    大佬们,米尔的T527无法启动
      liray LV 2 最后由 编辑
      [148]HELLO! BOOT0 is starting!
      [151]BOOT0 commit : {4721ad08}
      [155]periph0 has been enabled
      [158]set pll end
      [160]PL gpio voltage : 1.8V
      [164][pmu]: bus read error
      [167]PMU: AXP2202
      [171]power mode:33, sys_vol:920
      [185]dram_para_total:0x20
      [188]vaild para:16 select dram para7
      [191]board init ok
      [204]enable_jtag
      [206]card no is 2
      [208]sdcard 2 line count 8
      [mmc]: mmc driver ver 2025-10-16 17:09
      [mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [mmc]: Try MMC card 2
      [mmc]: RMCA OK!
      [mmc]: bias 17fb
      [mmc]: mmc 2 bias 17fb
      [mmc]: MMC 5.1
      [mmc]: HSSDR52/SDR25 8 bit
      [mmc]: 50000000 Hz
      [mmc]: 29600 MB
      [mmc]: SD/MMC 2 init OK!!!
      [281]DRAM BOOT DRIVE INFO: V0.67
      [285]DRAM_VCC set to 1160 mv
      [288]DRAM CLK =924 MHZ
      [291]DRAM Type =8 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
      [302]DRAM SIZE =4096 MBytes, para1 = 310a, para2 = 10001000, tpr13 = 6461
      [334]DRAM simple test OK.
      [337]dram size = 4096
      [344]nsi init 2023-2-23
      [446]Loading boot-pkg Succeed(index=0).
      [450]Entry_name = u-boot
      [461]Entry_name = monitor
      [464]Entry_name = scp
      [468]Entry_name = dtb
      [472]tunning data addr:0x4a0003e8
      [475]Jump to ATF: monitor_base = 0x48000000, uboot_base = 0x4a000000, optee_base = 0x0
      NOTICE: BL31: OP-TEE 32bit detected
      NOTICE: BL31: U-BOOT 32bit detected
      NOTICE: BL31: v2.5(debug):d6d86daf3
      NOTICE: BL31: Built : 17:20:24, Aug 7 2025
      NOTICE: BL31: No DTB found.
      nsi init ok 2022-11-08
      ERROR: Error initializing runtime service opteed_fast
      U-Boot 2018.07-00014-g8f9e7086 (Jan 15 2026 - 08:50:49 +0000) Allwinner Technology
      [00.657]CPU: Allwinner Family
      [00.660]Model: sun55iw3
      I2C: ready
      [00.736]DRAM: 4 GiB
      [00.740]Relocation Offset is: 75e26000
      [00.805]secure enable bit: 0
      [00.810]PMU: AXP2202
      [00.816]BMU: AXP2202
      [00.820][AXP2202] comm status : 0x0 = 0x20, 0x1 = 0x90
      [00.825][AXP2202] onoff status: 0x20 = 0x4, 0x21 = 0x0
      [00.829][AXP2202] reboot/charge status: 0xf0 = 0x0
      [00.834]PMU: AXP1530
      [00.836]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=462Mhz
      [00.843]gic: sec monitor mode
      SPI ALL: ready
      [00.884]flash init start
      [00.886]workmode = 0,storage type = 2
      [00.889]FDT ERROR:sunxi_dual_storage_handle:get property system_storage_type error
      [00.897][mmc]: mmc driver ver uboot2018:2024-10-18 9:01:00 -- uboot2018:2025-03-28 10:03:00
      [00.907][mmc]: SUNXI SDMMC Controller Version:0x50500
      [00.916][mmc]: 200 MHz...
      [00.918][mmc]: sample: 22 - 113(ps)
      [00.922][mmc]: ds: 22 - 113(ps)
      [00.939][mmc]: Best spd md: 4-HS400, freq: 4-150000000, Bus width: 8
      [00.945]sunxi flash init ok
      do not runing scanning usb for storage devices ...
      no usb storage device detect!
      [00.966]Loading Environment from SUNXI_FLASH... OK
      [00.974]No ethernet found.
      [00.984]Fail to get de's irq!
      [01.062]NOT support bridge yet
      [01.064]Warn: no find panel or bridge
      [01.068][PHY] Unset hs_clk_rate.
      dsi1@5508000: detailed mode clock 156000 kHz, flags[a]
      H: 1200 1256 1288 1336
      V: 1920 1924 1927 1957
      bus_format: 0
      [01.089]hdmi@5520000 disconnected
      [01.093]bad framebuffer width 0
      [01.108]bootloader is not found!
      [01.204][PHY] phy_config:0 Unset the lvl,Use the default cfg.
      [01.210][axp][err]: can't find cldo3 from table
      [01.214]enable power_ext cldo3, ret=-1
      [01.228][axp][err]: can't find dcdc4 from table
      [01.232]enable power_ext dcdc4, ret=-1
      [01.246][axp][err]: can't find cldo1 from table
      [01.250]enable power_ext cldo1, ret=-1
      [01.535]bootloader is not found!
      [01.551]failed to display uboot logo for disp 64
      [01.565]the secure storage item0 copy0 magic is bad
      [01.579]the secure storage item0 copy1 magic is bad
      [01.583]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [01.594]usb prepare ok
      [01.797]usb sof ok
      [01.798]usb probe ok
      [01.800]usb setup ok
      set address 0x6
      set address 0x6 ok
      try to update
      [02.207]do_burn_from_boot usb : have no handshake
      skip update boot_param
      root_partition is rootfs
      set root to /dev/mmcblk0p4
      [02.237]update part info
      [02.239]update bootcmd
      [02.249]change working_fdt 0xbbdd5e28 to 0xbbda5e28
      [02.258]The storage not support sample function
      ret 0
      [02.308]update dts
      avb_footer.c:22: ERROR: Footer magic is incorrect.
      [03.440]no vendor_boot partition is found
      Android's image name: sun55i_arm64
      kernel addr 0x40080000 0x41519008 exceed ramdisk scope
      ramdisk addr 0x41000000 0x41000000
      [03.501]Starting kernel ...
      [03.503]total: 3503 ms
      [03.506][mmc]: mmc exit start
      [03.523][mmc]: mmc 2 exit ok
      NOTICE: [SCP] :wait arisc ready....
      NOTICE: [SCP] :arisc version: []
      NOTICE: [SCP] :arisc startup ready
      NOTICE: [SCP] :arisc startup notify message feedback
      NOTICE: [SCP] :sunxi-arisc driver is starting
      NOTICE: BL3-1: Next image address = 0x40080000
      NOTICE: BL3-1: Next image spsr = 0x3c5
      [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
      [ 0.000000] Linux version 5.15.147 (lizhi@system08) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #20 SMP PREEMPT Wed Jan 21 19:26:36 CST 2026
      [ 0.000000] Machine model: sun55iw3
      [ 0.000000] earlycon: uart8250 at MMIO32 0x0000000002500000 (options '')
      [ 0.000000] printk: bootconsole [uart8250] enabled
      [ 0.072831] AW BSP version: d5853355a7, 2026-01-21 19:22:01 +0800
