    T113板子 spi1加了块nand flash 怎么识别出来
    • T
      taiwu001 LV 2 最后由 编辑
      spi0有一块 128M的 GD5F1GQ5UEYIGR nand flash,能正常下载固件运行,因为空间不够用现在在 spi1处也加了块 128M GD5F1GQ5UEYIGR作为存储数据用,请问各位老师 怎么把这个识别出来526c0a07-3eba-4da9-8460-8f8e252243c3-image.png
      改了设备树 &spi1 {
      pinctrl-1 = <&spi1_pins_c>;
      spi_slave_mode = <0>;
          spi1_cs_number = <1>;
          spi1_cs_bitmap = <1>;
          spi-nand@0 {
              compatible = "spi-nand";
              #address-cells = <1>;
              #size-cells = <1>;
              spi-max-frequency = <100000000>;
              reg = <0x0>;
              nand-on-flash-bbt;
              partitions {
                  compatible = "fixed-partitions";
                  #size-cells = <1>;
                  partition@0 {
                      label = "spi1-data";
                      reg = <0x0 0x8000000>;
      };   还是没出来 localhost:~# df -h
      Filesystem          Size  Used Avail Use% Mounted on
      /dev/root            26M   26M     0 100% /rom
      none                 55M     0   55M   0% /dev
      tmpfs                55M     0   55M   0% /tmp
      /dev/ubi0_7          66M  3.7M   59M   6% /overlay
      overlayfs:/overlay   66M  3.7M   59M   6% /
      tmpfs                11M  120K   11M   2% /run
      shm                  55M     0   55M   0% /dev/shm
      localhost:~# cat /proc/mtd
      dev:    size   erasesize  name
      mtd0: 00100000 00040000 "boot0"
      mtd1: 00300000 00040000 "uboot"
      mtd2: 00100000 00040000 "secure_storage"
      mtd3: 1fb00000 00040000 "sys"
      localhost:~# dmesg | grep -i "spi-nand"
      [    1.086831] sunxi-spinand-phy: get spi-nand Model from fdt fail
      [    1.995607] spi-nand: probe of spi1.0 failed with error -16
