    【XR806开发板试用】通过MQTT实现手机远程实现PWM控灯
      一、例程编译、烧录确认
      首先按照全志在线文档平台的点灯教程确保能正常编译、烧录和点灯:https://xr806.docs.aw-ol.com/...
      确保例程没问题后,我们再改造例程,实现我们想要的功能
      二、代码编写
      我们将led工程复制一份改文件夹名为mydemo,目录结构如下
      mydemo
          ├── BUILD.gn
          └── src
          └── main.c
      然后BUILD.gn内容增加头文件引用,部分配置如下:
      static_library("app_mydemo") {
      include_dirs += [
            "//device/xradio/xr806/xr_skylark/project"
      接下来是main.c,内容如下:
      #include <string.h>
      #include "ohos_init.h"
      #include "kernel/os/os.h"
      #include "iot_gpio.h"
      #include "wifi_device.h"
      #include "common/framework/net_ctrl.h"
      #include "net/mqtt/MQTTClient-C/MQTTClient.h"
      #include "driver/chip/hal_pwm.h"
      static OS_Thread_t g_mqtt_thread;
      #define PWM_OUTPUT_CHL        PWM_GROUP1_CH2
      #define PWM_OUTPUT_MODE       PWM_CYCLE_MODE
      #define WIFI_DEVICE_CONNECT_AP_SSID "ssid"//这里填你家路由器的SSID
      #define WIFI_DEVICE_CONNECT_AP_PSK "pwm"//这里填你家路由器的PWD
      #define MQTT_DEMO_CLIENT_ID "12345"
      #define MQTT_DEMO_HOST_NAME "broker-cn.emqx.io"//这个是免费调试用的MQTT服务器地址
      #define MQTT_DEMO_PORT      "1883"
      #define MQTT_DEMO_USERNAME  "12345678"
      #define MQTT_DEMO_PASSWORD  "12345678"
      #define MQTT_RESP_TOPIC "/to/master/light" //手机发出来的TOPIC
      #define MQTT_RECV_TOPIC  "/to/slave/light" //设备发出来的TOPIC
      #define MQTT_DEMO_BUF_SIZE (2*1024)
      static MQTTPacket_connectData mqtt_demo_connectData = MQTTPacket_connectData_initializer;
      static Client mqtt_demo_client;
      static Network mqtt_demo_network;
      static int max_duty_ratio = 0;
      static int mqtt_demo_publish(char *topic, char *msg) ;
      static int mqtt_demo_init(void) {
          char *send_buf;
          char *recv_buf;
          mqtt_demo_connectData.clientID.cstring = MQTT_DEMO_CLIENT_ID;
          mqtt_demo_connectData.keepAliveInterval = 30; // 30s
          mqtt_demo_connectData.cleansession = 0;
          mqtt_demo_connectData.MQTTVersion = 4; //Version of MQTT 3.1.1
          send_buf = malloc(MQTT_DEMO_BUF_SIZE);
          if (send_buf == NULL) {
              printf("no memory\n");
              return -1;
          recv_buf = malloc(MQTT_DEMO_BUF_SIZE);
          if (recv_buf == NULL) {
              free(send_buf);
              return -1;
          /* init network */
          NewNetwork(&mqtt_demo_network);
          /* init mqtt client object */
          MQTTClient(&mqtt_demo_client, &mqtt_demo_network, 6000,
                     (unsigned char *)send_buf, MQTT_DEMO_BUF_SIZE,
                     (unsigned char *)recv_buf, MQTT_DEMO_BUF_SIZE);
          /* set username and password */
          mqtt_demo_connectData.username.cstring = MQTT_DEMO_USERNAME;
          mqtt_demo_connectData.password.cstring = MQTT_DEMO_PASSWORD;
      static int mqtt_demo_connect(char *host_name, char *host_port) {
          int ret = -1;
          ret = ConnectNetwork(&mqtt_demo_network, host_name, atoi(host_port));
          if (ret != 0) {
              printf("mqtt connect faild, ret:%d, host:%s, port:%s\n", ret, host_name, host_port);
              goto exit;
          ret = MQTTConnect(&mqtt_demo_client, &mqtt_demo_connectData);
          if (ret != 0) {
              printf("mqtt connect faild, ret:%d\n", ret);
              mqtt_demo_network.disconnect(&mqtt_demo_network);
              goto exit;
          printf("mqtt connected\n");
      exit:
          return ret;
      static void mqtt_demo_msg_cb(MessageData *data) {
          printf("get a message, topic: %.*s, msg: %.*s\n", data->topicName->lenstring.len,
                 data->topicName->lenstring.data, data->message->payloadlen,
                 (char *)data->message->payload);
          if(!strncmp(data->topicName->lenstring.data, "/to/slave/light", 15) && data->message->payloadlen) {
              char *payload = data->message->payload;
              char str[8] = "";
              int max_len = data->message->payloadlen > 3 ? 3 : data->message->payloadlen;
              strncpy(str, payload, max_len);
              int duty = atoi(str);
              HAL_Status status = HAL_PWM_ChSetDutyRatio(PWM_OUTPUT_CHL, duty * max_duty_ratio / 100);
              if (status != HAL_OK)
                  printf("%s(): %d, PWM set duty ratio error\n", __func__, __LINE__);
              if(duty) {
                  mqtt_demo_publish(MQTT_RESP_TOPIC, "light on");
              } else {
                  mqtt_demo_publish(MQTT_RESP_TOPIC, "light off");
      static int mqtt_demo_subscribe(char *topic) {
          int ret = -1;
          if (mqtt_demo_client.isconnected) {
              ret = MQTTSubscribe(&mqtt_demo_client, topic, 0, mqtt_demo_msg_cb);
              if (ret != 0)
                  printf("mqtt subscribe faild ret:%d\n", ret);
          return ret;
      static int mqtt_demo_unsubscribe(char *topic) {
          int ret = -1;
              ret = MQTTUnsubscribe(&mqtt_demo_client, topic);
              if (ret != 0)
                  printf("mqtt unsubscribe faild, ret:%d\n", ret);
          return ret;
      static int mqtt_demo_publish(char *topic, char *msg) {
          int ret = -1;
          MQTTMessage message;
          memset(&message, 0, sizeof(message));
          message.qos = 0;
          message.retained = 0; /* disable retain the message in server */
          message.payload = msg;
          message.payloadlen = strlen(msg);
          ret = MQTTPublish(&mqtt_demo_client, topic, &message);
          if (ret != 0)
              printf("mqtt publish faild, ret:%d\n", ret);
          return ret;
      static int mqtt_demo_disconnect(void) {
          int ret = -1;
              ret = MQTTDisconnect(&mqtt_demo_client);
              if (ret != 0)
                  printf("mqtt disconnect fail, ret:%d\n", ret);
          return ret;
      static void mqtt_demo_deinit(void) {
          if (mqtt_demo_client.buf) {
              free(mqtt_demo_client.buf);
              mqtt_demo_client.buf = NULL;
          if (mqtt_demo_client.readbuf) {
              free(mqtt_demo_client.readbuf);
              mqtt_demo_client.readbuf = NULL;
      static void mqtt_task(void *arg)   {
          int ret;
          int reconnect_times = 0;
          mqtt_demo_init();
          ret = mqtt_demo_connect(MQTT_DEMO_HOST_NAME, MQTT_DEMO_PORT);
          if (ret != 0)
              goto exit;
          ret = mqtt_demo_subscribe(MQTT_RECV_TOPIC);
          if (ret != 0)
              goto exit;
          mqtt_demo_publish(MQTT_RESP_TOPIC, "light ready");
          while (1) {
              ret = MQTTYield(&mqtt_demo_client, 300);
              if (ret != 0) {
                  printf("mqtt yield err, ret:%d\n", ret);
      reconnect:
                  printf("mqtt reconnect\n");
                  mqtt_demo_disconnect();
                  if (ret != 0) {
                      reconnect_times++;
                      if (reconnect_times > 5)
                          goto exit;
                      OS_MSleep(5000); //5s
                      goto reconnect;
      exit:
          mqtt_demo_unsubscribe(MQTT_RECV_TOPIC);
          mqtt_demo_deinit();
          OS_ThreadDelete(&g_mqtt_thread);
      static void net_cb(uint32_t event, uint32_t data, void *arg) {
          uint16_t type = EVENT_SUBTYPE(event);
          switch (type) {
          case NET_CTRL_MSG_NETWORK_UP:
              printf("NET_CTRL_MSG_NETWORK_UP\n");
              if (!OS_ThreadIsValid(&g_mqtt_thread)) {
                  OS_ThreadCreate(&g_mqtt_thread, "connect_to_server_task",
                                      mqtt_task, (void *)NULL,  OS_THREAD_PRIO_APP, (8 * 1024));
              break;
          case NET_CTRL_MSG_NETWORK_DOWN:
              break;
          default:
              break;
      static void MainThread(void *arg)   {
          printf("MainThread start\r\n");
          HAL_Status status = HAL_ERROR;
          PWM_ClkParam clk_param;
          PWM_ChInitParam ch_param;
          clk_param.clk = PWM_CLK_HOSC;
          clk_param.div = PWM_SRC_CLK_DIV_1;
          status = HAL_PWM_GroupClkCfg(PWM_OUTPUT_CHL, &clk_param);
              printf("%s(): %d, PWM group clk config error\n", __func__, __LINE__);
          ch_param.hz = 1000;
          ch_param.mode = PWM_OUTPUT_MODE;
          ch_param.polarity = PWM_HIGHLEVE;
          max_duty_ratio = HAL_PWM_ChInit(PWM_OUTPUT_CHL, &ch_param);
          if (max_duty_ratio == -1)
              printf("%s(): %d, PWM ch init error\n", __func__, __LINE__);
          printf("max_duty_ratio=%d\n", max_duty_ratio);
          status = HAL_PWM_ChSetDutyRatio(PWM_OUTPUT_CHL, 0);
          status = HAL_PWM_EnableCh(PWM_OUTPUT_CHL, PWM_OUTPUT_MODE, 1);
              printf("%s(): %d, PWM ch enable error\n", __func__, __LINE__);
          if (WIFI_SUCCESS != EnableWifi()) {
              printf("Error: EnableWifi fail\n");
              return;
          OS_Sleep(1);
          if (WIFI_SUCCESS != Scan()) {
              printf("Error: Scan fail.\n");
              return;
          OS_Sleep(3);//这里为了方便用延时,实际用回调更好,否则3秒可能不够
          const char ssid_want_connect[] = WIFI_DEVICE_CONNECT_AP_SSID;
          const char psk[] = WIFI_DEVICE_CONNECT_AP_PSK;
          WifiScanInfo scan_results[30];
          unsigned int scan_num = 30;
          if (WIFI_SUCCESS != GetScanInfoList(scan_results, &scan_num)) {
              printf("Error: GetScanInfoList fail.\n");
              return;
          WifiDeviceConfig config = { 0 };
          int netId = 0;
          int i;
          for (i = 0; i < scan_num; i++) {
              printf("ssid: %s    ", scan_results[i].ssid);
              printf("securityType: %d\n", scan_results[i].securityType);
              if (0 == strcmp(scan_results[i].ssid, ssid_want_connect)) {
                  memcpy(config.ssid, scan_results[i].ssid,
                         WIFI_MAX_SSID_LEN);
                  memcpy(config.bssid, scan_results[i].bssid,
                         WIFI_MAC_LEN);
                  config.securityType = scan_results[i].securityType;
                  config.freq = scan_results[i].frequency;
                  break;
          if (i >= scan_num) {
              printf("Error: No found ssid in scan_results\n");
              return;
          if (WIFI_SUCCESS != AddDeviceConfig(&config, &netId)) {
              printf("Error: AddDeviceConfig Fail\n");
              return;
          printf("Config Success\n");
          if (WIFI_SUCCESS != ConnectTo(netId)) {
              printf("Error: ConnectTo Fail\n");
              return;
          observer_base *net_ob;
          net_ob = sys_callback_observer_create(CTRL_MSG_TYPE_NETWORK, NET_CTRL_MSG_ALL, net_cb, NULL);
          if (net_ob == NULL)
              return;
          if (sys_ctrl_attach(net_ob) != 0)
              return;
          while (1) {
              OS_MSleep(500);
      void LEDMain(void) {
          if (OS_ThreadCreate(&g_main_thread, "MainThread", MainThread, NULL, OS_THREAD_PRIO_APP, 4 * 1024) != OS_OK) {
      SYS_RUN(LEDMain);
      三、配置上层的BUILD.gn,并编译
      部分内容如下:
      group("ohosdemo") {
          deps = [
              #"hello_demo:app_hello",
              #"wlan_demo:app_WlanTest",
              "mydemo:app_mydemo",
      然后执行hb build -f,编译成功(若编译失败见论坛有解决方案)
      然后烧录到开发板上
      四、运行实例
      烧录完成后,开发板重新上电,输出如下日志
          Hello! OpenHarmony!
          System tag : OpenHarmony 1.1.2_LTS
      use default flash chip mJedec 0x0
      [FD I]: mode: 0x10, freq: 96000000Hz, drv: 0
      [FD I]: jedec: 0x0, suspend_support: 1
      mode select:e
      wlan information ===================================================
      firmware:
          version : R0-XR_C07.08.52.65_02.84 May 27 2021 11:41:33-Y02.84
          buffer  : 8
      driver:
          version : XR_V02.05
      mac address:
          in use        : 1c:98:c9:bc:50:01
          in use        : 1c:98:c9:bc:50:02
      wlan mode:a
      [VFS INF] LittleFS mount success.
      platform information ===============================================
      XR806 SDK v1.2.0  Dec 13 2021 13:06:05
      heap space [0x2238d0, 0x24bc00), size 164656
      cpu  clock 160000000 Hz
      HF   clock  40000000 Hz
      sdk option:
          XIP           : enable
          INT LF OSC    : enable
          SIP flash     : enable
      mac address:
          efuse         : 80:74:84:21:38:8e
      hiview init success.MainThread start
      max_duty_ratio=40000
      console init success
      [net INF] no need to switch wlan mode 0
      [net INF] msg <wlan scan success>
      ssid: TP-LINK_A668    securityType: 2
      Config Success
      en1: Trying to associate with a4:c7:4b:71:f9:84 (SSID='XXXXXX' freq=2462 MHz)
      en1: Associated with a4:c7:4b:71:f9:84
      en1: WPA: Key negotiation completed with a4:c7:4b:71:f9:84 [PTK=CCMP GTK=CCMP]
      en1: CTRL-EVENT-CONNECTED - Connection to a4:c7:4b:71:f9:84 completed [id=0 id_str=]
      [net INF] msg <wlan connected>
      [net INF] netif is link up
      [net INF] start DHCP...
      [net INF] IPv6 addr state change: 0x0 --> 0x1
      [net INF] msg <>
      [net INF] netif (IPv4) is up
      [net INF] address: 192.168.3.48
      [net INF] gateway: 192.168.3.1
      [net INF] netmask: 255.255.255.0
      [net INF] msg <network IPv6 state>
      WAR drop=1117, fctl=0x00d0.
      mqtt connected
      get a message, topic: /to/slave/light, msg: 0
      可以看到,开发板成功连接路由器,并接入了MQTT服务器
      五、手机测试
      本人的手机是Iphone,也不会手机APP开发,于是我们下载了一个叫MQTTTool的第三方APP验证点灯,其界面如下:
      Host和Port填对,由于是免费开放的MQTT服务器,其他参数任意,设置好以后点Connect即可连接上MQTT服务器。然后底部切换至Subscribe栏,订阅主题:
      若手机比设备先连接服务器并订阅相关主题,那么你会在订阅栏收到topic为/to/master/light的消息:light ready,这是因为设备连上服务器就会发布该topic。
      接下来是发布主题,我们往/to/slave/light主题发送一个0~100的数字,就会让设备以这个数字为占空比控制LED灯亮灭,如0表示灭灯,50表示50%的占空比驱动LED灯,100表示100%的占空比驱动LED灯。同时设备收到LED控制指令后,若占空比不为0,则发送消息light on,否则发送消息light off
      3483115163-61b74c1527603.jfif
      745186370-61b74c1c9e55a.jfif
      1649520644-61b74d4e8379a.jfif
      部分日志如下:
      mqtt connected
      [net INF] msg <>
      get a message, topic: /to/slave/light, msg: 100
      get a message, topic: /to/slave/light, msg: 50
      以上就是一个手机远程给LED进行PWM调光的应用实例
      本帖转自极术社区:https://aijishu.com/a/1060000000284320
      作者:ctspot
