    v821从uvc摄像头长时间取流(20分钟)uvcInput_WaiteBuffer UVC select timeout!
      mishan LV 3 最后由 编辑
      芯片:V821,kernel linux-5.4-ansc。摄像头是罗技 c930e
      流程是uvc获取mjpeg,通过vdec解码,传递给venc编码。uvc和vdec bind, vdec和venc bind。
      简化流程如下:
      // 绑定流程
      MPP_CHN_S UvcChn = {MOD_ID_UVC,  mDevName[0], uvc_channel_}
      MPP_CHN_S VdecChn = {MOD_ID_VDEC, 0, decode_channel_};
      MPP_CHN_S VencChn = {MOD_ID_VENC, 0, encode_channel_};
      AW_MPI_SYS_Bind(&UvcChn, &VdecChn);
      AW_MPI_SYS_Bind(&VdecChn, &VencChn);
      while (1) {
          eRet = AW_MPI_VENC_GetStream(encode_channel_, &stVencStream, 500);
          // 长时间运行后会报错,错误码是-5ff67ff2
          // 业务逻辑代码:处理h.264流
          // 释放
          AW_MPI_VENC_ReleaseStream(encode_channel_, &stVencStream);
      错误日志重复输出如下:
      W0101 04:25:30.063163   292 VideoDec_Component.c:4619] <ComponentThread> fatal error! wait vbs data timeout!
      E0101 04:25:30.072333   299 uvcInput.c:884] <uvcInput_WaiteBuffer> the /dev/video0 UVC select timeout!
      [1970-01-01 04:25:30.104] [error] [Uvc2Dec2Enc.cpp:194] fatal error! why not get stream from venc for too long? ret=-5ff67ff2
      W0101 04:25:30.259138   294 VideoEnc_Component.c:10888] <ComponentThread> Be careful! vencChn[0] timeout for waiting outputStream. input frames stat:ready[0]+using[0]+used[0]=total[0]
      E0101 04:25:30.273074   299 uvcInput.c:884] <uvcInput_WaiteBuffer> the /dev/video0 UVC select timeout!
      E0101 04:25:30.473610   299 uvcInput.c:884] <uvcInput_WaiteBuffer> the /dev/video0 UVC select timeout!
      dmesg没有任何错误日志。当出错后,程序一直运行直到Segmentation fault。能稳定复现,运行20~40分钟后就会出现。当出现段错误后,重新启动程序,从UVC无法获取任何帧!!!。以下是重新启动程序直接报错:
      I0101 05:24:50.466994   333 mpi_sys.c:893] <AW_MPI_SYS_SetConf> kfctmpdir is [/tmp]
      I0101 05:24:50.471314   333 mpi_sys.c:1560] <AW_MPI_SYS_Init> ISP init
      I0101 05:24:50.473061   333 isp_version.h:32] <isp_version_info> [ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
      IPCORE: ISP603
      branch: libisp-dev
      commit: 17ff2691536c2703ffcaf9f77a536289b475960b
      date  : Tue Nov 25 19:56:58 2025 +0800
      I0101 05:24:50.480214   333 mpi_sys.c:1562] <AW_MPI_SYS_Init> ISP init done
      I0101 05:24:50.482474   333 hwdisplay.c:84] <hw_display_init>
      I0101 05:24:50.483505   333 hwdisplay.c:1008] <hwd_init> (hwd_init 1008)
      E0101 05:24:50.986184   333 hwdisplay.c:1001] <tryOpenDev> fatal error! open dev[/dev/disp] fail. error[2-No such file or directory]!
      E0101 05:24:50.987246   333 hwdisplay.c:1018] <hwd_init> fatal error! Failed to open disp device
      E0101 05:24:50.988217   333 mpi_vo.c:382] <VO_Construct> fatal error! hw display init fail!
      E0101 05:24:50.989272   333 mpi_sys.c:1617] <AW_MPI_SYS_Init> VO Construct error!
      I0101 05:24:51.018701   333 audio_hw.c:199] <MakeAllMixerElemsAvailable> pcm open and close, all MixerElems maybe exist.
      I0101 05:24:51.019752   333 alsa_interface.c:736] <alsaOpenMixer> open mixer:hw:0
      I0101 05:24:51.022494   333 alsa_interface.c:792] <alsaOpenMixer> set playback vol_val to value: 27, mppValue:385
      I0101 05:24:51.023880   333 alsa_interface.c:805] <alsaOpenMixer> set playback soft_vol val to value: 130, mppValue:0
      I0101 05:24:51.025372   333 alsa_interface.c:736] <alsaOpenMixer> open mixer:hw:1
      I0101 05:24:51.028675   336 mpi_sys.c:1124] <MonitorEnvVarThread> detect user environment:
      I0101 05:24:51.029684   336 mpi_sys.c:1125] <MonitorEnvVarThread> /tmp/mpp_log_level
      I0101 05:24:51.030663   336 mpi_sys.c:1126] <MonitorEnvVarThread> /tmp/mpp_venc_sei_config_param
      I0101 05:24:51.092973   333 uvcInput.c:586] <uvcInput_SetDevAttr> the /dev/video0 UVC support video capture!
      I0101 05:24:51.093275   333 uvcInput.c:596] <uvcInput_SetDevAttr> the /dev/video0 UVC driver is uvcvideo
      I0101 05:24:51.093476   333 uvcInput.c:597] <uvcInput_SetDevAttr> the /dev/video0 UVC card is Logitech Webcam C930e
      I0101 05:24:51.093676   333 uvcInput.c:598] <uvcInput_SetDevAttr> the /dev/video0 UVC bus info is usb-sunxi-ehci-1
      I0101 05:24:51.093847   333 uvcInput.c:599] <uvcInput_SetDevAttr> the version is 328924
      I0101 05:24:51.094026   333 uvcInput.c:611] <uvcInput_SetDevAttr> the /dev/video0 UVC device can support YUYV 4:2:2 capture pixelformat[0x56595559]
      I0101 05:24:51.094204   333 uvcInput.c:611] <uvcInput_SetDevAttr> the /dev/video0 UVC device can support Motion-JPEG capture pixelformat[0x47504a4d]
      I0101 05:24:51.094358   333 uvcInput.c:614] <uvcInput_SetDevAttr> Congratulation: the /dev/video0 UVC support Motion-JPEG capture pixelformat
      I0101 05:24:51.112049   333 uvcInput.c:849] <uvcInput_SetDevAttr> the /dev/video0 UVC capture fixformat is 0x47504a4d
      I0101 05:24:51.113174   333 uvcInput.c:850] <uvcInput_SetDevAttr> the /dev/video0 UVC capture width is 1280
      I0101 05:24:51.114170   333 uvcInput.c:851] <uvcInput_SetDevAttr> the /dev/video0 UVC capture height is 720
      I0101 05:24:51.115135   333 uvcInput.c:852] <uvcInput_SetDevAttr> the /dev/video0 UVC capture fps is 30
      I0101 05:24:51.116118   333 uvcInput.c:853] <uvcInput_SetDevAttr> the /dev/video0 UVC capture bufCount is 3
      I0101 05:24:51.117175   333 uvcInput.c:854] <uvcInput_SetDevAttr> the /dev/video0 UVC capture bufLength is 1843200
      W0101 05:24:51.118140   333 uvcInput.c:857] <uvcInput_SetDevAttr> the /dev/video0 UVC had init!
      W0101 05:24:51.119700   333 UvcVirVi_Component.c:1026] <UvcComponentInit> UvcVirvi_Component had Init!!!
      I0101 05:24:51.120848   337 UvcVirVi_Component.c:1038] <Uvc_ComponentThread> UVC ComponentThread start run!
      E0101 05:24:51.123030   339 VideoDec_InputThread.c:70] <InputThread> VideoDecoder InputThread start run...
      [1970-01-01 05:24:51.124] [info] [Uvc2Dec2Enc.cpp:374] Decode init wh: 1280x720
      [1970-01-01 05:24:51.132] [info] [Uvc2Dec2Enc.cpp:451] venc set Rcmode= 2
      INFO   : cedarc <cdc_log_set_level:78>: Set log level to 5 from /etc/cedarc.conf
      I0101 05:24:51.154759   340 VideoEnc_Component.c:1353] <CedarvEncInit> VencChn[0] set VbrOptEn 0
      I0101 05:24:51.155822   340 VideoEnc_Component.c:1375] <CedarvEncInit> VencChn[0] set ProductCase mode: 0
      WARNING: cedarc <CheckSetParamInt:778>: Notice: sVbrParam.nQuality is 10, but its suggested value is 1 !
      I0101 05:24:51.157090   333 VideoEnc_Component.c:990] <setVbvBufferConfig> bitrate: 1953 Kbps, set encode vbv size [1442816]bytes, frame length threshold [942080]bytes
      I0101 05:24:51.157400   333 VideoEnc_Component.c:2537] <CedarvVideoEncInit> VencChn[0] Online Mode=1,Chn=0,BufNum=0,OnlineEnFlag=0,sensorID=0,bkID=0,VcuOn=1,MultiSensorOnlineEn=0
      WARNING: cedarc <resetEncoderVcu:887>: reset vcu and encoder
      [1970-01-01 05:24:51.231] [info] [RtspServerImpl.cpp:166] rtsp server start! url: rtsp://192.168.31.191:8554/ch0
      W0101 05:24:51.233866   333 VideoDec_Component.c:2539] <VideoDecComponentTunnelRequest> Low probability! input portIndex[0] buffer supplier[1] is not same as output portIndex[1] buffer supplier[2], respect output port decision!
      I0101 05:24:51.235034   333 VideoEnc_Component.c:8055] <VideoEncComponentTunnelRequest> set inputPortTunnelFlag = TRUE
      W0101 05:24:51.650037   333 uvcInput.c:460] <uvcInput_SetDevEnable> Be careful! uvcDev[/dev/video0] streamon cost:413ms
      I0101 05:24:51.651608   338 VideoDec_Component.c:676] <CedarvCodecInit> video_format: 0x101
      W0101 05:24:51.653470   345 uvcInput.c:1222] <uvcInput_CapThread> loop uvcInput_CapThread the UVC name is /dev/video0 , fd = 8
      I0101 05:24:51.665980   338 VideoDec_Component.c:781] <CedarvCodecInit> vdec output format set to [0x6]
      I0101 05:24:51.666434   338 VideoDec_Component.c:799] <CedarvCodecInit> config vbvBufferSize[0]KB
      WARNING: cedarc <InitializeVideoDecoder:470>: warning: the nDecodeSmoothFrameBufferNum is 0
      WARNING: cedarc <InitializeVideoDecoder:476>: warning: the nDeInterlaceHoldingFrameBufferNum is 0
      I0101 05:24:51.696103   338 VideoDec_Component.c:876] <CedarvCodecInit> vdecChn[0] video stream info:codecType[0x101], size[1280x720], frameRate[30000], isFramePackage[1]
      I0101 05:24:51.697782   339 VideoDec_InputThread.c:303] <InputThread> tunnel_BufferSupplyOutput is not processed here.
      E0101 05:24:51.854970   345 uvcInput.c:884] <uvcInput_WaiteBuffer> the /dev/video0 UVC select timeout!
      E0101 05:24:52.055609   345 uvcInput.c:884] <uvcInput_WaiteBuffer> the /dev/video0 UVC select timeout!
      W0101 05:24:52.199092   338 VideoDec_Component.c:4619] <ComponentThread> fatal error! wait vbs data timeout!
      [1970-01-01 05:24:52.197] [error] [Uvc2Dec2Enc.cpp:194] fatal error! why not get stream from venc for too long? ret=0x-5ff67ff2
      W0101 05:24:52.237116   340 VideoEnc_Component.c:10888] <ComponentThread> Be careful! vencChn[0] timeout for waiting outputStream. input frames stat:ready[0]+using[0]+used[0]=total[0]
      E0101 05:24:52.256233   345 uvcInput.c:884] <uvcInput_WaiteBuffer> the /dev/video0 UVC select timeout!
      E0101 05:24:52.456973   345 uvcInput.c:884] <uvcInput_WaiteBuffer> the /dev/video0 UVC select timeout!
      E0101 05:24:52.657617   345 uvcInput.c:884] <uvcInput_WaiteBuffer> the /dev/video0 UVC select timeout!
      用v4l2-ctl获取mjpeg流,能正确运行。
      v4l2-ctl -d /dev/video0 --set-fmt-video=width=640,height=480,pixelformat=MJPG --stream-mmap --stream-to=test.mjpg
      输出:
      < 64.45 fps, dropped buffers: 71
      < 64.83 fps, dropped buffers: 66
      < 64.72 fps, dropped buffers: 52
      << 65.22 fps, dropped buffers: 132
      <<< 65.38 fps, dropped buffers: 64
      <<< 66.11 fps, dropped buffers: 172
      < 65.66 fps, dropped buffers: 43
      <<< 65.75 fps, dropped buffers: 53
      << 65.32 fps, dropped buffers: 50
      << 64.37 fps, dropped buffers: 203
      << 64.51 fps, dropped buffers: 61
      < 64.06 fps, dropped buffers: 207
      < 64.09 fps, dropped buffers: 121
      以下是uvc插入时的日志:
      [    5.186790] usb 1-1: New USB device found, idVendor=046d, idProduct=0843, bcdDevice= 0.13
      [    5.187704] usb 1-1: New USB device strings: Mfr=0, Product=2, SerialNumber=1
      [    5.188525] usb 1-1: Product: Logitech Webcam C930e
      [    5.189064] usb 1-1: SerialNumber: A597F8EE
      [    5.190900] uvcvideo: Found UVC 1.00 device Logitech Webcam C930e (046d:0843)
      [    5.196754] input: Logitech Webcam C930e as /devices/platform/soc@2002000/44101000.ehci0-controller/usb1/1-12
      请问如何修复此问题?
        mishan LV 3 最后由 编辑
        可能是罗技c930e的问题,有时候测试几个小时都没问题。换了一个海康的USB摄像头测试几个小时未出现。不确定此结论是否正确。
