    请问 uboot 不能驱动PWM7 (PD22) 是什么原因呢?
    4520
      whycan晕哥 LV 9 最后由 whycan 编辑
      uboot-board.dts:
      &pwm7_pin_a {
              pins = "PD22";
              function = "pwm7";
              allwinner,muxsel = <5>;
              drive-strength = <10>;
              bias-pull-up;
      &pwm7_pin_b {
              pins = "PD22";
              muxsel = <0>;
              function = "gpio_in";
      &pwm7 {
              pinctrl-0 = <&pwm7_pin_a>;
              pinctrl-1 = <&pwm7_pin_b>;
      或者:
      &pio {
              pwm7_pin_a: pwm7@0 {
                      pins = "PD22";
                      function = "pwm7";
                      bias-pull-up;
              pwm7_pin_b: pwm7@1 {
                      pins = "PD22";
      &pwm7 {
      LCD0配置:
      &lcd0 {
      lcd_backlight = <100>;
      lcd_pwm_used = <1>;
      lcd_pwm_ch = <7>;
      lcd_pwm_freq = <9000>;
      lcd_pwm_pol = <1>;
      日志:
      U-Boot 2018.05-g0a88ac9-dirty-config-dirty (Jan 14 2022 - 08:49:40 +0800) Allwinner Technology
      [00.273]DRAM:  64 MiB
      [00.275]Relocation Offset is: 01f02000
      [00.279]secure enable bit: 0
      [00.282]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.288]flash init start
      [00.290]workmode = 0,storage type = 1
      [00.294][mmc]: mmc driver ver uboot2018:2021-04-16 14:23:00-1
      [00.299][mmc]: get sdc_type fail and use default host:tm1.
      [00.306][mmc]: can't find node "mmc0",will add new node
      [00.310][mmc]: fdt err returned <no error>
      [00.314][mmc]: Using default timing para
      [00.318][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.336][mmc]: card_caps:0x3000000a
      [00.339][mmc]: host_caps:0x3000003f
      [00.343]sunxi flash init ok
      [00.345]line:714 init_clocks
      __clk_init: clk pll_periph0x2 already initialized
      register fix_factor clk error
      [00.355]drv_disp_init
      [00.370]###LCD init
      [00.372]drv_disp_init finish
      [00.374]boot_gui_init:start
      [00.377]set disp.dev2_output_type fail. using defval=0
      [00.382]I80_HX8537 NO info[00.386]I80_HX8537 POWER ON[00.408]boot_gui_init:finish
      [00.578]I80_HX8537 INITED ![00.757]hx8357 inited[00.759]hx8357 inited[00.761]hx8357 inited[00.763]hx8357 inited[00.764]hx8357 inited[00.766]hx8357 initedpartno erro : can't find partition bootloader
      54 bytes read in 2 ms (26.4 KiB/s)
      [00.784]bmp_name=bootlogo.bmp size 307254
      307254 bytes read in 15 ms (19.5 MiB/s)
      [00.823]Loading Environment from SUNXI_FLASH... OK
      [00.843]out of usb burn from boot: not need burn key
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.853]update part info
      [00.857]update bootcmd
      [00.860]change working_fdt 0x42ac1da8 to 0x42aa1da8
      [00.882]update dts
      FDT ERROR:get muxsel err returned FDT_ERR_INTERNAL
      [00.929]I80_HX8537 BL OPEN ![00.932]LCD open finish
      Android's image name: d1-whycanpi0a_hx
      [01.314]
      Starting kernel ...
      都是这个错误:
      引脚设置复用失败?
        然后死马做活马医, 改成gpio配置背光:
        &lcd0 {
        lcd_gpio_1 = <&pio PD 22 1 0 3 1>;
        然后 lcd驱动里面:
        static void LCD_power_on(u32 sel)
                sunxi_lcd_pin_cfg(sel, 1);
                sunxi_lcd_delay_ms(20);
                sunxi_lcd_gpio_set_value(sel, 1, 1);//backlight on
        这样背光正常了。
          whycan晕哥 LV 9 @whycan 最后由 编辑
          @whycan
          u-boot 命令行读 PD_CFG2 的寄存器内容是 :
          => mm 0x02000098
          02000098: 0f222222
          说明 PD22_SELECT 是 1111 (IO disable)
          那是dts配错了,还是u-boot有 bug 呢?
            @whycan
            root@TinaLinux:/# devmem 0x02000098
            0x05222222
            进入Linux 之后,读出 PD22_SELECT 是 0101,
            刚好是 PWM 复用。
              按住 s 上电启动可以进入u-boot命令行,输入两行命令可以把PD22拉高:
              mw 0x02000098 0x01222222
              mw 0x020000A0 0x00400000
