    Request: GLIBC 2.31 Compatible NPU Userspace Libraries for A733 SoC (libGAL.so)
    A Series
    • R
      rajecx LV 2 最后由 编辑
      Dear Allwinner Technical Support Team,
      We are working on deploying an AI inference pipeline on the Cubie A7Z board which uses the Allwinner A733 SoC.
      Board Details:
      • Board: Cubie A7Z (A733 SoC)
      • OS: Debian 11 Bullseye
      • Kernel: 5.15.147-14-a733
      • GLIBC Version: 2.31
      What We Have Done:
      • Successfully converted YOLOX model to .nb format using Pegasus/Acuity Toolkit (unified-tina AI-SDK v2.0.10.1)
      • Successfully compiled inference binary natively on the board
      • Confirmed NPU kernel driver (vipcore) is loaded and /dev/vipcore exists
      • Confirmed NPU interrupt is registered at /proc/interrupts
      The Problem:
      All three variants of libGAL.so provided in the unified-tina AI-SDK require GLIBC 2.33:
      • lib/glibc-gcc10_2_0/libGAL.so → requires GLIBC 2.33
      • lib/glibc-gcc13_2_0/libGAL.so → requires GLIBC 2.33
      • lib/aarch64-none-linux-gnu/libGAL.so → requires GLIBC 2.33
      However the official Debian 11 Bullseye OS for Cubie A7Z only provides GLIBC 2.31. This causes the following error at runtime:
      GLIBC_2.33 not found (required by libGAL.so)
      Our Request:
      Could you please provide:
      1. NPU userspace libraries (libGAL.so and all dependent .so files) compiled against GLIBC 2.31 for Debian 11 Bullseye
      2. OR the official Tina Linux image for Cubie A7Z / A733 SoC with pre-matched NPU libraries
      This is blocking our production AI deployment on the Cubie A7Z board. Any urgent assistance would be greatly appreciated.
