    xr806使用tcp socket与手机通信
    • K
      kw___ LV 5 最后由 编辑
      参考:基于星辰处理器的全志XR806开源鸿蒙开发板上手体验 - 极术社区 - 连接开发者与智能计算生态 (aijishu.com) 搭建环境。并成功编译。
      项目源码 : https://gitee.com/kingwho/smart-home
      在同一个局域网中,手机与xr806连接后,手机 APP 每隔 1s,发送按键的值给 xr806,用于控制xr806的led,然后xr806在返回按键,温度,适度(温度,适度为模拟数据)数据给手机app显示。
      将 smart_home 放入 device/xradio/xr806/ohosdemo 下的目录,并修改 device/xradio/xr806/ohosdemo/BUILD.gn 为
      group("ohosdemo") {
          deps = [
              #"hello_demo:app_hello",
              #"wlan_demo:app_WlanTest",
              "smart_home:app_smart_home",
      目录结构
      ├── BUILD.gn
      └── src
          ├── main.c
          ├── tcp_net_socket.c
          └── tcp_net_socket.h
      使用 WIFI 编译时会报错,进行如下操作即可,在随后的编译中可能还会出现,再次如下操作执行即可。
      cd device/xradio/xr806/xr_skylark/project/demo/wlan_ble_demo/image/xr806
      cp image_wlan_ble.cfg image_wlan_ble.cfg.bk
      cat image_auto_cal.cfg > image_wlan_ble.cfg
      cjson使用这些宏会报错,建议直接使用 cjson 宏定义后面函数。
      #define cJSON_AddNullToObject(object,name) cJSON_AddItemToObject(object, name, cJSON_CreateNull())
      #define cJSON_AddTrueToObject(object,name) cJSON_AddItemToObject(object, name, cJSON_CreateTrue())
      #define cJSON_AddFalseToObject(object,name) cJSON_AddItemToObject(object, name, cJSON_CreateFalse())
      #define cJSON_AddBoolToObject(object,name,b) cJSON_AddItemToObject(object, name, cJSON_CreateBool(b))
      #define cJSON_AddNumberToObject(object,name,n) cJSON_AddItemToObject(object, name, cJSON_CreateNumber(n))
      #define cJSON_AddStringToObject(object,name,s) cJSON_AddItemToObject(object, name, cJSON_CreateString(s))
      #define cJSON_AddRawToObject(object,name,s) cJSON_AddItemToObject(object, name, cJSON_CreateRaw(s))
      xr806连接WIFI后 IP地址可由串口输出打印查看
      [net INF] msg <wlan scan success>
      GetScanInfoList Success.
      AddDeviceConfig Success.
      [net INF] no need to switch wlan mode 0
      en1: Trying to associate with 94:83:c4:0e:70:be (SSID='GL-MT300N-V2-0be' freq=2437 MHz)
      ConnectTo Success
      en1: Associated with 94:83:c4:0e:70:be
      en1: WPA: Key negotiation completed with 94:83:c4:0e:70:be [PTK=CCMP GTK=CCMP]
      en1: CTRL-EVENT-CONNECTED - Connection to 94:83:c4:0e:70:be completed [id=0 id_str=]
      [net INF] msg <wlan connected>
      [net INF] netif is link up
      [net INF] start DHCP...
      [net INF] netif (IPv4) is up
      [net INF] address: 192.168.8.248
      [net INF] gateway: 192.168.8.1
      [net INF] netmask: 255.255.255.0
      [net INF] msg <network IPv6 state>
      [net INF] IPv6 addr state change: 0x0 --> 0x1
      [net INF] msg <>
      xr806 的固件更新后,需要使用下载器软件重新加载下固件,否则下载的可能还是上次的固件。
      BUILD.gn
      static_library("app_smart_home") {
         configs = []
         sources = [
            "src/main.c",
            "src/tcp_net_socket.c",
         cflags = board_cflags
         include_dirs += [
            "//third_party/lwip/src/include",
            "//third_party/cJSON",
      tcp_net_socket.c
      #include <stdlib.h>
      #include <string.h>
      #include "lwip/sockets.h"
      int tcp_server_init(int port)
          int sfd = 0;
          struct sockaddr_in saddr;
          sfd = socket(AF_INET,SOCK_STREAM,0);
          memset(&saddr, 0, sizeof(struct sockaddr));
          saddr.sin_family  = AF_INET;
          saddr.sin_port    = htons(port);
          saddr.sin_addr.s_addr = INADDR_ANY;
          bind(sfd, (struct  socket*)&saddr, sizeof(struct sockaddr));
          listen(sfd,5);
          return sfd;
      int tcp_server_accept(int sfd)
          int cfd = 0;
          struct  sockaddr_in caddr;
          memset(&caddr, 0, sizeof(struct sockaddr));
          int addrl = sizeof(struct sockaddr);
          cfd = accept(sfd , (struct sockaddr*)&caddr , &addrl);
          return cfd;
      main.c
      #include <stdlib.h>
      #include <string.h>
      #include "ohos_init.h"
      #include "kernel/os/os.h"
      #include "iot_gpio.h"
      #include "wifi_device.h"
      #include "cJSON.h"
      #include "tcp_net_socket.h"
      static void wifi_connect(char *ssid, char *passwd);
      	unsigned int led_pin = 21; /* GPIOA_PIN21 */
      	unsigned int key_pin = 11; /* GPIOA_PIN11 */
      	IotGpioValue key_value;
      	int led_value = 0;
      	unsigned int tem = 0, hum = 0, s = 0;
      	cJSON* dev_dat = NULL;
          int sfd = 0;
          int cfd = 0;
      	char send_buf[512] = {0};
      	char recv_buf[512] = {0};
      	wifi_connect("GL-MT300N-V2-0be", "goodlife");
      	IoTGpioInit(led_pin);
      	IoTGpioSetDir(led_pin, IOT_GPIO_DIR_OUT);
      	IoTGpioInit(key_pin);
      	IoTGpioSetDir(key_pin, IOT_GPIO_DIR_IN);
      	sfd = tcp_server_init(8080);
          cfd = tcp_server_accept(sfd);
      	while (1) {
      		srand( s++ );
      		tem = rand()%10 + 20;
      		hum = rand()%20 + 40;
      		IoTGpioGetInputVal(key_pin, &key_value);
      		printf("kw : hello world! key : %d tem : %d hum : %d\r\n", key_value, tem, hum);
      		IoTGpioSetOutputVal(led_pin, led_value);
      		recv(cfd, recv_buf, sizeof(recv_buf), 0);
      		memset(send_buf, 0, sizeof(send_buf));
      		sprintf(send_buf, "{\"led\":\"%d\",\"key\":\"%d\",\"tem\":\"%d\",\"hum\":\"%d\"}",\
      						led_value, key_value, tem, hum);
      		send(cfd,send_buf, strlen(send_buf),0);
      		dev_dat = cJSON_Parse(recv_buf);
      		led_value = cJSON_GetObjectItem(dev_dat, "led")->valuestring[0] - '0';
      		printf("led data : %d\r\n", led_value);
      		cJSON_Delete(dev_dat);
      	char *ssid_want_connect = ssid;
      	char *psk = passwd;
      	if (WIFI_SUCCESS != EnableWifi()) {
      		printf("Error: EnableWifi fail.\n");
      		return;
      	printf("EnableWifi Success.\n");
      	if (WIFI_STA_ACTIVE == IsWifiActive())
      		printf("Wifi is active.\n");
      	OS_Sleep(1);
      	if (WIFI_SUCCESS != Scan()) {
      		printf("Error: Scan fail.\n");
      		return;
      	printf("Wifi Scan Success.\n");
      	OS_Sleep(1);
      	WifiScanInfo scan_results[30];
      	unsigned int scan_num = 30;
      	if (WIFI_SUCCESS != GetScanInfoList(scan_results, &scan_num)) {
      		printf("Error: GetScanInfoList fail.\n");
      		return;
      	WifiDeviceConfig config = { 0 };
      	int netId = 0;
      	int i;
      	for (i = 0; i < scan_num; i++) {
      		if (0 == strcmp(scan_results[i].ssid, ssid_want_connect)) {
      			memcpy(config.ssid, scan_results[i].ssid,
      			       WIFI_MAX_SSID_LEN);
      			memcpy(config.bssid, scan_results[i].bssid,
      			       WIFI_MAC_LEN);
      			config.securityType = scan_results[i].securityType;
      			config.freq = scan_results[i].frequency;
      			break;
      	if (i >= scan_num) {
      		printf("Error: No found ssid in scan_results\n");
      		return;
      	printf("GetScanInfoList Success.\n");
      	if (WIFI_SUCCESS != AddDeviceConfig(&config, &netId)) {
      		printf("Error: AddDeviceConfig Fail\n");
      		return;
      	printf("AddDeviceConfig Success.\n");
      	if (WIFI_SUCCESS != ConnectTo(netId)) {
      		printf("Error: ConnectTo Fail\n");
      		return;
      	printf("ConnectTo Success\n");
      	OS_Sleep(3);
      	WifiLinkedInfo get_linked_res;
      	if (WIFI_SUCCESS != GetLinkedInfo(&get_linked_res)) {
      		printf("Error: GetLinkedInfo Fail\n");
      		return;
      	printf("GetLinkedInfo Success.\n");
      	printf("ssid: %s\n", get_linked_res.ssid);
      	printf("bssid: ");
      	for (int j = 0; j < WIFI_MAC_LEN; j++) {
      		printf("%02X", get_linked_res.bssid[j]);
      	printf("\n");
      	printf("rssi: %d\n", get_linked_res.rssi);
      	unsigned char get_mac_res[WIFI_MAC_LEN];
      	if (WIFI_SUCCESS != GetDeviceMacAddress(get_mac_res)) {
      		printf("Error: GetDeviceMacAddress Fail\n");
      		return;
      	printf("GetDeviceMacAddress Success.\n");
      	for (int j = 0; j < WIFI_MAC_LEN - 1; j++) {
      		printf("%02X:", get_mac_res[j]);
      	printf("%02X\n", get_mac_res[WIFI_MAC_LEN - 1]);
      void SmartHome(void)
      			    OS_THREAD_PRIO_APP, 8 * 1024) != OS_OK) {
      SYS_RUN(SmartHome);
      APP 采用 APIClode 开发,使用 html js 进行开发
      APICloude Studio 软件下载,以及使用:
      https://docs.apicloud.com/apicloud3/#wifi-preview
      手机安装 Apploader,可以进行调试
      安装Apploader下载 : https://docs.apicloud.com/Download/download
      将 SmartHome 导入 APICloude Studio
      html/main.html 对应登录界面, 如下可修改默认 IP 和端口号
          <div id="bt_log">
              <form name="myForm" action="" onsubmit="return validateForm()" method="post">
                 <div><label>IP地址</label><input type="text" name="ip" value="192.168.8.248"></div>
                  <div><label>端口号</label><input type="text" name="port" value="8080"></div>
                  <div><input type="submit" class="btn" value="登录" onmouseover="this.style.backgroundPosition='left -36px'"
                      onmouseout="this.style.backgroundPosition='left top'"></div>
              </form>
           </div>
      html/user_app.html 对应应用界面,与 xr806 在同一个局域网中,同进行通信,通信使用的为 json 数据。
