    T113S4烧录之后异常
      Shaco_Ma LV 4 最后由 编辑
      大佬们,问个问题啊,就是烧录之后貌似无法启动
      前提:使用的是荣品的tina sdk,里面支持了t113s3,目前烧录可以正常启动t113s3,存储介质为nand,256m,移植了正点原子的SDK的brandy相关部分,包括spl-pub,tool,uboot等,同时,使用荣品的SDK的kernel和longan的rootfs,同时移植了正点原子的SDK的device的t113_s4的相关配置等
      问题:目前是可以编译通过,生成的固件夜歌原来的t113s3的固件大小差不多,但是目前有个问题是,烧录工具到88%左右就停止,提示烧录错误,具体可以看一下串口日志和烧录工具的调试日志,看烧录工具的日志是获取boot0的存储类型失败,不知道这个有没有什么分析方向?
      串口日志:
      [2221]fes begin commit:069ed30b88
      [2224]set pll start
      [2230]periph0 has been enabled
      [2233]set pll end
      [2235][pmu]: bus read error
      [2237]board init ok
      [2239]beign to init dram
      [2241]ZQ value = 0x2b
      [2243]get_pmu_exist() = -1
      [2246]ddr_efuse_type: 0xa
      [2248]trefi:7.8ms
      [2251][AUTO DEBUG] single rank and full DQ!
      [2255]ddr_efuse_type: 0xa
      [2257]trefi:7.8ms
      [2260][AUTO DEBUG] rank 0 row = 14
      [2263][AUTO DEBUG] rank 0 bank = 8
      [2266][AUTO DEBUG] rank 0 page size = 2 KB
      [2270]DRAM BOOT DRIVE INFO: V0.34
      [2274]DRAM CLK = 792 MHz
      [2276]DRAM Type = 3 (2:DDR2,3:DDR3)
      [2279]DRAMC ZQ value: 0x7b7bfb
      [2282]DRAM ODT value: 0x42.
      [2285]ddr_efuse_type: 0xa
      [2288]DRAM SIZE = 256 MB
      [2291]DRAM simple test OK.
      [2294]rtc standby flag is 0x0, super standby flag is 0x0
      [2299]init dram ok
      U-Boot 2018.07 (Mar 11 2026 - 10:40:27 +0000) Allwinner Technology
      [04.839]CPU: Allwinner Family
      [04.842]Model: sun8iw20
      [04.844]DRAM: 256 MiB
      [04.847]Relocation Offset is: 0cecc000
      [04.873]secure enable bit: 0
      [04.876]PMU: no found
      [04.878]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
      [04.884]gic: normal mode
      [04.886]sunxi flash map init
      [04.890]line:703 init_clocks
      [04.892]init_clocks:finish
      [04.895]flash init start
      [04.897]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [04.905][mmc]: mmc driver ver uboot2018:2023-07-4 16:18:00
      [04.911][mmc]: Is not Boot mode!
      [04.914][mmc]: SUNXI SDMMC Controller Version:0x50310
      [04.925][mmc]: Try SD card 2
      [04.930][mmc]: mmc 2 cmd timeout 100 status 100
      [04.935][mmc]: smc 2 err, cmd 8, RTO
      [04.938][mmc]: mmc 2 close bus gating and reset
      [04.943][mmc]: mmc 2 cmd timeout 100 status 100
      [04.947][mmc]: smc 2 err, cmd 55, RTO
      [04.951][mmc]: mmc 2 close bus gating and reset
      [04.955][mmc]: Try MMC card 2
      [04.964][mmc]: mmc 2 cmd timeout 100 status 100
      [04.968][mmc]: smc 2 err, cmd 1, RTO
      [04.971][mmc]: mmc 2 close bus gating and reset
      [04.975][mmc]: Card did not respond to voltage select!
      [04.980][mmc]: SD/MMC 2 init error!
      [04.986][mmc]: mmc init product failed
      MMC init failed
      try emmc fail
      [04.992]sunxi-spinand: AW SPINand MTD Layer Version: 1.12 20231023
      [04.998]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.16 20231109
      [05.006]sunxi-spinand-phy: request spi0 gpio ok
      [05.010]sunxi-spinand-phy: request general tx dma channel ok!
      [05.015]sunxi-spinand-phy: request general rx dma channel ok!
      [05.021]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [05.025]sunxi-spinand-phy: init spic0 clk ok
      [05.029]sunxi-spinand-phy: detect munufacture from id table: Winbond
      [05.036]sunxi-spinand-phy: detect spinand id: ff22aaef ffffffff
      [05.041]sunxi-spinand-phy: ========== arch info ==========
      [05.046]sunxi-spinand-phy: Model: W25N02KVZEIR
      [05.052]sunxi-spinand-phy: Munufacture: Winbond
      [05.057]sunxi-spinand-phy: DieCntPerChip: 1
      [05.061]sunxi-spinand-phy: BlkCntPerDie: 2048
      [05.066]sunxi-spinand-phy: PageCntPerBlk: 64
      [05.070]sunxi-spinand-phy: SectCntPerPage: 4
      [05.075]sunxi-spinand-phy: OobSizePerPage: 64
      [05.079]sunxi-spinand-phy: BadBlockFlag: 0x0
      [05.084]sunxi-spinand-phy: OperationOpt: 0x7
      [05.088]sunxi-spinand-phy: MaxEraseTimes: 65000
      [05.093]sunxi-spinand-phy: EccFlag: 0x0
      [05.098]sunxi-spinand-phy: EccType: 2
      [05.102]sunxi-spinand-phy: EccProtectedType: 3
      [05.107]sunxi-spinand-phy: ========================================
      [05.113]sunxi-spinand-phy:
      [05.115]sunxi-spinand-phy: ========== physical info ==========
      [05.121]sunxi-spinand-phy: TotalSize: 256 M
      [05.125]sunxi-spinand-phy: SectorSize: 512 B
      [05.129]sunxi-spinand-phy: PageSize: 2 K
      [05.133]sunxi-spinand-phy: BlockSize: 128 K
      [05.137]sunxi-spinand-phy: OOBSize: 64 B
      [05.141]sunxi-spinand-phy: ========================================
      [05.147]sunxi-spinand-phy:
      [05.150]sunxi-spinand-phy: ========== logical info ==========
      [05.155]sunxi-spinand-phy: TotalSize: 256 M
      [05.159]sunxi-spinand-phy: SectorSize: 512 B
      [05.163]sunxi-spinand-phy: PageSize: 4 K
      [05.167]sunxi-spinand-phy: BlockSize: 256 K
      [05.172]sunxi-spinand-phy: OOBSize: 128 B
      [05.176]sunxi-spinand-phy: ========================================
      [05.182]sunxi-spinand-phy: W25N02KVZEIR reset rx bit width to 1
      [05.188]sunxi-spinand-phy: W25N02KVZEIR reset tx bit width to 1
      [05.193]sunxi-spinand-phy: block lock register: 0x00
      [05.198]sunxi-spinand-phy: feature register: 0x19
      [05.202]sunxi-spinand-phy: sunxi physic nand init end
      [05.616]sunxi-spinand-phy: set spic0 clk to 100 Mhz
      [06.731]sunxi-spinand-phy: Sample mode:2 min_delay:5000 max_delay:15080 right_delay:0)
      [06.874]Loading Environment from SUNXI_FLASH... OK
      [06.879]try to burn key
      [06.881]out of usb burn from boot: not boot mode
      sunxi work mode=0x10
      run usb efex
      buf queue page size = 16384
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x16
      set address 0x16 ok
      err: invalid wValue, (0, 0)
      set address 0x16
      set address 0x16 ok
      SUNXI_EFEX_DRAM_MASK:32512
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x12
      origin_erase_flag = 0x1
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      SUNXI_EFEX_EXT4_UBIFS_TAG & do nothing
      the 0 mbr table is ok
      the 1 mbr table is ok
      the 2 mbr table is ok
      the 3 mbr table is ok
      MBR DUMP**
      total mbr part 8
      part[0] name :boot-resource
      part[0] classname :DISK
      part[0] addrlo :0x1f8
      part[0] lenlo :0x85e0
      part[0] user_type :32768
      part[0] keydata :0
      part[0] ro :0
      part[1] name :env
      part[1] classname :DISK
      part[1] addrlo :0x87d8
      part[1] lenlo :0x1f8
      part[1] user_type :32768
      part[1] keydata :0
      part[1] ro :0
      part[2] name :env-redund
      part[2] classname :DISK
      part[2] addrlo :0x89d0
      part[2] lenlo :0x1f8
      part[2] user_type :32768
      part[2] keydata :0
      part[2] ro :0
      part[3] name :boot
      part[3] classname :DISK
      part[3] addrlo :0x8bc8
      part[3] lenlo :0x89d0
      part[3] user_type :32768
      part[3] keydata :0
      part[3] ro :0
      part[4] name :rootfs
      part[4] classname :DISK
      part[4] addrlo :0x11598
      part[4] lenlo :0x50000
      part[4] user_type :32768
      part[4] keydata :0
      part[4] ro :0
      part[5] name :dsp0
      part[5] classname :DISK
      part[5] addrlo :0x61598
      part[5] lenlo :0x7e0
      part[5] user_type :32768
      part[5] keydata :0
      part[5] ro :0
      part[6] name :private
      part[6] classname :DISK
      part[6] addrlo :0x61d78
      part[6] lenlo :0x7e0
      part[6] user_type :32768
      part[6] keydata :0
      part[6] ro :0
      part[7] name :UDISK
      part[7] classname :DISK
      part[7] addrlo :0x62558
      part[7] lenlo :0x0
      part[7] user_type :33024
      part[7] keydata :0
      part[7] ro :0
      total part: 9
      mbr 0, 1f8, 8000
      boot-resource 1, 85e0, 8000
      env 2, 1f8, 8000
      env-redund 3, 1f8, 8000
      boot 4, 89d0, 8000
      rootfs 5, 50000, 8000
      dsp0 6, 7e0, 8000
      private 7, 7e0, 8000
      UDISK 8, 0, 8100
      [11.164]erase blk 0 to blk 32
      need erase flash: 18
      [11.255]erase blk 0 to blk 32
      [11.343]erase blk 40 to blk 2048
      [16.656]get secure storage map err
      [16.659]erase secure storage block 0 err
      [16.662]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sy
      s)
      #: name size offset mask_flags
      0: boot0 0x00100000 0x00000000 1
      1: uboot 0x00300000 0x00100000 1
      2: secure_storage 0x00100000 0x00400000 1
      3: sys 0x0fb00000 0x00500000 0
      defaults:
      mtdids : nand0=nand
      [16.713]MTD info (4)
      [16.715]pagesize: 0x1000
      [16.717]blksize: 0x40000
      [16.719]num offset bytes name
      [16.723]0 0x00000000 0x00100000 boot0
      [16.726]1 0x00100000 0x00300000 uboot
      [16.730]2 0x00400000 0x00100000 secure_storage
      [16.734]3 0x00500000 0x0fb00000 sys
      [16.738]ubi attach the last part of mtd device: NO.3
      [16.744]ubi0: attaching mtd4
      [16.960]ubi0: scanning is finished
      [16.963]ubi0: empty MTD device detected
      [16.992]ubi0: attached mtd4 (name "sys", size 251 MiB)
      [16.996]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [17.002]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [17.009]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [17.015]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
      [17.020]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
      [17.027]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
      [17.035]ubi0: available PEBs: 960, total reserved PEBs: 44, PEBs reserved for bad PEB handling: 40
      SUNXI_EFEX_MBR_TAG
      mbr size = 0x10000
      force mbr
      defaults:
      mtdids : nand0=nand
      [22.823]MTD info (4)
      [22.825]pagesize: 0x1000
      [22.827]blksize: 0x40000
      [22.829]num offset bytes name
      [22.833]0 0x00000000 0x00100000 boot0
      [22.837]1 0x00100000 0x00300000 uboot
      [22.840]2 0x00400000 0x00100000 secure_storage
      [22.845]3 0x00500000 0x0fb00000 sys
      [22.848]MBR info (unalign):
      [22.851]partno addr sects type name
      [22.855]0 0x00000000 0x000001f8 0x00000001 mbr
      [22.860]1 0x000001f8 0x000085e0 0x00008000 boot-resource
      [22.866]2 0x000087d8 0x000001f8 0x00008000 env
      [22.871]3 0x000089d0 0x000001f8 0x00008000 env-redund
      [22.876]4 0x00008bc8 0x000089d0 0x00008000 boot
      [22.881]5 0x00011598 0x00050000 0x00008000 rootfs
      [22.886]6 0x00061598 0x000007e0 0x00008000 dsp0
      [22.891]7 0x00061d78 0x000007e0 0x00008000 private
      [22.896]8 0x00062558 0x00000000 0x00008100 UDISK
      [22.901]ubi attach the last part of mtd device: NO.3
      [22.905]MBR info (align):
      [22.908]partno addr sects type name
      [22.913]0 0x00002800 0x000001f8 0x00000001 mbr
      [22.917]1 0x000029f8 0x000085e0 0x00008000 boot-resource
      [22.923]2 0x0000afd8 0x000001f8 0x00008000 env
      [22.928]3 0x0000b1d0 0x000001f8 0x00008000 env-redund
      [22.933]4 0x0000b3c8 0x000089d0 0x00008000 boot
      [22.938]5 0x00013d98 0x000501a8 0x00008000 rootfs
      [22.943]6 0x00063f40 0x000007e0 0x00008000 dsp0
      [22.948]7 0x00064720 0x000007e0 0x00008000 private
      [22.953]8 0x00064f00 0x00000000 0x00008100 UDISK
      [22.958]ubi attach the last part of mtd device: NO.3
      [22.963]ubi attatch mtd, name: sys
      [22.966]ubi0: detaching mtd4
      [22.969]ubi0: mtd4 is detached
      [22.972]ubi0: attaching mtd4
      [23.399]ubi0: scanning is finished
      [23.409]ubi0: attached mtd4 (name "sys", size 251 MiB)
      [23.413]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [23.420]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [23.426]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [23.432]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
      [23.438]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
      [23.444]ubi0: max/mean erase counter: 1/1, WL threshold: 4096, image sequence number: 0
      [23.452]ubi0: available PEBs: 960, total reserved PEBs: 44, PEBs reserved for bad PEB handling: 40
      Creating static volume mbr of size 258048
      Creating dynamic volume boot-resource of size 17547264
      Creating dynamic volume boot of size 18063360
      Creating dynamic volume rootfs of size 167989248
      Creating dynamic volume dsp0 of size 1032192
      Creating dynamic volume private of size 1032192
      No size specified -> Using max size (41287680)
      [23.694]reset last volume size to 0x13b00
      Creating dynamic volume UDISK of size 41287680
      [23.726]existed volume UDISK size is 80640(sects) , inside ubi part size is 0(sects),existed volume size to
      update inside ubi part size
      [23.738]existed volume UDISK size is 80640(sects) , inside ubi part size is 0(sects),existed volume size to
      [23.775]fill gap start: volume mbr sects 0x178
      [23.893]fill gap end: volume mbr
      [23.896]update partition map
      [23.899]logical area info: 960 258048 last_lba: 483839
      [23.911]logical area info: 960 258048 last_lba: 483839
      [23.922]logical area info: 960 258048 last_lba: 483839
      [23.934]logical area info: 960 258048 last_lba: 483839
      [23.945]logical area info: 960 258048 last_lba: 483839
      [23.957]logical area info: 960 258048 last_lba: 483839
      [23.968]logical area info: 960 258048 last_lba: 483839
      [23.980]logical area info: 960 258048 last_lba: 483839
      [23.992]logical area info: 960 258048 last_lba: 483839
      [24.003]logical area info: 960 258048 last_lba: 483839
      [24.015]logical area info: 960 258048 last_lba: 483839
      [24.026]logical area info: 960 258048 last_lba: 483839
      [24.038]logical area info: 960 258048 last_lba: 483839
      [24.049]logical area info: 960 258048 last_lba: 483839
      [24.061]logical area info: 960 258048 last_lba: 483839
      [24.072]logical area info: 960 258048 last_lba: 483839
      [24.084]logical area info: 960 258048 last_lba: 483839
      [24.095]logical area info: 960 258048 last_lba: 483839
      [24.107]logical area info: 960 258048 last_lba: 483839
      [24.119]logical area info: 960 258048 last_lba: 483839
      [24.130]logical area info: 960 258048 last_lba: 483839
      [24.142]logical area info: 960 258048 last_lba: 483839
      [24.153]logical area info: 960 258048 last_lba: 483839
      [24.165]logical area info: 960 258048 last_lba: 483839
      [24.176]logical area info: 960 258048 last_lba: 483839
      [24.188]logical area info: 960 258048 last_lba: 483839
      [24.199]logical area info: 960 258048 last_lba: 483839
      [24.211]logical area info: 960 258048 last_lba: 483839
      [28.052]fill gap start: volume boot-resource sects 0x1876
      [28.163]fill gap end: volume boot-resource
      FEX_CMD_fes_verify_value, start 0x1f8, size high 0x0:low 0xdad400
      FEX_CMD_fes_verify_value 0xaa43f1c8
      [29.750]fill gap start: volume env sects 0xf8
      [29.838]fill gap end: volume env
      FEX_CMD_fes_verify_value, start 0x87d8, size high 0x0:low 0x20000
      FEX_CMD_fes_verify_value 0xf837d977
      [29.916]fill gap start: volume env-redund sects 0xf8
      [30.005]fill gap end: volume env-redund
      FEX_CMD_fes_verify_value, start 0x89d0, size high 0x0:low 0x20000
      [34.015]fill gap start: volume boot sects 0x18c4
      [34.125]fill gap end: volume boot
      FEX_CMD_fes_verify_value, start 0x8bc8, size high 0x0:low 0xe21800
      FEX_CMD_fes_verify_value 0x52713200
      [46.724]fill gap start: volume rootfs sects 0x3b540
      [47.598]fill gap end: volume rootfs
      FEX_CMD_fes_verify_value, start 0x11598, size high 0x0:low 0x2958000
      FEX_CMD_fes_verify_value 0x7ee8d4ba
      [52.092]fill gap start: volume dsp0 sects 0x569
      [52.185]fill gap end: volume dsp0
      FEX_CMD_fes_verify_value, start 0x61598, size high 0x0:low 0x4ecb0
      FEX_CMD_fes_verify_value 0x2e679ba6
      bootfile_mode=4
      SUNXI_EFEX_BOOT1_TAG
      boot1 size = 0x140000, max size = 0x400000
      uboot size = 0x140000
      storage type = 0
      [52.289]uboot blk range [8-32)
      [52.292]download uboot to block 8 (10 blocks) len 1280K
      [52.623]download uboot to block 18 (10 blocks) len 1280K
      bootfile_mode=4
      烧录工具调试日志:
      00000001 0.00000000 [4332] OUT 1
      00000002 2.13815570 [4332] IN 1
      00000003 2.24932408 [4332] ********* before Fel2Fes *********
      00000004 2.24982595 [4332] ********* pFel2FesParam->extend = 0xefe8da00 *********
      00000005 2.25154471 [4332] ***************************************
      00000006 2.28711128 [4332] ToolEntry_fel****
      00000007 2.28981948 [4332] ***************************************
      00000008 2.29153228 [4332] PANIC : enter fel choose mode
      00000009 2.29560971 [4332] fel other=0x1fa4b0
      00000010 2.29940987 [4332] OS SourceCodePage = 936
      00000011 2.30869961 [4332] WRN: fail in LoadPluginCenter, f(IniLanPlg)L45
      00000012 2.32967281 [4332] WRN: f(exist_multiple_lang_tips)L94, Fail to init plg of iniLan, "Please update LiveSuit"
      00000013 2.33866453 [4332] user choose to erase all
      00000014 2.35690212 [4332] Img_OpenItem now!
      00000015 2.36415243 [4332] Img_OpenItem[FES ][FES_1-0000000000]
      00000016 2.37967491 [4332] down file length = 52a0.
      00000017 2.38280082 [4332] magic eGON.BT0mðþh R, it is fes1
      00000018 2.38649964 [4332] down and run fes1 at addr 0x28000
      00000019 2.39042473 [4332] Clear dram log OK.
      00000020 2.43007469 [4332] DOWN FES1_dram OK
      00000021 2.94046164 [4332] dram paras[0]: 0x318
      00000022 2.94248009 [4332] dram paras[1]: 0x3
      00000023 2.94338155 [4332] dram paras[2]: 0x7b7bfb
      00000024 2.94465923 [4332] dram paras[3]: 0x1
      00000025 2.94566727 [4332] dram paras[4]: 0x10e2
      00000026 2.94658446 [4332] dram paras[5]: 0x1000000
      00000027 2.94713211 [4332] dram paras[6]: 0x1c70
      00000028 2.94769478 [4332] dram paras[7]: 0x42
      00000029 2.94852209 [4332] dram paras[8]: 0x18
      00000030 2.94939446 [4332] dram paras[9]: 0x0
      00000031 2.94991159 [4332] dram paras[10]: 0x4a2195
      00000032 2.95448160 [4332] dram paras[11]: 0x2423190
      00000033 2.95919967 [4332] dram paras[12]: 0x8b061
      00000034 2.96110392 [4332] dram paras[13]: 0xb4787896
      00000035 2.96299553 [4332] dram paras[14]: 0x0
      00000036 2.96449566 [4332] dram paras[15]: 0x48484848
      00000037 2.96571565 [4332] dram paras[16]: 0x48
      00000038 2.96659994 [4332] dram paras[17]: 0x1621121e
      00000039 2.96750951 [4332] dram paras[18]: 0x0
      00000040 2.96839929 [4332] dram paras[19]: 0x0
      00000041 2.96925807 [4332] dram paras[20]: 0x80000
      00000042 2.97015476 [4332] dram paras[21]: 0x340000
      00000043 2.97086763 [4332] dram paras[22]: 0x25
      00000044 2.97138429 [4332] dram paras[23]: 0x34006103
      00000045 2.97319388 [4332] dram paras[24]: 0x0
      00000046 2.97574186 [4332] dram paras[25]: 0x0
      00000047 2.97618675 [4332] dram paras[26]: 0x0
      00000048 2.97741437 [4332] dram paras[27]: 0x0
      00000049 2.97863770 [4332] dram paras[28]: 0x0
      00000050 2.97967768 [4332] dram paras[29]: 0x0
      00000051 2.98065996 [4332] dram paras[30]: 0x0
      00000052 2.98215365 [4332] dram paras[31]: 0x0
      00000053 2.98633242 [4332] RUN fes1 OK.
      00000054 2.98932266 [4332] INFO: try to down and run fes2
      00000055 2.98952532 [4332] Img_OpenItem now!
      00000056 2.98978329 [4332] Img_OpenItem[12345678][UBOOT_0000000000]
      00000057 2.99037886 [4332] fes2 size 0xe4000
      00000058 2.99400640 [4332] uboot down and run addr 0x43000000
      00000059 2.99480510 [4332] dtb_syscfg_base 0x43200000
      00000060 4.90807581 [4332] INFO: try to down dtb at 0x43200000
      00000061 4.90835905 [4332] Img_OpenItem now!
      00000062 4.90849733 [4332] Img_OpenItem[COMMON ][DTB_CONFIG000000]
      00000063 4.90971088 [4332] down_dtb_syscfg size 0xba00
      00000064 5.01061058 [4332] INFO: try to down soc cfg at 0x43300000
      00000065 5.01096964 [4332] Img_OpenItem now!
      00000066 5.01115656 [4332] Img_OpenItem[COMMON ][SYS_CONFIG_BIN00]
      00000067 5.01193619 [4332] down_dtb_syscfg size 0x1400
      00000068 5.02862692 [4332] INFO: try to down board cfg at 0x43380000
      00000069 5.02876377 [4332] Img_OpenItem now!
      00000070 5.02904224 [4332] Img_OpenItem[COMMON ][BOARD_CONFIG_BIN]
      00000071 5.03001022 [4332] down_dtb_syscfg size 0x400
      00000072 5.03866100 [4332] INFO: down dtb syscfg OK
      00000073 5.03986597 [4332] INFO: down fes2 ok
      00000074 5.04772806 [4332] INFO: run fes2 ok
      00000075 5.04837465 [4332] Closing image now!
      00000076 5.04858017 [4332] CloseImage OK
      00000077 5.04886198 [4332] *********** after Fel2Fes *********
      00000078 7.14139986 [4332] OUT 1
      00000079 11.08561420 [4332] IN 1
      00000080 11.08653355 [4332] Wait for fes device in time
      00000081 11.09194279 [4332] Open C:\download\PhoenixSuit\image_dl.para failed
      00000082 11.09541416 [4332] priv_info = 0xd4a2c70
      00000083 11.09679699 [4332] erase flash flag 18
      00000084 11.09829521 [4332] Ê£Óà 1 ·Ö 38 Ãë
      00000085 11.09850121 [4332]
      00000086 11.10112953 [4332] set erase flag 18
      00000087 11.11405945 [4332] fes_check_crc.media_crc=0
      00000088 11.11465549 [4332] ID=2, fes_thread() : get download map
      00000089 11.11479664 [4332] Ê£Óà 1 ·Ö 36 Ãë
      00000090 11.11485577 [4332]
      00000091 11.11616516 [4332] fes_thread, get download map
      00000092 11.11625195 [4332] Img_OpenItem now!
      00000093 11.11631393 [4332] Img_OpenItem[12345678][1234567890DLINFO]
      00000094 11.11721802 [4332] DOWNLOAD MAP DUMP
      00000095 11.11778259 [4332] total download part 6
      00000096 11.11827278 [4332]
      00000097 11.11878395 [4332] download part[0] name :boot-resource
      00000098 11.11931229 [4332] download part[0] download file:BOOT-RESOURCE_FE
      00000099 11.12059402 [4332] download part[0] verify file :VBOOT-RESOURCE_F
      00000100 11.12114239 [4332] download part[0] lenlo :0x85e0
      00000101 11.12165165 [4332] download part[0] addrlo :0x1f8
      00000102 11.12224197 [4332] download part[0] encrypt :0
      00000103 11.12256527 [4332] download part[0] verify :1
      00000104 11.12306023 [4332]
      00000105 11.12408447 [4332] download part[1] name :env
      00000106 11.12511063 [4332] download part[1] download file:ENV_FEX000000000
      00000107 11.12574768 [4332] download part[1] verify file :VENV_FEX00000000
      00000108 11.12624931 [4332] download part[1] lenlo :0x1f8
      00000109 11.12675858 [4332] download part[1] addrlo :0x87d8
      00000110 11.12739086 [4332] download part[1] encrypt :0
      00000111 11.12795162 [4332] download part[1] verify :1
      00000112 11.12865353 [4332]
      00000113 11.12913704 [4332] download part[2] name :env-redund
      00000114 11.12954617 [4332] download part[2] download file:ENV_FEX000000000
      00000115 11.13457775 [4332] download part[2] verify file :VENV_FEX00000000
      00000116 11.13485622 [4332] download part[2] lenlo :0x1f8
      00000117 11.13568783 [4332] download part[2] addrlo :0x89d0
      00000118 11.13637161 [4332] download part[2] encrypt :0
      00000119 11.13672924 [4332] download part[2] verify :1
      00000120 11.13806725 [4332]
      00000121 11.13944435 [4332] download part[3] name :boot
      00000122 11.14009666 [4332] download part[3] download file:BOOT_FEX00000000
      00000123 11.14072895 [4332] download part[3] verify file :VBOOT_FEX0000000
      00000124 11.14160728 [4332] download part[3] lenlo :0x89d0
      00000125 11.14231396 [4332] download part[3] addrlo :0x8bc8
      00000126 11.14278221 [4332] download part[3] encrypt :0
      00000127 11.14332771 [4332] download part[3] verify :1
      00000128 11.14376545 [4332]
      00000129 11.14433098 [4332] download part[4] name :rootfs
      00000130 11.14481258 [4332] download part[4] download file:ROOTFS-UBIFS_FEX
      00000131 11.14540195 [4332] download part[4] verify file :VROOTFS-UBIFS_FE
      00000132 11.14587593 [4332] download part[4] lenlo :0x50000
      00000133 11.14634514 [4332] download part[4] addrlo :0x11598
      00000134 11.14679146 [4332] download part[4] encrypt :0
      00000135 11.14717960 [4332] download part[4] verify :1
      00000136 11.14767551 [4332]
      00000137 11.14821339 [4332] download part[5] name :dsp0
      00000138 11.14868355 [4332] download part[5] download file:AMP_DSP0_FEX0000
      00000139 11.14909363 [4332] download part[5] verify file :VAMP_DSP0_FEX000
      00000140 11.14983082 [4332] download part[5] lenlo :0x7e0
      00000141 11.15016937 [4332] download part[5] addrlo :0x61598
      00000142 11.15069580 [4332] download part[5] encrypt :0
      00000143 11.15121460 [4332] download part[5] verify :1
      00000144 11.15168571 [4332]
      00000145 11.15239048 [4332] ID=2, fes_thread() : --167--
      00000146 11.15330315 [4332] unknown Tools command.
      00000147 11.15464115 [4332] Ê£Óà 1 ·Ö 32 Ãë
      00000148 11.15493774 [4332]
      00000149 11.15813923 [4332] dlbitmap = 0
      00000150 11.15861034 [4332] dlbitmap = 0x0,according the dlinfo to download.......
      00000151 11.15870094 [4332] Img_OpenItem now!
      00000152 11.15874767 [4332] Img_OpenItem[12345678][1234567890___MBR]
      00000153 11.15972519 [4332] value =0
      00000154 11.16034412 [4332] ubifs: checking part -- boot-resource
      00000155 11.16043854 [4332] Img_OpenItem now!
      00000156 11.16050243 [4332] Img_OpenItem[RFSFAT16][BOOT-RESOURCE_FEVBOOT-RESOURCE_F]
      00000157 11.16101742 [4332] id[2]:part_name = boot-resource, packet_len_high = 0x0, packet_len_low = 0xDAD400, pkt_name = BOOT-RESOURCE_FEVBOOT-RESOURCE_F, verify_file = VBOOT-RESOURCE_F, encrypt = 1
      00000158 11.16173077 [4332] value =0
      00000159 11.16235447 [4332] ubifs: checking part -- env
      00000160 11.16248035 [4332] Img_OpenItem now!
      00000161 11.16256714 [4332] Img_OpenItem[RFSFAT16][ENV_FEX000000000VENV_FEX00000000]
      00000162 11.16305733 [4332] id[2]:part_name = env, packet_len_high = 0x0, packet_len_low = 0x20000, pkt_name = ENV_FEX000000000VENV_FEX00000000, verify_file = VENV_FEX00000000, encrypt = 1
      00000163 11.16384125 [4332] value =0
      00000164 11.16425610 [4332] ubifs: checking part -- env-redund
      00000165 11.16444206 [4332] Img_OpenItem now!
      00000166 11.16464043 [4332] Img_OpenItem[RFSFAT16][ENV_FEX000000000VENV_FEX00000000]
      00000167 11.16527843 [4332] id[2]:part_name = env-redund, packet_len_high = 0x0, packet_len_low = 0x20000, pkt_name = ENV_FEX000000000VENV_FEX00000000, verify_file = VENV_FEX00000000, encrypt = 1
      00000168 11.16595173 [4332] value =0
      00000169 11.16614246 [4332] ubifs: checking part -- boot
      00000170 11.16617584 [4332] Img_OpenItem now!
      00000171 11.16622925 [4332] Img_OpenItem[RFSFAT16][BOOT_FEX00000000VBOOT_FEX0000000]
      00000172 11.16638660 [4332] id[2]:part_name = boot, packet_len_high = 0x0, packet_len_low = 0xE21800, pkt_name = BOOT_FEX00000000VBOOT_FEX0000000, verify_file = VBOOT_FEX0000000, encrypt = 1
      00000173 11.16676998 [4332] value =0
      00000174 11.16770554 [4332] ubifs: checking part -- rootfs
      00000175 11.16809559 [4332] Img_OpenItem now!
      00000176 11.16842079 [4332] Img_OpenItem[RFSFAT16][ROOTFS-UBIFS_FEXVROOTFS-UBIFS_FE]
      00000177 11.16912270 [4332] id[2]:part_name = rootfs, packet_len_high = 0x0, packet_len_low = 0x2958000, pkt_name = ROOTFS-UBIFS_FEXVROOTFS-UBIFS_FE, verify_file = VROOTFS-UBIFS_FE, encrypt = 1
      00000178 11.17353344 [4332] ubifs: open ubifs interface ok. ubifs partition : rootfs
      00000179 11.17366314 [4332] Img_OpenItem now!
      00000180 11.17371368 [4332] Img_OpenItem[12345678][1234567890___MBR]
      00000181 11.17449856 [4332] MBR DUMP
      00000182 11.17520714 [4332] total mbr part 8
      00000183 11.17578793 [4332]
      00000184 11.17649555 [4332] part[0] name :boot-resource
      00000185 11.17700195 [4332] part[0] classname :DISK
      00000186 11.17747021 [4332] part[0] addrlo :0x1f8
      00000187 11.17793655 [4332] part[0] lenlo :0x85e0
      00000188 11.17853355 [4332] part[0] user_type :32768
      00000189 11.17920494 [4332] part[0] keydata :0
      00000190 11.17979813 [4332] part[0] ro :0
      00000191 11.18031120 [4332]
      00000192 11.18081856 [4332] part[1] name :env
      00000193 11.18133736 [4332] part[1] classname :DISK
      00000194 11.18185520 [4332] part[1] addrlo :0x87d8
      00000195 11.18247795 [4332] part[1] lenlo :0x1f8
      00000196 11.18303394 [4332] part[1] user_type :32768
      00000197 11.18432999 [4332] part[1] keydata :0
      00000198 11.18513680 [4332] part[1] ro :0
      00000199 11.18654919 [4332]
      00000200 11.18727684 [4332] part[2] name :env-redund
      00000201 11.18777847 [4332] part[2] classname :DISK
      00000202 11.18813038 [4332] part[2] addrlo :0x89d0
      00000203 11.18836117 [4332] part[2] lenlo :0x1f8
      00000204 11.18839645 [4332] part[2] user_type :32768
      00000205 11.18908978 [4332] part[2] keydata :0
      00000206 11.18966484 [4332] part[2] ro :0
      00000207 11.19013596 [4332]
      00000208 11.19088459 [4332] part[3] name :boot
      00000209 11.19155407 [4332] part[3] classname :DISK
      00000210 11.19221783 [4332] part[3] addrlo :0x8bc8
      00000211 11.19288826 [4332] part[3] lenlo :0x89d0
      00000212 11.19350910 [4332] part[3] user_type :32768
      00000213 11.19391155 [4332] part[3] keydata :0
      00000214 11.19440651 [4332] part[3] ro :0
      00000215 11.19503307 [4332]
      00000216 11.19547939 [4332] part[4] name :rootfs
      00000217 11.19619846 [4332] part[4] classname :DISK
      00000218 11.19672203 [4332] part[4] addrlo :0x11598
      00000219 11.19719887 [4332] part[4] lenlo :0x50000
      00000220 11.19764805 [4332] part[4] user_type :32768
      00000221 11.19821167 [4332] part[4] keydata :0
      00000222 11.19882488 [4332] part[4] ro :0
      00000223 11.20052433 [4332]
      00000224 11.20181370 [4332] part[5] name :dsp0
      00000225 11.20294380 [4332] part[5] classname :DISK
      00000226 11.20404911 [4332] part[5] addrlo :0x61598
      00000227 11.20570278 [4332] part[5] lenlo :0x7e0
      00000228 11.20611000 [4332] part[5] user_type :32768
      00000229 11.20678139 [4332] part[5] keydata :0
      00000230 11.20737553 [4332] part[5] ro :0
      00000231 11.20818806 [4332]
      00000232 11.20861340 [4332] part[6] name :private
      00000233 11.20914364 [4332] part[6] classname :DISK
      00000234 11.20956039 [4332] part[6] addrlo :0x61d78
      00000235 11.21032524 [4332] part[6] lenlo :0x7e0
      00000236 11.21086502 [4332] part[6] user_type :32768
      00000237 11.21135712 [4332] part[6] keydata :0
      00000238 11.21238041 [4332] part[6] ro :0
      00000239 11.21261406 [4332]
      00000240 11.21319771 [4332] part[7] name :UDISK
      00000241 11.21361256 [4332] part[7] classname :DISK
      00000242 11.21411324 [4332] part[7] addrlo :0x62558
      00000243 11.21470737 [4332] part[7] lenlo :0x0
      00000244 11.21536446 [4332] part[7] user_type :33024
      00000245 11.21590614 [4332] part[7] keydata :0
      00000246 11.21645641 [4332] part[7] ro :0
      00000247 11.21784687 [4332]
      00000248 13.96790886 [6100] [qingshellext]DllCanUnloadNow, module=C:\Program Files (x86)\Kingsoft\WPS Office\11.8.2.8411\office6\qingshellext64.dll
      00000249 20.32331276 [6100] [qingshellext]DllCanUnloadNow, module=C:\Program Files (x86)\Kingsoft\WPS Office\11.8.2.8411\office6\qingshellext64.dll
      00000250 24.43139839 [4332] fes_check_crc.media_crc=0
      00000251 24.43983841 [4332] ID=2, fes_thread() : --163--
      00000252 24.44027138 [4332] Ê£Óà 1 ·Ö 29 Ãë
      00000253 24.44040871 [4332]
      00000254 24.44211769 [4332] download image
      00000255 24.44318008 [4332] dlbitmap = 0
      00000256 24.44361496 [4332] dlbitmap = 0x0,according the dlinfo to download.......
      00000257 24.44388771 [4332] value =0
      00000258 24.44390488 [4332] Img_OpenItem now!
      00000259 24.44411659 [4332] Img_OpenItem[RFSFAT16][BOOT-RESOURCE_FEVBOOT-RESOURCE_F]
      00000260 24.44454193 [4332] id[2]:part_name = boot-resource, packet_len_high = 0x0, packet_len_low = 0xDAD400, pkt_name = BOOT-RESOURCE_FEVBOOT-RESOURCE_F, verify_file = VBOOT-RESOURCE_F, encrypt = 1
      00000261 24.47081375 [4332] sparse: bad magic, it is NOT a sparse format part
      00000262 28.25632668 [4332] part boot-resource need verify
      00000263 28.25721931 [4332] Img_OpenItem now!
      00000264 28.25786209 [4332] Img_OpenItem[RFSFAT16][VBOOT-RESOURCE_F]
      00000265 28.26129341 [4332] the verify value of part boot-resource is 0xaa43f1c8
      00000266 29.89189529 [4332] INFO: ID = 2, pc_crc = 0xaa43f1c8, nand_crc = 0xaa43f1c8
      00000267 29.89624977 [4332] INFO: ID = 2, pc_crc = 0xaa43f1c8, nand_crc = 0xaa43f1c8, it's OK
      00000268 29.89803886 [4332] id[2]: down pkt_name(BOOT-RESOURCE_FEVBOOT-RESOURCE_F) to part(boot-resource) successful
      00000269 29.89869118 [4332] Ê£Óà 1 ·Ö 16 Ãë
      00000270 29.89896393 [4332]
      00000271 29.90401840 [4332] download_firmware: boot-resource 23
      00000272 29.90401840 [4332]
      00000273 29.91197205 [4332] value =0
      00000274 29.91296577 [4332] Img_OpenItem now!
      00000275 29.91407967 [4332] Img_OpenItem[RFSFAT16][ENV_FEX000000000VENV_FEX00000000]
      00000276 29.92845154 [4332] id[2]:part_name = env, packet_len_high = 0x0, packet_len_low = 0x20000, pkt_name = ENV_FEX000000000VENV_FEX00000000, verify_file = VENV_FEX00000000, encrypt = 1
      00000277 29.93087387 [4332] sparse: bad magic, it is NOT a sparse format part
      00000278 29.95859909 [4332] part env need verify
      00000279 29.95866966 [4332] Img_OpenItem now!
      00000280 29.95873833 [4332] Img_OpenItem[RFSFAT16][VENV_FEX00000000]
      00000281 29.95943069 [4332] the verify value of part env is 0xf837d977
      00000282 30.07795906 [4332] INFO: ID = 2, pc_crc = 0xf837d977, nand_crc = 0xf837d977
      00000283 30.07847977 [4332] INFO: ID = 2, pc_crc = 0xf837d977, nand_crc = 0xf837d977, it's OK
      00000284 30.07886314 [4332] id[2]: down pkt_name(ENV_FEX000000000VENV_FEX00000000) to part(env) successful
      00000285 30.07941818 [4332] Ê£Óà 1 ·Ö 3 Ãë
      00000286 30.07952309 [4332]
      00000287 30.08141708 [4332] download_firmware: env 36
      00000288 30.08141708 [4332]
      00000289 30.08184242 [4332] value =0
      00000290 30.08201218 [4332] Img_OpenItem now!
      00000291 30.08231354 [4332] Img_OpenItem[RFSFAT16][ENV_FEX000000000VENV_FEX00000000]
      00000292 30.08269119 [4332] id[2]:part_name = env-redund, packet_len_high = 0x0, packet_len_low = 0x20000, pkt_name = ENV_FEX000000000VENV_FEX00000000, verify_file = VENV_FEX00000000, encrypt = 1
      00000293 30.09367371 [4332] sparse: bad magic, it is NOT a sparse format part
      00000294 30.12171173 [4332] part env-redund need verify
      00000295 30.12272263 [4332] Img_OpenItem now!
      00000296 30.12327766 [4332] Img_OpenItem[RFSFAT16][VENV_FEX00000000]
      00000297 30.12535286 [4332] the verify value of part env-redund is 0xf837d977
      00000298 30.24422073 [4332] INFO: ID = 2, pc_crc = 0xf837d977, nand_crc = 0xf837d977
      00000299 30.24482536 [4332] INFO: ID = 2, pc_crc = 0xf837d977, nand_crc = 0xf837d977, it's OK
      00000300 30.24563789 [4332] id[2]: down pkt_name(ENV_FEX000000000VENV_FEX00000000) to part(env-redund) successful
      00000301 30.24614334 [4332] Ê£Óà 50 Ãë
      00000302 30.24662781 [4332]
      00000303 30.24896049 [4332] download_firmware: env-redund 49
      00000304 30.24896049 [4332]
      00000305 30.25065994 [4332] value =0
      00000306 30.25078964 [4332] Img_OpenItem now!
      00000307 30.25092125 [4332] Img_OpenItem[RFSFAT16][BOOT_FEX00000000VBOOT_FEX0000000]
      00000308 30.25129509 [4332] id[2]:part_name = boot, packet_len_high = 0x0, packet_len_low = 0xE21800, pkt_name = BOOT_FEX00000000VBOOT_FEX0000000, verify_file = VBOOT_FEX0000000, encrypt = 1
      00000309 30.28450966 [4332] sparse: bad magic, it is NOT a sparse format part
      00000310 34.22239685 [4332] part boot need verify
      00000311 34.22254562 [4332] Img_OpenItem now!
      00000312 34.22269058 [4332] Img_OpenItem[RFSFAT16][VBOOT_FEX0000000]
      00000313 34.22394562 [4332] the verify value of part boot is 0x52713200
      00000314 35.89991760 [4332] INFO: ID = 2, pc_crc = 0x52713200, nand_crc = 0x52713200
      00000315 35.90089417 [4332] INFO: ID = 2, pc_crc = 0x52713200, nand_crc = 0x52713200, it's OK
      00000316 35.90314102 [4332] id[2]: down pkt_name(BOOT_FEX00000000VBOOT_FEX0000000) to part(boot) successful
      00000317 35.90871048 [4332] Ê£Óà 37 Ãë
      00000318 35.90991211 [4332]
      00000319 35.92224121 [4332] download_firmware: boot 62
      00000320 35.92224121 [4332]
      00000321 35.92762375 [4332] value =0
      00000322 35.92878723 [4332] Img_OpenItem now!
      00000323 35.92895508 [4332] Img_OpenItem[RFSFAT16][ROOTFS-UBIFS_FEXVROOTFS-UBIFS_FE]
      00000324 35.93079758 [4332] id[2]:part_name = rootfs, packet_len_high = 0x0, packet_len_low = 0x2958000, pkt_name = ROOTFS-UBIFS_FEXVROOTFS-UBIFS_FE, verify_file = VROOTFS-UBIFS_FE, encrypt = 1
      00000325 35.95619965 [4332] sparse: bad magic, it is NOT a sparse format part
      00000326 40.97866058 [4332] Ê£Óà 31 Ãë
      00000327 40.97931290 [4332]
      00000328 43.79898071 [4332] Ê£Óà 28 Ãë
      00000329 43.79928589 [4332]
      00000330 46.65299606 [4332] Ê£Óà 25 Ãë
      00000331 46.65308380 [4332]
      00000332 46.91484451 [4332] part rootfs need verify
      00000333 46.91493225 [4332] Img_OpenItem now!
      00000334 46.91513443 [4332] Img_OpenItem[RFSFAT16][VROOTFS-UBIFS_FE]
      00000335 46.91665649 [4332] the verify value of part rootfs is 0x7ee8d4ba
      00000336 52.19670486 [4332] INFO: ID = 2, pc_crc = 0x7ee8d4ba, nand_crc = 0x7ee8d4ba
      00000337 52.19695282 [4332] INFO: ID = 2, pc_crc = 0x7ee8d4ba, nand_crc = 0x7ee8d4ba, it's OK
      00000338 52.19733810 [4332] id[2]: down pkt_name(ROOTFS-UBIFS_FEXVROOTFS-UBIFS_FE) to part(rootfs) successful
      00000339 52.19762421 [4332] Ê£Óà 24 Ãë
      00000340 52.19769669 [4332]
      00000341 52.20264816 [4332] download_firmware: rootfs 75
      00000342 52.20264816 [4332]
      00000343 52.20550919 [4332] value =0
      00000344 52.20558548 [4332] Img_OpenItem now!
      00000345 52.20568466 [4332] Img_OpenItem[RFSFAT16][AMP_DSP0_FEX0000VAMP_DSP0_FEX000]
      00000346 52.20586395 [4332] id[2]:part_name = dsp0, packet_len_high = 0x0, packet_len_low = 0x4ECB0, pkt_name = AMP_DSP0_FEX0000VAMP_DSP0_FEX000, verify_file = VAMP_DSP0_FEX000, encrypt = 1
      00000347 52.20912552 [4332] sparse: bad magic, it is NOT a sparse format part
      00000348 52.30040741 [4332] part dsp0 need verify
      00000349 52.30049133 [4332] Img_OpenItem now!
      00000350 52.30057144 [4332] Img_OpenItem[RFSFAT16][VAMP_DSP0_FEX000]
      00000351 52.30108643 [4332] the verify value of part dsp0 is 0x2e679ba6
      00000352 52.44284439 [4332] INFO: ID = 2, pc_crc = 0x2e679ba6, nand_crc = 0x2e679ba6
      00000353 52.44298553 [4332] INFO: ID = 2, pc_crc = 0x2e679ba6, nand_crc = 0x2e679ba6, it's OK
      00000354 52.44323730 [4332] id[2]: down pkt_name(AMP_DSP0_FEX0000VAMP_DSP0_FEX000) to part(dsp0) successful
      00000355 52.44338989 [4332] Ê£Óà 11 Ãë
      00000356 52.44342422 [4332]
      00000357 52.44432449 [4332] download_firmware: dsp0 88
      00000358 52.44432449 [4332]
      00000359 52.44606781 [4332] Ê£Óà 11 Ãë
      00000360 52.44611740 [4332]
      00000361 52.44722366 [4332] ID=2, fes_thread() : --161--
      00000362 52.44742966 [4332] unknown Tools command.
      00000363 52.44934464 [4332] secure_type=4
      00000364 52.44940948 [4332] Img_OpenItem now!
      00000365 52.44948578 [4332] Img_OpenItem[12345678][BOOTPKG-00000000]
      00000366 53.16808319 [4332] fes_check_crc.media_crc=0
      00000367 53.17190933 [4332] Ê£Óà 6 Ãë
      00000368 53.17321014 [4332]
      00000369 53.17591858 [4332] ID=2, fes_thread() : --160--
      00000370 53.17949295 [4332] secure_type=4
      00000371 53.17957687 [4332] ERR : download_boot0() : get boot0 storage type fail
      00000372 53.17994690 [4332] ERR : ID=2, fes_thread() : step 160 ,fail
      00000373 53.18015289 [4332]
      00000374 53.18015289 [4332] INFO: ID=2, update failed
      00000375 53.18015289 [4332]
      00000376 53.18041611 [4332] trans log buf
      00000377 53.18056488 [4332] *************************
      00000378 53.18070602 [4332] cmd_common_get_cmd_set_vers
      00000379 53.18085098 [4332] *************************
      00000380 53.18259430 [4332] cur version:2.0
      00000381 53.18369293 [4332] log_info.buf_start:0x0, log_info.buf_size:0x0
      00000382 53.18427277 [4332] PANIC : cmd_fes_up() : data len == 0
      00000383 55.28519821 [4332] trans log buf
      00000384 55.28666306 [4332] PANIC : cmd_common_get_cmd_set_vers() : priv_info == NULL
      00000385 55.28774261 [4332] cur version:0.0
      00000386 55.29267120 [4332] PANIC : dev_manager_open_fel_dev() : priv_info == NULL
      00000387 55.29273605 [4332] ERR : ID=2, fes_thread() : close fes ,fail
      00000388 55.29538727 [4332]
      00000389 55.29538727 [4332] INFO: ID=2, update failed
      00000390 55.29538727 [4332]
      00000391 55.29589081 [4332] Closing image now!
      00000392 55.29636383 [4332] CloseImage OK
      其中看到都是烧录成了,但是最后获取boot0的存储类型失败了,这个boot0是spl吗?有没有什么方向可以参考的?
