    hello 没有如约出现 怎么办?
    7606
      HU_710774265 LV 4 最后由 编辑
      配置1
      /home/make/xr806_openharmony/device/xradio/xr806/BUILD.gn
      import("//build/lite/config/subsystem/lite_subsystem.gni")
      import("//build/lite/config/component/lite_component.gni")
      import("//base/security/huks/build/config.gni")
      build_ext_component("libSDK") {
        exec_path = rebase_path(".", root_build_dir)
        outdir = rebase_path("$root_out_dir")
        command = "./build.sh ${outdir}"
        deps = [
          "//build/lite/:ohos",
          "//kernel/liteos_m:kernel",
          "os:liteos_glue",
        if (IsBootloader == "false") {
          deps += [
            "adapter/hals:adapter",
            "adapter/console:app_console",
            "ohosdemo:ohosdemo",
        if (disable_huks_binary == true) {
          deps += [
            "//base/security/huks/frameworks/huks_lite:huks_sdk",
      group("xr806") {
      配置2
      /home/make/xr806_openharmony/device/xradio/xr806/ohosdemo/BUILD.gn
      group("ohosdemo") {
          deps = [
              "hello_demo:app_hello",
              "iot_peripheral:app_peripheral",
              "wlan_demo:app_WlanTest",
      配置3
      /home/make/xr806_openharmony/device/xradio/xr806/liteos_m/SDKconfig.gni
      #Build by config.py DO NOT EDIT!
      SDK_cflags = [
          "-mcpu=cortex-m33",
          "-mtune=cortex-m33",
          "-march=armv8-m.main+dsp",
          "-mfpu=fpv5-sp-d16",
          "-mfloat-abi=softfp",
          "-mcmse",
          "-mthumb",
          "-c",
          "-g",
          "-fno-common",
          "-fmessage-length=0",
          "-fno-exceptions",
          "-ffunction-sections",
          "-fdata-sections",
          "-fomit-frame-pointer",
          "-Wall",
          #"-Werror",
          "-Wno-cpp",
          "-Wpointer-arith",
          "-Wno-error=unused-function",
          "-MMD",
          "-MP",
          "-Os",
          "-DNDEBUG",
          "-Wno-error=stringop-truncation",
          "-Wno-error=restrict",
          "-includexr_config.h",
          "-includecommon/prj_conf_opt.h",
          "-DCONFIG_CHIP_ARCH_VER=3",
          "-DCONFIG_ARCH_APP_CORE",
          "-DCONFIG_CPU_CM33F",
      ProjectPath = "demo/wlan_ble_demo"
      declare_args() {IsBootloader = "false"}
      链接上开发板后信息
      	Hello! OpenHarmony!
      	System tag : OpenHarmony 1.1.2_LTS
      use default flash chip mJedec 0x0
      [FD I]: mode: 0x10, freq: 96000000Hz, drv: 0
      [FD I]: jedec: 0x0, suspend_support: 1
      mode select:e
      wlan information ===================================================
      firmware:
          version : R0-XR_C07.08.52.65_02.84 May 27 2021 11:41:33-Y02.84
          buffer  : 8
      driver:
          version : XR_V02.05
      mac address:
          in use        : dc:9d:09:b9:44:01
          in use        : dc:9d:09:b9:44:02
      wlan mode:a
      [VFS INF] SPIFFS mount success.
      platform information ===============================================
      XR806 SDK v1.2.0  Dec 13 2021 13:40:36
      heap space [0x228848, 0x247c00), size 127928
      cpu  clock 160000000 Hz
      HF   clock  40000000 Hz
      sdk option:
          XIP           : enable
          INT LF OSC    : enable
          SIP flash     : enable
      mac address:
          efuse         : 80:74:84:21:41:d2
      hiview init success.
      console init success set is ok
      此处我修改源码保证是我编译的非原唱固件
      I 1 条回复 最后回复 回复 引用 分享 0
      • I
        何镜勇 LV 4 @HU_710774265 最后由 编辑
        @hu_710774265 上代码吧
        H 1 条回复 最后回复 回复 引用 分享 0
          HU_710774265 LV 4 @I_A_student 最后由 编辑
          @i_a_student
          代码就是当前最新仓库的
          xr806_openharmony/device/xradio/xr806/ohosdemo/hello_demo/
            main.c
            #include "ohos_init.h"
            #include "kernel/os/os.h"
            	while (1) {
            		printf("hello world!\n");
            		LOS_Msleep(1000);
            void HelloTestMain(void)
            	printf("Wifi Test Start\n");
            			    OS_THREAD_PRIO_APP, 4 * 1024) != OS_OK) {
            SYS_RUN(HelloTestMain);
            我修改了
            新加 "adapter/hello_demo:app_hello",
            #"ohosdemo:ohosdemo", 这行去掉了
            把文件
            hello_demo
            整体复制到
            /home/make/xr806_openharmony/device/xradio/xr806/adapter/
            目录下了
            编译日志如下
            [OHOS INFO] WARNING at the command-line "--args":1:420: Build argument has no effect.
            [OHOS INFO] ohos_build_compiler_specified="gcc" product_path="/home/make/xr806_openharmony/vendor/xradio/xr806" device_path="/home/make/xr806_openharmony/device/xradio/xr806/liteos_m" ohos_kernel_type="liteos_m" enable_ohos_kernel_liteos_m_fs = false enable_ohos_kernel_liteos_m_cppsupport = false disable_huks_binary = false disable_authenticate = false ohos_build_type="debug" ohos_build_time="1639347138627" ohos_build_datetime="2021-12-13 14:12:18" ohos_full_compile=true
            [OHOS INFO]        ^--------------------
            [OHOS INFO] The variable "ohos_build_datetime" was set as a build argument
            [OHOS INFO] but never appeared in a declare_args() block in any buildfile.
            [OHOS INFO]
            [OHOS INFO] To view all possible args, run "gn args --list <out_dir>"
            [OHOS INFO]
            [OHOS INFO] The build continued as if that argument was unspecified.
            [OHOS INFO]
            [OHOS INFO] Done. Made 61 targets from 62 files in 330ms
            [OHOS INFO] [1/253] STAMP obj/applications/sample/wifi-iot/app/startup/startup.stamp
            [OHOS INFO] [2/253] STAMP obj/applications/sample/wifi-iot/app/app.stamp
            [OHOS INFO] [3/253] gcc cross compiler obj/base/hiviewdfx/hievent_lite/frameworks/libhievent_lite.hiview_event.o
            [OHOS INFO] [4/253] gcc cross compiler obj/base/hiviewdfx/hilog_lite/frameworks/mini/libhilog_lite.hiview_log_limit.o
            [OHOS INFO] [5/253] gcc cross compiler obj/base/hiviewdfx/hiview_lite/libhiview_lite.hiview_service.o
            [OHOS INFO] [6/253] gcc cross compiler obj/base/hiviewdfx/hilog_lite/frameworks/mini/libhilog_lite.hiview_log.o
            [OHOS INFO] [7/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.key_agreement.o
            [OHOS INFO] [8/253] gcc cross compiler obj/base/hiviewdfx/hievent_lite/frameworks/libhievent_lite.hiview_output_event.o
            [OHOS INFO] [9/253] gcc cross compiler obj/base/hiviewdfx/hiview_lite/libhiview_lite.hiview_cache.o
            [OHOS INFO] [10/253] gcc cross compiler obj/base/hiviewdfx/hilog_lite/command/libhilog_lite_command.hilog_lite_command.o
            [OHOS INFO] [11/253] STAMP obj/base/startup/syspara_lite/frameworks/token/token_notes.stamp
            [OHOS INFO] [12/253] AR libs/libhilog_lite_command.a
            [OHOS INFO] [13/253] gcc cross compiler obj/base/hiviewdfx/hiview_lite/libhiview_lite.hiview_config.o
            [OHOS INFO] [14/253] STAMP obj/build/lite/ndk.stamp
            [OHOS INFO] [15/253] gcc cross compiler obj/base/startup/syspara_lite/frameworks/parameter/src/param_impl_hal/libsysparam.param_impl_hal.o
            [OHOS INFO] [16/253] gcc cross compiler obj/base/startup/syspara_lite/frameworks/token/src/token_impl_hal/libtoken_static.token.o
            [OHOS INFO] [17/253] gcc cross compiler obj/base/hiviewdfx/hiview_lite/libhiview_lite.hiview_file.o
            [OHOS INFO] [18/253] gcc cross compiler obj/base/hiviewdfx/hilog_lite/frameworks/mini/libhilog_lite.hiview_output_log.o
            [OHOS INFO] [19/253] gcc cross compiler obj/base/hiviewdfx/hiview_lite/libhiview_lite.hiview_util.o
            [OHOS INFO] [20/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/auth_info/libhichainsdk.add_auth_info.o
            [OHOS INFO] [21/253] AR libs/libhiview_lite.a
            [OHOS INFO] [22/253] AR libs/libhilog_lite.a
            [OHOS INFO] [23/253] gcc cross compiler obj/base/startup/syspara_lite/frameworks/parameter/src/libsysparam.parameter_common.o
            [OHOS INFO] [24/253] STAMP obj/base/hiviewdfx/hilog_lite/frameworks/mini/hilog_lite_ndk.stamp
            [OHOS INFO] [25/253] AR libs/libhievent_lite.a
            [OHOS INFO] [26/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/auth_info/libhichainsdk.add_auth_info_client.o
            [OHOS INFO] [27/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/auth_info/libhichainsdk.auth_info.o
            [OHOS INFO] [28/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/auth_info/libhichainsdk.remove_auth_info_client.o
            [OHOS INFO] [29/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/auth_info/libhichainsdk.exchange_auth_info.o
            [OHOS INFO] [30/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.key_agreement_client.o
            [OHOS INFO] [31/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/auth_info/libhichainsdk.exchange_auth_info_client.o
            [OHOS INFO] [32/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/json/libhichainsdk.commonutil.o
            [OHOS INFO] [33/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.key_agreement_server.o
            [OHOS INFO] [34/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/json/libhichainsdk.jsonutil.o
            [OHOS INFO] [35/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.sec_clone_server.o
            [OHOS INFO] [36/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.sts_client.o
            [OHOS INFO] [37/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.pake_server.o
            [OHOS INFO] [38/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.pake_client.o
            [OHOS INFO] [39/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/log/libhichainsdk.log.o
            [OHOS INFO] [40/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.add_auth_info_request.o
            [OHOS INFO] [41/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/libhichainsdk.hichain.o
            [OHOS INFO] [42/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.add_auth_info_data.o
            [OHOS INFO] [43/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.add_auth_info_response.o
            [OHOS INFO] [44/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/schedule/libhichainsdk.build_object.o
            [OHOS INFO] [45/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.auth_ack_request.o
            [OHOS INFO] [46/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/huks_adapter/libhichainsdk.huks_adapter.o
            [OHOS INFO] [47/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.sts_server.o
            [OHOS INFO] [48/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.auth_start_response.o
            [OHOS INFO] [49/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.auth_ack_response.o
            [OHOS INFO] [50/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/schedule/libhichainsdk.distribution.o
            [OHOS INFO] [51/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.inform_message.o
            [OHOS INFO] [52/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.auth_start_request.o
            [OHOS INFO] [53/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.exchange_auth_data.o
            [OHOS INFO] [54/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.exchange_request.o
            [OHOS INFO] [55/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.import_add_auth_data.o
            [OHOS INFO] [56/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.exchange_response.o
            [OHOS INFO] [57/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.pake_client_confirm.o
            [OHOS INFO] [58/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.parsedata.o
            [OHOS INFO] [59/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.key_agreement_version.o
            [OHOS INFO] [60/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.pake_request.o
            [OHOS INFO] [61/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.rmv_auth_info_data.o
            [OHOS INFO] [62/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.pake_server_confirm.o
            [OHOS INFO] [63/253] STAMP obj/base/security/huks/frameworks/huks_lite/huks_sdk.stamp
            [OHOS INFO] [64/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.rmv_auth_info_response.o
            [OHOS INFO] [65/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.rmv_auth_info_request.o
            [OHOS INFO] [66/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.pake_response.o
            [OHOS INFO] [67/253] STAMP obj/device/xradio/xr806/xr806.stamp
            [OHOS INFO] [68/253] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.sec_clone_data.o
            [OHOS INFO] [69/253] AR libs/libhichainsdk.a
            [OHOS INFO] [70/253] STAMP obj/base/security/deviceauth/frameworks/deviceauth_lite/hichainsdk.stamp
            [OHOS INFO] [71/253] gcc cross compiler obj/base/startup/bootstrap_lite/services/source/libbootstrap.bootstrap_service.o
            [OHOS INFO] [72/253] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/adapter/cmsis/libsamgr_adapter.memory_adapter.o
            [OHOS INFO] [73/253] gcc cross compiler obj/base/startup/bootstrap_lite/services/source/libbootstrap.system_init.o
            [OHOS INFO] [74/253] AR libs/libbootstrap.a
            [OHOS INFO] [75/253] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.iot_watchdog.o
            [OHOS INFO] [76/253] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.lowpower.o
            [OHOS INFO] [77/253] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.reset.o
            [OHOS INFO] [78/253] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.iot_uart.o
            [OHOS INFO] [79/253] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_lowpower.o
            [OHOS INFO] [80/253] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_flash.o
            [OHOS INFO] [81/253] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_reset.o
            [OHOS INFO] [82/253] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_i2c.o
            [OHOS INFO] [83/253] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_gpio.o
            [OHOS INFO] [84/253] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_pwm.o
            [OHOS INFO] [85/253] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_watchdog.o
            [OHOS INFO] [86/253] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_uart.o
            [OHOS INFO] [87/253] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_mem.o
            [OHOS INFO] [88/253] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm.o
            [OHOS INFO] [89/253] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.command.o
            [OHOS INFO] [90/253] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.main.o
            [OHOS INFO] [91/253] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_net_ap.o
            [OHOS INFO] [92/253] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_net_sta.o
            [OHOS INFO] [93/253] AR libs/libapp_console.a
            [OHOS INFO] [94/253] gcc cross compiler obj/device/xradio/xr806/adapter/hals/communication/wifi_lite/wifiservice/source/libwifiservice.wifi_device_util.o
            [OHOS INFO] [95/253] gcc cross compiler obj/device/xradio/xr806/adapter/hals/communication/wifi_lite/wifiservice/source/libwifiservice.wifi_hotspot.o
            [OHOS INFO] [96/253] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.iot_flash.o
            [OHOS INFO] [97/253] gcc cross compiler obj/device/xradio/xr806/adapter/hals/communication/wifi_lite/wifiservice/source/libwifiservice.wifi_device.o
            [OHOS INFO] [98/253] gcc cross compiler obj/device/xradio/xr806/adapter/hals/communication/blue_lite/src/libohos_bt_gatt.ohos_bt_gap.o
            [OHOS INFO] [99/253] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.iot_gpio.o
            [OHOS INFO] [100/253] gcc cross compiler obj/device/xradio/xr806/adapter/hals/communication/blue_lite/src/libohos_bt_gatt.ohos_bt_gatt.o
            [OHOS INFO] [101/253] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.iot_i2c.o
            [OHOS INFO] [102/253] AR libs/libohos_bt_gatt.a
            [OHOS INFO] [103/253] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.iot_pwm.o
            [OHOS INFO] [104/253] AR libs/libhal_iothardware.a
            [OHOS INFO] [105/253] STAMP obj/base/iot_hardware/peripheral/iothardware.stamp
            [OHOS INFO] [106/253] STAMP obj/base/iot_hardware/peripheral/iothardware_ndk.stamp
            [OHOS INFO] [107/253] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_queue.o
            [OHOS INFO] [108/253] gcc cross compiler obj/device/xradio/xr806/adapter/hello_demo/src/libapp_hello.main.o
            [OHOS INFO] [109/253] COPY ../../../foundation/distributedschedule/samgr_lite/config/system_capability.json obj/foundation/distributedschedule/samgr_lite/config/system_capability.json
            [OHOS INFO] [110/253] gcc cross compiler obj/device/xradio/xr806/adapter/hals/utils/file/src/libhal_file_static.hal_file.o
            [OHOS INFO] [111/253] AR libs/libapp_hello.a
            [OHOS INFO] [112/253] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_mutex.o
            [OHOS INFO] [113/253] STAMP obj/foundation/distributedschedule/samgr_lite/ConfigFiles.stamp
            [OHOS INFO] [114/253] gcc cross compiler obj/device/xradio/xr806/adapter/hals/communication/wifi_lite/xr_wifi/libxr_wifi_adapter.xr_wifi_adapter.o
            [OHOS INFO] [115/253] AR libs/libhal_file_static.a
            [OHOS INFO] [116/253] AR libs/libxr_wifi_adapter.a
            [OHOS INFO] [117/253] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_errno.o
            [OHOS INFO] [118/253] STAMP obj/device/xradio/xr806/adapter/hals/adapter.stamp
            [OHOS INFO] [119/253] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_debug.o
            [OHOS INFO] [120/253] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_semaphore.o
            [OHOS INFO] [121/253] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_freertos.o
            [OHOS INFO] [122/253] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/registry/libsamgr.service_registry.o
            [OHOS INFO] [123/253] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_time.o
            [OHOS INFO] [124/253] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_thread.o
            [OHOS INFO] [125/253] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_timer.o
            [OHOS INFO] [126/253] AR libs/libliteos_glue.a
            [OHOS INFO] [127/253] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/communication/broadcast/source/libbroadcast.broadcast_service.o
            [OHOS INFO] [128/253] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/source/libsamgr_source.feature.o
            [OHOS INFO] [129/253] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/communication/broadcast/source/libbroadcast.pub_sub_feature.o
            [OHOS INFO] [130/253] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/source/libsamgr_source.iunknown.o
            [OHOS INFO] [131/253] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/communication/broadcast/source/libbroadcast.pub_sub_implement.o
            [OHOS INFO] [132/253] AR libs/libbroadcast.a
            [OHOS INFO] [133/253] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/adapter/cmsis/libsamgr_adapter.queue_adapter.o
            [OHOS INFO] [134/253] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/adapter/cmsis/libsamgr_adapter.thread_adapter.o
            [OHOS INFO] [135/253] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/adapter/cmsis/libsamgr_adapter.time_adapter.o
            [OHOS INFO] [136/253] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/source/libsamgr_source.message.o
            [OHOS INFO] [137/253] AR libs/libsamgr_adapter.a
            [OHOS INFO] [138/253] gcc cross compiler obj/kernel/liteos_m/components/backtrace/libbacktrace.los_backtrace.o
            [OHOS INFO] [139/253] AR libs/libbacktrace.a
            [OHOS INFO] [140/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.fwscanf_s.o
            [OHOS INFO] [141/253] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/source/libsamgr_source.common.o
            [OHOS INFO] [142/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.gets_s.o
            [OHOS INFO] [143/253] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/source/libsamgr.samgr_lite.o
            [OHOS INFO] [144/253] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/source/libsamgr_source.service.o
            [OHOS INFO] [145/253] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/source/libsamgr_source.task_manager.o
            [OHOS INFO] [146/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.memmove_s.o
            [OHOS INFO] [147/253] AR libs/libsamgr_source.a
            [OHOS INFO] [148/253] AR libs/libsamgr.a
            [OHOS INFO] [149/253] STAMP obj/foundation/distributedschedule/samgr_lite/samgr.stamp
            [OHOS INFO] [150/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.fscanf_s.o
            [OHOS INFO] [151/253] gcc cross compiler obj/kernel/liteos_m/kal/libkal.kal.o
            [OHOS INFO] [152/253] STAMP obj/foundation/distributedschedule/samgr_lite/samgr_lite_ndk.stamp
            [OHOS INFO] [153/253] gcc cross compiler obj/kernel/liteos_m/components/exchook/libexchook.los_exchook.o
            [OHOS INFO] [154/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.scanf_s.o
            [OHOS INFO] [155/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.securecutil.o
            [OHOS INFO] [156/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.memset_s.o
            [OHOS INFO] [157/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.snprintf_s.o
            [OHOS INFO] [158/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.sprintf_s.o
            [OHOS INFO] [159/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.memcpy_s.o
            [OHOS INFO] [160/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.sscanf_s.o
            [OHOS INFO] [161/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.strcat_s.o
            [OHOS INFO] [162/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.strncat_s.o
            [OHOS INFO] [163/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.secureinput_a.o
            [OHOS INFO] [164/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.secureprintoutput_a.o
            [OHOS INFO] [165/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.strncpy_s.o
            [OHOS INFO] [166/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.strcpy_s.o
            [OHOS INFO] [167/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.swprintf_s.o
            [OHOS INFO] [168/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.swscanf_s.o
            [OHOS INFO] [169/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.strtok_s.o
            [OHOS INFO] [170/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.secureprintoutput_w.o
            [OHOS INFO] [171/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vfwscanf_s.o
            [OHOS INFO] [172/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vfscanf_s.o
            [OHOS INFO] [173/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vsnprintf_s.o
            [OHOS INFO] [174/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vscanf_s.o
            [OHOS INFO] [175/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vsprintf_s.o
            [OHOS INFO] [176/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vswprintf_s.o
            [OHOS INFO] [177/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vsscanf_s.o
            [OHOS INFO] [178/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.secureinput_w.o
            [OHOS INFO] [179/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vswscanf_s.o
            [OHOS INFO] [180/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vwscanf_s.o
            [OHOS INFO] [181/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wcscpy_s.o
            [OHOS INFO] [182/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wcscat_s.o
            [OHOS INFO] [183/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wcsncat_s.o
            [OHOS INFO] [184/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wcstok_s.o
            [OHOS INFO] [185/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wcsncpy_s.o
            [OHOS INFO] [186/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wmemmove_s.o
            [OHOS INFO] [187/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wmemcpy_s.o
            [OHOS INFO] [188/253] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wscanf_s.o
            [OHOS INFO] [189/253] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.errno.o
            [OHOS INFO] [190/253] gcc cross compiler obj/kernel/liteos_m/components/cpup/libcpup.los_cpup.o
            [OHOS INFO] [191/253] AR libs/libsec.a
            [OHOS INFO] [192/253] AR libs/libcpup.a
            [OHOS INFO] [193/253] AR libs/libwifiservice.a
            [OHOS INFO] [194/253] STAMP obj/foundation/communication/wifi_lite/wifi.stamp
            [OHOS INFO] [195/253] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.libc.o
            [OHOS INFO] [196/253] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_init.o
            [OHOS INFO] [197/253] gcc cross compiler obj/kernel/liteos_m/components/exchook/libexchook.los_exc_info.o
            [OHOS INFO] [198/253] AR libs/libexchook.a
            [OHOS INFO] [199/253] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.malloc.o
            [OHOS INFO] [200/253] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_event.o
            [OHOS INFO] [201/253] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.pthread.o
            [OHOS INFO] [202/253] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.pthread_attr.o
            [OHOS INFO] [203/253] gcc cross compiler obj/utils/native/lite/kv_store/src/kvstore_common/libutils_kv_store.kvstore_common.o
            [OHOS INFO] [204/253] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_mux.o
            [OHOS INFO] [205/253] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.pthread_mutex.o
            [OHOS INFO] [206/253] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.semaphore.o
            [OHOS INFO] [207/253] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_sem.o
            [OHOS INFO] [208/253] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_swtmr.o
            [OHOS INFO] [209/253] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_queue.o
            [OHOS INFO] [210/253] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.time.o
            [OHOS INFO] [211/253] AR libs/libposix.a
            [OHOS INFO] [212/253] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_tick.o
            [OHOS INFO] [213/253] gcc cross compiler obj/kernel/liteos_m/kal/cmsis/libcmsis.cmsis_liteos.o
            [OHOS INFO] [214/253] AR libs/libcmsis.a
            [OHOS INFO] [215/253] AR libs/libkal.a
            [OHOS INFO] [216/253] gcc cross compiler obj/kernel/liteos_m/kernel/arch/arm/cortex-m33/gcc/libarch.los_dispatch.o
            [OHOS INFO] [217/253] gcc cross compiler obj/kernel/liteos_m/kernel/arch/arm/cortex-m33/gcc/libarch.los_context.o
            [OHOS INFO] [218/253] gcc cross compiler obj/kernel/liteos_m/kernel/arch/arm/cortex-m33/gcc/libarch.los_exc.o
            [OHOS INFO] [219/253] gcc cross compiler obj/kernel/liteos_m/kernel/src/mm/libkernel.los_membox.o
            [OHOS INFO] [220/253] gcc cross compiler obj/kernel/liteos_m/utils/libutils.los_error.o
            [OHOS INFO] [221/253] gcc cross compiler obj/kernel/liteos_m/utils/libutils.los_debug.o
            [OHOS INFO] [222/253] AR libs/libutils.a
            [OHOS INFO] [223/253] gcc cross compiler obj/kernel/liteos_m/kernel/arch/arm/cortex-m33/gcc/libarch.los_timer.o
            [OHOS INFO] [224/253] STAMP obj/vendor/xradio/xr806/xr806.stamp
            [OHOS INFO] [225/253] gcc cross compiler obj/utils/native/lite/file/src/file_impl_hal/libnative_file.file.o
            [OHOS INFO] [226/253] AR libs/libnative_file.a
            [OHOS INFO] [227/253] gcc cross compiler obj/kernel/liteos_m/kernel/arch/arm/cortex-m33/gcc/libarch.los_interrupt.o
            [OHOS INFO] [228/253] STAMP obj/utils/native/lite/file/file.stamp
            [OHOS INFO] [229/253] gcc cross compiler obj/utils/native/lite/kv_store/src/kvstore_impl_hal/libutils_kv_store.kv_store.o
            [OHOS INFO] [230/253] AR libs/libarch.a
            [OHOS INFO] [231/253] gcc cross compiler obj/utils/native/lite/os_dump/libdump_static.dump_syspara.o
            [OHOS INFO] [232/253] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_task.o
            [OHOS INFO] [233/253] AR libs/libutils_kv_store.a
            [OHOS INFO] [234/253] STAMP obj/utils/native/lite/kv_store/kv_store.stamp
            [OHOS INFO] [235/253] gcc cross compiler obj/vendor/xradio/xr806/hals/utils/token/libhal_token_static.hal_token.o
            [OHOS INFO] [236/253] gcc cross compiler obj/kernel/liteos_m/kernel/src/mm/libkernel.los_memory.o
            [OHOS INFO] [237/253] AR libs/libkernel.a
            [OHOS INFO] [238/253] AR libs/libhal_token_static.a
            [OHOS INFO] [239/253] STAMP obj/kernel/liteos_m/kernel.stamp
            [OHOS INFO] [240/253] AR libs/libtoken_static.a
            [OHOS INFO] [241/253] gcc cross compiler obj/vendor/xradio/xr806/hals/utils/sys_param/libhal_sysparam.hal_sys_param.o
            [OHOS INFO] [242/253] STAMP obj/base/startup/syspara_lite/frameworks/token/token.stamp
            [OHOS INFO] [243/253] AR libs/libhal_sysparam.a
            [OHOS INFO] [244/253] AR libs/libsysparam.a
            [OHOS INFO] [245/253] STAMP obj/base/startup/syspara_lite/frameworks/parameter/parameter.stamp
            [OHOS INFO] [246/253] STAMP obj/base/startup/syspara_lite/frameworks/parameter/parameter_notes.stamp
            [OHOS INFO] [247/253] AR libs/libdump_static.a
            [OHOS INFO] [248/253] STAMP obj/utils/native/lite/os_dump/utils_os_dump.stamp
            [OHOS INFO] [249/253] STAMP obj/build/lite/ohos.stamp
            [OHOS INFO] [250/253] ACTION //build/lite:gen_rootfs(//build/lite/toolchain:arm-none-eabi-gcc)
            [OHOS INFO] [251/253] STAMP obj/build/lite/gen_rootfs.stamp
            [OHOS INFO] [252/253] ACTION //device/xradio/xr806:libSDK(//build/lite/toolchain:arm-none-eabi-gcc)
            [OHOS INFO] [253/253] STAMP obj/device/xradio/xr806/libSDK.stamp
            [OHOS INFO] /home/make/xr806_openharmony/vendor/xradio/xr806/fs.yml not found, stop packing fs. If the product does not need to be packaged, ignore it.
            [OHOS INFO] wifi_skylark build success
            [OHOS INFO] cost time: 0:00:14
            • I
              @hu_710774265 1、检查一下BUILD.gn修改后是否保存。2、检查BUILD.gn是否把hello_demo的.c文件包含进编译,例如故意在main.c里面打错别字,也可以在map文件里面检查。
              • I
                @hu_710774265 在 hello 没有如约出现 怎么办? 中说:
                从编译日志来看,应该是成功编译了,而且hello_demo也编译进去了,检查一下镜像的生成时间,看看是不是下载了旧的img文件。
                  这个问题有点奇怪了
                  Wifi Test Start
                  console init success 2 set is ok
                  hello world!
                  hello world!
                  hello world!
                  hello world!
                  我还原了
                      deps += [
                        #"adapter/hello_demo:app_hello",
                  然后对
                  /home/make/xr806_openharmony/device/xradio/xr806/xr_skylark/ohos.mk
                  增加了行
                  OHOSSOURCE = -Wl,--whole-archive
                  OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libapp_console.a
                  这行我加的OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libapp_hello.a
                  OHOSSOURCE += -Wl,--no-whole-archive
                  现在 app_hello app_WlanTest
                  都进来了????
                  app_peripheral 哪去了??????
                  J 1 条回复 最后回复 回复 引用 分享 1
                    另外教程里面 环境配置 没有具体说明怎么配置怎么用
                    我就只在命令行进行了
                    拉的repo 位置
                    如果没有repo工具,可通过下面的git命令获取repo。
                    git clone https://gerrit-googlesource.lug.ustc.edu.cn/git-repo
                    拉代码
                    mkdir xr806_openharmony
                    cd xr806_openharmony
                    repo init -u https://gitee.com/openharmony-sig/manifest.git -b OpenHarmony_1.0.1_release --no-repo-verify -m devboard_xr806.xml
                    repo sync -c
                    repo forall -c 'git lfs pull' #下载部分大容量二进制文件
                      最终发现
                      libcopy.py
                      处理了ohos.mk
                      估计又是 py脚本的锅。
                        [OHOS ERROR] [266/267] ACTION //device/xradio/xr806:libSDK(//build/lite/toolchain:arm-none-eabi-gcc)
                        [OHOS ERROR] FAILED: obj/device/xradio/xr806/libSDK_build_ext_components.txt
                        [OHOS ERROR] /usr/bin/python3 ../../../build/lite/build_ext_components.py --path=../../../device/xradio/xr806 --command=./build.sh\ /home/make/xr806_openharmony/out/xr806/wifi_skylark --target_dir=/home/make/xr806_openharmony/out/xr806/wifi_skylark/obj/device/xradio/xr806/build.log --out_dir=/home/make/xr806_openharmony/out/xr806/wifi_skylark/error.log
                        [OHOS ERROR] Traceback (most recent call last):
                        [OHOS ERROR] File "/home/make/xr806_openharmony/device/xradio/xr806/libcopy.py", line 47, in <module>
                        [OHOS ERROR] vendorf = open('.{0}/../../../vendor/xradio/xr806/config.json'.format(pwd),'r')
                        [OHOS ERROR] FileNotFoundError: [Errno 2] No such file or directory: './home/make/xr806_openharmony/device/xradio/xr806/../../../vendor/xradio/xr806/config.json'
                        [OHOS ERROR] make[1]: 进入目录“/home/make/xr806_openharmony/device/xradio/xr806/xr_skylark/project/demo/wlan_ble_demo/gcc”
                        [OHOS ERROR] ../../../../project/project.mk:4: ../../../../ohos.mk: 没有那个文件或目录
                        [OHOS ERROR] make[1]: *** 没有规则可制作目标“../../../../ohos.mk”。 停止。
                        [OHOS ERROR] make[1]: 离开目录“/home/make/xr806_openharmony/device/xradio/xr806/xr_skylark/project/demo/wlan_ble_demo/gcc”
                        [OHOS ERROR] make: *** [Makefile:164:build] 错误 2
                        [OHOS ERROR] you can check build log in /home/make/xr806_openharmony/out/xr806/wifi_skylark/build.log
                        [OHOS ERROR] command: "/home/make/xr806_openharmony/prebuilts/build-tools/linux-x86/bin/ninja -w dupbuild=warn -C /home/make/xr806_openharmony/out/xr806/wifi_skylark" failed
                        [OHOS ERROR] return code: 1
                        [OHOS ERROR] execution path: /home/make/xr806_openharmony
                          当我尝试修复libcopy.py后
                          hb build -f
                          ohos.mk 内容
                          # Rules for ohos library
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libapp_peripheral.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libapp_WlanTest.a
                          OHOSSOURCE += -Wl,--start-group
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libnative_file.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libutils_kv_store.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libohos_bt_gatt.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libbroadcast.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libarch.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libhilog_lite_command.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libwifiservice.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libhal_iothardware.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libsamgr_source.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libtoken_static.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libhal_sysparam.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libdump_static.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libcpup.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libcmsis.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libxr_wifi_adapter.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libutils.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libsamgr.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libsysparam.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libliteos_glue.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libhichainsdk.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libhievent_lite.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libposix.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libkal.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libhal_file_static.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libbacktrace.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libkernel.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libbootstrap.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libhilog_lite.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libsamgr_adapter.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libsec.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libexchook.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libhiview_lite.a
                          OHOSSOURCE += $(ROOT_PATH)/lib/ohos/libhal_token_static.a
                          OHOSSOURCE += -Wl,--end-group
                          # end of file
                          日志
                          [OHOS INFO] ohos_build_compiler_specified="gcc" product_path="/home/make/xr806_openharmony/vendor/xradio/xr806" device_path="/home/make/xr806_openharmony/device/xradio/xr806/liteos_m" ohos_kernel_type="liteos_m" enable_ohos_kernel_liteos_m_fs = false enable_ohos_kernel_liteos_m_cppsupport = false disable_huks_binary = false disable_authenticate = false ohos_build_type="debug" ohos_build_time="1639355514891" ohos_build_datetime="2021-12-13 16:31:54" ohos_full_compile=true
                          [OHOS INFO]
                          [OHOS INFO]
                          [OHOS INFO]
                          [OHOS INFO] Done. Made 64 targets from 65 files in 356ms
                          [OHOS INFO] [1/267] STAMP obj/applications/sample/wifi-iot/app/startup/startup.stamp
                          [OHOS INFO] [2/267] STAMP obj/applications/sample/wifi-iot/app/app.stamp
                          [OHOS INFO] [3/267] gcc cross compiler obj/base/hiviewdfx/hilog_lite/frameworks/mini/libhilog_lite.hiview_log_limit.o
                          [OHOS INFO] [4/267] gcc cross compiler obj/base/hiviewdfx/hievent_lite/frameworks/libhievent_lite.hiview_event.o
                          [OHOS INFO] [5/267] gcc cross compiler obj/base/hiviewdfx/hiview_lite/libhiview_lite.hiview_cache.o
                          [OHOS INFO] [6/267] gcc cross compiler obj/base/hiviewdfx/hilog_lite/command/libhilog_lite_command.hilog_lite_command.o
                          [OHOS INFO] [7/267] AR libs/libhilog_lite_command.a
                          [OHOS INFO] [8/267] gcc cross compiler obj/base/hiviewdfx/hiview_lite/libhiview_lite.hiview_service.o
                          [OHOS INFO] [9/267] gcc cross compiler obj/base/hiviewdfx/hilog_lite/frameworks/mini/libhilog_lite.hiview_log.o
                          [OHOS INFO] [10/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.key_agreement.o
                          [OHOS INFO] [11/267] gcc cross compiler obj/base/hiviewdfx/hievent_lite/frameworks/libhievent_lite.hiview_output_event.o
                          [OHOS INFO] [12/267] STAMP obj/base/startup/syspara_lite/frameworks/token/token_notes.stamp
                          [OHOS INFO] [13/267] gcc cross compiler obj/base/hiviewdfx/hiview_lite/libhiview_lite.hiview_config.o
                          [OHOS INFO] [14/267] STAMP obj/build/lite/ndk.stamp
                          [OHOS INFO] [15/267] gcc cross compiler obj/base/hiviewdfx/hiview_lite/libhiview_lite.hiview_file.o
                          [OHOS INFO] [16/267] gcc cross compiler obj/base/startup/syspara_lite/frameworks/token/src/token_impl_hal/libtoken_static.token.o
                          [OHOS INFO] [17/267] gcc cross compiler obj/base/hiviewdfx/hiview_lite/libhiview_lite.hiview_util.o
                          [OHOS INFO] [18/267] gcc cross compiler obj/base/startup/syspara_lite/frameworks/parameter/src/param_impl_hal/libsysparam.param_impl_hal.o
                          [OHOS INFO] [19/267] AR libs/libhiview_lite.a
                          [OHOS INFO] [20/267] AR libs/libhievent_lite.a
                          [OHOS INFO] [21/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/auth_info/libhichainsdk.add_auth_info_client.o
                          [OHOS INFO] [22/267] gcc cross compiler obj/base/hiviewdfx/hilog_lite/frameworks/mini/libhilog_lite.hiview_output_log.o
                          [OHOS INFO] [23/267] AR libs/libhilog_lite.a
                          [OHOS INFO] [24/267] STAMP obj/base/hiviewdfx/hilog_lite/frameworks/mini/hilog_lite_ndk.stamp
                          [OHOS INFO] [25/267] gcc cross compiler obj/base/startup/syspara_lite/frameworks/parameter/src/libsysparam.parameter_common.o
                          [OHOS INFO] [26/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/auth_info/libhichainsdk.add_auth_info.o
                          [OHOS INFO] [27/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/auth_info/libhichainsdk.auth_info.o
                          [OHOS INFO] [28/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/auth_info/libhichainsdk.remove_auth_info_client.o
                          [OHOS INFO] [29/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/auth_info/libhichainsdk.exchange_auth_info_client.o
                          [OHOS INFO] [30/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/auth_info/libhichainsdk.exchange_auth_info.o
                          [OHOS INFO] [31/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/json/libhichainsdk.commonutil.o
                          [OHOS INFO] [32/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.key_agreement_client.o
                          [OHOS INFO] [33/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/json/libhichainsdk.jsonutil.o
                          [OHOS INFO] [34/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.key_agreement_server.o
                          [OHOS INFO] [35/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.sec_clone_server.o
                          [OHOS INFO] [36/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.sts_client.o
                          [OHOS INFO] [37/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.pake_client.o
                          [OHOS INFO] [38/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/libhichainsdk.hichain.o
                          [OHOS INFO] [39/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.pake_server.o
                          [OHOS INFO] [40/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.add_auth_info_request.o
                          [OHOS INFO] [41/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/log/libhichainsdk.log.o
                          [OHOS INFO] [42/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/schedule/libhichainsdk.build_object.o
                          [OHOS INFO] [43/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.add_auth_info_data.o
                          [OHOS INFO] [44/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.add_auth_info_response.o
                          [OHOS INFO] [45/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/huks_adapter/libhichainsdk.huks_adapter.o
                          [OHOS INFO] [46/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/key_agreement/libhichainsdk.sts_server.o
                          [OHOS INFO] [47/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/schedule/libhichainsdk.distribution.o
                          [OHOS INFO] [48/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.auth_ack_response.o
                          [OHOS INFO] [49/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.auth_ack_request.o
                          [OHOS INFO] [50/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.auth_start_response.o
                          [OHOS INFO] [51/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.exchange_auth_data.o
                          [OHOS INFO] [52/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.auth_start_request.o
                          [OHOS INFO] [53/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.inform_message.o
                          [OHOS INFO] [54/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.exchange_request.o
                          [OHOS INFO] [55/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.import_add_auth_data.o
                          [OHOS INFO] [56/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.key_agreement_version.o
                          [OHOS INFO] [57/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.exchange_response.o
                          [OHOS INFO] [58/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.pake_client_confirm.o
                          [OHOS INFO] [59/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.pake_request.o
                          [OHOS INFO] [60/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.rmv_auth_info_data.o
                          [OHOS INFO] [61/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.parsedata.o
                          [OHOS INFO] [62/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.rmv_auth_info_request.o
                          [OHOS INFO] [63/267] STAMP obj/base/security/huks/frameworks/huks_lite/huks_sdk.stamp
                          [OHOS INFO] [64/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.pake_response.o
                          [OHOS INFO] [65/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.pake_server_confirm.o
                          [OHOS INFO] [66/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.rmv_auth_info_response.o
                          [OHOS INFO] [67/267] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_time.o
                          [OHOS INFO] [68/267] gcc cross compiler obj/base/startup/bootstrap_lite/services/source/libbootstrap.bootstrap_service.o
                          [OHOS INFO] [69/267] gcc cross compiler obj/base/security/deviceauth/frameworks/deviceauth_lite/source/struct/libhichainsdk.sec_clone_data.o
                          [OHOS INFO] [70/267] gcc cross compiler obj/base/startup/bootstrap_lite/services/source/libbootstrap.system_init.o
                          [OHOS INFO] [71/267] STAMP obj/device/xradio/xr806/xr806.stamp
                          [OHOS INFO] [72/267] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_thread.o
                          [OHOS INFO] [73/267] AR libs/libhichainsdk.a
                          [OHOS INFO] [74/267] AR libs/libbootstrap.a
                          [OHOS INFO] [75/267] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_timer.o
                          [OHOS INFO] [76/267] STAMP obj/base/security/deviceauth/frameworks/deviceauth_lite/hichainsdk.stamp
                          [OHOS INFO] [77/267] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.iot_uart.o
                          [OHOS INFO] [78/267] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.lowpower.o
                          [OHOS INFO] [79/267] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.iot_watchdog.o
                          [OHOS INFO] [80/267] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.reset.o
                          [OHOS INFO] [81/267] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_flash.o
                          [OHOS INFO] [82/267] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_reset.o
                          [OHOS INFO] [83/267] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_lowpower.o
                          [OHOS INFO] [84/267] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_gpio.o
                          [OHOS INFO] [85/267] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_i2c.o
                          [OHOS INFO] [86/267] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_pwm.o
                          [OHOS INFO] [87/267] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_uart.o
                          [OHOS INFO] [88/267] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_iot_watchdog.o
                          [OHOS INFO] [89/267] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_mem.o
                          [OHOS INFO] [90/267] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.main.o
                          [OHOS INFO] [91/267] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm.o
                          [OHOS INFO] [92/267] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.command.o
                          [OHOS INFO] [93/267] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_net_ap.o
                          [OHOS INFO] [94/267] gcc cross compiler obj/device/xradio/xr806/adapter/console/src/libapp_console.cmd_hm_net_sta.o
                          [OHOS INFO] [95/267] AR libs/libapp_console.a
                          [OHOS INFO] [96/267] gcc cross compiler obj/device/xradio/xr806/adapter/hals/communication/wifi_lite/wifiservice/source/libwifiservice.wifi_device_util.o
                          [OHOS INFO] [97/267] gcc cross compiler obj/device/xradio/xr806/adapter/hals/communication/wifi_lite/wifiservice/source/libwifiservice.wifi_hotspot.o
                          [OHOS INFO] [98/267] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.iot_flash.o
                          [OHOS INFO] [99/267] gcc cross compiler obj/device/xradio/xr806/adapter/hals/communication/wifi_lite/wifiservice/source/libwifiservice.wifi_device.o
                          [OHOS INFO] [100/267] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.iot_gpio.o
                          [OHOS INFO] [101/267] gcc cross compiler obj/device/xradio/xr806/adapter/hals/communication/blue_lite/src/libohos_bt_gatt.ohos_bt_gatt.o
                          [OHOS INFO] [102/267] gcc cross compiler obj/device/xradio/xr806/adapter/hals/communication/blue_lite/src/libohos_bt_gatt.ohos_bt_gap.o
                          [OHOS INFO] [103/267] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.iot_i2c.o
                          [OHOS INFO] [104/267] AR libs/libohos_bt_gatt.a
                          [OHOS INFO] [105/267] gcc cross compiler obj/device/xradio/xr806/ohosdemo/iot_peripheral/src/libapp_peripheral.test_i2c.o
                          [OHOS INFO] [106/267] gcc cross compiler obj/device/xradio/xr806/adapter/hals/communication/wifi_lite/xr_wifi/libxr_wifi_adapter.xr_wifi_adapter.o
                          [OHOS INFO] [107/267] AR libs/libxr_wifi_adapter.a
                          [OHOS INFO] [108/267] gcc cross compiler obj/device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite/libhal_iothardware.iot_pwm.o
                          [OHOS INFO] [109/267] gcc cross compiler obj/device/xradio/xr806/ohosdemo/iot_peripheral/src/libapp_peripheral.test_lowpower.o
                          [OHOS INFO] [110/267] AR libs/libhal_iothardware.a
                          [OHOS INFO] [111/267] gcc cross compiler obj/device/xradio/xr806/ohosdemo/hello_demo/src/libapp_hello.main.o
                          [OHOS INFO] [112/267] STAMP obj/base/iot_hardware/peripheral/iothardware.stamp
                          [OHOS INFO] [113/267] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_errno.o
                          [OHOS INFO] [114/267] STAMP obj/base/iot_hardware/peripheral/iothardware_ndk.stamp
                          [OHOS INFO] [115/267] STAMP obj/device/xradio/xr806/adapter/hals/adapter.stamp
                          [OHOS INFO] [116/267] AR libs/libapp_hello.a
                          [OHOS INFO] [117/267] gcc cross compiler obj/device/xradio/xr806/ohosdemo/wlan_demo/libapp_WlanTest.main.o
                          [OHOS INFO] [118/267] gcc cross compiler obj/device/xradio/xr806/adapter/hals/utils/file/src/libhal_file_static.hal_file.o
                          [OHOS INFO] [119/267] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_semaphore.o
                          [OHOS INFO] [120/267] AR libs/libhal_file_static.a
                          [OHOS INFO] [121/267] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_mutex.o
                          [OHOS INFO] [122/267] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_queue.o
                          [OHOS INFO] [123/267] gcc cross compiler obj/device/xradio/xr806/ohosdemo/iot_peripheral/src/libapp_peripheral.test_flash.o
                          [OHOS INFO] [124/267] gcc cross compiler obj/device/xradio/xr806/ohosdemo/iot_peripheral/src/libapp_peripheral.main.o
                          [OHOS INFO] [125/267] gcc cross compiler obj/device/xradio/xr806/ohosdemo/iot_peripheral/src/libapp_peripheral.test_gpio.o
                          [OHOS INFO] [126/267] gcc cross compiler obj/device/xradio/xr806/ohosdemo/iot_peripheral/src/libapp_peripheral.test_reset.o
                          [OHOS INFO] [127/267] gcc cross compiler obj/utils/native/lite/kv_store/src/kvstore_impl_hal/libutils_kv_store.kv_store.o
                          [OHOS INFO] [128/267] gcc cross compiler obj/device/xradio/xr806/ohosdemo/iot_peripheral/src/libapp_peripheral.test_pwm.o
                          [OHOS INFO] [129/267] COPY ../../../foundation/distributedschedule/samgr_lite/config/system_capability.json obj/foundation/distributedschedule/samgr_lite/config/system_capability.json
                          [OHOS INFO] [130/267] gcc cross compiler obj/utils/native/lite/kv_store/src/kvstore_common/libutils_kv_store.kvstore_common.o
                          [OHOS INFO] [131/267] gcc cross compiler obj/device/xradio/xr806/ohosdemo/wlan_demo/libapp_WlanTest.test_case.o
                          [OHOS INFO] [132/267] STAMP obj/foundation/distributedschedule/samgr_lite/ConfigFiles.stamp
                          [OHOS INFO] [133/267] gcc cross compiler obj/device/xradio/xr806/ohosdemo/iot_peripheral/src/libapp_peripheral.test_uart.o
                          [OHOS INFO] [134/267] gcc cross compiler obj/device/xradio/xr806/ohosdemo/iot_peripheral/src/libapp_peripheral.test_watchdog.o
                          [OHOS INFO] [135/267] AR libs/libapp_WlanTest.a
                          [OHOS INFO] [136/267] AR libs/libapp_peripheral.a
                          [OHOS INFO] [137/267] STAMP obj/device/xradio/xr806/ohosdemo/ohosdemo.stamp
                          [OHOS INFO] [138/267] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_debug.o
                          [OHOS INFO] [139/267] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/registry/libsamgr.service_registry.o
                          [OHOS INFO] [140/267] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/communication/broadcast/source/libbroadcast.broadcast_service.o
                          [OHOS INFO] [141/267] gcc cross compiler obj/device/xradio/xr806/os/libliteos_glue.os_freertos.o
                          [OHOS INFO] [142/267] AR libs/libliteos_glue.a
                          [OHOS INFO] [143/267] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/adapter/cmsis/libsamgr_adapter.memory_adapter.o
                          [OHOS INFO] [144/267] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/communication/broadcast/source/libbroadcast.pub_sub_feature.o
                          [OHOS INFO] [145/267] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/adapter/cmsis/libsamgr_adapter.queue_adapter.o
                          [OHOS INFO] [146/267] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/adapter/cmsis/libsamgr_adapter.thread_adapter.o
                          [OHOS INFO] [147/267] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/adapter/cmsis/libsamgr_adapter.time_adapter.o
                          [OHOS INFO] [148/267] AR libs/libsamgr_adapter.a
                          [OHOS INFO] [149/267] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/source/libsamgr_source.iunknown.o
                          [OHOS INFO] [150/267] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/source/libsamgr_source.feature.o
                          [OHOS INFO] [151/267] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/communication/broadcast/source/libbroadcast.pub_sub_implement.o
                          [OHOS INFO] [152/267] AR libs/libbroadcast.a
                          [OHOS INFO] [153/267] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/source/libsamgr_source.common.o
                          [OHOS INFO] [154/267] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/source/libsamgr_source.message.o
                          [OHOS INFO] [155/267] gcc cross compiler obj/kernel/liteos_m/components/backtrace/libbacktrace.los_backtrace.o
                          [OHOS INFO] [156/267] AR libs/libbacktrace.a
                          [OHOS INFO] [157/267] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/source/libsamgr_source.service.o
                          [OHOS INFO] [158/267] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/source/libsamgr_source.task_manager.o
                          [OHOS INFO] [159/267] gcc cross compiler obj/foundation/distributedschedule/samgr_lite/samgr/source/libsamgr.samgr_lite.o
                          [OHOS INFO] [160/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.gets_s.o
                          [OHOS INFO] [161/267] AR libs/libsamgr_source.a
                          [OHOS INFO] [162/267] AR libs/libsamgr.a
                          [OHOS INFO] [163/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.fwscanf_s.o
                          [OHOS INFO] [164/267] STAMP obj/foundation/distributedschedule/samgr_lite/samgr.stamp
                          [OHOS INFO] [165/267] STAMP obj/foundation/distributedschedule/samgr_lite/samgr_lite_ndk.stamp
                          [OHOS INFO] [166/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.memmove_s.o
                          [OHOS INFO] [167/267] gcc cross compiler obj/kernel/liteos_m/kal/libkal.kal.o
                          [OHOS INFO] [168/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.securecutil.o
                          [OHOS INFO] [169/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.scanf_s.o
                          [OHOS INFO] [170/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.fscanf_s.o
                          [OHOS INFO] [171/267] gcc cross compiler obj/kernel/liteos_m/components/exchook/libexchook.los_exchook.o
                          [OHOS INFO] [172/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.secureprintoutput_a.o
                          [OHOS INFO] [173/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.memset_s.o
                          [OHOS INFO] [174/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.memcpy_s.o
                          [OHOS INFO] [175/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.snprintf_s.o
                          [OHOS INFO] [176/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.sprintf_s.o
                          [OHOS INFO] [177/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.sscanf_s.o
                          [OHOS INFO] [178/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.strcat_s.o
                          [OHOS INFO] [179/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.secureinput_a.o
                          [OHOS INFO] [180/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.strncat_s.o
                          [OHOS INFO] [181/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.strtok_s.o
                          [OHOS INFO] [182/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.swprintf_s.o
                          [OHOS INFO] [183/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.strcpy_s.o
                          [OHOS INFO] [184/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.secureprintoutput_w.o
                          [OHOS INFO] [185/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.strncpy_s.o
                          [OHOS INFO] [186/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.swscanf_s.o
                          [OHOS INFO] [187/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vfscanf_s.o
                          [OHOS INFO] [188/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.secureinput_w.o
                          [OHOS INFO] [189/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vscanf_s.o
                          [OHOS INFO] [190/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vfwscanf_s.o
                          [OHOS INFO] [191/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vsnprintf_s.o
                          [OHOS INFO] [192/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vsprintf_s.o
                          [OHOS INFO] [193/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vsscanf_s.o
                          [OHOS INFO] [194/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vswprintf_s.o
                          [OHOS INFO] [195/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vswscanf_s.o
                          [OHOS INFO] [196/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.vwscanf_s.o
                          [OHOS INFO] [197/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wcscpy_s.o
                          [OHOS INFO] [198/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wcscat_s.o
                          [OHOS INFO] [199/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wcsncat_s.o
                          [OHOS INFO] [200/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wcstok_s.o
                          [OHOS INFO] [201/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wcsncpy_s.o
                          [OHOS INFO] [202/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wmemmove_s.o
                          [OHOS INFO] [203/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wscanf_s.o
                          [OHOS INFO] [204/267] gcc cross compiler obj/third_party/bounds_checking_function/src/libsec.wmemcpy_s.o
                          [OHOS INFO] [205/267] AR libs/libsec.a
                          [OHOS INFO] [206/267] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.libc.o
                          [OHOS INFO] [207/267] AR libs/libwifiservice.a
                          [OHOS INFO] [208/267] STAMP obj/foundation/communication/wifi_lite/wifi.stamp
                          [OHOS INFO] [209/267] gcc cross compiler obj/kernel/liteos_m/components/cpup/libcpup.los_cpup.o
                          [OHOS INFO] [210/267] AR libs/libcpup.a
                          [OHOS INFO] [211/267] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.errno.o
                          [OHOS INFO] [212/267] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_init.o
                          [OHOS INFO] [213/267] gcc cross compiler obj/kernel/liteos_m/components/exchook/libexchook.los_exc_info.o
                          [OHOS INFO] [214/267] AR libs/libexchook.a
                          [OHOS INFO] [215/267] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.malloc.o
                          [OHOS INFO] [216/267] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_event.o
                          [OHOS INFO] [217/267] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.pthread.o
                          [OHOS INFO] [218/267] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.pthread_mutex.o
                          [OHOS INFO] [219/267] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.pthread_attr.o
                          [OHOS INFO] [220/267] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.semaphore.o
                          [OHOS INFO] [221/267] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_mux.o
                          [OHOS INFO] [222/267] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_sem.o
                          [OHOS INFO] [223/267] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_swtmr.o
                          [OHOS INFO] [224/267] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_tick.o
                          [OHOS INFO] [225/267] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_queue.o
                          [OHOS INFO] [226/267] gcc cross compiler obj/kernel/liteos_m/kal/posix/src/libposix.time.o
                          [OHOS INFO] [227/267] gcc cross compiler obj/kernel/liteos_m/kernel/src/mm/libkernel.los_membox.o
                          [OHOS INFO] [228/267] gcc cross compiler obj/kernel/liteos_m/kal/cmsis/libcmsis.cmsis_liteos.o
                          [OHOS INFO] [229/267] AR libs/libposix.a
                          [OHOS INFO] [230/267] AR libs/libcmsis.a
                          [OHOS INFO] [231/267] AR libs/libkal.a
                          [OHOS INFO] [232/267] gcc cross compiler obj/kernel/liteos_m/kernel/arch/arm/cortex-m33/gcc/libarch.los_dispatch.o
                          [OHOS INFO] [233/267] gcc cross compiler obj/kernel/liteos_m/kernel/arch/arm/cortex-m33/gcc/libarch.los_exc.o
                          [OHOS INFO] [234/267] gcc cross compiler obj/kernel/liteos_m/kernel/arch/arm/cortex-m33/gcc/libarch.los_context.o
                          [OHOS INFO] [235/267] gcc cross compiler obj/kernel/liteos_m/utils/libutils.los_debug.o
                          [OHOS INFO] [236/267] gcc cross compiler obj/kernel/liteos_m/kernel/arch/arm/cortex-m33/gcc/libarch.los_timer.o
                          [OHOS INFO] [237/267] gcc cross compiler obj/kernel/liteos_m/utils/libutils.los_error.o
                          [OHOS INFO] [238/267] AR libs/libutils_kv_store.a
                          [OHOS INFO] [239/267] AR libs/libutils.a
                          [OHOS INFO] [240/267] STAMP obj/utils/native/lite/kv_store/kv_store.stamp
                          [OHOS INFO] [241/267] STAMP obj/vendor/xradio/xr806/xr806.stamp
                          [OHOS INFO] [242/267] gcc cross compiler obj/kernel/liteos_m/kernel/arch/arm/cortex-m33/gcc/libarch.los_interrupt.o
                          [OHOS INFO] [243/267] gcc cross compiler obj/utils/native/lite/file/src/file_impl_hal/libnative_file.file.o
                          [OHOS INFO] [244/267] AR libs/libarch.a
                          [OHOS INFO] [245/267] AR libs/libnative_file.a
                          [OHOS INFO] [246/267] gcc cross compiler obj/utils/native/lite/os_dump/libdump_static.dump_syspara.o
                          [OHOS INFO] [247/267] STAMP obj/utils/native/lite/file/file.stamp
                          [OHOS INFO] [248/267] gcc cross compiler obj/vendor/xradio/xr806/hals/utils/sys_param/libhal_sysparam.hal_sys_param.o
                          [OHOS INFO] [249/267] gcc cross compiler obj/vendor/xradio/xr806/hals/utils/token/libhal_token_static.hal_token.o
                          [OHOS INFO] [250/267] AR libs/libhal_sysparam.a
                          [OHOS INFO] [251/267] AR libs/libhal_token_static.a
                          [OHOS INFO] [252/267] gcc cross compiler obj/kernel/liteos_m/kernel/src/mm/libkernel.los_memory.o
                          [OHOS INFO] [253/267] AR libs/libtoken_static.a
                          [OHOS INFO] [254/267] AR libs/libsysparam.a
                          [OHOS INFO] [255/267] gcc cross compiler obj/kernel/liteos_m/kernel/src/libkernel.los_task.o
                          [OHOS INFO] [256/267] STAMP obj/base/startup/syspara_lite/frameworks/token/token.stamp
                          [OHOS INFO] [257/267] STAMP obj/base/startup/syspara_lite/frameworks/parameter/parameter.stamp
                          [OHOS INFO] [258/267] STAMP obj/base/startup/syspara_lite/frameworks/parameter/parameter_notes.stamp
                          [OHOS INFO] [259/267] AR libs/libdump_static.a
                          [OHOS INFO] [260/267] STAMP obj/utils/native/lite/os_dump/utils_os_dump.stamp
                          [OHOS INFO] [261/267] AR libs/libkernel.a
                          [OHOS INFO] [262/267] STAMP obj/kernel/liteos_m/kernel.stamp
                          [OHOS INFO] [263/267] STAMP obj/build/lite/ohos.stamp
                          [OHOS INFO] [264/267] ACTION //build/lite:gen_rootfs(//build/lite/toolchain:arm-none-eabi-gcc)
                          [OHOS INFO] [265/267] STAMP obj/build/lite/gen_rootfs.stamp
                          [OHOS INFO] [266/267] ACTION //device/xradio/xr806:libSDK(//build/lite/toolchain:arm-none-eabi-gcc)
                            jimmy606 LV 3 @HU_710774265 最后由 编辑
                            @hu_710774265 我也碰到相同的问题了😢
                            • Referenced by  D Deadpersimmon
