    V821 boot problem
      sanek11591 LV 2 最后由 编辑
      Hello everyone, making some experiments with SC1742v develop board, and on last image burning i got flash timeout error and the board stopped booting and nor flash seems to be dead as i can`t even erase it. I took another nor memory of same capacity but another vendor and flashed it the same was as i did previously with Phoenixsuit. But the board stopped booting - always Kernel panic on mounting.
      U-Boot 2018.07-gc5fe54d6-dirty (Dec 11 2025 - 03:32:45 +0000) Allwinner Technology
      I2C: ready
      [00.288]DRAM: 64 MiB
      [00.290]Relocation Offset is: 01f2e000, reloc addr is: 83f2e000
      [00.298]secure enable bit: 0
      [00.301]drivers/sunxi_power/pmu_axpnull.c pmu_axpnull_probe 26 axpdummy probe
      FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL
      [00.316]axp2601 pmic_bus_read fail
      [00.319]BMU: AXPNULL
      [00.321]CPU=960 MHz,PERI=3072 Mhz,AHB=192 Mhz, APB=96Mhz
      SPI ALL: ready
      [00.329]flash init start
      [00.332]workmode = 0,storage type = 3
      SF: sr: 0x42, sr2: 0xff, sr3: 0x07
      [00.343]spi sample_mode:0 sample_delay:24
      [00.347]spif sunxi_slave->max_hz:100000000
      SF: Detected mx25l12805d( ) with page size 256 Bytes, erase size 64 KiB, total 16 MiB
      [00.360]sunxi flash init ok
      [00.364]Loading Environment from SUNXI_FLASH... OK
      ** Unable to read file bootlogo.jpg **
      sunxi_jpeg_display:313 length_of_file invalid:0
      [00.402]get secure storage map err
      [00.405]sunxi secure storage is not supported
      [00.409]usb burn from boot
      delay time 0
      [00.421]usb prepare ok
      [00.594]usb sof ok
      [00.596]usb probe ok
      [00.598]usb setup ok
      set address 0x22
      set address 0x22 ok
      [01.004]do_burn_from_boot usb : have no handshake
      [01.008]get secure storage map err
      List file under ULI/factory
      [01.017]get secure storage map err
      [01.020]get secure storage map err
      [01.023]get secure storage map err
      [01.026]get secure storage map err
      root_partition is rootfs
      set root to /dev/mtdblock7
      [01.034]update part info
      [01.037]update bootcmd
      [01.041]change working_fdt 0x836edea0 to 0x836cdea0
      [01.062]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      [01.070]update dts
      [11.204]no vendor_boot partition is found
      Android's image name: sun300i_riscv32
      Detect comp gzip
      ERROR: reserving fdt memory region failed (addr=80ffff00 size=100)
      [11.458]
      Starting kernel ...
      [ 0.000000] Linux version 5.4.220 (ross@ross) (gcc version 10.4.0 (2024-02-02_nds32le-linux-glibc-v5d-bbc31ec98)) #7 PREEMPT Wed Jan 28 16:41:53 MSK 2026
      [ 0.000000] printk: bootconsole [earlycon0] enabled
      [ 0.440881] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,7)
      [ 0.450214] CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.220 #7
      [ 0.456742] Call Trace:
      [ 0.459513] [<c002cfa8>] walk_stackframe+0x0/0xba
      [ 0.464815] [<c056aa20>] dump_backtrace+0x30/0x3c
      [ 0.470109] [<c056aa3a>] show_stack+0xe/0x16
      [ 0.474922] [<c0578d22>] dump_stack+0x1c/0x24
      [ 0.479827] [<c056abf0>] panic+0xe6/0x268
      [ 0.484340] [<c0001eb0>] mount_block_root+0x20e/0x280
      [ 0.490021] [<c0001fa4>] mount_root+0x82/0x8e
      [ 0.494926] [<c0002110>] prepare_namespace+0x160/0x16e
      [ 0.500711] [<c0001b18>] kernel_init_freeable+0x19a/0x1d2
      [ 0.506790] [<c0578ee8>] kernel_init+0x12/0xd4
      [ 0.511793] [<c002bd92>] ret_from_exception+0x0/0xc
      [ 0.517292] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,7) ]---
      What did i do wrong?
