    F133-A启动内核时死机
    H/F/TV Series
    • Q
      QL2017 LV 5 最后由 编辑
      我的芯片是F133-A,用的在线文档的D1s的SDK,运行的时候就是莫名死机,每次都是卡在一个地方,重启多次也没用,求大神指导!!
      日志:
      [30]HELLO! BOOT0 is starting!
      [33]BOOT0 commit : 88480af
      [36]set pll start
      [37]periph0 has been enabled
      [40]set pll end
      [42][pmu]: bus read error
      [44]board init ok
      [46]ZQ value = 0x30
      [48]get_pmu_exist() = -1
      [50]ddr_efuse_type: 0xa
      [52]trefi:7.8ms
      [54][AUTO DEBUG] single rank and full DQ!
      [58]ddr_efuse_type: 0xa
      [61]trefi:7.8ms
      [63][AUTO DEBUG] rank 0 row = 13
      [66][AUTO DEBUG] rank 0 bank = 4
      [69][AUTO DEBUG] rank 0 page size = 2 KB
      [73]DRAM BOOT DRIVE INFO: V0.33
      [75]DRAM CLK = 396 MHz
      [78]DRAM Type = 2 (2:DDR2,3:DDR3)
      [81]DRAMC read ODT off.
      [83]DRAM ODT off.
      [85]ddr_efuse_type: 0xa
      [88]DRAM SIZE =64 M
      [89]dram_tpr4:0x0
      [91]PLL_DDR_CTRL_REG:0xf8002000
      [94]DRAM_CLK_REG:0xc0000000
      [97][TIMING DEBUG] MR2= 0x0
      [101]DRAM simple test OK.
      [104]dram size =64
      [105]card no is 0
      [107]sdcard 0 line count 4
      [110][mmc]: mmc driver ver 2021-04-2 16:45
      [119][mmc]: Wrong media type 0x0
      [122][mmc]: Try SD card 0
      [126][mmc]: mmc 0 cmd 8 timeout, err 100
      [129][mmc]: mmc 0 cmd 8 err 100
      [132][mmc]: mmc 0 send if cond failed
      [139][mmc]: HSSDR52/SDR25 4 bit
      [142][mmc]: 50000000 Hz
      [144][mmc]: 240 MB
      [146][mmc]: SD/MMC 0 init OK!!!
      [194]Loading boot-pkg Succeed(index=0).
      [198]Entry_name = opensbi
      [201]Entry_name = u-boot
      [205]Entry_name = dtb
      [208]mmc not para
      [209]Jump to second Boot.
      / __ \ / | _ _ |
      __ ___ _ __ | (
      | | | | '_ \ / _ \ '_ \ ___ | _ < | |
      | || | |) | __/ | | |) | |) || |
      _
      /| ./ _|| ||/|____/|
      |_|
      Platform Name : T-HEAD Xuantie Platform
      Platform Max HARTs : 1
      Current Hart : 0
      Firmware Base : 0x41fc0400
      Firmware Size : 75 KB
      Runtime SBI Version : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP0 : 0x0000000041fc0000-0?
      U-Boot 2018.07-ge987def5-dirty (Jan 15 2026 - 22:40:06 +0800) Allwinner Technology
      [00.278]DRAM: 64 MiB
      [00.281]Relocation Offset is: 01ee9000
      [00.285]secure enable bit: 0
      [00.289]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
      sunxi flash map init
      SPI ALL: ready
      [00.300]flash init start
      [00.302]workmode = 0,storage type = 1
      [00.305][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.311][mmc]: get sdc_type fail and use default host:tm1.
      [00.318][mmc]: can't find node "mmc0",will add new node
      [00.322][mmc]: fdt err returned <no error>
      [00.326][mmc]: Using default timing para
      [00.330][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.347][mmc]: card_caps:0x3000000a
      [00.350][mmc]: host_caps:0x3000003f
      [00.353]sunxi flash init ok
      [00.356]line:703 init_clocks
      [00.359]drv_disp_init
      [00.375]drv_disp_init finish
      [00.380]Loading Environment from SUNXI_FLASH... OK
      [00.400]boot_gui_init:start
      [00.403]set disp.dev2_output_type fail. using defval=0
      [00.408]LCD open finish
      [00.411]set disp.fb0_rot_used fail. using defval=0
      [00.415]set disp.fb0_rot_degree fail. using defval=0
      [00.421]boot_gui_init:finish
      [00.428]bmp_name=bootlogo.bmp size 38454
      [00.437]out of usb burn from boot: not need burn key
      [00.442]Item0 (Map) magic is bad
      [00.445]the secure storage item0 copy0 magic is bad
      [00.449]Item0 (Map) magic is bad
      [00.452]the secure storage item0 copy1 magic is bad
      [00.457]Item0 (Map) magic is bad
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.468]update part info
      [00.471]update bootcmd
      [00.473]change working_fdt 0x42aa8da0 to 0x42a88da0
      [00.483]The storage not support sample function
      [00.517]update dts
      Hit any key to stop autoboot: 1  0
      input addr exceed dram scope
      [01.837]no vendor_boot partition is found
      Android's image name: d1s-nezha
      Detect comp none
      [01.859]
      Starting kernel ...
      [01.861][mmc]: MMC Device 2 not found
      [01.865][mmc]: mmc 2 not find, so not exit
      [ 0.000000] Linux version 5.4.61 (link@nexa-H310M-S2-2-0) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #31 PREEMPT Thu Jan 15 14:44:44 UTC 2026 [ 0.000000] earlycon: sbi0 at I/O port 0x0 (options '') [ 0.000000] printk: bootconsole [sbi0] enabled [ 0.000000] cma: Reserved 8 MiB at 0x0000000043800000 [ 0.000000] Zone ranges: [ 0.000000] DMA32 [mem 0x0000000040000000-0x0000000043ffffff]
      [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000040000000-0x0000000043ffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x0000000043ffffff] [ 0.000000] On node 0 totalpages: 16384 [ 0.000000] DMA32 zone: 224 pages used for memmap [ 0.000000] DMA32 zone: 0 pages reserved [ 0.000000] DMA32 zone: 16384 pages, LIFO batch:3 [ 0.000000] elf_hwcap is 0x20112d [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16160 [ 0.000000] Kernel command line: earlycon=sbi console=ttyS2,115200 loglevel=8 earlyprintk=sunxi-uart,0x02500800 clk_ignore_unused initcall_debug=0 console=ttyS2,115200 loglevel=8 root=/dev/mmcblk0p5 init=/pseudo_init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:recovery@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.07-ge987def5-dirty(01/15/2026-22:40:06) mbr_offset=1556480 disp_reserve=1536000,0x0000000042b3a000 androidboot.dramsize=64 [ 0.000000] Dentry cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.000000] Inode-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.000000] Sorting __ex_table... [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 47048K/65536K available (4617K kernel code, 430K rwdata, 1803K rodata, 168K init, 230K bss, 10296K reserved, 8192K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [ 0.000000] NR_IRQS: 0, nr_irqs: 0, preallocated irqs: 0 [ 0.000000] plic: mapped 200 interrupts with 1 handlers for 2 contexts. [ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
      [ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000010] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.008075] riscv_timer_clockevent depends on broadcast, but no broadcast function available [ 0.016997] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.026544] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.036144] pid_max: default: 32768 minimum: 301 [ 0.041103] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear) [ 0.048113] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear) [ 0.058466] ASID allocator initialised with 65536 entries [ 0.061506] rcu: Hierarchical SRCU implementation. [ 0.067128] devtmpfs: initialized [ 0.093307] random: get_random_u32 called from bucket_table_alloc.isra.27+0x102/0x124 with crng_init=0 [ 0.094841] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.095206] futex hash table entries: 256 (order: 0, 6144 bytes, linear) [ 0.099436] pinctrl core: initialized pinctrl subsystem [ 0.105874] NET: Registered protocol family 16 [ 0.111368] DMA: preallocated 256 KiB pool for atomic allocations [ 0.115205] cpuidle: using governor menu [ 0.178356] rtc_ccu: sunxi ccu init OK [ 0.194424] clock: sunxi ccu init OK [ 0.196711] clock: sunxi ccu init OK [ 0.239719] sun6i-dma 3002000.dma-controller: sunxi dma probed [ 0.242910] iommu: Default domain type: Translated [ 0.243259] sunxi iommu: irq = 4 [ 0.245034] SCSI subsystem initialized [ 0.245670] usbcore: registered new interface driver usbfs [ 0.245913] usbcore: registered new interface driver hub [ 0.246520] usbcore: registered new device driver usb [ 0.251838] videodev: Linux video capture interface: v2.00 [ 0.258408] Advanced Linux Sound Architecture Driver Initialized. [ 0.264262] Bluetooth: Core ver 2.22 [ 0.266902] NET: Registered protocol family 31 [ 0.271306] Bluetooth: HCI device and connection manager initialized [ 0.277832] Bluetooth: HCI socket layer initialized [ 0.282669] Bluetooth: L2CAP socket layer initialized [ 0.287864] Bluetooth: SCO socket layer initialized [ 0.293118] pwm module init! [ 0.297911] g2d 5410000.g2d: Adding to iommu group 0 [ 0.301420] G2D: rcq version initialized.major:252 [ 0.306914] clocksource: Switched to clocksource riscv_clocksource [ 0.332777] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver [ 0.337748] NET: Registered protocol family 2 [ 0.339096] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear) [ 0.339313] TCP established hash table entries: 512 (order: 0, 4096 bytes, linear) [ 0.339468] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear) [ 0.346194] TCP: Hash tables configured (established 512 bind 512) [ 0.352763] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [ 0.359167] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear) [ 0.366380] NET: Registered protocol family 1 [ 0.374307] workingset: timestamp_bits=62 max_order=14 bucket_order=0 [ 0.390429] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.390920] ntfs: driver 2.1.32 [Flags: R/W]. [ 0.419045] io scheduler mq-deadline registered [ 0.419154] io scheduler kyber registered [ 0.420491] [DISP]disp_module_init [ 0.421397] disp 5000000.disp: Adding to iommu group 0 [ 0.422328] [DISP] parser_disp_init_para,line:1430: [ 0.422335] of_property_read fb0_width fail [ 0.423344] [DISP] disp_init,line:2387: [ 0.423350] smooth display screen:0 type:1 mode:4 [ 0.485671] display_fb_request,fb_id:0 [ 0.497088] [DISP]disp_module_init finish [ 0.498361] sunxi_sid_init()783 - insmod ok [ 0.498861] disp_al_manager_apply ouput_type:1 [ 0.499182] [DISP] lcd_clk_config,line:774: [ 0.499202] disp 0, clk: pll(360000000),clk(360000000),dclk(30000000) dsi_rate(30000000) [ 0.499202] clk real:pll(360000000),clk(360000000),dclk(90000000) dsi_rate(150000000) [ 0.509337] pwm-regulator: supplied by regulator-dummy [ 0.516131] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator [ 0鸞 0.546340] printk: console [ttyS2] enabled
      [ 0.546340] printk: console [ttyS2] enabled [ 0.551165] printk: bootconsole [sbi0] disabled
      [ 0.551165] printk: bootconsole [sbi0] disabled [ 0.562150] misc dump reg init
      [ 0.569845] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [ 0.581225] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [ 0.588537] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [ 0.595866] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [ 0.603337] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [ 0.609922] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [ 0.616892] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [ 0.624704] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
      [ 0.632686] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [ 0.640904] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [ 0.648752] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [ 0.655529] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [ 0.663167] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=141 assert=0
      [ 0.671790] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
      [ 0.679966] [ADDR_MGT] addr_mgt_probe: success.
      [ 0.686466] libphy: Fixed MDIO Bus: probed
      [ 0.692856] sun8iw20-pinctrl 2000000.pinctrl: pin PE2 already requested by 2500800.uart; cannot claim for 4500000.eth
      [ 0.704824] sun8iw20-pinctrl 2000000.pinctrl: pin-130 (4500000.eth) status -22
      [ 0.713003] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 130 (PE2) from group PE2 on device 2000000.pinctrl
      [ 0.725093] sunxi-gmac 4500000.eth: Error applying setting, reverse things back
      [ 0.733389] sunxi-gmac: probe of 4500000.eth failed with error -22
      [ 0.740712] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [ 0.748103] sunxi-ehci: EHCI SUNXI driver
      [ 0.753397] get ehci1-controller wakeup-source is fail.
      [ 0.759460] sunxi ehci1-controller don't init wakeup source
      [ 0.765720] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe000704210, 0x:ffffffd00406d000, irq_no:31
      [ 0.779288] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
      [ 0.792062] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [ 0.804499] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [ 0.811892] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [ 0.821923] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
      [ 0.856982] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [ 0.866461] hub 1-0:1.0: USB hub found
      [ 0.870865] hub 1-0:1.0: 1 port detected
      [ 0.876579] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [ 0.883636] sunxi-ohci: OHCI SUNXI driver
      [ 0.889024] get ohci1-controller wakeup-source is fail.
      [ 0.895047] sunxi ohci1-controller don't init wakeup source
      [ 0.901368] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe0007045d8
      [ 0.911848] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
      [ 0.924518] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [ 0.937079] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [ 0.944373] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [ 0.954330] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
      [ 1.032454] hub 2-0:1.0: USB hub found
      [ 1.036746] hub 2-0:1.0: 1 port detected
      [ 1.042920] usbcore: registered new interface driver uas
      [ 1.049263] usbcore: registered new interface driver usb-storage
      [ 1.058784] sunxi-rtc 7090000.rtc: registered as rtc0
      [ 1.064608] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:44 UTC (44)
      [ 1.073682] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [ 1.079872] i2c /dev entries driver
      [ 1.083851] IR NEC protocol handler initialized
      [ 1.092920] usbcore: registered new interface driver uvcvideo
      [ 1.099428] USB Video Class driver (1.1.1)
      [ 1.104015] sunxi cedar version 1.1
      [ 1.108332] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [ 1.114623] VE: install start!!!
      [ 1.114623]
      [ 1.120368] VE: cedar-ve the get irq is 6
      [ 1.120368]
      [ 1.126869] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
      [ 1.126869]
      [ 1.138557] VE: install end!!!
      [ 1.138557]
      [ 1.143631] VE: sunxi_cedar_probe
      [ 1.147950] Bluetooth: HCI UART driver ver 2.3
      [ 1.152937] Bluetooth: HCI UART protocol H4 registered
      [ 1.158759] Bluetooth: HCI UART protocol BCSP registered
      [ 1.165156] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
      [ 1.175736] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [ 1.185777] sunxi-mmc 4020000.sdmmc: ctl-spec-caps 8
      [ 1.192034] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [ 1.198427] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [ 1.204877] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [ 1.211332] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [ 1.217929] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [ 1.224481] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [ 1.231070] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [ 1.238943] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.250186] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [ 1.270403] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.294749] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
      [ 1.300901] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.313925] sunxi_led_probe()1749 - start
      [ 1.318707] sunxi_get_str_of_property()1595 - failed to get the string of propname led_regulator!
      [ 1.328767] sunxi_register_led_classdev()1483 - led_classdev start
      [ 1.337028] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.349580] sunxi_led_probe()1845 - finish
      [ 1.355191] ashmem: initialized
      [ 1.358963] exFAT: Version 1.3.0
      [ 1.363693] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.380618] [AUDIOCODEC][sunxi_codec_parse_params][2437]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [ 1.380618]
      [ 1.398074] [AUDIOCODEC][sunxi_codec_parse_params][2473]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [ 1.409800] [AUDIOCODEC][sunxi_internal_codec_probe][2634]:codec probe finished
      [ 1.418071] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.431674] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [ 1.441751] [SNDCODEC][sunxi_card_init][583]:card init finished
      [ 1.452484] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [ 1.465248] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      [ 1.478124] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [ 1.487534] mmc0: host does not support reading read-only switch, assuming write-enable
      [ 1.497031] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      [ 1.505736] NET: Registered protocol family 10
      [ 1.510879] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [ 1.524463] Segment Routing with IPv6
      [ 1.529018] NET: Registered protocol family 17
      [ 1.534325] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [ 1.546227] Bluetooth: RFCOMM TTY layer initialized
      [ 1.551895] Bluetooth: RFCOMM socket layer initialized
      [ 1.557761] Bluetooth: RFCOMM ver 1.11
      [ 1.563629] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [ 1.587120] mmc0: new high speed SD card at address 0001
      [ 1.608422] mmcblk0: mmc0:0001 asdfg 240 MiB
      [ 1.626414] sun8iw20-pinctrl 2000000.pinctrl: pin PE2 already requested by 2500800.uart; cannot claim for 4500000.eth
      [ 1.638640] sun8iw20-pinctrl 2000000.pinctrl: pin-130 (4500000.eth) status -22
      [ 1.647213] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 130 (PE2) from group PE2 on device 2000000.pinctrl
      [ 1.659779] sunxi-gmac 4500000.eth: Error applying setting, reverse things back
      [ 1.668306] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
      [ 1.673677] sunxi-gmac: probe of 4500000.eth failed with error -22
      [ 1.684793] sun8iw20-pinctrl 2000000.pinctrl: pin PE13 already requested by 2000000.pinctrl:141; cannot claim for 2502800.twi
      [ 1.697602] sun8iw20-pinctrl 2000000.pinctrl: pin-141 (2502800.twi) status -22
      [ 1.705694] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 141 (PE13) from group PE13 on device 2000000.pinctrl
      [ 1.718060] sunxi-i2c 2502800.twi: Error applying setting, reverse things back
      [ 1.726219] sunxi-i2c: probe of 2502800.twi failed with error -22
      [ 1.735680] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [ 1.750890] get ehci0-controller wakeup-source is fail.
      [ 1.756990] sunxi ehci0-controller don't init wakeup source
      [ 1.763258] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe000703a80, 0x:ffffffd0040f7000, irq_no:2e
      [ 1.776825] [sunxi-ehci0]: Not init ehci0
      [ 1.782041] get ohci0-controller wakeup-source is fail.
      [ 1.788122] sunxi ohci0-controller don't init wakeup source
      [ 1.794388] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe000703e48
      [ 1.804859] [sunxi-ohci0]: Not init ohci0
      [ 1.812136] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
      [ 1.827194] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [ 1.836885] cfg80211: failed to load regulatory.db
      [ 1.842373] clk: Not disabling unused clocks
      [ 1.847256] ALSA device list:
      [ 1.850585] #0: audiocodec
      [ 1.853823] alloc_fd: slot 0 not NULL!
      [ 1.863632] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
      [ 1.874414] devtmpfs: mounted
      [ 1.878189] Freeing unused kernel memory: 168K
      [ 1.883172] This architecture does not have kernel memory protection.
      [ 1.890574] Run /pseudo_init as init process
      mount: mounting /dev/by-name/rootfs_data on /overlay failed: Invalid argument
      Mount Failed: formating /dev/by-name/rootfs_data to ext4 ...
      /pseudo_init: line 403: mkfs.ext4: not found
      /etc/init.d/rcS: line 152: mkfs.ext4: not found
      ------run rc.final file-----
      : values=on
      ------light up RGB LED-----
      [ 3.099555] file system registered
      [ 3.152246] configfs-gadget 4100000.udc-controller: failed to start g1: -19
      [ 3.229335] read descriptors
      [ 3.232591] read strings
      [ 3.566996] [DISP] fb_free_reserve_mem,line:2267:
      [ 3.567005] [DISP] fb_free_reserve_mem wait for sync timeout
      [ 3.580640] Freeing logo buffer memory: 1500K
      ------light u
      H 1 条回复 最后回复 回复 引用 分享 0
        hdq000 LV 2 @QL2017 最后由 编辑
        @ql2017 帮顶一下,感谢分享,很有用。
        Q 1 条回复 最后回复 回复 引用 分享 0
        • Q
          QL2017 LV 5 @hdq000 最后由 编辑
          @hdq000 已经解决了,似乎这个SDK就是无法启动,我的方案是获取SDK那里下方有一个nezha开发板的补丁包,打上补丁之后lunch选多出来的方案就能编译成功和顺利启动
