    【XR806开发板试用】实时时钟
      HU_710774265 LV 4 最后由 编辑
      spi+ntp+max7219=实时时钟
      wifi 通过ntp获取时间 交由8位数码管显示
      PIN 使用
      1-5V
      11-GND
      12-SPI0_MOSI
      13-SPI0_CS0
      14-SPI0_MISO -未使用
      15-SPI0_CLK
      接线
      xr806----------8位数码管max7219
      1-----------------vcc
      11----------------gnd
      12----------------din
      13----------------cs
      15----------------clk
      nano 是命令行文本编辑工具 纯个人习惯
      make 是我当前帐号的名字
      cd /home/make/xr806_openharmony/device/xradio/xr806/ohosdemo/
      也可cd ~/xr806_openharmony/device/xradio/xr806/ohosdemo/ 即当前登录帐号目录
      nano BUILD.gn
      group("ohosdemo") {
          deps = [
           "sntp:app_sntp_Test",
      ctrl+o 保存
      回车
      ctrl+x 退出
      创建目录
      mkdir sntp
      cd sntp
      nano BUILD.gn
      static_library("app_sntp_Test") {
         configs = []
         sources = [
            "main.c",
         cflags = board_cflags
         include_dirs += [
              "//device/xradio/xr806/xr_skylark/include/net/sntp",
      ctrl+o 保存
      回车
      ctrl+x 退出
      nano main.c
      #include "ohos_init.h"
      #include "kernel/os/os.h"
      #include "wifi_device.h"
      #include "sntp.h"
      #include "iot_gpio.h"
      #include "driver/chip/hal_spi.h"
      #include "common/framework/platform_init.h"
      /* spi */
      #define DEMO_SPI_MCLK (48 * 1000 * 1000)
      #define DEMO_SPI_CS_LEVEL 0
      #define DEMO_SPI_PORT SPI0
      #define DEMO_SPI_CS SPI_TCTRL_SS_SEL_SS0
      #define DEMO_FLASH_INSTRUCTION_RDID 0x9F /* flash jedec id */
      static OS_Thread_t g_time_thread;
      #define WIFI_DEVICE_CONNECT_AP_SSID "11111111"//wifi名称
      #define WIFI_DEVICE_CONNECT_AP_PSK "11111111"//wifi密码
      #define SNTP_YEAR_OFFSET (2000)
      #define CMD_SYSLOG printf
      #define CMD_LOG(flags, fmt, arg...) \
      	do                              \
      		if (flags)                  \
      			CMD_SYSLOG(fmt, ##arg); \
      	} while (0)
      /*8 DIGITS begin*/
      #define NUMBER_OF_DIGITS 8
      typedef enum
      	REG_NO_OP = 0x00,
      	REG_DIGIT_0 = 0x01,
      	REG_DIGIT_1 = 0x02,
      	REG_DIGIT_2 = 0x03,
      	REG_DIGIT_3 = 0x04,
      	REG_DIGIT_4 = 0x05,
      	REG_DIGIT_5 = 0x06,
      	REG_DIGIT_6 = 0x07,
      	REG_DIGIT_7 = 0x08,
      	REG_DECODE_MODE = 0x09,	 //译码方式,0x00为不译码,0xff为译码
      	REG_INTENSITY = 0x0A,	 //显示亮度,取值范围0~f
      	REG_SCAN_LIMIT = 0x0B,	 // 8位扫描显示,取值范围0x01~0x07
      	REG_SHUTDOWN = 0x0C,	 //操作方式,0x00为低功耗模式,0x01为正常操作模式
      	REG_DISPLAY_TEST = 0x0F, //显示状态,0x00为正常显示,0x01为显示测试
      } MAX7219_REGISTERS;
      typedef enum
      	DIGIT_1 = 1,
      	DIGIT_2 = 2,
      	DIGIT_3 = 3,
      	DIGIT_4 = 4,
      	DIGIT_5 = 5,
      	DIGIT_6 = 6,
      	DIGIT_7 = 7,
      	DIGIT_8 = 8
      } MAX7219_Digits;
      typedef enum
      	NUM_0 = 0x00,
      	NUM_1 = 0x01,
      	NUM_2 = 0x02,
      	NUM_3 = 0x03,
      	NUM_4 = 0x04,
      	NUM_5 = 0x05,
      	NUM_6 = 0x06,
      	NUM_7 = 0x07,
      	NUM_8 = 0x08,
      	NUM_9 = 0x09,
      	MINUS = 0x0A, //-号
      	LETTER_E = 0x0B,
      	LETTER_H = 0x0C,
      	LETTER_L = 0x0D,
      	LETTER_P = 0x0E,
      	BLANK = 0x0F,  //无显示
      	LETTER_AR = 0x10 //=16 =SYMBOLS  AorR
      } MAX7219_Numeric;
      void max7219_Init(uint8_t intensivity);
      void max7219_SetIntensivity(uint8_t intensivity);
      void max7219_Clean(void);
      /*void max7219_SendData(uint8_t addr, uint8_t data);*/
      void max7219_Turn_On(void);
      void max7219_Turn_Off(void);
      void max7219_Decode_On(void);
      void max7219_Decode_Off(void);
      void max7219_PrintDigit(MAX7219_Digits position, MAX7219_Numeric numeric, bool point);
      MAX7219_Digits max7219_PrintItos(MAX7219_Digits position, int value);
      MAX7219_Digits max7219_PrintNtos(MAX7219_Digits position, uint32_t value, uint8_t n);
      MAX7219_Digits max7219_PrintFtos(MAX7219_Digits position, float value, uint8_t n);
      int LED8Main(void);
      static uint8_t decodeMode = 0x00;
      static uint8_t SYMBOLS[] = {
      	0x7E, // numeric 0
      	0x30, // numeric 1
      	0x6D, // numeric 2
      	0x79, // numeric 3
      	0x33, // numeric 4
      	0x5B, // numeric 5
      	0x5F, // numeric 6
      	0x70, // numeric 7
      	0x7F, // numeric 8
      	0x7B, // numeric 9
      	0x01, // minus
      	0x4F, // letter E
      	0x37, // letter H
      	0x0E, // letter L
      	0x67, // letter P
      	0x00, // blank
      	0x77  //AorR
      static uint16_t getSymbol(uint8_t number);
      static uint32_t lcdPow10(uint8_t n);
      /*8 DIGITS func end*/
      	max7219_Turn_On();
      	max7219_SendData(REG_SCAN_LIMIT, NUMBER_OF_DIGITS - 1);
      	max7219_SetIntensivity(intensivity);
      	max7219_Clean();
      //显示亮度
      	if (intensivity > 0x0F)
      		return;
      	max7219_SendData(REG_INTENSITY, intensivity);
      void max7219_Clean()
      	uint8_t clear = 0x00;
      	if (decodeMode == 0xFF)
      		clear = BLANK;
      	for (int i = 0; i < 8; ++i)
      		max7219_SendData(i + 1, clear);
      // #define data_len (20*1024)
      #define data_len (20 * 1024)
      uint8_t tx_data[data_len] = {0};
      inline void max7219_SendData(uint8_t addr, uint8_t data)
      	HAL_Status ret = HAL_OK;
      	HAL_SPI_CS(DEMO_SPI_PORT, 1);
      	// printf("spi write...\n");
      	tx_data[0] = addr;
      	tx_data[1] = data;
      	ret = HAL_SPI_Transmit(DEMO_SPI_PORT, &tx_data, 2);
      	if (ret != HAL_OK)
      		printf("spi 1write failed");
      	HAL_SPI_CS(DEMO_SPI_PORT, 0);
      //操作方式
      	max7219_SendData(REG_SHUTDOWN, 0x01);
      //操作方式
      	max7219_SendData(REG_SHUTDOWN, 0x00);
      //译码方式
      	decodeMode = 0xFF;
      	max7219_SendData(REG_DECODE_MODE, decodeMode);
      //译码方式
      	decodeMode = 0x00;
      	if (position > NUMBER_OF_DIGITS)
      		return;
      	if (point)
      		if (decodeMode == 0x00)
      			max7219_SendData(position, getSymbol(numeric) | (1 << 7));
      		else if (decodeMode == 0xFF)
      			max7219_SendData(position, numeric | (1 << 7));
      			max7219_SendData(position, getSymbol(numeric) & (~(1 << 7)));
      			max7219_SendData(position, numeric & (~(1 << 7)));
      	max7219_SendData(REG_DECODE_MODE, 0xFF);
      	int32_t i;
      	if (value < 0)
      		if (position > 0)
      			max7219_SendData(position, MINUS);
      			position--;
      		value = -value;
      	i = 1;
      	while ((value / i) > 9)
      		i *= 10;
      	if (position > 0)
      		max7219_SendData(position, value / i);
      		position--;
      	i /= 10;
      	while (i > 0)
      		if (position > 0)
      			max7219_SendData(position, (value % (i * 10)) / i);
      			position--;
      		i /= 10;
      	return position;
      	if (n > 0u)
      		uint32_t i = lcdPow10(n - 1u);
      		while (i > 0u) /* Display at least one symbol */
      			if (position > 0u)
      				max7219_SendData(position, (value / i) % 10u);
      				position--;
      			i /= 10u;
      	return position;
      	if (n > 4)
      		n = 4;
      	if (value < 0.0)
      		if (position > 0)
      			position--;
      		value = -value;
      	position = max7219_PrintItos(position, (int32_t)value);
      	if (n > 0u)
      		max7219_PrintDigit(position + 1, ((int32_t)value) % 10, true);
      		position = max7219_PrintNtos(position, (uint32_t)(value * (float)lcdPow10(n)), n);
      	return position;
      	return SYMBOLS[number];
      	uint32_t retval = 1u;
      	while (n > 0u)
      		retval *= 10u;
      		n--;
      	return retval;
      static int wifi_device_connect()
      	const char ssid_want_connect[] = WIFI_DEVICE_CONNECT_AP_SSID;
      	const char psk[] = WIFI_DEVICE_CONNECT_AP_PSK;
      	if (WIFI_SUCCESS != EnableWifi())
      		printf("Error: EnableWifi fail.\n");
      		return;
      	printf("EnableWifi Success.\n");
      	if (WIFI_STA_ACTIVE == IsWifiActive())
      		printf("Wifi is active.\n");
      	OS_Sleep(1);
      	if (WIFI_SUCCESS != Scan())
      		printf("Error: Scan fail.\n");
      		return;
      	printf("Wifi Scan Success.\n");
      	OS_Sleep(1);
      	WifiScanInfo scan_results[30];
      	unsigned int scan_num = 30;
      	if (WIFI_SUCCESS != GetScanInfoList(scan_results, &scan_num))
      		printf("Error: GetScanInfoList fail.\n");
      		return;
      	WifiDeviceConfig config = {0};
      	int netId = 0;
      	int i;
      	for (i = 0; i < scan_num; i++)
      		if (0 == strcmp(scan_results[i].ssid, ssid_want_connect))
      			memcpy(config.ssid, scan_results[i].ssid,
      				   WIFI_MAX_SSID_LEN);
      			memcpy(config.bssid, scan_results[i].bssid,
      				   WIFI_MAC_LEN);
      			config.securityType = scan_results[i].securityType;
      			config.freq = scan_results[i].frequency;
      			break;
      	if (i >= scan_num)
      		printf("Error: No found ssid in scan_results\n");
      		return;
      	printf("GetScanInfoList Success.\n");
      	if (WIFI_SUCCESS != AddDeviceConfig(&config, &netId))
      		printf("Error: AddDeviceConfig Fail\n");
      		return;
      	printf("AddDeviceConfig Success.\n");
      	if (WIFI_SUCCESS != ConnectTo(netId))
      		printf("Error: ConnectTo Fail\n");
      		return;
      	printf("ConnectTo Success\n");
      static int my_sntp_init()
      	if (sntp_set_server(0, "0.cn.pool.ntp.org") == 0)
      		printf("set OK \r\n");
      int LED8Main(void)
      	printf("platform_init.\n");
      	/*platform_init();*/
      	printf("spi demo started.\n");
      	SPI_Global_Config spi_param;
      	spi_param.cs_level = DEMO_SPI_CS_LEVEL;
      	spi_param.mclk = DEMO_SPI_MCLK;
      	HAL_SPI_Init(DEMO_SPI_PORT, &spi_param);
      	SPI_Config spi_Config;
      	uint8_t cmd = DEMO_FLASH_INSTRUCTION_RDID; /* read flash id cmd */
      	uint32_t data = 0;
      	spi_Config.firstBit = SPI_TCTRL_FBS_MSB; //
      	//SPI_LITTLEENDIAN;//第一字节 SPI_LITTLEENDIAN,SPI_BIGENDIAN
      	spi_Config.mode = SPI_CTRL_MODE_MASTER;
      	//SPI_MODE_MASTER;//SPI_MODE_SLAVE 从,SPI_MODE_MASTER 主
      	spi_Config.opMode = SPI_OPERATION_MODE_POLL;
      	spi_Config.sclk = 24000000;
      	spi_Config.sclkMode = SPI_SCLK_Mode0;
      	printf("spi open...\n");
      	ret = HAL_SPI_Open(DEMO_SPI_PORT, DEMO_SPI_CS, &spi_Config, 5000);
      	if (ret != HAL_OK)
      		printf("spi open failed");
      		return ret;
      	HAL_SPI_Config(DEMO_SPI_PORT, SPI_ATTRIBUTION_IO_MODE, SPI_IO_MODE_NORMAL);
      	printf("spi demo over.\n");
      //抄  https://github.com/taburyak/STM32_MAX7219_SPI
      //demos https://stm32withoutfear.blogspot.com/2019/06/stm32-7segments-8digits-max7219-spi.html
      	printf("MainThread.\n");
      	LED8Main();
      	max7219_Init(7);
      	max7219_SetIntensivity(1);
      	max7219_Decode_Off();
      				max7219_SendData(DIGIT_4,79);
      				max7219_SendData(DIGIT_3, 119);
      				max7219_SendData(DIGIT_2, 119);
      	LOS_Msleep(5000);
      	max7219_Decode_On();
      	max7219_PrintNtos(DIGIT_8,88888888, 8); //此处前面带 0 补充4位
      	LOS_Msleep(1000);
      	max7219_Clean();
      	int modi;
      	int setint = 1;
      	while (1)
      		modi++;
      		setint++;
      		if (setint == 16)
      			setint = 1;
      		max7219_SetIntensivity(setint);
      			// max7219_Clean();
      			if (sntp_request(NULL) != 0)
      				//视频中用手捂住开发板后会进入此处
      				/*max7219_PrintDigit(DIGIT_4, LETTER_E, false);*/
      				LOS_Msleep(1);
      				max7219_Clean();
      				LOS_Msleep(1);
      				max7219_PrintDigit(DIGIT_6, LETTER_AR,false);//A OR R
      				max7219_SendData(DIGIT_4,79);//E
      				max7219_SendData(DIGIT_3, 119);//R
      				max7219_SendData(DIGIT_2, 119);//R
      				LOS_Msleep(5000);
      				max7219_Clean();
      				printf("<sntp> <response : fail>\n");
      				// goto bexit;
      				// max7219_Clean();
      				sntp_time *time = (sntp_time *)sntp_obtain_time();
      				printf("<sntp><response:success>\n");
      				//11111111
      				if (modi % 2 == 0)
      					max7219_PrintNtos(DIGIT_8, time->year + SNTP_YEAR_OFFSET, 4);//年
      					max7219_PrintNtos(DIGIT_4, time->mon, 2);					  //月
      					max7219_PrintNtos(DIGIT_2, time->day, 2);					  //日
      					max7219_PrintNtos(DIGIT_8, time->hour, 2);//小时     第一位无数字自动补充0
      					max7219_PrintDigit(DIGIT_6, BLANK, true);// 。
      					max7219_PrintNtos(DIGIT_5, time->min, 2);//分        第一位无数字自动补充0
      					max7219_PrintDigit(DIGIT_3, BLANK, true);// 。
      					max7219_PrintNtos(DIGIT_2, time->sec & 0x3f, 2);//秒 第一位无数字自动补充0
      				CMD_LOG(1, "sntp(%u-%02u-%02u ", time->year + SNTP_YEAR_OFFSET, time->mon, time->day);
      				CMD_LOG(1, "%02u:%02u:%02u)\n", time->hour, time->min, time->sec);
      				LOS_Msleep(4000);
      		{   //初始化连接 wifi
      			max7219_Clean();
      			max7219_PrintDigit(DIGIT_8, BLANK, true);
      			LOS_Msleep(1000);
      			max7219_PrintDigit(DIGIT_7, BLANK, true);
      			LOS_Msleep(1000);
      			LOS_Msleep(1000);
      			max7219_PrintDigit(DIGIT_5, BLANK, true);
      			printf("Wifi is passive.\n");
      			wifi_device_connect();
      			max7219_PrintDigit(DIGIT_4, BLANK, true);
      			LOS_Msleep(1000);
      			LOS_Msleep(1000);
      			max7219_PrintDigit(DIGIT_2, BLANK, true);
      			LOS_Msleep(1000);
      			max7219_PrintDigit(DIGIT_1, BLANK, true);
      			LOS_Msleep(1000);
      	printf("bexit is passive.\n");
      void SNTPTestMain(void) //(2)
      	printf("SNTP Test Start\n");
      	if (OS_ThreadIsValid(&g_main_thread))
      		printf("sntp task is running\n");
      							OS_THREAD_PRIO_APP, 4 * 1024) != OS_OK)
      			printf("[ERR] Create SNTP Test  MainThread Failed\n");
      SYS_RUN(SNTPTestMain);
      //必须以app开头 否则不会调用
      ctrl+o 保存
      回车
      ctrl+x 退出
      对上面操作完毕后
      由于我们修改了/home/make/xr806_openharmony/device/xradio/xr806/ohosdemo/BUILD.gn
      hb build -f
      必须-f 如若未修改BUILD.gn 大可不必 直接 hb build 即可
      H 1 条回复 最后回复 回复 引用 分享 1
        HU_710774265 LV 4 @HU_710774265 最后由 编辑
