    全志在线 D1哪吒开发板开机连接wifi热点, 启动 sshd 服务
    5128
      1. 下载 dropbear-D1.tgz源码 (尴尬, 没找到上传菜单), 解压, 编译:
      根据实际情况修改 gcc 路径
      CROSS=/opt/D1/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/bin/riscv64-unknown-linux-gnu- make
      1. 修改 wifi 热点配置
      package/allwinner/wifimanager/files/wpa_supplicant_overlay.conf
      disable_scan_offload=1
      network={
          ssid="whycan"
          psk="13800138000"
      1. 修改文件系统, 添加文件 allwinner/d1-nezha/base-files/etc/init.d/S51dropbear
      # Allow a few customizations from a config file
      test -r /etc/default/dropbear && . /etc/default/dropbear
      start() {
              DROPBEAR_ARGS="$DROPBEAR_ARGS -R"
              # If /etc/dropbear is a symlink to /var/run/dropbear, and
              #   - the filesystem is RO (i.e. we can not rm the symlink),
              #     create the directory pointed to by the symlink.
              #   - the filesystem is RW (i.e. we can rm the symlink),
              #     replace the symlink with an actual directory
              if [ -L /etc/dropbear \
                   -a "$(readlink /etc/dropbear)" = "/var/run/dropbear" ]
              then
                      if rm -f /etc/dropbear >/dev/null 2>&1; then
                              mkdir -p /etc/dropbear
                              echo "No persistent location to store SSH host keys. New keys will be"
                              echo "generated at each boot. Are you sure this is what you want to do?"
                              mkdir -p "$(readlink /etc/dropbear)"
                      fi
              fi
              printf "Starting dropbear sshd: "
              umask 077
              start-stop-daemon -S -q -p /var/run/dropbear.pid \
                      --exec /usr/sbin/dropbear -- $DROPBEAR_ARGS
              [ $? = 0 ] && echo "OK" || echo "FAIL"
      stop() {
              printf "Stopping dropbear sshd: "
              start-stop-daemon -K -q -p /var/run/dropbear.pid
      restart() {
              stop
              start
      case "$1" in
        start)
              start
        stop)
              stop
        restart|reload)
              restart
              exit 1
      esac
      exit $?
      把前面编译的 dropbear 复制到 allwinner/d1-nezha/base-files/usr/sbin/
      1. 执行编译/打包/烧录:
      source build/envsetup.sh;lunch d1_nezha-tina;make;pack
      1. 启动手动执行 (因为还不会自动执行, 折腾了很多次也没搞定)
      #获取IP
      udhcpc -i wlan0
      #启动ssh服务
      /etc/init.d/S51dropbear restart
      root@TinaLinux:/# udhcpc -i wlan0
      udhcpc: started, v1.27.2
      udhcpc: sending discover
      udhcpc: sending select for 192.168.43.224
      udhcpc: lease of 192.168.43.224 obtained, lease time 3599
      udhcpc: ifconfig wlan0 192.168.43.224 netmask 255.255.255.0 broadcast 192.168.43.255
      udhcpc: setting default routers: 192.168.43.1
      root@TinaLinux:/#
      root@TinaLinux:/#
      root@TinaLinux:/# /etc/init.d/S51dropbear restart
      Stopping dropbear sshd: OK
      Starting dropbear sshd: OK
      1. 给板子的root设置一个密码 passwd
      2. 用 Xshell, mobaxterm, putty, ssh命令行等都可以连接到 192.168.43.224
      参考链接:
      全志 A33 官方 dragonboard SDK 建立 SSHD 服务器, 电脑通过WIFI连接A33 SSHD服务器 [分享]
      http://whycan.com/t_6312.html
        DOT小文哥 LV 8 @whycan 最后由 编辑
        @whycan 好东西,可以独远程快乐了
        • LogPI
          LogPI LV 4 最后由 编辑
          Stopping dropbear sshd: FAIL
          Starting dropbear sshd: start-stop-daemon: unrecognized option '--exec'
          需要将--exec改为-x
          sora1874 1 条回复 最后回复 回复 引用 分享 0
          • Referenced by  Kirin Kirin
          • sora1874
            sora1874 LV 5 @LogPI 最后由 编辑
            @logpi etc/init.d/S51dropbear脚本里面的exec嘛
