    XR806是否支持C++编译
    3651
      haijun LV 3 最后由 编辑
      请问,XR806是否支持C++编译?
        HU_710774265 LV 4 最后由 编辑
        如果你去看 官方教程 拉源码回来
        xr806_openharmony/device/xradio/xr806/xr_skylark/src/cplusplus/ 看这个目录
        cpp_init.c cpp_mem.cpp Makefile
        当然你看编译环境 是有g++的
        tools/gcc-arm-none-eabi-10-2020-q4-major/bin/
        arm-none-eabi-ar arm-none-eabi-gdb-add-index
        arm-none-eabi-as arm-none-eabi-gdb-add-index-py
        arm-none-eabi-c++ arm-none-eabi-gdb-py
        arm-none-eabi-c++filt arm-none-eabi-gprof
        arm-none-eabi-cpp arm-none-eabi-ld
        arm-none-eabi-elfedit arm-none-eabi-ld.bfd
        arm-none-eabi-g++ arm-none-eabi-lto-dump
        arm-none-eabi-gcc arm-none-eabi-nm
        arm-none-eabi-gcc-10.2.1 arm-none-eabi-objcopy
        arm-none-eabi-gcc-ar arm-none-eabi-objdump
        arm-none-eabi-gcc-nm arm-none-eabi-ranlib
        arm-none-eabi-gcc-ranlib arm-none-eabi-readelf
        arm-none-eabi-gcov arm-none-eabi-size
        arm-none-eabi-gcov-dump arm-none-eabi-strings
        arm-none-eabi-gcov-tool arm-none-eabi-strip
        H 1 条回复 最后回复 回复 引用 分享 0
          haijun LV 3 @HU_710774265 最后由 编辑
          @hu_710774265您好,请问我应该怎么设置?我尝试了半天也没有编译成功
            HU_710774265 LV 4 @haijun 最后由 编辑
            @haijun
            libcplusplus.a
            [make@archlinux cplusplus]$ ls
            cpp_init.c  cpp_init.o   cpp_mem.d  libcplusplus.a
            cpp_init.d  cpp_mem.cpp  cpp_mem.o  Makefile
            make menuconfig
            [*] C++ support
            所以是支持c++的
            具体宏变量是 CONFIG_CPLUSPLUS 自己搜吧
