    D1S/F33 LCD驱动问题
    H/F/TV Series
    • B
      bgv1122 LV 3 最后由 编辑
      mango开发板,跑mango官网首页固件能正常显示,但这个固件没有cma,因此打算自己从全志官网的SDK编译,但irq一直无中断,请问这是什么情况:
      root@TinaLinux:/# cat /sys/class/disp/disp/attr/sys
      screen 0:
      de_rate 300000000 hz, ref_fps:60
      mgr0: 800x480 fmt[rgb] cs[0x204] range[full] eotf[0x4] bits[8bits] err[0] force_sync[0] unblank direct_show[false] iommu[0]
      dmabuf: cache[0] cache max[0] umap skip[0] umap skip max[0]
      lcd output backlight( 50) fps:25.5 800x 480
      err:0 skip:0 irq:0 vsync:0 vsync_skip:0
      BUF enable ch[1] lyr[0] z[16] prem[N] a[pixel 255] fmt[ 0] fb[ 800, 480; 800, 480; 800, 480] crop[ 0, 0, 800, 480] frame[ 0, 0, 800,1280] addr[ffc00000, 0, 0] flags[0x 0] trd[0,0]
      depth[ 0] root@TinaLinux:/#
      这是lcd0的配置:
      &lcd0 {
      compatible = "allwinner,sunxi-lcd0";
      lcd_used = <1>;
      lcd_driver_name = "default_lcd";
      lcd_backlight = <50>;
      lcd_if = <0>;
      lcd_x = <800>;
      lcd_y = <480>;
      lcd_width = <150>;
      lcd_height = <94>;
      lcd_dclk_freq = <48>;
      lcd_pwm_used = <0>;
      lcd_pwm_ch = <7>;
      lcd_pwm_freq = <500>;
      lcd_pwm_pol = <0>;
      lcd_bl_en = <&pio PD 22 1 0 3 1>; /* 设为纯 GPIO 输出高电平 */
      lcd_hbp = <55>;
      lcd_ht  = <1240>;
      lcd_hspw = <20>;
      lcd_vbp = <35>;
      lcd_vt  = <650>;
      lcd_vspw = <10>;
      lcd_lvds_if = <0>;
      lcd_lvds_colordepth = <1>;
      lcd_lvds_mode = <0>;
      lcd_frm = <0>;
      lcd_io_phase = <0>;
      lcd_gamma_en = <0>;
      lcd_bright_curve_en = <0>;
      lcd_cmap_en = <0>;
      deu_mode = <0>;
      lcdgamma4iep = <22>;
      smart_color = <90>;
      pinctrl-0 = <&rgb18_pins_a>;
      pinctrl-1 = <&rgb18_pins_b>;
