T113 MQ-R板子用tina 无法进入系统
用论坛下载得T113 tina sdk编译了一版固件,烧录到sd卡,启动不了。log如下:
[113]HELLO! BOOT0 is starting! [116]BOOT0 commit : 4d16602 [119]set pll start [121]fix vccio detect value:0xc0 [128]periph0 has been enabled [131]set pll end [133][pmu]: bus read error [135]board init ok [137]ZQ value = 0x2f [139]get_pmu_exist() = -1 [142]ddr_efuse_type: 0xa [144]trefi:7.8ms [147][AUTO DEBUG] single rank and full DQ! [151]ddr_efuse_type: 0xa [153]trefi:7.8ms [156][AUTO DEBUG] rank 0 row = 13 [159][AUTO DEBUG] rank 0 bank = 8 [162][AUTO DEBUG] rank 0 page size = 2 KB [166]DRAM BOOT DRIVE INFO: V0.33 [170]DRAM CLK = 792 MHz [172]DRAM Type = 3 (2:DDR2,3:DDR3) [175]DRAMC read ODT off. [178]DRAM ODT value: 0x42. [180]ddr_efuse_type: 0xa [184]DRAM SIZE =128 M [186]dram_tpr4:0x0 [187]PLL_DDR_CTRL_REG:0xf8004100 [191]DRAM_CLK_REG:0xc0000000 [193][TIMING DEBUG] MR2= 0x18 [200]DRAM simple test OK. [203]rtc standby flag is 0x0, super standby flag is 0x0 [208]dram size =128 [211]card no is 0 [212]sdcard 0 line count 4 [215][mmc]: mmc driver ver 2021-05-21 14:47 [224][mmc]: Wrong media type 0x0 [227][mmc]: ***Try SD card 0*** [238][mmc]: HSSDR52/SDR25 4 bit [241][mmc]: 50000000 Hz [243][mmc]: 3840 MB [245][mmc]: ***SD/MMC 0 init OK!!!*** [341]Loading boot-pkg Succeed(index=0). [345]Entry_name = u-boot [352]Entry_name = optee [356]Entry_name = dtb [359]mmc not para [361]Jump to second Boot. M/TC: OP-TEE version: 6aef7bb2-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Jul 23 09:25:11 UTC 2021 arm E/TC:0 0 check_hardware_info:90 hardware check error1 E/TC:0 0 Panic at core/arch/arm/plat-sun8iw20p1/main.c:301 <plat_init> E/TC:0 0 Call stack: E/TC:0 0 0x41b0a271
关闭optee功能
@yuzukitsuru 怎么关闭啊,uboot 添加CONFIG_NOT_USE_OPTEE25 选项编译报错
问题解决:让基友少走弯路,把修改共享出来
@mhcsoft
M/TC: OP-TEE version: 6aef7bb2-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Jul 23 09:25:11 UTC 2021 arm卡在这步。 老铁到底怎么关闭的。 对比你的defconfig 也区别。
@bynce 请问板子串口是怎么接的,用这个config 通过tf卡启动,可以启动看到logo,就是死活没有串口日志
@eddardzhu 接了E2和E3作收发,没有数据输出,但是有logo
/home/eddard/IMG_20220530_165101.jpg
@xiaowenge 请问板子串口是怎么接的,用这个config 通过tf卡启动,可以启动看到logo,就是死活没有串口日志
@eddardzhu 串口接地了没有。
@mhcsoft 在 T113 MQ-R板子用tina 无法进入系统 中说:
大佬,这个文件与 brandy/brandy-2.0/u-boot-2018/configs/sun8iw20p1_evb2_defconfig 一模一样,一行都没改。
@memory 没贴错,你看错名 了 ,还是我俩版本不一样
@mhcsoft
能不能贴一下具体的选项呀!全局搜索了一下uboot 下面的 .config ,没发现打开OPTEE的选项被选中。 -
@captain 在 T113 MQ-R板子用tina 无法进入系统 中说:
@mhcsoft
能不能贴一下具体的选项呀!全局搜索了一下uboot 下面的 .config ,没发现打开OPTEE的选项被选中。同问
