    A773的开发版模型量化报错了
    A Series
      amushen LV 2 最后由 编辑
      报错内容如下,请帮助看看啥问题:
      I 18:45:57 Save vx network source file to /workspace/ai-sdk/models/yolov5s-sim/wksp/yolov5s-sim_uint8/.project
      D 18:45:57 Generate fake input /workspace/ai-sdk/models/yolov5s-sim/wksp/yolov5s-sim_uint8/images_208_0.tensor
      gcc -Wall -std=c++0x -I. -I/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/include/ -I/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/include/CL -I/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/include/VX -I/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/include/ovxlib -I/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/include/jpeg -D__linux__ -DLINUX -O3 -c vnn_pre_process.c
      cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C
      vnn_pre_process.c: In function ‘handle_multiple_inputs’:
      vnn_pre_process.c:649:11: warning: variable ‘p1’ set but not used [-Wunused-but-set-variable]
      649 | char *p1 = NULL;
      At top level:
      vnn_pre_process.c:609:13: warning: ‘get_image_handle_buffer’ defined but not used [-Wunused-function]
      609 | static void get_image_handle_buffer
      -DLINUX -O3 -c main.c
      _ -DLINUX -O3 -c vnn_yolov5ssimuint8.c
      gcc -Wall -std=c++0x -I. -I/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/include/ -I/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/include/CL -I/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/include/VX -I/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/include/ovxlib -I/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/include/jpeg -D__linux__ -DLINUX -O3 -c vnn_post_process.c
      gcc -Wall -std=c++0x -I. -I/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/include/ -I/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/include/CL -I/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/include/VX -I/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/include/ovxlib -I/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/include/jpeg -D__linux__ -DLINUX -O3 -O3 vnn_pre_process.o main.o vnn_yolov5ssimuint8.o vnn_post_process.o -L/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/lib -lOpenVX -lOpenVXU -lCLC -lVSC -lGAL -lovxlib -lEmulator -lvdtproxy -L/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/lib/vsim -lOpenVX -lOpenVXU -lCLC -lVSC -lGAL -lovxlib -lEmulator -lvdtproxy -L/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/lib/x64_linux -lOpenVX -lOpenVXU -lCLC -lVSC -lGAL -lovxlib -lEmulator -lvdtproxy -L/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/lib/x64_linux/vsim -lOpenVX -lOpenVXU -lCLC -lVSC -lGAL -lovxlib -lEmulator -lvdtproxy -L/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/lib/x64_linux/vsim -lOpenVX -lOpenVXU -lCLC -lVSC -lGAL -lovxlib -lEmulator -lvdtproxy -L/root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/../common/lib/ -lvdtproxy /root/Vivante_IDE/VivanteIDE5.11.0/cmdtools/vsimulator/../common/lib/libjpeg.a -o gen_nbg
      Segmentation fault (core dumped)
      E 18:45:59 Fatal model generation error: 35584
      W 18:45:59 ----------------Error(1),Warning(0)----------------
      E 18:45:59 ('Fatal model generation error: 35584', 'nbg_generate')
      File "acuitylib/app/exporter/ovxlib_case/casegenerator.py", line 327, in acuitylib.app.exporter.ovxlib_case.casegenerator.CaseGenerator._gen_nb_file
      File "acuitylib/acuitylog.py", line 264, in acuitylib.acuitylog.AcuityLog.e
      acuitylib.acuityerror.AcuityError: ('Fatal model generation error: 35584', 'nbg_generate')
      During handling of the above exception, another exception occurred:
      File "/root/acuity-toolkit-whl-6.30.22/bin/pegasus.py", line 131, in <module>
      main(args)
      File "/root/acuity-toolkit-whl-6.30.22/bin/pegasus.py", line 116, in main
      ret = exporter.execute(args)
      File "acuitylib/app/exporter/commands.py", line 220, in acuitylib.app.exporter.commands.execute
      File "acuitylib/vsi_nn.py", line 738, in acuitylib.vsi_nn.VSInn.export_ovxlib
      File "acuitylib/interface/exporter.py", line 84, in acuitylib.interface.exporter.OvxlibExporter.export
      File "acuitylib/app/exporter/ovxlib_case/export_ovxlib.py", line 113, in acuitylib.app.exporter.ovxlib_case.export_ovxlib.ExportOvxlib.run
      File "acuitylib/app/exporter/ovxlib_case/casegenerator.py", line 409, in acuitylib.app.exporter.ovxlib_case.casegenerator.CaseGenerator.generate
      File "acuitylib/app/exporter/ovxlib_case/casegenerator.py", line 359, in acuitylib.app.exporter.ovxlib_case.casegenerator.CaseGenerator._gen_special_case
      File "acuitylib/app/exporter/ovxlib_case/casegenerator.py", line 338, in acuitylib.app.exporter.ovxlib_case.casegenerator.CaseGenerator._gen_nb_file
      File "acuitylib/acuitylog.py", line 260, in acuitylib.acuitylog.AcuityLog.e
      acuitylib.acuityerror.AcuityError: (AcuityError('Fatal model generation error: 35584', 'nbg_generate'), None)
      =========== End Generate yolov5s-sim ovx C code with type of ===========
      Y 1 条回复 最后回复 回复 引用 分享 0
        yuewuya LV 3 @amushen 最后由 编辑
        @amushen hello,有A733的SDK吗?能不能共享一下?
