    xr806鸿蒙代码编译出错
    5
    5292
    • nihui
      nihui LV 6 最后由 编辑
      [OHOS INFO] hb root path: /home/nihui/osd/xr806
      OHOS Which product do you need?  wifi_skylark
      [OHOS INFO] ERROR at //device/xradio/xr806/liteos_m/config.gni:14:1: Unable to load "/home/nihui/osd/xr806/device/xradio/xr806/liteos_m/SDKconfig.gni".
      [OHOS INFO] import("//device/xradio/xr806/liteos_m/SDKconfig.gni")
      [OHOS INFO] ^----------------------------------------------------
      [OHOS INFO] See //build/lite/config/BUILDCONFIG.gn:14:1: whence it was imported.
      [OHOS INFO] import("${device_path}/config.gni")
      [OHOS ERROR] you can check build log in /home/nihui/osd/xr806/out/xr806/wifi_skylark/build.log
      [OHOS ERROR] command: "/home/nihui/osd/xr806/prebuilts/build-tools/linux-x86/bin/gn gen /home/nihui/osd/xr806/out/xr806/wifi_skylark --root=/home/nihui/osd/xr806 --dotfile=/home/nihui/osd/xr806/build/lite/.gn --script-executable=/usr/bin/python3 --args=ohos_build_compiler_specified="gcc" product_path="/home/nihui/osd/xr806/vendor/xradio/xr806" device_path="/home/nihui/osd/xr806/device/xradio/xr806/liteos_m" ohos_kernel_type="liteos_m" enable_ohos_kernel_liteos_m_fs = false enable_ohos_kernel_liteos_m_cppsupport = false disable_huks_binary = false disable_authenticate = false ohos_build_type="debug" ohos_build_time="1639157835366" ohos_build_datetime="2021-12-11 09:37:15" ohos_full_compile=true" failed
      [OHOS ERROR] return code: 1
      [OHOS ERROR] execution path: /home/nihui/osd/xr806
      看起来是缺少device/xradio/xr806/liteos_m/SDKconfig.gni,怎么办呢?
      S 1 条回复 最后回复 回复 引用 分享 0
        salt_fish LV 3 @nihui 最后由 编辑
        @nihui 这个文件是动态文件,需要按步骤现在device/xradio/xr_skylark/xr806文件夹下,执行一下make lib -j后,返回根目录再执行一下hb build -f
        nihui 1 条回复 最后回复 回复 引用 分享 0
        • nihui
          nihui LV 6 @salt_fish 最后由 编辑
          @salt_fish 看了下 device/xradio/xr806/xr_skylark/config.py,感觉里面有bug
          #!/usr/bin/python
          # -*- coding: UTF-8 -*-
          import os
          pwd = os.path.dirname (__file__)
          f = open('.{0}/.config'.format(pwd),'r')
          DATA = ['#XR806 config']
          for line in f.readlines():
              if line[0] != '#' and line[0] != '\n':
                  line = line.strip('\n')
                  DATA.append(line)
          GNf = open('.{0}/../liteos_m/SDKconfig.gni'.format(pwd),'w')
            File "/home/nihui/osd/xr806/device/xradio/xr806/xr_skylark/config.py", line 34, in <module>
          FileNotFoundError: [Errno 2] No such file or directory: './home/nihui/osd/xr806/device/xradio/xr806/xr_skylark/.config'
          make: *** [Makefile:125:menuconfig] 错误 1
          打开文件的路径前面有个点,导致打开失败,无法写入 SDKconfig.gni
          I 1 条回复 最后回复 回复 引用 分享 0
          • I
            何镜勇 LV 4 @nihui 最后由 编辑
            @nihui 是的,这里是个bug,应该改成相对路径。
            M 1 条回复 最后回复 回复 引用 分享 0
              mysteryli LV 7 @I_A_student 最后由 编辑
              @i_a_student 在 xr806鸿蒙代码编译出错 中说:
              我也出现了这个问题,这个问题在新的代码已经修复掉了吗?
              我本地要怎么修改才能编译通过呢?
