    【新人上手】D1哪吒开发板Tina Linux 下WiFi的连接
    • Randolph
      Randolph LV 6 最后由 Randolph 编辑
      16、查看wifi规格
      支持2.4G wifi,支持13个工作信道(Channel1-13),提供wifi扫描命令,可搜索到附件的wifi list。
      执行:
      wifi_scan_results_test
      可以看到:
      root@TinaLinux:/# wifi_scan_results_test
      ***Start scan!***
      bssid / frequency / signal level / flags / ssid
      0e:e0:df:1e:6a:36       2472    -39     [WPA2-PSK-CCMP][ESS]    RANDOLPH
      Wifi get_scan_results: Success!
      17、station模式
      开机时如检测到曾经连接过wifi,则自动连接上一此连接的wifi。
      执行:
      wifi_connect_ap_test <ssid> <psk>
      可见:
      root@TinaLinux:/# wifi_connect_ap_test  RANDOLPH xxxxxxxx
      Connected to the AP(RANDOLPH)
      Getting ip address(RANDOLPH)......
      auto connected Successful  !!!!
      Connecting to the network(RANDOLPH)......
      sh: odhcp6c: not found
      [   84.050715] wlan0: deauthenticating from 0e:e0:df:1e:6a:36 by local choice (reason=3)
      [   84.085703] [WSM_WRN] Issue unjoin command(TX).
      [   84.092916] [WSM_WRN] STA mode, send_deauth_to_self
      [   84.098429] [TXRX_WRN] Issue unjoin command(TX) by self.
      [   85.775478] wlan0: authenticate with 0e:e0:df:1e:6a:36 (try 1)
      [   85.782532] [STA_WRN] [HT40][xradio_join_work][bss_ht_info]:
      [   85.782532] [primary_chan  :0x0000000d]
      [   85.782532] [ht_param      :0x00000000]
      [   85.782532] [operation_mode:0x00000000]
      [   85.782532] [stbc_param    :0x00000000]
      [   85.782532] [basic_set[0]  :0x00000000]
      [   85.810406] [STA_WRN] [HT40][xradio_join_work][PhyModeCfg:0x0007]
      [   85.810406] [ModemFlags    :0x00000007]
      [   85.810406] [ChWidthCfg    :0x00000000]
      [   85.810406] [PriChCfg      :0x00000000]
      [   85.810406] [BandCfg       :0x00000000]
      [   85.810406] [STBC_Enable   :0x00000000]
      [   85.810406] [PreambleCfg   :0x00000000]
      [   85.810406] [SGI_Enable    :0x00000000]
      [   85.810406] GF_Enable      :0x00000000]
      [   85.867864] wlan0: authenticated
      [   85.872260] wlan0: associate with 0e:e0:df:1e:6a:36 (try 1)
      [   85.886562] wlan0: RX AssocResp from 0e:e0:df:1e:6a:36 (capab=0x411 status=0 aid=1)
      [   85.895310] wlan0: associated
      [   85.904359] [AP_WRN] arp_addr_cnt not clear at disconnecting,filter abnormal enable!!!
      [   85.914312] [AP_WRN] [STA] ASSOC HTCAP 11N 58
      [   85.919277] [AP_WRN] [HT40][xradio_bss_info_changed][ht_prot:0x00000000][HtProtMode:0x0000][Green:0x0000]
      [   85.919673] [AP_WRN] [HT40][xradio_bss_info_changed][PhyModeCfg:0xd007]
      [   85.919673] [ModemFlags    :0x00000007]
      [   85.919673] [ChWidthCfg    :0x00000000]
      [   85.919673] [PriChCfg      :0x00000000]
      [   85.919673] [BandCfg       :0x00000000]
      [   85.919673] [STBC_Enable   :0x00000000]
      [   85.919673] [PreambleCfg   :0x00000001]
      [   85.919673] [SGI_Enable    :0x00000001]
      [   85.919673] [GF_Enable     :0x00000001]
      Wifi connect ap : Success!
      可以ping百度验证:
      root@TinaLinux:/# ping baidu.com
      PING baidu.com (220.181.38.148): 56 data bytes
      64 bytes from 220.181.38.148: seq=0 ttl=50 time=84.309 ms
      64 bytes from 220.181.38.148: seq=1 ttl=50 time=75.818 ms
      64 bytes from 220.181.38.148: seq=2 ttl=50 time=69.916 ms
      64 bytes from 220.181.38.148: seq=3 ttl=50 time=71.139 ms
      64 bytes from 220.181.38.148: seq=4 ttl=50 time=102.807 ms
      ^C
      --- baidu.com ping statistics ---
      5 packets transmitted, 5 packets received, 0% packet loss
      round-trip min/avg/max = 69.916/80.797/102.807 ms
      18、Softap模式
      支持softap模式,提供softap模式demo,开启后可被其他设备连入。
      执行:
      softap_up <ssid> <pwd> <broadcast/hidden>
      softap_down
      可见
      root@TinaLinux:/# softap_up nezha 12345678 broadcast
      Start hostapd test!
      wpa2-psk!
      Start to set softap!
      Message is: OK
      Set softap finished!
      [  433.525126] [TXRX_WRN] drop=1771, fctl=0x00d0.
      [  433.552706] wlan0: deauthenticating from 0e:e0:df:1e:6a:36 by local choice (reason=3)
      [  433.589037] [WSM_WRN] Issue unjoin command(TX).
      [  433.599152] [WSM_WRN] STA mode, send_deauth_to_self
      [  433.604623] [TXRX_WRN] Issue unjoin command(TX) by self.
      [  433.678548] [STA_WRN] !!! xradio_remove_interface: vif_id=0
      [  435.741366] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=40:3f:ea:5e:f0:32
      [  435.758671] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=40:3f:ea:5e:f0:32
      [  435.784698] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
      Start to start softap!
      SoftAP started successfullyHaving catch sig_chld!
      Message is: OK
      Start softap finished!
      打开手机wifi可见:
      关闭则执行:
      softap_down
      注意:是无法访问网络的。
      19、自动搜索
      已连接ap后,会自动搜索保存的列表,重启后自动连接。
      20、信号强度获取
      同16条,结果中可见。
        luciferseva LV 3 最后由 编辑
        为啥没有softap这个东东
