u8 para_list[64];
      /*add panel initialization below*/
      static struct LCM_setting_table lcm_initialization_setting[] = {
      	{REGFLAG_DELAY, REGFLAG_DELAY, {120}},            /* 120 ms after reset  */
      	/* Page-1  (0x3001) */
      	{0xFF, 1, {0x30}},
      	{0xFF, 1, {0x52}},
      	{0xFF, 1, {0x01}},
      	{0xE3, 1, {0x04}},
      	{0x08, 1, {0x0E}},
      	{0x25, 1, {0x10}},
      	{0x28, 1, {0x5F}},
      	{0x2C, 1, {0x22}},
      	{0x30, 1, {0x58}},
      	{0x45, 1, {0x91}},
      	{0x37, 1, {0x9C}},
      	{0x38, 1, {0xA7}},
      	{0x39, 1, {0x27}},
      	{0x44, 1, {0x00}},
      	{0x49, 1, {0x1C}},
      	{0x59, 1, {0xFE}},
      	{0x5C, 1, {0x00}},
      	{0x91, 1, {0x77}},
      	{0x92, 1, {0x77}},
      	{0xA0, 1, {0x55}},
      	{0xA1, 1, {0x50}},
      	{0xA3, 1, {0x58}},
      	{0xA4, 1, {0x9C}},
      	{0xA7, 1, {0x02}},
      	{0xA8, 1, {0x01}},
      	{0xA9, 1, {0x01}},
      	{0xAA, 1, {0xFC}},
      	{0xAB, 1, {0x28}},
      	{0xAC, 1, {0x06}},
      	{0xAD, 1, {0x06}},
      	{0xAE, 1, {0x06}},
      	{0xAF, 1, {0x03}},
      	{0xB0, 1, {0x08}},
      	{0xB1, 1, {0x26}},
      	{0xB2, 1, {0x28}},
      	{0xB3, 1, {0x28}},
      	{0xB4, 1, {0x03}},
      	{0xB5, 1, {0x08}},
      	{0xB6, 1, {0x26}},
      	{0xB7, 1, {0x08}},
      	{0xB8, 1, {0x26}},
      	{0xC0, 1, {0x00}},
      	{0xC1, 1, {0x00}},
      	{0xC3, 1, {0x0F}},
      	/* Page-2  (0x3002) */
      	{0xFF, 1, {0x30}},
      	{0xFF, 1, {0x52}},
      	{0xFF, 1, {0x02}},
      	{0xB0, 1, {0x00}},
      	{0xB1, 1, {0x05}},
      	{0xB2, 1, {0x02}},
      	{0xB3, 1, {0x24}},
      	{0xB4, 1, {0x25}},
      	{0xB5, 1, {0x30}},
      	{0xB6, 1, {0x0C}},
      	{0xB7, 1, {0x27}},
      	{0xB8, 1, {0x0F}},
      	{0xB9, 1, {0x05}},
      	{0xBA, 1, {0x11}},
      	{0xBB, 1, {0x10}},
      	{0xBC, 1, {0x11}},
      	{0xBD, 1, {0x12}},
      	{0xBE, 1, {0x17}},
      	{0xBF, 1, {0x0C}},
      	{0xC0, 1, {0x14}},
      	{0xC1, 1, {0x0A}},
      	{0xD0, 1, {0x08}},
      	{0xD1, 1, {0x0F}},
      	{0xD2, 1, {0x09}},
      	{0xD3, 1, {0x35}},
      	{0xD4, 1, {0x38}},
      	{0xD5, 1, {0x3D}},
      	{0xD6, 1, {0x1B}},
      	{0xD7, 1, {0x3B}},
      	{0xD8, 1, {0x0F}},
      	{0xD9, 1, {0x05}},
      	{0xDA, 1, {0x11}},
      	{0xDB, 1, {0x10}},
      	{0xDC, 1, {0x11}},
      	{0xDD, 1, {0x14}},
      	{0xDE, 1, {0x19}},
      	{0xDF, 1, {0x11}},
      	{0xE0, 1, {0x19}},
      	{0xE1, 1, {0x09}},
      	/* Page-3  (0x3003) */
      	{0xFF, 1, {0x30}},
      	{0xFF, 1, {0x52}},
      	{0xFF, 1, {0x03}},
      	{0x08, 1, {0x8B}},
      	{0x09, 1, {0x8A}},
      	{0x0A, 1, {0x89}},
      	{0x0B, 1, {0x88}},
      	{0x34, 1, {0x61}},
      	{0x35, 1, {0xD4}},
      	{0x36, 1, {0x24}},
      	{0x37, 1, {0x03}},
      	{0x40, 1, {0x8B}},
      	{0x41, 1, {0x8A}},
      	{0x42, 1, {0x89}},
      	{0x43, 1, {0x88}},
      	{0x45, 1, {0x01}},
      	{0x46, 1, {0x02}},
      	{0x48, 1, {0x03}},
      	{0x49, 1, {0x04}},
      	{0x50, 1, {0x87}},
      	{0x51, 1, {0x86}},
      	{0x52, 1, {0x85}},
      	{0x53, 1, {0x84}},
      	{0x55, 1, {0x05}},
      	{0x56, 1, {0x06}},
      	{0x58, 1, {0x07}},
      	{0x59, 1, {0x08}},
      	{0x80, 1, {0x0F}},
      	{0x81, 1, {0x0E}},
      	{0x82, 1, {0x07}},
      	{0x83, 1, {0x06}},
      	{0x84, 1, {0x05}},
      	{0x85, 1, {0x04}},
      	{0x92, 1, {0x0E}},
      	{0x93, 1, {0x0F}},
      	{0x94, 1, {0x01}},
      	{0x95, 1, {0x00}},
      	{0x96, 1, {0x0F}},
      	{0x97, 1, {0x0E}},
      	{0x98, 1, {0x07}},
      	{0x99, 1, {0x06}},
      	{0x9A, 1, {0x05}},
      	{0x9B, 1, {0x04}},
      	{0xA8, 1, {0x0E}},
      	{0xA9, 1, {0x0F}},
      	{0xAA, 1, {0x01}},
      	{0xAB, 1, {0x00}},
      	{0xE0, 1, {0x02}},
      	{0xE1, 1, {0x52}},
      	/* Page-0  (0x3000) */
      	{0xFF, 1, {0x30}},
      	{0xFF, 1, {0x52}},
      	{0xFF, 1, {0x00}},
      	{0x35, 1, {0x00}},
      	{0x36, 1, {0x02}},
      	{0x53, 1, {0x2C}},
      	/* Display ON sequence */
      	//SLP OUT
      	{0x11,     0,     {0x00} },  	// SLPOUT
      	{REGFLAG_DELAY, REGFLAG_DELAY, {120} },
      	//DISP ON
      	{0x29,     0,     {0x00} },  	// DSPON
      	{REGFLAG_DELAY, REGFLAG_DELAY, {100} },
      	{REGFLAG_END_OF_TABLE, REGFLAG_END_OF_TABLE, {} }
      /*static void LCD_panel_try_switch(u32 sel)
      	u8 result[16] = {0};
      	u32 num = 0;
      	sunxi_lcd_delay_ms(100);
      	sunxi_lcd_dsi_dcs_read(sel, 0x04, result, &num);
      	printf("get lcd id 0x%x\n", result[0]);
      	if (result[0] == 0x93) {
      		LCD_power_off(sel);
      		sunxi_lcd_switch_compat_panel(sel, 1);
      		return;
      	__u32 i;
          pr_info("[LCD] %s: screen %u - start init table\n", __func__, sel);
      	sunxi_lcd_dsi_clk_enable(sel);
          pr_info("[LCD] %s: sending SW reset\n", __func__);
      	sunxi_lcd_dsi_dcs_write_0para(sel, DSI_DCS_SOFT_RESET);
      	//sunxi_lcd_delay_ms(10);
      	sunxi_lcd_delay_ms(120);
          pr_info("[LCD] %s: entering init table loop\n", __func__);
      	for (i = 0; ; i++) {
      			if (lcm_initialization_setting[i].count == REGFLAG_END_OF_TABLE)
      				break;
      			else if (lcm_initialization_setting[i].count == REGFLAG_DELAY)
      				sunxi_lcd_delay_ms(lcm_initialization_setting[i].para_list[0]);
      #ifdef SUPPORT_DSI
      				dsi_dcs_wr(sel, lcm_initialization_setting[i].cmd, lcm_initialization_setting[i].para_list, lcm_initialization_setting[i].count);
      		//break;
          pr_info("[LCD] %s: screen %u - init table done\n", __func__, sel);
      	return;
      	sunxi_lcd_dsi_dcs_write_0para(sel, DSI_DCS_SET_DISPLAY_OFF);
      	sunxi_lcd_dsi_dcs_write_0para(sel, DSI_DCS_ENTER_SLEEP_MODE);
      	sunxi_lcd_delay_ms(80);
      	return ;
      //sel: 0:lcd0; 1:lcd1
      static s32 LCD_user_defined_func(u32 sel, u32 para1, u32 para2, u32 para3)
      /*static s32 LCD_set_bright(u32 sel, u32 bright)
      	sunxi_lcd_dsi_dcs_write_1para(sel,0x51,bright);
      __lcd_panel_t K080_IM2HYL802R_800X1280_mipi_panel = {
      	/* panel driver name, must mach the name of lcd_drv_name in sys_config.fex */
      	.name = "K080_IM2HYL802R_800X1280",
      	.func = {
      		.cfg_panel_info = LCD_cfg_panel_info,
      		.lcd_user_defined_func = LCD_user_defined_func,
      		//.set_bright = LCD_set_bright,
      设备树:
      disp: disp@06000000 {
      			fb0_width                = <720>;
      			fb0_height               = <1280>;
      			/*VCC-LCD*/
      			cldo4-supply = <&reg_cldo4>;
      			/*VCC-LVDS-1.8V*/
      			cldo1-supply = <&reg_cldo1>;
      			/*VCC-DSI*/
      			/*VCC-PD-3.3V*/
      			cldo3-supply = <&reg_cldo3>;
      ;lcd0 configuration
      ;Pin setting for gpio:
      ;fsync setting, pulse to csi
      		lcd0: lcd0@01c0c000 {
      			lcd_used            = <1>;
      			lcd_if              = <4>;
      			lcd_x               = <720>;
      			lcd_y               = <1280>;
      			lcd_width           = <150>;
      			lcd_height          = <36>;
      			lcd_dclk_freq       = <58>;
      			lcd_pwm_used        = <1>;
      			lcd_pwm_ch          = <0>;
      			lcd_pwm_pol         = <1>;
      			lcd_hbp             = <30>;
      			lcd_ht              = <770>;
      			lcd_hspw            = <6>;
      			lcd_vbp             = <16>;
      			lcd_vt              = <1311>;
      			lcd_vspw            = <4>;
      			lcd_frm             = <0>;
      			lcd_gamma_en        = <0>;
      			lcd_cmap_en         = <0>;
      			deu_mode            = <0>;
      			smart_color         = <90>;
      			lcd_dsi_if          = <0>;
      			lcd_dsi_lane        = <4>;
      			lcd_dsi_te          = <0>;
      			lcd_dsi_eotp        = <0>;
      			lcd_pin_power       = "cldo3";      /* VCC-PD   (3.3 V) */
      			lcd_power1          = "cldo1";      /* VCC-LVDS (1.8 V) */
      			lcd_power2          = "cldo4";      /* VCC-LCD  (3.3 V) */
      			lcd_gpio_1          = <&pio PD 22 1 0 3 1>;    /* RESET */
      			lcd_bl_en           = <&pio PD 23 1 1 0 3 1>;  /* backlight */
      参考mtk的驱动参数:
       * Copyright (C) 2016 MediaTek Inc.
       * it under the terms of the GNU General Public License version 2 as
       * See http://www.gnu.org/licenses/gpl-2.0.html for more details.
      #ifdef BUILD_LK
      #include <string.h>
      #include <platform/mt_gpio.h>
      #include <platform/mt_pmic.h>
      #include <platform/sync_write.h>
      #include <platform/ddp_hal.h>
      #else
      #include <linux/string.h>
      #include <linux/wait.h>
      #include <linux/gpio.h>
      #include <linux/pinctrl/consumer.h>
      #include <linux/of_gpio.h>
      #include <asm-generic/gpio.h>
      #include <linux/kernel.h>
      #include <linux/mm.h>
      #include <linux/mm_types.h>
      #include <linux/module.h>
      #include <linux/types.h>
      #include <linux/slab.h>
      #include <linux/vmalloc.h>
      #ifdef CONFIG_OF
      #include <linux/of.h>
      #include <linux/of_irq.h>
      #include <linux/of_address.h>
      #include <linux/of_device.h>
      #include <linux/regulator/consumer.h>
      #include "lcm_drv.h"
      #ifndef BUILD_LK
      extern int inettek_gpio_set(const char *name);
      extern int lcm_vgp_supply_enable(void);
      extern int lcm_vgp_supply_disable(void);
      extern int lcm_get_vgp_supply(struct device *dev);
      #ifdef BUILD_LK
      #define LCD_2V8_EN                 (38 | 0x80000000)
      #define LCD_RST_PIN                (66 | 0x80000000)
      #define LCD_3V3_RST_PIN            (70 | 0x80000000)
      #define LCD_AVDD_EN                (20 | 0x80000000)  // VSN +VSP
      #define LCD_GAMA_EN                (0  | 0x80000000)  // AVDD + VGL + VGH
      /*  Local Constants */
      #define FRAME_WIDTH        (720)
      #define FRAME_HEIGHT       (1280)
      #define GPIO_OUT_ONE        1
      #define GPIO_OUT_ZERO       0
      #define REGFLAG_DELAY            0xFE
      #define REGFLAG_END_OF_TABLE     0x00
      #define LCM_ID_NV3052            (0x3052)
      /*  Local Variables */
      #ifndef BUILD_LK
      static unsigned int GPIO_LCD_PWR;
      static unsigned int GPIO_LCD_RST;
      static unsigned int GPIO_3V3_LCD_RST;
      static void lcm_request_gpio_control(struct device *dev)
          GPIO_LCD_PWR = of_get_named_gpio(dev->of_node, "gpio_lcd_pwr", 0);
          gpio_request(GPIO_LCD_PWR, "GPIO_LCD_PWR");
          GPIO_LCD_RST = of_get_named_gpio(dev->of_node, "gpio_lcd_rst", 0);
          gpio_request(GPIO_LCD_PWR, "GPIO_LCD_RST");
          GPIO_3V3_LCD_RST = of_get_named_gpio(dev->of_node, "gpio_3v3_lcd_rst", 0);
          gpio_request(GPIO_LCD_PWR, "GPIO_3V3_LCD_RST");
      static int lcm_driver_probe(struct device *dev, void const *data)
          lcm_request_gpio_control(dev);
          lcm_get_vgp_supply(dev);
          lcm_vgp_supply_enable();
      static const struct of_device_id lcm_platform_of_match[] = {
              .compatible = "mickey,nv3052_bv055hdl_nb6",
              .data = 0,
              /* sentinel */
      MODULE_DEVICE_TABLE(of, platform_of_match);
      static int lcm_platform_probe(struct platform_device *pdev)
          const struct of_device_id *id;
          id = of_match_node(lcm_platform_of_match, pdev->dev.of_node);
          if (!id)
              return -ENODEV;
          return lcm_driver_probe(&pdev->dev, id->data);
      static struct platform_driver lcm_driver = {
          .probe = lcm_platform_probe,
          .driver = {
                 .name = "nv3052_bv055hdl_nb6",
                 .owner = THIS_MODULE,
                 .of_match_table = lcm_platform_of_match,
      static int __init lcm_drv_init(void)
          if (platform_driver_register(&lcm_driver)) {
              pr_err("LCM: failed to register this driver!\n");
              return -ENODEV;
      static void __exit lcm_drv_exit(void)
          platform_driver_unregister(&lcm_driver);
      late_initcall(lcm_drv_init);
      module_exit(lcm_drv_exit);
      MODULE_AUTHOR("mediatek");
      MODULE_DESCRIPTION("LCM display subsystem driver");
      MODULE_LICENSE("GPL");
      extern void mdelay(unsigned long msec);
      #ifdef BUILD_LK
      static LCM_UTIL_FUNCS lcm_util = {
          .set_reset_pin = NULL,
          .udelay = NULL,
          .mdelay = NULL,
      #else
      static LCM_UTIL_FUNCS lcm_util = { 0 };
      #define SET_RESET_PIN(v)        (lcm_util.set_reset_pin((v)))
      #define UDELAY(n)                (lcm_util.udelay(n))
      #define MDELAY(n)                (lcm_util.mdelay(n))
      /* Local Functions */
      #define dsi_set_cmdq_V2(cmd, count, ppara, force_update) \
               (lcm_util.dsi_set_cmdq_V2(cmd, count, ppara, force_update))
      #define dsi_set_cmdq(pdata, queue_size, force_update) \
               (lcm_util.dsi_set_cmdq(pdata, queue_size, force_update))
      #define wrtie_cmd(cmd) \
               (lcm_util.dsi_write_cmd(cmd))
      #define write_regs(addr, pdata, byte_nums) \
               (lcm_util.dsi_write_regs(addr, pdata, byte_nums))
      #define read_reg \
               (lcm_util.dsi_read_reg())
      #define read_reg_v2(cmd, buffer, buffer_size) \
               (lcm_util.dsi_dcs_read_lcm_reg_v2(cmd, buffer, buffer_size))
      #ifdef BUILD_LK
      static void pmic_vgp2_enable(bool en, int vol_mv)
          unsigned int val;
          if (!en)
              mt6392_upmu_set_rg_vgp2_en(0x0);
          else {
              switch (vol_mv) {
                  case 1200:
                      val = 0x00;
                      break;
                  case 1300:
                      val = 0x01;
                      break;
                  case 1500:
                      val = 0x02;
                      break;
                  case 1800:
                      val = 0x03;
                      break;
                  case 2000:
                      val = 0x04;
                      break;
                  case 2800:
                      val = 0x05;
                      break;
                  case 3000:
                      val = 0x06;
                      break;
                  case 3300:
                      val = 0x07;
                      break;
                  default:
                      val = 0x05;
                      break;
              //VGP2 0x00=1.2V, 0x01=1.3V, 0x02=1.5V, 0x03=1.8V, 0x04=2.0V, 0x05=2.8V, 0x06=3.0V, 0x07=3.3V
              mt6392_upmu_set_rg_vgp2_vosel(val);
              mt6392_upmu_set_rg_vgp2_en(0x1);
      #ifdef BUILD_LK
      static void lcm_set_gpio_output(unsigned int GPIO, unsigned int output)
          mt_set_gpio_mode(GPIO, GPIO_MODE_00);
          mt_set_gpio_dir(GPIO, GPIO_DIR_OUT);
          mt_set_gpio_out(GPIO, output);
          unsigned char cmd;
          unsigned char count;
          unsigned char para_list[4];
      //update initial param for IC boe_nt71391_dsi_vdo 0.01
      //----------NV305F+BOE5.5(BV055HDL-NB6) Initial------------------
          {REGFLAG_DELAY, 120, {}},
          {0xFF,0x01,{0x30}},
          {0xFF,0x01,{0x52}},
          {0xFF,0x01,{0x01}},
          {0xE3,0x01,{0x04}},
          {0x08,0x01,{0x0e}},
          {0x25,0x01,{0x10}},
          {0x28,0x01,{0x5F}},
          {0x2C,0x01,{0x22}},
          {0x30,0x01,{0x58}},
          {0x45,0x01,{0x91}},
          {0x37,0x01,{0x9C}},
          {0x38,0x01,{0xA7}},
          {0x39,0x01,{0x27}},
          {0x44,0x01,{0x00}},
          {0x49,0x01,{0x1C}},
          {0x59,0x01,{0xFE}},
          {0x5C,0x01,{0x00}},
          {0x91,0x01,{0x77}},
          {0x92,0x01,{0x77}},
          {0xA0,0x01,{0x55}},
          {0xA1,0x01,{0x50}},
          {0xA3,0x01,{0x58}},
          {0xA4,0x01,{0x9C}},
          {0xA7,0x01,{0x02}},
          {0xA8,0x01,{0x01}},
          {0xA9,0x01,{0x01}},
          {0xAA,0x01,{0xFC}},
          {0xAB,0x01,{0x28}},
          {0xAC,0x01,{0x06}},
          {0xAD,0x01,{0x06}},
          {0xAE,0x01,{0x06}},
          {0xAF,0x01,{0x03}},
          {0xB0,0x01,{0x08}},
          {0xB1,0x01,{0x26}},
          {0xB2,0x01,{0x28}},
          {0xB3,0x01,{0x28}},
          {0xB4,0x01,{0x03}},
          {0xB5,0x01,{0x08}},
          {0xB6,0x01,{0x26}},
          {0xB7,0x01,{0x08}},
          {0xB8,0x01,{0x26}},
          {0xc0,0x01,{0x00}},
          {0xc1,0x01,{0x00}},
          {0xc3,0x01,{0x0F}},
          {0xFF,0x01,{0x30}},
          {0xFF,0x01,{0x52}},
          {0xFF,0x01,{0x02}},
          {0xB0,0x01,{0x00}},
          {0xB1,0x01,{0x05}},
          {0xB2,0x01,{0x02}},
          {0xB3,0x01,{0x24}},
          {0xB4,0x01,{0x25}},
          {0xB5,0x01,{0x30}},
          {0xB6,0x01,{0x0C}},
          {0xB7,0x01,{0x27}},
          {0xB8,0x01,{0x0F}},
          {0xB9,0x01,{0x05}},
          {0xBA,0x01,{0x11}},
          {0xBB,0x01,{0x10}},
          {0xBC,0x01,{0x11}},
          {0xBD,0x01,{0x12}},
          {0xBE,0x01,{0x17}},
          {0xBF,0x01,{0x0C}},
          {0xC0,0x01,{0x14}},
          {0xC1,0x01,{0x0A}},
          {0xD0,0x01,{0x08}},
          {0xD1,0x01,{0x0F}},
          {0xD2,0x01,{0x09}},
          {0xD3,0x01,{0x35}},
          {0xD4,0x01,{0x38}},
          {0xD5,0x01,{0x3D}},
          {0xD6,0x01,{0x1B}},
          {0xD7,0x01,{0x3B}},
          {0xD8,0x01,{0x0F}},
          {0xD9,0x01,{0x05}},
          {0xDA,0x01,{0x11}},
          {0xDB,0x01,{0x10}},
          {0xDC,0x01,{0x11}},
          {0xDD,0x01,{0x14}},
          {0xDE,0x01,{0x19}},
          {0xDF,0x01,{0x11}},
          {0xE0,0x01,{0x19}},
          {0xE1,0x01,{0x09}},
          {0xFF,0x01,{0x30}},
          {0xFF,0x01,{0x52}},
          {0xFF,0x01,{0x03}},
          {0x08,0x01,{0x8B}},
          {0x09,0x01,{0x8A}},
          {0x0A,0x01,{0x89}},
          {0x0B,0x01,{0x88}},
          {0x34,0x01,{0x61}},
          {0x35,0x01,{0xD4}},
          {0x36,0x01,{0x24}},
          {0x37,0x01,{0x03}},
          {0x40,0x01,{0x8B}},
          {0x41,0x01,{0x8A}},
          {0x42,0x01,{0x89}},
          {0x43,0x01,{0x88}},
          {0x45,0x01,{0x01}},
          {0x46,0x01,{0x02}},
          {0x48,0x01,{0x03}},
          {0x49,0x01,{0x04}},
          {0x50,0x01,{0x87}},
          {0x51,0x01,{0x86}},
          {0x52,0x01,{0x85}},
          {0x53,0x01,{0x84}},
          {0x55,0x01,{0x05}},
          {0x56,0x01,{0x06}},
          {0x58,0x01,{0x07}},
          {0x59,0x01,{0x08}},
          {0x80,0x01,{0x0F}},
          {0x81,0x01,{0x0E}},
          {0x82,0x01,{0x07}},
          {0x83,0x01,{0x06}},
          {0x84,0x01,{0x05}},
          {0x85,0x01,{0x04}},
          {0x92,0x01,{0x0E}},
          {0x93,0x01,{0x0F}},
          {0x94,0x01,{0x01}},
          {0x95,0x01,{0x00}},
          {0x96,0x01,{0x0F}},
          {0x97,0x01,{0x0E}},
          {0x98,0x01,{0x07}},
          {0x99,0x01,{0x06}},
          {0x9A,0x01,{0x05}},
          {0x9B,0x01,{0x04}},
          {0xA8,0x01,{0x0E}},
          {0xA9,0x01,{0x0F}},
          {0xAA,0x01,{0x01}},
          {0xAB,0x01,{0x00}},
          {0xE0,0x01,{0x02}},
          {0xE1,0x01,{0x52}},
          {0xFF,0x01,{0x30}},
          {0xFF,0x01,{0x52}},
          {0xFF,0x01,{0x00}},
          {0x35,0x01,{0x00}},
          {0x36,0x01,{0x02}},
          {0x53,0x01,{0x2C}},
          {0x11,0x01,{0x00}},
          {REGFLAG_DELAY, 200, {}},
          {0x29,0x01,{0x00}}, //Display ON
          {REGFLAG_DELAY, 100, {}},
          {REGFLAG_END_OF_TABLE, 0x00, {}},
      static void push_table(struct LCM_setting_table *table, unsigned int count, unsigned char force_update)
          unsigned int i;
          for(i = 0; i < count; i++) {
              unsigned cmd;
              cmd = table[i].cmd;
              switch (cmd) {
                  case REGFLAG_DELAY :
                      MDELAY(table[i].count);
                      break;
                  case REGFLAG_END_OF_TABLE :
                      break;
                  default:
                      dsi_set_cmdq_V2(cmd, table[i].count, table[i].para_list, force_update);
                      //MDELAY(10);//soso add or it will fail to send register
      /*  LCM Driver Implementations */
      #ifdef BUILD_LK
      static void lcm_set_util_funcs(const LCM_UTIL_FUNCS *util)
          memcpy(&lcm_util, util, sizeof(LCM_UTIL_FUNCS));
      #else
      static void lcm_get_params(LCM_PARAMS *params)
          memset(params, 0, sizeof(LCM_PARAMS));
          params->type   = LCM_TYPE_DSI;
          params->width  = FRAME_WIDTH;
          params->height = FRAME_HEIGHT;
          params->dsi.mode = SYNC_EVENT_VDO_MODE;
          params->dsi.LANE_NUM                = LCM_FOUR_LANE;
          params->dsi.data_format.color_order = LCM_COLOR_ORDER_RGB;
          params->dsi.data_format.trans_seq   = LCM_DSI_TRANS_SEQ_MSB_FIRST;
          params->dsi.data_format.padding     = LCM_DSI_PADDING_ON_LSB;
          params->dsi.data_format.format      = LCM_DSI_FORMAT_RGB888;
          /* Highly depends on LCD driver capability. */
          params->dsi.packet_size = 256;
          /* Video mode setting */
          params->dsi.intermediat_buffer_num = 0;
          params->dsi.PS = LCM_PACKED_PS_24BIT_RGB888;
          params->dsi.word_count=FRAME_WIDTH*3;
          params->dsi.vertical_sync_active        = 2;
          params->dsi.vertical_backporch            = 14;
          params->dsi.vertical_frontporch            = 16;
          params->dsi.vertical_active_line        = FRAME_HEIGHT;
          params->dsi.horizontal_sync_active        = 2;
          params->dsi.horizontal_backporch        = 44;
          params->dsi.horizontal_frontporch        = 46;
          params->dsi.horizontal_active_pixel        = FRAME_WIDTH;
          params->dsi.ssc_disable    = 1;    //0表示开展频,1表示关展频
          params->dsi.ssc_range     = 6;    //6为展频幅度6%,此值可以修改
          params->dsi.PLL_CLOCK     = 205;
        params->dsi.esd_check_enable = 1; //enable ESD check
      	params->dsi.customization_esd_check_enable = 1; //0 TE ESD CHECK  1 LCD REG CHECK
      	params->dsi.lcm_esd_check_table[0].cmd          = 0x0F;//0X0A
      	params->dsi.lcm_esd_check_table[0].count        = 1;
      	params->dsi.lcm_esd_check_table[0].para_list[0] = 0xC0;//0X9C
        params->dsi.cont_clock    = 0;
        params->dsi.clk_lp_per_line_enable = 1;
      static unsigned int lcm_compare_id(void);
      static void lcm_reset(void)
          #ifdef BUILD_LK
          printf("[LK/LCM]xxxxxxx %s enter\n", __func__);
          #else
          printk("[Kernel/LCM] %s enter\n", __func__);
          #ifdef BUILD_LK
          lcm_set_gpio_output(LCD_RST_PIN, GPIO_OUT_ONE);
          lcm_set_gpio_output(LCD_3V3_RST_PIN, GPIO_OUT_ONE);
          MDELAY(20);
          lcm_set_gpio_output(LCD_RST_PIN, GPIO_OUT_ZERO);
          lcm_set_gpio_output(LCD_3V3_RST_PIN, GPIO_OUT_ZERO);
          MDELAY(10);
          MDELAY(50);
          #else
          inettek_gpio_set("lcm_rst_en1");
          inettek_gpio_set("lcm_3v3_rst_en1");
          MDELAY(20);
          inettek_gpio_set("lcm_rst_en0");
          inettek_gpio_set("lcm_3v3_rst_en0");
          MDELAY(10);
          MDELAY(20);
      static void lcm_init(void)
          #ifdef BUILD_LK
          #else
          lcm_reset();
          push_table(lcm_initialization_setting, sizeof(lcm_initialization_setting) / sizeof(struct LCM_setting_table), 1);
      static void lcm_resume(void)
          #ifdef BUILD_LK
          #else
          lcm_reset();
      static void lcm_init_power(void)
          #ifdef BUILD_LK
          #else
          #ifdef BUILD_LK
          pmic_vgp2_enable(false, 1800);    //VCC_LCD8_1V8
          lcm_set_gpio_output(LCD_2V8_EN, GPIO_OUT_ONE);    //VCC_LCD_3V3
          MDELAY(20);
          pmic_vgp2_enable(true, 1800);    //VCC_LCD8_1V8
          MDELAY(10);
          lcm_set_gpio_output(LCD_AVDD_EN, GPIO_OUT_ONE);
          lcm_set_gpio_output(LCD_GAMA_EN, GPIO_OUT_ZERO);
          #else
          inettek_gpio_set("lcm_vcc_en1");
          inettek_gpio_set("lcm_avdd_en1");
          inettek_gpio_set("lcm_gama_en0");
      static void lcm_resume_power(void)
          #ifdef BUILD_LK
          #else
          #ifdef BUILD_LK
          #else
      static void lcm_suspend(void)
          #ifndef BUILD_LK
          //unsigned int data_array[16];
          // data_array[0] = 0x00280500; /* Display Off */
          // dsi_set_cmdq(data_array, 1, 1);
          // MDELAY(10);
          // data_array[0] = 0x00100500; /* Sleep In */
          // MDELAY(120);
      static void lcm_suspend_power(void)
          #ifdef BUILD_LK
          #else
          #ifdef BUILD_LK
          lcm_set_gpio_output(LCD_2V8_EN, GPIO_OUT_ZERO);    //VCC_LCD_3V3
          pmic_vgp2_enable(false,1800);
          MDELAY(10);
          lcm_set_gpio_output(LCD_AVDD_EN, GPIO_OUT_ZERO);
          #else
          MDELAY(10);
          inettek_gpio_set("lcm_avdd_en0");
          lcm_vgp_supply_disable();
          inettek_gpio_set("lcm_vcc_en0");
          MDELAY(10);
          unsigned int id = 0xffff;
          unsigned int version_id = 0xff;
          unsigned char buffer[3];
          unsigned int hw_ver = 0;
          unsigned int array[16];
          buffer[0] = 0xff;
          buffer[1] = 0xff;
          buffer[2] = 0xff;
          lcm_init_power();
          lcm_reset();
          // array[0] = 0x00023700;// read id return two byte,version and id
          array[0] = 0x00033700;// read id return two byte,version and id
          dsi_set_cmdq(array, 1, 1);
          read_reg_v2(0x04, buffer, 3);
          id = buffer[1]|(buffer[0]<<8);;    //we only need ID
          version_id = buffer[2];
      #ifdef BUILD_LK
          extern int g_hw_ver;
          hw_ver = g_hw_ver;
          //Read NV3052 ID, ID=0x3052, version_id=0x2, hw_ver=0x1
          printf("Read NV3052 ID, ID=0x%x, version_id=0x%x, hw_ver=0x%x\n", id , version_id , hw_ver);
          printf("[LK/LCM] %s %s is nv3052_bv055hdl_nb6! \n", __func__,hw_ver?"i50_lcm":"i70Plus_lcm");
      #else
          printk("Read NV3052 ID, ID=0x%x, version_id=0x%x, hw_ver=0x%x\n", id , version_id , hw_ver);
          printk("[Kernel/LCM] %s %s is nv3052_bv055hdl_nb6! \n", __func__,hw_ver?"i50_lcm":"i70Plus_lcm");
          if (hw_ver && (LCM_ID_NV3052 == id))
              return 1;
      LCM_DRIVER nv3052_bv055hdl_nb6_dsi_vdo_lcm_drv = {
          .name            = "nv3052_bv055hdl_nb6_dsi_vdo",
          .set_util_funcs = lcm_set_util_funcs,
          .get_params     = lcm_get_params,
          .init           = lcm_init,
          .init_power     = lcm_init_power,
          .suspend        = lcm_suspend,
          .resume         = lcm_resume,
          .resume_power    = lcm_resume_power,
          .suspend_power    = lcm_suspend_power,
          .compare_id     = lcm_compare_id,
        devin_liu LV 2 最后由 编辑
        先uboot能不能亮,主要就是时序和初始化参数要对就可以
