    XR806编译导致云服务器死机
      long0304 LV 3 最后由 编辑
      我在编译XR806的时候,一到253这一步的时候,占用内存就会猛涨,然后云服务器就会直接死机。有没有dalao知道为啥
      [OHOS INFO] [230/255] AR libs/libutils.a
      [OHOS INFO] [231/255] STAMP obj/kernel/liteos_m/kernel.stamp
      [OHOS INFO] [232/255] gcc cross compiler obj/utils/native/lite/file/src/file_impl_hal/libnative_file.file.o
      [OHOS INFO] [233/255] AR libs/libnative_file.a
      [OHOS INFO] [234/255] STAMP obj/utils/native/lite/file/file.stamp
      [OHOS INFO] [235/255] STAMP obj/vendor/xradio/xr806/xr806.stamp
      [OHOS INFO] [236/255] gcc cross compiler obj/utils/native/lite/kv_store/src/kvstore_impl_hal/libutils_kv_store.kv_store.o
      [OHOS INFO] [237/255] AR libs/libutils_kv_store.a
      [OHOS INFO] [238/255] STAMP obj/utils/native/lite/kv_store/kv_store.stamp
      [OHOS INFO] [239/255] gcc cross compiler obj/utils/native/lite/os_dump/libdump_static.dump_syspara.o
      [OHOS INFO] [240/255] gcc cross compiler obj/vendor/xradio/xr806/hals/utils/token/libhal_token_static.hal_token.o
      [OHOS INFO] [241/255] AR libs/libhal_token_static.a
      [OHOS INFO] [242/255] AR libs/libtoken_static.a
      [OHOS INFO] [243/255] STAMP obj/base/startup/syspara_lite/frameworks/token/token.stamp
      [OHOS INFO] [244/255] gcc cross compiler obj/vendor/xradio/xr806/hals/utils/sys_param/libhal_sysparam.hal_sys_param.o
      [OHOS INFO] [245/255] AR libs/libhal_sysparam.a
      [OHOS INFO] [246/255] AR libs/libsysparam.a
      [OHOS INFO] [247/255] STAMP obj/base/startup/syspara_lite/frameworks/parameter/parameter_notes.stamp
      [OHOS INFO] [248/255] STAMP obj/base/startup/syspara_lite/frameworks/parameter/parameter.stamp
      [OHOS INFO] [249/255] AR libs/libdump_static.a
      [OHOS INFO] [250/255] STAMP obj/utils/native/lite/os_dump/utils_os_dump.stamp
      [OHOS INFO] [251/255] STAMP obj/build/lite/ohos.stamp
      [OHOS INFO] [252/255] ACTION //build/lite:gen_rootfs(//build/lite/toolchain:arm-none-eabi-gcc)
      [OHOS INFO] [253/255] STAMP obj/build/lite/gen_rootfs.stamp
      ^C[OHOS WARNING] User Abort
      编译前内存占用 ↓
      编译到253位置后内存占用疯狂上涨↓
      这一步好像是打包镜像的阶段,为什么会在编译到这一步的时候内存会这样上涨呢?
        long0304 LV 3 @long0304 最后由 编辑
        @long0304 这个内存会直接加到1.8G,然后会内存爆满死机,我现在是用ctrl+c中断了,然后截的图
