    全志D1s 使用 tplayerdemo播放 mp4视频出现错误。请各位大佬们帮着看看。问题出在什么哪?谢谢!
    7
    8
    7981
      lmjlzyljy LV 2 最后由 whycan 编辑
      root@TinaLinux:/mnt/SDCARD# tplayerdemo 1.mp4
      WARNING: awplayer <cdx_log_set_level:30>: cdx Set log level to 6
      INFO   : cedarc <CedarPluginVDInit:79>: register h264 decoder success!
      INFO   : cedarc <CedarPluginVDInit:84>: register mjpeg decoder success!
      INFO   : cedarc <CedarPluginVDInit:86>: register mpeg2 decoder success!
      INFO   : cedarc <CedarPluginVDInit:92>: register mpeg4dx decoder success!
      INFO   : cedarc <CedarPluginVDInit:79>: register mpeg4H263 decoder success!
      INFO   : cedarc <CedarPluginVDInit:90>: register mpeg4Normal decoder success!
      INFO   : cedarc <CedarPluginVDInit:74>: register vc1 decoder success!
      INFO   : cedarc <CedarPluginVDInit:85>: register h265 decoder success!
      INFO   : cedarc <CedarPluginVDInit:70>: register vp6Soft decoder success!
      INFO   : cedarc <CedarPluginVDInit:88>: register Wmv12Soft decoder success!
      * This program implements a simple player, you can type commands to control the player.
      * To show what commands supported, type 'help'.
      dd: writing '/dev/fb0': No space left on device
      4801+0 records in
      4800+0 records out
      argc = 2
      argv[0] = tplayerdemo
      argv[1] = 1.mp4
      may be is one file:cut down suffix is:.mp4
      find the matched type:.mp4
      create player:0
      >>>>>>>>>>>>>>>>>>>>>>>>>>>[SNDCODEC][sunxi_card_hw_params][620]:stream_flag: 0
      >>>> tina_multimedia <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      tag   : tina3.5
      branch: tina-dev
      xplayer:process message XPLAYER_COMMAND_SET_AUDIOSINK.
      xplayer:process message XPLAYER_COMMAND_SET_SURFACE.
      xplayer:process message XPLAYER_COMMAND_SET_SUBCTRL.
      xplayer:process message XPLAYER_COMMAND_SET_DI.
      create player[0]:0x1df2ddb0
      screen width:1024,screen height:600
      1:playVideo:0
      before TPlayerSetDataSource,94720:1.mp4
      xplayer:process message XPLAYER_COMMAND_SET_SOURCE.
      setDataSource end
      xplayer:pVE: enable hw clock
      rocess message XPLAYER_COMMAND_Penable_cedar_hw_clk,552
      REPARE.
      warning: unknown callback from Tinaplayer.
      INFO   : ceVE: VE real_freq=576000000
      darc <log_set_level:43>: Set log level to 5 from /vendor/etc/cedarc.conf
      ERROR  : cedarc <DebugCheckConfig:301>: now cedarc log level:5
      TPlayerPrepare end
      TPlayerSetHoldLastPicture()
      xplayer:process message XPLAYER_COMMAND_START.
      (Allwinner Audio Middle Layer),line(971) : Create Decoder!!=====
      (Allwinner Audio Middle Layer),line(603) : AudioDec_Installaudiolib ok
      (Allwinner Audio Middle Layer),line(606) : audio decoder init start ...
      (AllwinnerAlibs),line(50) :
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Audio <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      tag   : audiocodec-v1.2
      branch: new
      commit: 3ba65962c01cbf1280ddda19d843009b6ef8ce85
      date  : Tue Jan 8 16:25:27 2019 +0800
      (AllwinnerAlibs),line(700) : ----Loading so success!
      (AllwinnerAlibs),line(902) : *************pAudioStreamInfo start******************
      (AllwinnerAlibs),line(903) : eCodecFormat         :id(4), name(aac low-complexy)
      (AllwinnerAlibs),line(904) : eSubCodecFormat      :0
      (AllwinnerAlibs),line(905) : nChannelNum          :2
      (AllwinnerAlibs),line(906) : nBitsPerSample       :16
      (AllwinnerAlibs),line(907) : nSampleRate          :44100
      (AllwinnerAlibs),line(908) : nAvgBitrate          :128000
      (AllwinnerAlibs),line(909) : nMaxBitRate          :128000
      (AllwinnerAlibs),line(910) : nFileSize            :0
      (AllwinnerAlibs),line(911) : eAudioBitstreamSource:0
      (AllwinnerAlibs),line(912) : eDataEncodeType      :0
      (AllwinnerAlibs),line(913) : nCodecSpecificDataLen:2
      (AllwinnerAlibs),line(914) : pCodecSpecificData   :0x3fc805c1f0
      (AllwinnerAlibs),line(915) : nFlags               :0
      (AllwinnerAlibs),line(916) : nBlockAlign          :0
      (AllwinnerAlibs),line(917) : *************pAudioStreamInfo end  ******************
      (AAC Decoder),line(36) : init successs...
      (Allwinner Audio Middle Layer),line(614) : AUDIO DECODE INIT OK...0
      started.
      AW_ION_IOC_NEW_ALLOC error
      ERROR  : awplayer <setLayerBuffer:259>: SunxiMemPalloc mHoldLastPictureBuf fail,with = 1920,height = 1088
      ERROR  : awplayer <setLayerBuffer:351>: SunxiMemPalloc err
      ERROR  : awplayer <__LayerDequeueBuffer:780>: can not initialize layer.
      WARNING: cedarc <RequestVideoStreamBuffer:1274>: request stream buffer fail,                  6264205 bytes valid data in SBM[0], total buffer size is 6291456 bytes.
      ^CGot signal 2, exiting ...
      xplayer:process message XPLAYER_COMMAND_RESET.
      (AAC Decoder),line(44) : exit successs...
      (AllwinnerAlibs),line(750) : ----dlclose so success!
      (Allwinner Audio Middle Layer),line(920) : destroy_ResampleInfo!!
      (Allwinner Audio Resample),line(68) : Destroy_ResampleInfo...
      L1 PageTable Invalid
      0x0 is not mapped!
      DE invalid address: 0x0, data:0x0, id:0x4
      can not free NULL buffer
      can L1 PageTable Invalid
      0x0 is not mapped!
      can not free NULL1 PageTable Invalid
      0x0 is not mapped!
      L buffer
      0x0 is not mapped!
      0x0 is not mapped!
      0x0 is not mapped!
      0x0 is not mapped!
      0x0 is not mapped!
      0x0 is not mapped!
      0x0 is not mapped!
      0x0 is not mapped!
      0x0 is not mapped!
      0x0 is not mapped!
      VE: disable hw clock
      0x0 is not mapped!
      disable_cedar_hw_clk,592
      0x0 is not mapped!
      0x0 is not mapped!
      TPlayerDestroy(0) successfully
      destroy tplayer
      tplaydemo exit
      A B 2 条回复 最后回复 回复 引用 分享 0
        anruliu LV 6 @lmjlzyljy 最后由 编辑
        @lmjlzyljy 很明显报内存申请失败的log了,播放前可以执行free看剩余内存多少
        • B
          bndxgae LV 3 @lmjlzyljy 最后由 编辑
          @lmjlzyljy 把视频文件和分辩率缩小,直到可以播放,不要问为什么?😁
          • BedRock
            BedRock LV 6 最后由 编辑
            这个故事告诉我们需要换片子了😀
              houxiaoni LV 5 最后由 编辑
              内存不够了,如果要播放1080P的视频可以考虑开启缩放,调用TPlayerSetScaleDownRatio接口即可
              U 1 条回复 最后回复 回复 引用 分享 0
              • U
                ubuntu LV 7 @houxiaoni 最后由 编辑
                @houxiaoni
                内存足够也寄😧
                H 1 条回复 最后回复 回复 引用 分享 0
                  houxiaoni LV 5 @ubuntu 最后由 编辑
                  @ubuntu 是不是内存碎片导致的大块内存申请不出来了
                    chenyinchang LV 4 最后由 编辑
                    @houxiaoni 大佬,请教一下,我这边也出现:
                    不过只有我在播放http-flv、rtsp本地流视频的时候(过一段时间,出现时间不定。另注:走的WIFI,iperf打流8小时都很稳定,速度跑在满速,ping外网地址延迟也很稳定、不跳动。)就会出现,播放本地视频的时候无问题。这种要怎么解决?或者有什么排查方向?我已经看了好多天源码,但缺乏文档帮助,想做排查和修改都很难😖
