    【惊】在麻雀上运行国产rt-smart系统
    6
    10
    9225
    • mangogeek
      mangogeek LV 8 最后由 mangogeek 编辑
      想必RT-Thread系统大家不陌生了,RT-Thread Smart(简称 rt-smart)是基于 RT-Thread 操作系统衍生的新分支,面向带 MMU,中高端应用的芯片,例如 ARM Cortex-A 系列芯片,MIPS 芯片,带 MMU 的 RISC-V 芯片等。rt-smart 在 RT-Thread 操作系统的基础上启用独立、完整的进程方式,同时以混合微内核模式执行。
      官方文档:https://www.rt-thread.org/document/site/#/rt-thread-version/rt-thread-smart/rt-smart-quickstart/rt-smart-quickstart
      内核:rt_smart_kernel.bin
      硬件:麻雀,MQ1或MQ1W
      RT-smart包(自带编译器):mango_rtsmart_app.zip
      1. 分区
      使用fdisk分区。
      将u盘挂载到ubuntu系统后,笔者设备路径是/dev/sdb。使用的32GB TF卡,扇区大小512字节,根据说明预留8M的空闲,那么计算得知分区扇区开始于:16384
      命令:sudo fdisk /dev/sdb
      选:o,n,p,1,16384,回车
      Command (m for help): o
      Created a new DOS disklabel with disk identifier 0x3668b987.
      Command (m for help): n
      Partition type
         p   primary (0 primary, 0 extended, 4 free)
         e   extended (container for logical partitions)
      Select (default p): p
      Partition number (1-4, default 1): 1
      First sector (2048-62410751, default 2048): 16384
      Last sector, +sectors or +size{K,M,G,T,P} (16384-62410751, default 62410751):
      Created a new partition 1 of type 'Linux' and of size 29.8 GiB.
      Command (m for help): w
      The partition table has been altered.
      正确的分区效果如下:
      mango@virtual:/dev$ sudo fdisk -l /dev/sdb
      Disk /dev/sdb: 29.8 GiB, 31954305024 bytes, 62410752 sectors
      Units: sectors of 1 * 512 = 512 bytes
      Sector size (logical/physical): 512 bytes / 512 bytes
      I/O size (minimum/optimal): 512 bytes / 512 bytes
      Disklabel type: dos
      Disk identifier: 0x3668b987
      Device     Boot Start      End  Sectors  Size Id Type
      /dev/sdb1       16384 62410751 62394368 29.8G 83 Linux
      mango@virtual:/dev$
      然后格式化sdb1:
      $ sudo mkfs -t fat /dev/sdb1
      2. 刷入rt-smart内核
      $ sudo dd if=rt_smart_kernel.bin of=/dev/sdb bs=1024
      2888+1 records in
      2888+1 records out
      2957313 bytes (3.0 MB, 2.8 MiB) copied, 8.32574 s, 355 kB/s
      $ sync
      3. 启动rtt
      此时将TF卡放入麻雀,串口0(底部排针的7,8脚),串口波特率500000,然后上电:
      [26]HELLO! BOOT0 is starting!
      [27]BOOT0 commit : fb73c68
      [28]set pll start
      [28]periph0 has been enabled
      [29]set pll end
      [30]board init ok
      [30]ZQ value = 0x2f***********
      [31]get_pmu_exist() = -1
      [32]ddr_efuse_type: 0xa
      [33][AUTO DEBUG] single rank and full DQ!
      [34]ddr_efuse_type: 0xa
      [35][AUTO DEBUG] rank 0 row = 13
      [36][AUTO DEBUG] rank 0 bank = 4
      [37][AUTO DEBUG] rank 0 page size = 2 KB
      [37]DRAM BOOT DRIVE INFO: V0.24
      [38]DRAM CLK = 528 MHz
      [39]DRAM Type = 2 (2:DDR2,3:DDR3)
      [40]DRAMC read ODT  off.
      [40]DRAM ODT off.
      [41]ddr_efuse_type: 0xa
      [42]DRAM SIZE =64 M
      [44]DRAM simple test OK.
      [45]dram size =64
      [45]card no is 0
      [45]sdcard 0 line count 4
      [46][mmc]: mmc driver ver 2021-04-2 16:45
      [52][mmc]: Wrong media type 0x0
      [53][mmc]: ***Try SD card 0***
      [60][mmc]: HSSDR52/SDR25 4 bit
      [61][mmc]: 50000000 Hz
      [61][mmc]: 30474 MB
      [62][mmc]: ***SD/MMC 0 init OK!!!***
      [98]Loading boot-pkg Succeed(index=0).
      [99]*******************TOC1 Item Message*************************
      [100]Entry_name        = opensbi
      [101]Entry_data_offset = 0x600
      [102]Entry_data_len    = 0x188e0
      [103]encrypt           = 0x0
      [103]Entry_type        = 0x0
      [104]run_addr          = 0x40000000
      [105]index             = 0x0
      [105]Entry_end         = 0x3b454949
      [106]*************************************************************
      [108]*******************TOC1 Item Message*************************
      [109]Entry_name        = dtb
      [110]Entry_data_offset = 0x19000
      [111]Entry_data_len    = 0x7475
      [111]encrypt           = 0x0
      [112]Entry_type        = 0x0
      [113]run_addr          = 0x40200000
      [114]index             = 0x0
      [114]Entry_end         = 0x3b454949
      [115]*************************************************************
      [117]*******************TOC1 Item Message*************************
      [118]Entry_name        = kernel
      [119]Entry_data_offset = 0x20600
      [120]Entry_data_len    = 0xa6cf0
      [120]encrypt           = 0x0
      [121]Entry_type        = 0x0
      [122]run_addr          = 0x40400000
      [123]index             = 0x0
      [123]Entry_end         = 0x3b454949
      [124]*************************************************************
      [126]Jump to second Boot.
      OpenSBI v0.9-165-gefbc2b8
              |_|
      Platform Name             : Allwinner D1 NeZha
      Platform Features         : medeleg
      Platform HART Count       : 1
      Platform IPI Device       : aclint-mswi
      Platform Timer Device     : aclint-mtimer @ 24000000Hz
      Platform Console Device   : uart8250
      Platform HSM Device       : ---
      Platform Reboot Device    : sunxi-wdt-reset
      Platform Shutdown Device  : ---
      Firmware Base             : 0x40000000
      Firmware Size             : 248 KB
      Runtime SBI Version       : 0.3
      Domain0 Name              : root
      Domain0 Boot HART         : 0
      Domain0 HARTs             : 0*
      Domain0 Region00          : 0x0000000014008000-0x000000001400bfff (I)
      Domain0 Region01          : 0x0000000014000000-0x0000000014007fff (I)
      Domain0 Region02          : 0x0000000040000000-0x000000004003ffff ()
      Domain0 Region03          : 0x0000000000000000-0xffffffffffffffff (R,W,X)
      Domain0 Next Address      : 0x0000000040400000
      Domain0 Next Arg1         : 0x0000000040200000
      Domain0 Next Mode         : S-mode
      Domain0 SysReset          : yes
      Boot HART ID              : 0
      Boot HART Domain          : root
      Boot HART ISA             : rv64imafdcvsux
      Boot HART Features        : scounteren,mcounteren,mcountinhibit,time
      Boot HART PMP Count       : 16
      Boot HART PMP Granularity : 2048
      Boot HART PMP Address Bits: 38
      Boot HART MHPM Count      : 0
      Boot HART MIDELEG         : 0x0000000000000222
      Boot HART MEDELEG         : 0x000000000000b1ff
      heap: [0x404fbdf4 - 0x41cfbdf4]
      [I/I2C] I2C bus [i2c2] registered
      - RT -     Thread Smart Operating System
       / | \     5.0.0 build Dec 31 2021
       2006 - 2020 Copyright by rt-thread team
      lwIP-2.1.2 initialized!
      SDC:hal_sdc_create host:000000004051bdf8 id:0
      SDC:Not implement __mci_restore_io,798
      SDC:Not imp hal_sdc_init,2218
      SDC:hal_sdc_init,2251 no imp
      SDC:hal_sdc_init,2259 no imp
      SDC:SDC Host Capability:0x3820f Ocr avail:0x3f0000
      SDC:SDC cd_mode:2 present_val:0
      SDC:SDC id:0 dma_use:1 present:1
       driver version SD/MMC/SDIO Host Controller Driver(v0.27 2021-04-30 16:50) init ok.
      card_detect insert
      SD:mmc_card_create card:000000004052e1a8 id:0
      SDC:SDC clock=400000 kHz,src:0, n:1, m:14
      SD:***** Try sd *****
      SD:card ocr: ffffffffc0ff8000
      SD:Card CID number:55
      SD:card raw cid:
      SD:card raw csd:
      SD:card raw scr:
      SD:card raw SD status:
      SDC:SDC clock=50000000 kHz,src:1, n:0, m:5
      SD:card is switched to high speed mode, clk:50000 KHz
      SD:Set bus width type: 2
      SD:
      ============= card information ==============
      SD:Card Type     : SDHC
      SD:Card Spec Ver : 5.0
      SD:Card RCA      : 0x0001
      SD:Card OCR      : 0x40ff8000
      SD:    vol_window  : 0x00ff8000
      SD:    to_1v8_acpt : 0
      SD:    high_capac  : 0
      SD:Card CSD      :
      SD:    speed       : 50000 KHz
      SD:    cmd class   : 0x5b5
      SD:    capacity    : 30474MB
      SD:Card CUR_STA  :
      SD:    speed_mode  : HS: 50 MHz
      SD:    bus_width   : 2
      SD:    speed_class : 10
      SD:=============================================
      SD:***** sd init ok *****
      Initial card success
      [I/sal.skt] Socket Abstraction Layer initialize success.
      file system initialization done!
      gt9xx_probe
      Hello RISC-V
      msh />[D/TOUCH.gt9xx] 39 31 31 0 0
      [I/TOUCH.gt9xx] Found chip gt911
      [I/TOUCH.gt9xx] GT9xx Config version: 0x00
      [I/TOUCH.gt9xx] GT9xx Sensor id: 0xFF
      msh />
      4. 运行应用程序
      祭出祖传hello程序:根据说明自行编译,输出为:hello.elf 文件,直接
      拷贝到TF卡的文件系统中
      然后重新将tf卡放进麻雀,开机启动:
      msh />ls
      Directory /:
      System Volume Information<DIR>
      etc                 <DIR>
      hello.elf           237512
      vi.elf              398544
      msh />
      msh />./hello.elf
      msh />hello world!
      至此,吊炸天的hello程序就运行起来了!
      5. 扩展之编译
      • 请在Linux下使用此开发环境包(已经自带64位Linux系统的编译器环境),如果要在Windows下使用,请自行配置安装编译在tools目录下,然后参照smart-env.sh里的脚本配置好环境变量。
      • 在Linux下使用步骤:
        • 首先执行source smart-env.sh riscv64,也可以根据自己的环境稍作修改。
        • 进入userapp目录进行应用编译,例如编译自带的hello应用程序,只需要执行scons --app=hello。
        • 编译好的应用程序会生成在root/bin目录下,将其拷贝到SD卡中(注意是8M偏移的起始分区),然后进入rt-smart系统中,启动挂载成功后即可运行。
      • mangogeek
        mangogeek LV 8 最后由 编辑
        Randolph 1 条回复 最后回复 回复 引用 分享 1
        • Randolph
          Randolph LV 6 @mangogeek 最后由 编辑
          @mangogeek 这个有完整的SDK供下载吗?😳
          • BedRock
            BedRock LV 6 最后由 编辑
            上面不是有包嘛😊
            Randolph 1 条回复 最后回复 回复 引用 分享 0
            • Randolph
              Randolph LV 6 @BedRock 最后由 编辑
              @bedrock 内核的没有🤤
              • mangogeek
                当前状态是内核层源码没开源
                  huyuxiang LV 2 最后由 编辑
                  B 1 条回复 最后回复 回复 引用 分享 0
                  • T
                    tfx2001 LV 2 最后由 编辑
                    @mangogeek 内核源码预计什么时候能开源呢
                    • mangogeek
                      mangogeek LV 8 @tfx2001 最后由 编辑
                      @tfx2001 不知道,他们没有告诉我开源计划。
                      • B
                        jasonhu LV 4 @huyuxiang 最后由 编辑
                        @huyuxiang 你需要更新一下工具链,请下载http://117.143.63.254:9012/www/rt-smart/aarch64-linux-musleabi_for_i686-w64-mingw32_latest.zip,放到tools/gnu_gcc目录下,重新编译即可。
                        • Referenced by  Randolph Randolph
