    xr806 spi驱动出现问题
    4062
      aktoey LV 3 最后由 编辑
      在做xr806的spi驱动的时候,只加了HAL_SPI_Deinit(DEMO_SPI_PORT);都会出错,代码如下:
      SPI_Global_Config spi_param;
      spi_param.cs_level = DEMO_SPI_CS_LEVEL;
      spi_param.mclk = DEMO_SPI_MCLK;
      HAL_SPI_Init(DEMO_SPI_PORT, &spi_param);
      while (1) {
      IoTGpioSetOutputVal(GPIO_ID_PA21, 1);
      OS_MSleep(500);
      IoTGpioSetOutputVal(GPIO_ID_PA21, 0);
      OS_MSleep(500);
      void LCDMain(void)
      if (OS_ThreadCreate(&g_main_thread, "MainThread", MainThread, NULL,OS_THREAD_PRIO_APP, 4 * 1024) != OS_OK) {
      SYS_RUN(LCDMain);
      串口打印的log是如下内容
      Hello! OpenHarmony!
      System tag : OpenHarmony 1.1.2_LTS
      use default flash chip mJedec 0x0
      [FD I]: mode: 0x10, freq: 96000000Hz, drv: 0
      [FD I]: jedec: 0x0, suspend_support: 1
      mode select:e
      wlan information ===================================================
      firmware:
      version : R0-XR_C07.08.52.65_02.84 May 27 2021 11:41:33-Y02.84
      buffer : 8
      driver:
      version : XR_V02.05
      mac address:
      in use : 4c:6e:c8:3e:c2:01
      in use : 4c:6e:c8:3e:c2:02
      wlan mode:a
      [VFS INF] SPIFFS mount success.
      platform information ===============================================
      XR806 SDK v1.2.0 Jan 15 2022 15:52:31
      heap space [0x228900, 0x247c00), size 127744
      cpu clock 160000000 Hz
      HF clock 40000000 Hz
      sdk option:
      XIP : enable
      INT LF OSC : enable
      SIP flash : enable
      mac address:
      efuse : 80:74:84:05:ba:de
      hiview init success.[SPI Alert] Changing State incorrectly in HAL_SPI_Deinit
      console init success
      I 1 条回复 最后回复 回复 引用 分享 0
      • I
        何镜勇 LV 4 @aktoey 最后由 编辑
        @aktoey 去初始化函数,只有在初始化成功后才能使用
          aktoey LV 3 @I_A_student 最后由 编辑
          @i_a_student 我先试的init然后才试的deinit,都不行
          • I
            @aktoey 试了一下,没啥问题,破案了,一定是你敲代码的姿势不对。
