    F133用卡烧录NOR失败/无响应
    • Q
      QL2017 LV 5 最后由 编辑
      以下是启动和烧录过程的完整log:
      [33]HELLO! BOOT0 is starting!
      [35]BOOT0 commit : 88480af
      [38]set pll start
      [40]periph0 has been enabled
      [43]set pll end
      [44][pmu]: bus read error
      [47]board init ok
      [48]ZQ value = 0x2d
      [50]get_pmu_exist() = -1
      [53]ddr_efuse_type: 0xa
      [55]trefi:7.8ms
      [57][AUTO DEBUG] single rank and full DQ!
      [61]ddr_efuse_type: 0xa
      [63]trefi:7.8ms
      [65][AUTO DEBUG] rank 0 row = 13
      [68][AUTO DEBUG] rank 0 bank = 4
      [71][AUTO DEBUG] rank 0 page size = 2 KB
      [75]DRAM BOOT DRIVE INFO: V0.33
      [78]DRAM CLK = 528 MHz
      [80]DRAM Type = 2 (2:DDR2,3:DDR3)
      [83]DRAMC read ODT  off.
      [86]DRAM ODT off.
      [87]ddr_efuse_type: 0xa
      [90]DRAM SIZE =64 M
      [92]dram_tpr4:0x0
      [94]PLL_DDR_CTRL_REG:0xf8002b00
      [96]DRAM_CLK_REG:0xc0000000
      [99][TIMING DEBUG] MR2= 0x0
      [103]DRAM simple test OK.
      [106]dram size =64
      [108]card no is 0
      [109]sdcard 0 line count 4
      [112][mmc]: mmc driver ver 2021-04-2 16:45
      [121][mmc]: Wrong media type 0x0
      [124][mmc]: ***Try SD card 0***
      [134][mmc]: HSSDR52/SDR25 4 bit
      [137][mmc]: 50000000 Hz
      [139][mmc]: 30360 MB
      [141][mmc]: ***SD/MMC 0 init OK!!!***
      [189]Loading boot-pkg Succeed(index=0).
      [193]Entry_name        = opensbi
      [196]Entry_name        = u-boot
      [200]Entry_name        = dtb
      [203]mmc not para
      [204]Jump to second Boot.
              |_|
      Platform Max HARTs     : 1
      Current Hart           : 0
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP3    : 0x0000000000020000-0x0000000000027fff (A,_H¨H¨Ӓ½½с2018.07-ge987def5 (Nov 07 2022 - 03:11:27 +0000) Allwinner Technology
      [00.289]DRAM:  64 MiB
      [00.291]Relocation Offset is: 01eea000
      [00.296]secure enable bit: 0
      [00.299]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      sunxi flash map init
      SPI ALL:   ready
      [00.309]flash init start
      [00.311]workmode = 17,storage type = 1
      try card 2
      set card number 2
      get card number 2
      [00.319][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.325][mmc]: get sdc_type fail and use default host:tm4.
      [00.331][mmc]: Is not Boot mode!
      [00.334][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.345][mmc]: ************Try SD card 2************
      [00.350][mmc]: mmc 2 cmd timeout 100 status 100
      [00.354][mmc]: smc 2 err, cmd 8,  RTO
      [00.358][mmc]: mmc 2 close bus gating and reset
      [00.363][mmc]: mmc 2 cmd timeout 100 status 100
      [00.367][mmc]: smc 2 err, cmd 55,  RTO
      [00.370][mmc]: mmc 2 close bus gating and reset
      [00.374][mmc]: ************Try MMC card 2************
      [00.383][mmc]: mmc 2 cmd timeout 100 status 100
      [00.387][mmc]: smc 2 err, cmd 1,  RTO
      [00.391][mmc]: mmc 2 close bus gating and reset
      [00.395][mmc]: Card did not respond to voltage select!
      [00.400][mmc]: ************SD/MMC 2 init error!************
      [00.405][mmc]: mmc init product failed
      MMC init failed
      try emmc fail
      [00.412]sunxi-spinand: AW SPINand MTD Layer Version: 1.8 20220106
      [00.418]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211217
      [00.426]sunxi-spinand-phy: request spi0 gpio ok
      [00.430]sunxi-spinand-phy: request general tx dma channel ok!
      [00.436]sunxi-spinand-phy: request general rx dma channel ok!
      [00.441]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [00.446]sunxi-spinand-phy: init spic0 clk ok
      [01.450]sunxi-spinand-phy: read id failed : -110
      try nand fail
      [01.458]sunxi_upper_lock, invalid address!
      [01.467]spi sunxi_slave->max_hz:100000000
      [02.450]Sample mode:1 start:0 end:51 right_sample_delay:0x19
      SF: Detected w25q256 with page size 256 Bytes, erase size 64 KiB, total 32 MiB
      [02.718][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [02.724][mmc]: get sdc_type fail and use default host:tm1.
      [02.730][mmc]: can't find node "mmc0",will add new node
      [02.735][mmc]: fdt err returned <no error>
      [02.738][mmc]: Using default timing para
      [02.742][mmc]: SUNXI SDMMC Controller Version:0x50310
      [02.761][mmc]: card_caps:0x3000000a
      [02.764][mmc]: host_caps:0x3000003f
      [02.767]line:703 init_clocks
      [02.770]init_clocks:finish
      [02.773]drv_disp_init
      [02.782]get flash lcd idx 0
      [02.791]HDMI 2.0 driver init start!
      [02.795]drv_disp_init finish
      [02.798]boot_gui_init:start
      [02.801]set disp.dev2_output_type fail. using defval=0
      [02.806]disp 0, clk: pll(420000000),clk(420000000),dclk(70000000) dsi_rate(150000000)
           clk real:pll(420000000),clk(420000000),dclk(105000000) dsi_rate(150000000)
      [02.842]switch device: sel=0, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
      [02.849]set disp.fb0_rot_used fail. using defval=0
      [03.015]set disp.fb0_rot_degree fail. using defval=0
      [03.023]boot_gui_init:finish
      [03.025]Loading Environment from SUNXI_FLASH... OK
      [03.030]try to burn key
      [03.032]out of usb burn from boot: not need burn key
      sunxi work mode=0x11
      run card sprite
      [03.044]try sprite_led_gpio config
      [03.047]sprite_led_gpio start
      [03.050]sunxi sprite begin
      firmware name <NULL>
      img start = 0x120
      try to read mmc start 288
      read mmc ok
      [03.062]firmware probe ok
      [03.065]fetch download map
      *************DOWNLOAD MAP DUMP************
      total download part 5
      [03.075]LCD open finish
      download part[0] name          :boot-resource
      download part[0] download file :BOOT-RESOURCE_FE
      download part[0] verify file   :VBOOT-RESOURCE_F
      download part[0] lenlo         :0x100
      download part[0] addrlo        :0x20
      download part[0] encrypt       :0x0
      download part[0] verify        :0x1
      download part[1] name          :env
      download part[1] download file :ENV_FEX000000000
      download part[1] verify file   :VENV_FEX00000000
      download part[1] lenlo         :0x100
      download part[1] addrlo        :0x120
      download part[1] encrypt       :0x0
      download part[1] verify        :0x1
      download part[2] name          :env-redund
      download part[2] download file :ENV_FEX000000000
      download part[2] verify file   :VENV_FEX00000000
      download part[2] lenlo         :0x100
      download part[2] addrlo        :0x220
      download part[2] encrypt       :0x0
      download part[2] verify        :0x1
      download part[3] name          :boot
      download part[3] download file :BOOT_FEX00000000
      download part[3] verify file   :VBOOT_FEX0000000
      download part[3] lenlo         :0x3c00
      download part[3] addrlo        :0x320
      download part[3] encrypt       :0x0
      download part[3] verify        :0x1
      download part[4] name          :rootfs
      download part[4] download file :ROOTFS_NOR_FEX00
      download part[4] verify file   :VROOTFS_NOR_FEX0
      download part[4] lenlo         :0x3000
      download part[4] addrlo        :0x3f20
      download part[4] encrypt       :0x0
      download part[4] verify        :0x1
      [03.205]fetch mbr
      the 0 mbr table is ok
      total mbr part 6
      part[0] classname :DISK
      part[0] user_type :32768
      part[0] keydata   :0
      part[0] ro        :0
      part[1] name      :env
      part[1] classname :DISK
      part[1] user_type :32768
      part[1] keydata   :0
      part[1] ro        :0
      part[2] classname :DISK
      part[2] user_type :32768
      part[2] keydata   :0
      part[2] ro        :0
      part[3] name      :boot
      part[3] classname :DISK
      part[3] user_type :32768
      part[3] keydata   :0
      part[3] ro        :0
      part[4] classname :DISK
      part[4] user_type :32768
      part[4] keydata   :0
      part[4] ro        :0
      part[5] name      :UDISK
      part[5] classname :DISK
      part[5] addrlo    :0x6f20
      part[5] lenlo     :0x0
      part[5] user_type :33024
      part[5] keydata   :0
      part[5] ro        :0
      total mbr part 6
      part[0] user_type :0x8000
      part[0] keydata   :0x0
      part[0] ro        :0x0
      part[1] name      :env
      part[1] user_type :0x8000
      part[1] keydata   :0x0
      part[1] ro        :0x0
      part[2] user_type :0x8000
      part[2] keydata   :0x0
      part[2] ro        :0x0
      part[3] name      :boot
      part[3] user_type :0x8000
      part[3] keydata   :0x0
      part[3] ro        :0x0
      part[4] user_type :0x8000
      part[4] keydata   :0x0
      part[4] ro        :0x0
      part[5] name      :UDISK
      part[5] lenlo     :0x0
      part[5] user_type :0x8100
      part[5] keydata   :0x0
      part[5] ro        :0x0
      [03.406]begin to erase flash
      total part: 7
      mbr 0, 20, 8000
      boot-resource 1, 100, 8000
      env 2, 100, 8000
      env-redund 3, 100, 8000
      boot 4, 3c00, 8000
      rootfs 5, 3000, 8000
      UDISK 6, 0, 8100
      need erase flash: 1
      [03.429]read item0 copy0
      [03.432][mmc]: MMC: block number 0x3008 exceeds max(0x0)
      read first backup failed in fun sunxi_sprite_mmc_secread line 466
      [03.442][mmc]: MMC: block number 0x3008 exceeds max(0x0)
      [03.453]unknown error happen in item 0 read
      [03.457]get secure storage map err
      secure storage init err
      no part need to protect user data
      erase size: 65536 ,sector size: 65536
      total 512 sectors, erase index 0
      total 512 sectors, erase index 16
      total 512 sectors, erase index 32
      total 512 sectors, erase index 48
      total 512 sectors, erase index 64
      total 512 sectors, erase index 80
      total 512 sectors, erase index 96
      total 512 sectors, erase index 112
      total 512 sectors, erase index 128
      total 512 sectors, erase index 144
      total 512 sectors, erase index 160
      total 512 sectors, erase index 176
      total 512 sectors, erase index 192
      total 512 sectors, erase index 208
      total 512 sectors, erase index 224
      total 512 sectors, erase index 240
      total 512 sectors, erase index 256
      total 512 sectors, erase index 272
      total 512 sectors, erase index 288
      total 512 sectors, erase index 304
      total 512 sectors, erase index 320
      total 512 sectors, erase index 336
      total 512 sectors, erase index 352
      total 512 sectors, erase index 368
      total 512 sectors, erase index 384
      total 512 sectors, erase index 400
      total 512 sectors, erase index 416
      total 512 sectors, erase index 432
      total 512 sectors, erase index 448
      total 512 sectors, erase index 464
      total 512 sectors, erase index 480
      total 512 sectors, erase index 496
      [94.071]successed in erasing flash
      SF: write offset not multiple of erase size
      write primary GPT success
      spinor: skip backup GPT
      [94.087]update partition map
      GUID Partition Table Entry Array CRC is wrong: 0xeadcc20a != 0xb2aa7578
      GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
      [94.112]begin to download part
      [94.115]begin to download part boot-resource
      partdata hi 0x0
      partdata lo 0x14000
      sparse: bad magic
      [94.272]successed in writting part boot-resource
      origin_verify value = e6f75b5c, active_verify value = e6f75b5c
      [94.286]successed in verify part boot-resource
      [94.291]successed in download part boot-resource
      [94.295]begin to download part env
      partdata hi 0x0
      partdata lo 0x20000
      sparse: bad magic
      [94.527]successed in writting part env
      origin_verify value = 82bf05f6, active_verify value = 82bf05f6
      [94.540]successed in verify part env
      [94.543]successed in download part env
      [94.547]begin to download part env-redund
      partdata hi 0x0
      partdata lo 0x20000
      sparse: bad magic
      [94.780]successed in writting part env-redund
      [94.793]successed in verify part env-redund
      [94.797]successed in download part env-redund
      [94.801]begin to download part boot
      partdata hi 0x0
      partdata lo 0x6c0800
      sparse: bad magic
      到这里就没响应了,重启也无法进入NOR内的系统,SDK是AWOL的D1S打了nezha补丁的nezha-d1s-nor镜像,谢谢大佬指点!
