    v821切换到spi nand flash(XT26G01CWSIG) 系统无法启动
    20
    5532
      QY157 LV 4 最后由 awwwwa 编辑
      日志如下:
      [0]HELLO! BOOT0 is starting!
      [0]BOOT0 commit :
      [0]set pll start
      [1]set pll end
      [1]reset_src: rtc wdg rst
      [2]reset_src: det rst
      [2]reset_src: pwron rst
      [3]board init ok: use hosc 40M
      [4]mode:0x1 sample delay:0xf
      [4]OperationOpt:7
      [4]spinand quad mode error
      [4]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [5]BOOT_PARAM_OFFSET:0x500000
      [6]boot param - magic error
      [6]DRAM use internal ZQ!!
      [7]ZQ value = 0x30
      [7]DRAM BOOT DRIVE INFO: V1.02
      [7]DRAM CLK = 520 MHz
      [7]DRAM Type = 2 (2:DDR2,3:DDR3)
      [7]DRAMC read ODT off.
      [8]DRAM ODT off.
      [8]ddr_clk0 = 1040 MHz
      [9]trefi: 7.8us
      [9]DRAM Size = 64 MB
      [11]DRAM simple test OK.
      [11]dram size =64
      [11]mode:0x1 sample delay:0xf
      [11]OperationOpt:7
      [11]spinand quad mode error
      [12]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [12]mode:0x1 sample delay:0xf
      [12]OperationOpt:7
      [13]spinand quad mode error
      [13]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [13]block from 8 to 32
      [141]Check is correct. Find a good uboot copy at block 8
      [142]dma 0x2009c7c int is not used yet
      [142]dma 0x2009c7c int is free, you do not need to free it again
      [142]Entry_name        = opensbi
      [143]Entry_name        = u-boot
      [145]Entry_name        = melis-elf
      [148]Jump to OpenSBI: opensbi_base = 0x80fc0000, dtb_base = 0x0, uboot_base = 0x82000000
      OpenSBI 92310c8ed361641fa38c20bd0073be189e0f1282
         ____                    _____ ____ _____
        / __ \                  / ____|  _ \_   _|
       | |  | |_ __   ___ _ __ | (___ | |_) || |
       | |  | | '_ \ / _ \ '_ \ \___ \|  _ < | |
       | |__| | |_) |  __/ | | |____) | |_) || |_
        \____/| .__/ \___|_| |_|_____/|____/_____|
              |_|
      init msb region pma attribute
      Platform Name             : sun300iw1
      Platform Features         : medeleg
      Platform HART Count       : 1
      Platform IPI Device       : sunxi_plicsw
      Platform Timer Device     : sunxi_plmt @ 40000000Hz
      Platform Console Device   : sunxi_uart
      Platform HSM Device       : ---
      Platform PMU Device       : ---
      Platform Reboot Device    : sunxi_wdt
      Platform Shutdown Device  : sunxi_wdt
      Firmware Base             : 0x80fc0400
      Firmware Size             : 75 KB
      Runtime SBI Version       : 0.3
      Domain0 Name              : root
      Domain0 Boot HART         : 0
      Domain0 HARTs             : 0*
      Domain0 Region00          : 0x80fc0000-0x80fdffff ()
      Domain0 Region01          : 0x00000000-0xffffffff (R,W,X)
      Domain0 Next Address      : 0x82000000
      Domain0 Next Arg1         : 0x00000000
      Domain0 Next Mode         : S-mode
      Domain0 SysReset          : yes
      Boot HART ID              : 0
      Boot HART Domain          : root
      Boot HART ISA             : rv32imafdcnsux
      Boot HART Features        : scounteren,mcounteren,mcountinhibit,sscofpmf
      Boot HART PMP Count       : 64
      Boot HART PMP Granularity : 8
      Boot HART PMP Address Bits: 31
      Boot HART MHPM Count      : 4
      Boot HART MIDELEG         : 0x00000222
      Boot HART MEDELEG         : 0x0000b109
      U-Boot 2018.07 (Aug 15 2025 - 10:41:44 +0800) Allwinner Technology
      I2C:   ready
      [00.162]DRAM:  64 MiB
      [00.163]Relocation Offset is: 01f23000, reloc addr is: 83f23000
      [00.165]secure enable bit: 0
      [00.165]drivers/sunxi_power/pmu_axpnull.c pmu_axpnull_probe 26 axpdummy probe
      FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL
      [00.167]axp2601 pmic_bus_read fail
      [00.167]BMU: AXPNULL
      [00.168]CPU=960 MHz,PERI=3072 Mhz,AHB=192 Mhz, APB=96Mhz
      SPI ALL:   ready
      [00.170]flash init start
      [00.171]workmode = 0,storage type = 0
      [00.177]sunxi-spinand-phy: spinand sample_mode:1 sample_delay:f
      device nand0 <nand>, # parts = 4
       #: name		size		offset		mask_flags
       0: boot0               0x00100000	0x00000000	1
       1: uboot               0x00300000	0x00100000	1
       2: secure_storage      0x00100000	0x00400000	1
       3: sys                 0x07b00000	0x00500000	0
      active partition: nand0,0 - (boot0) 0x00100000 @ 0x00000000
      defaults:
      mtdids  : nand0=nand
      mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
      [00.330]ubi0: attaching mtd4
      [00.926]ubi0: scanning is finished
      [00.934]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [00.935]ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
      [00.935]ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
      [00.936]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [00.936]ubi0: good PEBs: 980, bad PEBs: 4, corrupted PEBs: 0
      [00.936]ubi0: user volume: 10, internal volumes: 1, max. volumes count: 128
      [00.937]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [00.938]ubi0: available PEBs: 0, total reserved PEBs: 980, PEBs reserved for bad PEB handling: 16
      [00.938]sunxi flash init ok
      [01.194]Loading Environment from SUNXI_FLASH... OK
      [01.235]usb burn from boot
      delay time 0
      [01.244]usb prepare ok
      [01.545]overtime
      [01.548]do_burn_from_boot usb : no usb exist
      List file under ULI/factory
      ** Unrecognized filesystem type **
      [01.575]update bootcmd
      [01.609]change working_fdt 0x838e2ea0 to 0x838c2ea0
      [01.617]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      [01.619]update dts
      Info: gmac phy mode = rmii, phy_interface = 6
      FDT ERROR:get muxsel err returned FDT_ERR_INTERNAL
      Error: gmac set pin failed
      [01.623]Board Net Initialization Failed
      [01.623]No ethernet found.
      Hit any key to stop autoboot:  0
      [02.238]no vendor_boot partition is found
      Android's image name: sun300i_riscv32
      Detect comp gzip
      ERROR: reserving fdt memory region failed (addr=80ffff00 size=100)
      [02.465]
      Starting kernel ...
      [    0.000000] Linux version 5.4.220 (yinqi@yinqi) (gcc version 10.4.0 (2024-02-02_nds32le-linux-glibc-v5d-bbc31ec98)) #2 PREEMPT Fri Aug 15 10:48:09 CST 2025
      [    0.000000] printk: bootconsole [earlycon0] enabled
      [    0.000000] Reserved memory: created CMA memory pool at 0x0000000083c00000, size 4 MiB
      [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
      [    0.000000] Reserved memory: created DMA memory pool at 0x0000000081200000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node vdev0buffer@81200000, compatible id shared-dma-pool
      [    0.000000] Reserved memory: created DMA memory pool at 0x0000000081646000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node e907_rpbuf@81646000, compatible id shared-dma-pool
      [    0.000000] Zone ranges:
      [    0.000000]   Normal   [mem 0x0000000080000000-0x0000000083ffffff]
      [    0.000000] Movable zone start for each node
      [    0.000000] Early memory node ranges
      [    0.000000]   node   0: [mem 0x0000000080000000-0x0000000080ffefff]
      [    0.000000]   node   0: [mem 0x0000000081244000-0x0000000081643fff]
      [    0.000000]   node   0: [mem 0x000000008164e000-0x0000000083ffffff]
      [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000083ffffff]
      [    0.000000] On node 0 totalpages: 15793
      [    0.000000]   Normal zone: 128 pages used for memmap
      [    0.000000]   Normal zone: 0 pages reserved
      [    0.000000]   Normal zone: 15793 pages, LIFO batch:3
      [    0.000000] SBI specification v0.3 detected
      [    0.000000] SBI implementation ID=0x1 Version=0x10000
      [    0.000000] SBI v0.2 TIME extension detected
      [    0.000000] SBI v0.2 IPI extension detected
      [    0.000000] SBI v0.2 RFENCE extension detected
      [    0.000000] SBI SRST extension detected
      [    0.000000] riscv: base ISA extensions acdfim
      [    0.000000] riscv: ELF capabilities acdfim
      [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
      [    0.000000] pcpu-alloc: [0] 0
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 15665
      [    0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x42500000 initcall_debug=0 console=ttyS0,1500000 loglevel=8 root=/dev/ubiblock0_7 rootwait rootfstype=squashfs init=/init rdinit=/rdinit partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:private@ubi0_5:riscv0@ubi0_6:rootfs@ubi0_7:rootfs_data@ubi0_8:UDISK@ubi0_9: cma=1M snum=7c000c71a300c822250 mac_addr= wifi_mac=60:c2:2a:12:48:6f bt_mac= selinux=0 specialstr= gpt=1 arm-smmu-v3.disable_bypass=0 androidboot.serialno=7c000c71a300c822250 androidboot.hardware=sun300iw1p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.07(08/15/2025-10:41:44) mbr_offset=1032192 bootreason=button aw-ubi-spinand.ubootblks=24 androidboot.dramfreq=520 androidboot.dramsize=64 mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys) uboot_backup=ubootA
      [    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
      [    0.000000] Sorting __ex_table...
      [    0.000000] Memory: 27108K/63172K available (5310K kernel code, 432K rwdata, 2008K rodata, 168K init, 345K bss, 31968K reserved, 4096K cma-reserved)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
      [    0.000000] rcu: Preemptible hierarchical RCU implementation.
      [    0.000000] 	Tasks RCU enabled.
      [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
      [    0.000000] NR_IRQS: 72, nr_irqs: 72, preallocated irqs: 0
      [    0.000000] plic: mapped 187 interrupts with 1 handlers for 2 contexts.
      [    0.000000] sunxi:ccu-ng:[INFO]: Current HOSC rate is 40000000HZ
      [    0.000000] AW BSP version: UNKNOWN, 2025-08-15 10:48:03
      [    0.000000] sunxi:ccu-ng:[INFO]: aon_ccu: sunxi ccu init OK
      [    0.000000] sunxi:ccu-ng:[INFO]: sunxi ccu common driver version: 1.2.4
      [    0.000000] sunxi:ccu-ng:[INFO]: ccu: sunxi ccu init OK
      [    0.000000] sunxi:ccu-ng:[INFO]: sunxi app ccu driver version: 0.7.2
      [    0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
      [    0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x939a85c40, max_idle_ns: 440795202120 ns
      [    0.000011] sched_clock: 64 bits at 40MHz, resolution 25ns, wraps every 4398046511100ns
      [    0.001079] Console: colour dummy device 80x25
      [    0.001158] Calibrating delay loop (skipped), value calculated using timer frequency.. 80.00 BogoMIPS (lpj=160000)
      [    0.001799] pid_max: default: 32768 minimum: 301
      [    0.002388] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.002723] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.005662] rcu: Hierarchical SRCU implementation.
      [    0.011077] devtmpfs: initialized
      [    0.032057] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
      [    0.032410] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
      [    0.033279] pinctrl core: initialized pinctrl subsystem
      [    0.041638] phys:80000000 low vir:c0000000 non-cache:dfc80000~e3c80000
      [    0.042819] NET: Registered protocol family 16
      [    0.048151] sunxi:ccu-ng:[INFO]: sunxi prcm ccu driver version: 0.0.4
      [    0.056385] sunxi:pin-42000000.pinctrl:[INFO]: pinctrl withstand voltage config mode=auto_hard
      [    0.056634] sunxi:pin:[INFO]: sunxi pinctrl core driver version: 1.4.8
      [    0.057827] sunxi:pin:[INFO]: sunxi rtc-pinctrl version: 0.0.2
      [    0.060225] sunxi:pin-42000540.pinctrl:[INFO]: pinctrl withstand voltage config mode=auto_hard
      [    0.064663] sunxi hwspinlock vbase:0x(ptrval)
      [    0.094655] SCSI subsystem initialized
      [    0.095049] usbcore: registered new interface driver usbfs
      [    0.095159] usbcore: registered new interface driver hub
      [    0.095544] usbcore: registered new device driver usb
      [    0.095997] mc: Linux media interface: v0.10
      [    0.096236] videodev: Linux video capture interface: v2.00
      [    0.097469] Advanced Linux Sound Architecture Driver Initialized.
      [    0.103063] sun6i-dma 43002000.dma-controller: sunxi dma probed, driver version: 1.2.11
      [    0.105049] sunxi-soc-regulator 4a000800.soc_pmu0: Supply for ldo1 (ldo1) resolved to itself
      [    0.105290] ldo1: supplied by regulator-dummy
      [    0.106476] ion_size_pool heap_size_pool@0: no small_source configurated, use cma as default
      [    0.108467] sunxi:pin-42000000.pinctrl:[INFO]: Auto power withstand voltage configuration detected, automatically exit!
      [    0.109089] sunxi-twi 42502000.twi0: 42502000.twi0 supply twi not found, using dummy regulator
      [    0.110457] sunxi:twi-42502000.twi0:[INFO]: v2.7.9 probe success
      [    0.111516] sunxi:pwm-42000c00.pwm:[INFO]: start probe
      [    0.112199] sunxi:pwm-42000c00.pwm:[INFO]: pwmchip probe success
      [    0.114694] clocksource: Switched to clocksource riscv_clocksource
      [    0.119503] thermal_sys: Registered thermal governor 'fair_share'
      [    0.119512] thermal_sys: Registered thermal governor 'bang_bang'
      [    0.119568] thermal_sys: Registered thermal governor 'step_wise'
      [    0.120057] thermal_sys: Registered thermal governor 'user_space'
      [    0.120486] thermal_sys: Registered thermal governor 'power_allocator'
      [    0.121571] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
      [    0.123059] sunxi_usb_udc 44100000.udc-controller: sunxi:sunxi_usb_udc UDC Inner DMA Feature - wordaddr: -1, extend: disabled
      [    0.124488] NET: Registered protocol family 2
      [    0.124847] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
      [    0.126023] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.126286] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.126967] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.127389] TCP: Hash tables configured (established 1024 bind 1024)
      [    0.128035] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
      [    0.128379] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
      [    0.129190] NET: Registered protocol family 1
      [    0.130036] RPC: Registered named UNIX socket transport module.
      [    0.130079] RPC: Registered udp transport module.
      [    0.130438] RPC: Registered tcp transport module.
      [    0.130942] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.132161] sunxi:spi-44025000.spi:[INFO]: spi manual set sample type_1, mode_1, delay_15
      [    0.132441] sunxi-spi-ng 44025000.spi: 44025000.spi supply spi not found, using dummy regulator
      [    0.133298] sunxi:spi-44025000.spi:[INFO]: bus num_0 mode_16 freq_100000000
      [    0.133573] sunxi:spi-44025000.spi:[INFO]: cs num_1 mode_1
      [    0.134045] of_dma_request_slave_channel: dma-names property of node '/soc@2002000/spi@44025000' missing or empty
      [    0.134926] sunxi:spi-44025000.spi:[ERR]: failed to request dma tx channel -19
      [    0.135557] sunxi:spi-44025000.spi:[WARN]: clk 100000000 not support, round to nearly 78769230
      [    0.136648] sunxi:spi-44025000.spi:[INFO]: probe success (Version 2.5.4)
      [    0.140353] workingset: timestamp_bits=30 max_order=13 bucket_order=0
      [    0.153175] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.154617] NFS: Registering the id_resolver key type
      [    0.154885] Key type id_resolver registered
      [    0.154913] Key type id_legacy registered
      [    0.155244] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    0.155757] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
      [    0.156672] fuse: init (API version 7.31)
      [    0.158230] NET: Registered protocol family 38
      [    0.158328] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
      [    0.158803] io scheduler mq-deadline registered
      [    0.159071] io scheduler kyber registered
      [    0.182643] loop: module loaded
      [    0.183676] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    0.183832] ehci-platform: EHCI generic platform driver
      [    0.184643] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    0.184758] ohci-platform: OHCI generic platform driver
      [    0.186474] usbcore: registered new interface driver uas
      [    0.186604] usbcore: registered new interface driver usb-storage
      [    0.187135] i2c /dev entries driver
      [    0.188465] usbcore: registered new interface driver usbhid
      [    0.188499] usbhid: USB HID core driver
      [    0.190424] uart-ng uart-ng0: uart-ng0 supply uart not found, using dummy regulator
      [    0.190929] sunxi:uart-ng-uart-ng0:[INFO]: cannot get the TX DMA channel!
      [    0.191121] sunxi:uart-ng-uart-ng0:[INFO]: cannot get the RX DMA channel!
      [    0.191728] sunxi:uart-ng:[INFO]: sunxi uart-ng driver version: 1.1.10
      [    0.192184] uart-ng0: ttyS0 at MMIO 0x42500000 (irq = 134, base_baud = 12000000) is a SUNXI
      [    0.192818] sunxi:uart-ng-uart-ng0:[INFO]: console setup baud 1500000 parity n bits 8, flow n
      [    0.193443] sunxi:uart-ng-uart-ng0:[INFO]: uart0, select set 6, baud 1500000, uartclk 192000000 beyond rance[24000000, 120000000]
      [    0.194407] printk: console [ttyS0] enabled
      [    0.195353] printk: bootconsole [earlycon0] disabled
      [    0.197491] sunxi:rtc-4a000c00.rtc:[WARN]: Fail to get clock 'rtc-1k'
      [    0.198340] sunxi:rtc-4a000c00.rtc:[WARN]: Fail to get clock 'rtc-spi'
      [    0.199297] sunxi:rtc:[INFO]:  Saving SoC boot-reason: COLD-BOOT
      [    0.200052] sunxi:rtc-4a000c00.rtc:[INFO]: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
      [    0.201334] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    0.202587] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    0.204182] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    0.205429] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    0.206657] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    0.208574] sunxi-rtc 4a000c00.rtc: registered as rtc0
      [    0.209276] sunxi:rtc_sun300iw1_frun_counter:[ERR]: rtc_frun_counter_init(83): rtc frun counter src not from extern32k osc
      [    0.210620] sunxi:rtc-4a000c00.rtc:[WARN]: clocksource not work: rtc free running counter
      [    0.211673] sunxi:rtc-4a000c00.rtc:[INFO]: sunxi rtc probed
      [    0.214209] sunxi-wdt 4a001000.watchdog: Watchdog enabled (timeout=300 sec, nowayout=0), driver version: 1.0.5
      [    0.217946] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: SD/MMC/SDIO Host Controller Driver(v5.55 2024-08-26 15:32)
      [    0.219496] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: ctl-spec-caps 8
      [    0.220385] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vmmc regulator found
      [    0.221294] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vqmmc regulator found
      [    0.222196] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vdmmc regulator found
      [    0.223120] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vd33sw regulator found
      [    0.224027] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vd18sw regulator found
      [    0.224935] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vq33sw regulator found
      [    0.225847] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vq18sw regulator found
      [    0.226781] sunxi:sunxi_mmc_host-44020000.sdmmc:[ERR]: manual set ocr
      [    0.227585] sunxi:sunxi_mmc_host-44020000.sdmmc:[WARN]: Cann't get pin bias hs pinstate,check if needed
      [    0.228831] sunxi:sunxi_mmc_host-44020000.sdmmc:[ERR]: Could not get store clock
      [    0.229760] sunxi:sunxi_mmc_host-44020000.sdmmc:[ERR]: Could not get msi_lite clock
      [    0.231262] sunxi-mmc 44020000.sdmmc: Got CD GPIO
      [    0.231985] sunxi-mmc 44020000.sdmmc: sunxi:sunxi_mmc_hostcd-set-debounce is missing, function is no used
      [    0.233806] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    0.247734] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    0.262047] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: detmode:gpio irq
      [    0.265212] sunxi:g2d_sunxi:[INFO]: [G2D]: rcq version initialized.major:245
      [    0.266098] sunxi:g2d_sunxi:[INFO]: [G2D]: g2d_module_init
      [    0.267974] sunxi:gpadc:[INFO]: sunxi_gpadc_init(): 2148: gpadc class register success
      [    0.269444] sunxi:gpadc-42009000.gpadc0:[WARN]: warn: sample rate not set
      [    0.270781] input: sunxi-gpadc0/channel0/input0 as /devices/platform/soc@2002000/42009000.gpadc0/input/input0
      [    0.272603] input: sunxi-gpadc0/channel1/input0 as /devices/platform/soc@2002000/42009000.gpadc0/input/input1
      [    0.274629] sunxi:gpadc-42009000.gpadc0:[INFO]: sunxi_gpadc probe success
      [    0.281842] sunxi-msgbox 43033000.msgbox: sunxi:sunxi_msgboxsunxi_msgbox_probe(): sunxi msgbox start probe
      [    0.283401] sunxi-msgbox 43033000.msgbox: sunxi:sunxi_msgboxsunxi_msgbox_probe(): sunxi msgbox probe success
      [    0.285972] sunxi-rproc 43030000.e907_rproc: sunxi rproc driver 2.4.3
      [    0.287102] sunxi-rproc 43030000.e907_rproc: rv-cfg base: 0x43030000, va: 0xdfc43000
      [    0.288137] sunxi-rproc 43030000.e907_rproc: find rproc standby error
      [    0.289201] sunxi-rproc 43030000.e907_rproc: timeout_ms: 6000
      [    0.289932] sunxi-rproc 43030000.e907_rproc: reset_type: 2
      [    0.290599] sunxi-rproc 43030000.e907_rproc: reg:        43031000
      [    0.291480] sunxi-rproc 43030000.e907_rproc: irq_num:    163
      [    0.292191] sunxi-rproc 43030000.e907_rproc: panic_on_timeout: 1
      [    0.293223] sunxi-rproc 43030000.e907_rproc: The bootloader doesn't boot up the remoteproc when auto-boot is enabled!
      [    0.294531] sunxi-rproc 43030000.e907_rproc: is_using_kernel_fw: 0
      [    0.295479] remoteproc remoteproc0: e907_rproc is available
      [    0.296342] sunxi-rproc 43030000.e907_rproc: sunxi rproc driver probe ok
      [    0.297988] sunxi-rpbuf-controller rpbuf_controller0@0: assigned reserved memory node e907_rpbuf@81646000
      [    0.300077] [ADDR_MGT] addr_mgt_probe: module version: v1.0.13
      [    0.301347] [ADDR_MGT] addr_mgt_probe: success.
      [    0.302458] NET: Registered protocol family 17
      [    0.303118] NET: Registered protocol family 15
      [    0.303803] Key type dns_resolver registered
      [    0.327081] UBI error: cannot open mtd sys, error -2
      [    0.327732] UBI: block: can't open volume on ubi0_-1, err=-19
      [    0.328437] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    0.329755] sunxi-rtc 4a000c00.rtc: setting system clock to 1970-01-01T00:00:02 UTC (2)
      [    0.333265] sunxi:disp:[WARN]: [DE]: not found boot_disp0
      [    0.334000] sunxi:disp:[WARN]: [DE]: sel 0, gamma_base=0xe4130040
      [    0.334875] sunxi:disp:[WARN]: [DE]: sel 0, gamma_ctrl_block 0xe4130040 val c352a000 dirty 0 size 8 gamma_tab_block 0xe4130100 val c352a0c0 dirty 0 size 1024
      [    0.337464] sunxi:disp:[ERR]: [FB]: fb_num 1 fb_format 0
      [    0.338175] sunxi:disp:[ERR]: [FB]: fbinfo: fb: 0, disp: 0 channel: 0 layer: 0 zorder: 16 w: 320 h: 192
      [    0.339649] sunxi:disp:[ERR]: [FB]: fb_num 0 use rot 0 degree0
      [    0.340394] sunxi:disp:[ERR]: [FB]: smooth display disp0: type64 mode4 disp1: type0 mode0
      [    0.343303] sunxi:disp:[ERR]: [FB]: display logo on display 0 channel 0 layer 0 type 0
      [    0.344407] sunxi:disp:[ERR]: [FB]: fb 0 vir 0x(ptrval) phy 0x83c80000
      [    0.345222] sunxi:disp:[ERR]: [FB]: platform_fb_post_init start
      [    0.346303] sunxi:disp:[WARN]: [DE]: attached ok, mgr0<-->dev0
      [    0.347098] sunxi:disp:[WARN]: [DE]: type:64,mode:4,fmt:rgb,bits:8bits,eotf:0,cs:0 dvi_hdmi:2, range:0 scan:0 ratio:8
      [    0.349612] sunxi:sound-common:[ERR]: 301 pacfg_level_trig_init(): pa-pin-0 (79) request failed
      [    0.350769] sunxi:sound-common:[ERR]: 612 snd_sunxi_pa_pin_init(): pacfg_level_trig_init failed
      [    0.353290] sunxi:sound-i2s:[WARN]: 2206 snd_sunxi_dts_params_init(): clk-en-post-delay missing
      [    0.354388] sunxi:sound-i2s:[WARN]: 2214 snd_sunxi_dts_params_init(): clk-keep missing
      [    0.356164] sunxi:sound-mach:[WARN]: 372 asoc_simple_parse_ucfmt(): set data late to default
      [    0.357653] debugfs: Directory 'soc@2002000:codec_plat' with parent 'audiocodec' already present!
      [    0.359023] sunxi-snd-mach soc@2002000:codec_mach: 42030000.codec <-> soc@2002000:codec_plat mapping ok
      [    0.361686] sunxi:sound-mach:[WARN]: 372 asoc_simple_parse_ucfmt(): set data late to default
      [    0.362839] sunxi-snd-mach soc@2002000:i2s0_mach: No 'sound-dai' property
      [    0.364009] debugfs: Directory '42032000.i2s0_plat' with parent 'sndi2s0' already present!
      [    0.365273] sunxi-snd-mach soc@2002000:i2s0_mach: snd-soc-dummy-dai <-> 42032000.i2s0_plat mapping ok
      [    0.372382] ALSA device list:
      [    0.372797]   #0: audiocodec
      [    0.373151]   #1: sndi2s0
      [    0.373742] sunxi:uart-ng-uart-ng0:[INFO]: uart0, select set 6, baud 1500000, uartclk 192000000 beyond rance[24000000, 120000000]
      [    0.375365] Waiting for root device /dev/ubiblock0_7...
      [    0.462775] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    0.464227] sunxi:pin-42000000.pinctrl:[INFO]: Auto power withstand voltage configuration detected, automatically exit!
      [    1.378907] sunxi_usb_udc 44100000.udc-controller: 44100000.udc-controller supply udc not found, using dummy regulator
        awwwwa LV 8 最后由 编辑
        使用quick_config 配置的吗
        Q 1 条回复 最后回复 回复 引用 分享 1
          QY157 LV 4 @awwwwa 最后由 编辑
          @awwwwa 是的
            awwwwa LV 8 最后由 编辑
            看日志是内核整套ubi都没开起来,可以再次运行quick_config,重新编译SDK测试下
            Q 2 条回复 最后回复 回复 引用 分享 1
              @awwwwa 重新 make distclean 并且 重新quick_config 还是一样的问题,这个要怎么解决呢?
                @awwwwa Waiting for root device /dev/ubiblock0_7 中 ubiblock0_7 名字是否正确,是不是因为这个名字错了,无法进入文件系统的情况下怎么查看这个名字,在uboot中能查看吗?
                  jasjac LV 2 最后由 编辑
                  @qy157 在 v821切换到spi nand flash(XT26G01CWSIG) 系统无法启动 中说:
                  这个问题解决了吗?
                    awwwwa LV 8 最后由 编辑
                    测试了下,正常启动NAND,启动日志如下
                    [3]BOOT0 commit : c620eacf52-dirty
                    [6]set pll start
                    [10]set pll end
                    [11]reset_src: rtc wdg rst
                    [13]reset_src: det rst
                    [15]reset_src: pwron rst
                    [18]board init ok: use hosc 40M
                    [21]rtc[5] value = 0xb0000000
                    [24]mode:0x1 sample delay:0xc
                    [26]OperationOpt:7
                    [28]spinand quad mode error
                    [31]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
                    [35]BOOT_PARAM_OFFSET:0x500000
                    [39]boot param - magic error
                    [42]DRAM use internal ZQ!!
                    [44]ZQ value = 0x2e
                    [46]DRAM BOOT DRIVE INFO: V1.02
                    [49]DRAM CLK = 520 MHz
                    [51]DRAM Type = 2 (2:DDR2,3:DDR3)
                    [54]DRAMC read ODT off.
                    [56]DRAM ODT off.
                    [58]ddr_clk0 = 1040 MHz
                    [61]trefi: 7.8us
                    [62]DRAM Size = 64 MB
                    [66]DRAM simple test OK.
                    [68]dram size =64
                    [70]mode:0x1 sample delay:0xc
                    [73]OperationOpt:7
                    [74]spinand quad mode error
                    [77]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
                    [82]mode:0x1 sample delay:0xc
                    [85]OperationOpt:7
                    [86]spinand quad mode error
                    [89]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
                    [94]block from 8 to 32
                    [220]Check is correct. Find a good uboot copy at block 8
                    [225]dma 0x2009d8c int is not used yet
                    [228]dma 0x2009d8c int is free, you do not need to free it again
                    [234]Entry_name        = opensbi
                    [237]Entry_name        = u-boot
                    [241]Entry_name        = melis-elf
                    [247]Jump to OpenSBI: opensbi_base = 0x80fc0000, dtb_base = 0x0, uboot_base = 0x82000000
                            |_|
                    Domain0 Name              : root
                    Domain0 HARTs             : 0*
                    Boot HART ID              : 0
                    U-Boot 2018.07-00001-g6c10d2cbd3-dirty (Aug 12 2025 - 15:29:57 +0800) Allwinner Technology
                    I2C:   ready
                    [00.408]DRAM:  64 MiB
                    [00.410]Relocation Offset is: 01f23000, reloc addr is: 83f23000
                    [00.418]secure enable bit: 0
                    [00.420]drivers/sunxi_power/pmu_axpnull.c pmu_axpnull_probe 26 axpdummy probe
                    [00.935]BMU: AXP2601
                    [00.937]CPU=960 MHz,PERI=3072 Mhz,AHB=192 Mhz, APB=96Mhz
                    SPI ALL:   ready
                    [00.946]flash init start
                    [00.948]workmode = 0,storage type = 0
                    [00.958]sunxi-spinand-phy: spinand sample_mode:1 sample_delay:c
                    defaults:
                    mtdids  : nand0=nand
                    [01.149]ubi0: attaching mtd4
                    [01.739]ubi0: scanning is finished
                    [01.749]ubi0: attached mtd4 (name "sys", size 123 MiB)
                    [01.754]ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
                    [01.760]ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
                    [01.767]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
                    [01.773]ubi0: good PEBs: 980, bad PEBs: 4, corrupted PEBs: 0
                    [01.778]ubi0: user volume: 10, internal volumes: 1, max. volumes count: 128
                    [01.785]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
                    [01.793]ubi0: available PEBs: 0, total reserved PEBs: 980, PEBs reserved for bad PEB handling: 16
                    [01.801]sunxi flash init ok
                    [02.054]Loading Environment from SUNXI_FLASH... OK
                    [02.099]usb burn from boot
                    delay time 0
                    [02.111]usb prepare ok
                    [02.377]usb sof ok
                    [02.379]usb probe ok
                    [02.380]usb setup ok
                    set address 0x36
                    set address 0x36 ok
                    try to update
                    [02.786]do_burn_from_boot usb : have no handshake
                    [02.822]update bootcmd
                    [02.858]change working_fdt 0x838e2ea0 to 0x838c2ea0
                    [02.874]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
                    [02.880]update dts
                    eth0
                    Warning: eth0 (eth0) using random MAC address - 3e:fd:af:11:ba:c6
                    [03.488]no vendor_boot partition is found
                    Detect comp gzip
                    [03.723]
                    Starting kernel ...
                    [    0.000000] Linux version 5.4.220 (awol@tina-dev) (gcc version 10.4.0 (2024-02-02_nds32le-linux-glibc-v5d-bbc31ec98)) #4 PREEMPT Tue Aug 12 15:30:27 HKT 2025
                    [    0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x42500000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/ubiblock0_7 rootwait rootfstype=squashfs init=/init rdinit=/rdinit partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:private@ubi0_5:riscv0@ubi0_6:rootfs@ubi0_7:rootfs_data@ubi0_8:UDISK@ubi0_9: cma=1M snum=0000000000000000000 mac_addr= wifi_mac= bt_mac= selinux=0 specialstr= gpt=1 arm-smmu-v3.disable_bypass=0 androidboot.serialno=0000000000000000000 androidboot.hardware=sun300iw1p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.07-00001-g6c10d2cbd3-dirty(08/12/2025-15:29:57) mbr_offset=1032192 bootreason=unknow aw-ubi-spinand.ubootblks=24 androidboot.dramfreq=520 androidboot.dramsize=64 mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys) uboot_backup=ubootA
                    [    0.000000] Memory: 27452K/63172K available (5134K kernel code, 357K rwdata, 1950K rodata, 172K init, 287K bss, 31624K reserved, 4096K cma-reserved)
                    [    0.000000] AW BSP version: a3b0c2d69e, 2025-08-11 13:06:54 +0800
                    [    0.008473] Console: colour dummy device 80x25
                    [    0.012473] Calibrating delay loop (skipped), value calculated using timer frequency.. 80.00 BogoMIPS (lpj=160000)
                    [    0.022711] pid_max: default: 32768 minimum: 301
                    [    0.027536] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                    [    0.034601] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                    [    0.044585] rcu: Hierarchical SRCU implementation.
                    [    0.053527] devtmpfs: initialized
                    [    0.078054] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
                    [    0.082252] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
                    [    0.089236] pinctrl core: initialized pinctrl subsystem
                    [    0.102476] phys:80000000 low vir:c0000000 non-cache:dfc80000~e3c80000
                    [    0.104464] NET: Registered protocol family 16
                    [    0.113253] sunxi:ccu-ng:[INFO]: sunxi prcm ccu driver version: 0.0.4
                    [    0.122260] sunxi:pin-42000000.pinctrl:[INFO]: pinctrl withstand voltage config mode=auto_hard
                    [    0.125298] sunxi:pin:[INFO]: sunxi pinctrl core driver version: 1.4.8
                    [    0.132293] sunxi:pin:[INFO]: sunxi rtc-pinctrl version: 0.0.2
                    [    0.140009] sunxi:pin-42000540.pinctrl:[INFO]: pinctrl withstand voltage config mode=auto_hard
                    [    0.150847] sunxi hwspinlock vbase:0x(ptrval)
                    [    0.181230] SCSI subsystem initialized
                    [    0.181650] usbcore: registered new interface driver usbfs
                    [    0.185528] usbcore: registered new interface driver hub
                    [    0.190353] usbcore: registered new device driver usb
                    [    0.195430] mc: Linux media interface: v0.10
                    [    0.199500] videodev: Linux video capture interface: v2.00
                    [    0.205746] Advanced Linux Sound Architecture Driver Initialized.
                    [    0.216000] sun6i-dma 43002000.dma-controller: sunxi dma probed, driver version: 1.2.11
                    [    0.220776] sunxi-soc-regulator 4a000800.soc_pmu0: Supply for ldo1 (ldo1) resolved to itself
                    [    0.227351] ldo1: supplied by regulator-dummy
                    [    0.232403] ion_size_pool heap_size_pool@0: no small_source configurated, use cma as default
                    [    0.241950] sunxi:pin-42000000.pinctrl:[INFO]: Auto power withstand voltage configuration detected, automatically exit!
                    [    0.251068] sunxi-twi 42502000.twi0: 42502000.twi0 supply twi not found, using dummy regulator
                    [    0.260114] sunxi:twi-42502000.twi0:[INFO]: v2.7.9 probe success
                    [    0.266432] sunxi:pwm-42000c00.pwm:[INFO]: start probe
                    [    0.267149] sunxi:pwm-42000c00.pwm:[INFO]: pwmchip probe success
                    [    0.278460] clocksource: Switched to clocksource riscv_clocksource
                    [    0.287335] thermal_sys: Registered thermal governor 'fair_share'
                    [    0.287344] thermal_sys: Registered thermal governor 'bang_bang'
                    [    0.288670] thermal_sys: Registered thermal governor 'step_wise'
                    [    0.294704] thermal_sys: Registered thermal governor 'user_space'
                    [    0.300637] thermal_sys: Registered thermal governor 'power_allocator'
                    [    0.307346] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
                    [    0.321990] sunxi_usb_udc 44100000.udc-controller: sunxi:sunxi_usb_udc UDC Inner DMA Feature - wordaddr: -1, extend: disabled
                    [    0.333426] NET: Registered protocol family 2
                    [    0.337145] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
                    [    0.345016] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
                    [    0.352427] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
                    [    0.359972] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
                    [    0.366989] TCP: Hash tables configured (established 1024 bind 1024)
                    [    0.373405] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
                    [    0.379794] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
                    [    0.387007] NET: Registered protocol family 1
                    [    0.391836] RPC: Registered named UNIX socket transport module.
                    [    0.397017] RPC: Registered udp transport module.
                    [    0.401607] RPC: Registered tcp transport module.
                    [    0.406304] RPC: Registered tcp NFSv4.1 backchannel transport module.
                    [    0.413614] sunxi:spi-44025000.spi:[INFO]: spi manual set sample type_1, mode_1, delay_12
                    [    0.421012] sunxi-spi-ng 44025000.spi: 44025000.spi supply spi not found, using dummy regulator
                    [    0.429752] sunxi:spi-44025000.spi:[INFO]: bus num_0 mode_16 freq_100000000
                    [    0.436504] sunxi:spi-44025000.spi:[INFO]: cs num_1 mode_1
                    [    0.442165] sunxi:spi-44025000.spi:[WARN]: clk 100000000 not support, round to nearly 78769230
                    [    0.451312] sunxi:spi-44025000.spi:[WARN]: clk 100000000 not support, round to nearly 78769230
                    [    0.459519] sunxi:spi-44025000.spi:[INFO]: probe success (Version 2.5.5)
                    [    0.469435] workingset: timestamp_bits=30 max_order=13 bucket_order=0
                    [    0.484916] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                    [    0.486566] NFS: Registering the id_resolver key type
                    [    0.490248] Key type id_resolver registered
                    [    0.494393] Key type id_legacy registered
                    [    0.498351] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                    [    0.505034] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
                    [    0.512724] fuse: init (API version 7.31)
                    [    0.517883] NET: Registered protocol family 38
                    [    0.520924] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
                    [    0.528157] io scheduler mq-deadline registered
                    [    0.532647] io scheduler kyber registered
                    [    0.559966] loop: module loaded
                    [    0.560986] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                    [    0.564099] ehci-platform: EHCI generic platform driver
                    [    0.569754] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                    [    0.575427] ohci-platform: OHCI generic platform driver
                    [    0.582004] usbcore: registered new interface driver uas
                    [    0.586066] usbcore: registered new interface driver usb-storage
                    [    0.591997] i2c /dev entries driver
                    [    0.596628] usbcore: registered new interface driver usbhid
                    [    0.600921] usbhid: USB HID core driver
                    [    0.606390] uart-ng uart-ng0: uart-ng0 supply uart not found, using dummy regulator
                    [    0.612609] sunxi:uart-ng-uart-ng0:[INFO]: cannot get the TX DMA channel!
                    [    0.619134] sunxi:uart-ng-uart-ng0:[INFO]: cannot get the RX DMA channel!
                    [    0.625908] sunxi:uart-ng:[INFO]: sunxi uart-ng driver version: 1.1.10
                    [    0.632371] uart-ng0: ttyS0 at MMIO 0x42500000 (irq = 134, base_baud = 12000000) is a SUNXI
                    [    0.640682] sunxi:uart-ng-uart-ng0:[INFO]: console setup baud 115200 parity n bits 8, flow n
                    [    0.649051] sunxi:uart-ng-uart-ng0:[INFO]: uart0, select set 0, baud 115200, uartclk 192000000 beyond rance[24000000, 120000000]
                    [    0.660666] printk: console [ttyS0] enabled
                    [    0.670917] printk: bootconsole [earlycon0] disabled
                    [    0.681979] sunxi:rtc-4a000c00.rtc:[WARN]: Fail to get clock 'rtc-1k'
                    [    0.692901] sunxi:rtc-4a000c00.rtc:[WARN]: Fail to get clock 'rtc-spi'
                    [    0.700394] sunxi:rtc:[INFO]:  Saving SoC boot-reason: COLD-BOOT
                    [    0.707210] sunxi:rtc-4a000c00.rtc:[INFO]: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
                    [    0.719011] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
                    [    0.730404] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
                    [    0.742084] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
                    [    0.753512] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
                    [    0.764935] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
                    [    0.777021] sunxi-rtc 4a000c00.rtc: registered as rtc0
                    [    0.782939] sunxi:rtc_sun300iw1_frun_counter:[ERR]: rtc_frun_counter_init(83): rtc frun counter src not from extern32k osc
                    [    0.795407] sunxi:rtc-4a000c00.rtc:[WARN]: clocksource not work: rtc free running counter
                    [    0.804659] sunxi:rtc-4a000c00.rtc:[INFO]: sunxi rtc probed
                    [    0.812830] sunxi-wdt 4a001000.watchdog: Watchdog enabled (timeout=300 sec, nowayout=0), driver version: 1.0.5
                    [    0.826837] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: SD/MMC/SDIO Host Controller Driver(v5.55 2024-08-26 15:32)
                    [    0.838848] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: ctl-spec-caps 8
                    [    0.846404] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vmmc regulator found
                    [    0.854697] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vqmmc regulator found
                    [    0.863074] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vdmmc regulator found
                    [    0.871477] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vd33sw regulator found
                    [    0.879926] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vd18sw regulator found
                    [    0.888389] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vq33sw regulator found
                    [    0.896838] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vq18sw regulator found
                    [    0.905302] sunxi:sunxi_mmc_host-44020000.sdmmc:[ERR]: manual set ocr
                    [    0.912630] sunxi:sunxi_mmc_host-44020000.sdmmc:[WARN]: Cann't get pin bias hs pinstate,check if needed
                    [    0.923362] sunxi:sunxi_mmc_host-44020000.sdmmc:[ERR]: Could not get store clock
                    [    0.931752] sunxi:sunxi_mmc_host-44020000.sdmmc:[ERR]: Could not get msi_lite clock
                    [    0.940967] sunxi-mmc 44020000.sdmmc: Got CD GPIO
                    [    0.946499] sunxi-mmc 44020000.sdmmc: sunxi:sunxi_mmc_hostcd-set-debounce is missing, function is no used
                    [    0.957969] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [    0.983495] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [    1.009792] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: detmode:gpio irq
                    [    1.018678] sunxi:sunxi-spinand:[INFO]: AW SPINand MTD Layer Version: 2.7 20240110
                    [    1.027261] sunxi:sunxi-spinand-phy:[INFO]: AW SPINand Phy Layer Version: 1.13 20231109
                    [    1.036560] sunxi:sunxi-spinand-phy:[INFO]: detect munufacture from id table: XTX
                    [    1.045025] sunxi:sunxi-spinand-phy:[INFO]: detect spinand id: ffff110b ffffffff
                    [    1.053395] sunxi:sunxi-spinand-phy:[INFO]: ========== arch info ==========
                    [    1.061279] sunxi:sunxi-spinand-phy:[INFO]: Model:               XT26G01C
                    [    1.068961] sunxi:sunxi-spinand-phy:[INFO]: Munufacture:         XTX
                    [    1.076139] sunxi:sunxi-spinand-phy:[INFO]: DieCntPerChip:       1
                    [    1.083138] sunxi:sunxi-spinand-phy:[INFO]: BlkCntPerDie:        1024
                    [    1.090414] sunxi:sunxi-spinand-phy:[INFO]: PageCntPerBlk:       64
                    [    1.097512] sunxi:sunxi-spinand-phy:[INFO]: SectCntPerPage:      4
                    [    1.104509] sunxi:sunxi-spinand-phy:[INFO]: OobSizePerPage:      64
                    [    1.111589] sunxi:sunxi-spinand-phy:[INFO]: BadBlockFlag:        0x0
                    [    1.118781] sunxi:sunxi-spinand-phy:[INFO]: OperationOpt:        0x7
                    [    1.125958] sunxi:sunxi-spinand-phy:[INFO]: MaxEraseTimes:       50000
                    [    1.133348] sunxi:sunxi-spinand-phy:[INFO]: EccFlag:             0x0
                    [    1.140540] sunxi:sunxi-spinand-phy:[INFO]: EccType:             11
                    [    1.147637] sunxi:sunxi-spinand-phy:[INFO]: EccProtectedType:    1
                    [    1.154632] sunxi:sunxi-spinand-phy:[INFO]: ========================================
                    [    1.163372] sunxi:sunxi-spinand-phy:[INFO]:
                    [    1.168203] sunxi:sunxi-spinand-phy:[INFO]: ========== physical info ==========
                    [    1.176480] sunxi:sunxi-spinand-phy:[INFO]: TotalSize:    128 M
                    [    1.183169] sunxi:sunxi-spinand-phy:[INFO]: SectorSize:   512 B
                    [    1.189874] sunxi:sunxi-spinand-phy:[INFO]: PageSize:     2 K
                    [    1.196382] sunxi:sunxi-spinand-phy:[INFO]: BlockSize:    128 K
                    [    1.203072] sunxi:sunxi-spinand-phy:[INFO]: OOBSize:      64 B
                    [    1.209661] sunxi:sunxi-spinand-phy:[INFO]: ========================================
                    [    1.218502] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                    [    1.231569] sunxi:sunxi-spinand-phy:[INFO]:
                    [    1.236410] sunxi:sunxi-spinand-phy:[INFO]: ========== logical info ==========
                    [    1.244615] sunxi:pin-42000000.pinctrl:[INFO]: Auto power withstand voltage configuration detected, automatically exit!
                    [    1.256810] sunxi:sunxi-spinand-phy:[INFO]: TotalSize:    128 M
                    [    1.263516] sunxi:sunxi-spinand-phy:[INFO]: SectorSize:   512 B
                    [    1.270263] sunxi:sunxi-spinand-phy:[INFO]: PageSize:     2 K
                    [    1.276805] sunxi:sunxi-spinand-phy:[INFO]: BlockSize:    128 K
                    [    1.283499] sunxi:sunxi-spinand-phy:[INFO]: OOBSize:      64 B
                    [    1.290090] sunxi:sunxi-spinand-phy:[INFO]: ========================================
                    [    1.298987] sunxi:sunxi-spinand-phy:[INFO]: block lock register: 0x00
                    [    1.307559] sunxi:sunxi-spinand-phy:[INFO]: feature register: 0x11
                    [    1.314652] sunxi:sunxi-spinand-phy:[INFO]: sunxi physic nand init end
                    [    1.322545] Creating 4 MTD partitions on "nand":
                    [    1.327877] 0x000000000000-0x000000100000 : "boot0"
                    [    1.347915] 0x000000100000-0x000000400000 : "uboot"
                    [    1.379900] 0x000000400000-0x000000500000 : "secure_storage"
                    [    1.399878] 0x000000500000-0x000008000000 : "sys"
                    [    1.544147] sunxi:sunxi-spinand-phy:[INFO]: phy blk 245 is bad
                    [    1.690664] sunxi:sunxi-spinand-phy:[INFO]: phy blk 440 is bad
                    [    1.827269] sunxi:sunxi-spinand-phy:[INFO]: phy blk 635 is bad
                    [    1.969603] sunxi:sunxi-spinand-phy:[INFO]: phy blk 830 is bad
                    [    2.117528] sunxi:g2d_sunxi:[INFO]: [G2D]: rcq version initialized.major:244
                    [    2.125590] sunxi:g2d_sunxi:[INFO]: [G2D]: g2d_module_init
                    [    2.133796] sunxi:gmac-44500000.gmac:[INFO]: Dts rx-delay: 0
                    [    2.140309] sunxi:gmac-44500000.gmac:[INFO]: Not found delay-maps in dts
                    [    2.147893] sunxi:gmac-44500000.gmac:[INFO]: Get max-mtu: 950
                    [    2.155382] sunxi:gmac-eth0:[INFO]: Use random mac address
                    [    2.162208] sunxi:gpadc:[INFO]: sunxi_gpadc_init(): 2236: gpadc class register success
                    [    2.171963] sunxi:gpadc-42009000.gpadc0:[WARN]: warn: sample rate not set
                    [    2.180074] input: sunxi-gpadc0/channel0/input0 as /devices/platform/soc@2002000/42009000.gpadc0/input/input0
                    [    2.192253] sunxi:gpadc-42009000.gpadc0:[INFO]: sunxi_gpadc probe success
                    [    2.206829] sunxi-msgbox 43033000.msgbox: sunxi:sunxi_msgboxsunxi_msgbox_probe(): sunxi msgbox start probe
                    [    2.218073] sunxi-msgbox 43033000.msgbox: sunxi:sunxi_msgboxsunxi_msgbox_probe(): sunxi msgbox probe success
                    [    2.230771] sunxi-rproc 43030000.e907_rproc: sunxi rproc driver 2.4.3
                    [    2.238295] sunxi-rproc 43030000.e907_rproc: rv-cfg base: 0x43030000, va: 0xdfc55000
                    [    2.247222] sunxi-rproc 43030000.e907_rproc: find rproc standby error
                    [    2.254819] sunxi-rproc 43030000.e907_rproc: timeout_ms: 6000
                    [    2.261400] sunxi-rproc 43030000.e907_rproc: reset_type: 2
                    [    2.267669] sunxi-rproc 43030000.e907_rproc: reg:        43031000
                    [    2.274572] sunxi-rproc 43030000.e907_rproc: irq_num:    164
                    [    2.280983] sunxi-rproc 43030000.e907_rproc: panic_on_timeout: 1
                    [    2.288113] sunxi-rproc 43030000.e907_rproc: The bootloader doesn't boot up the remoteproc when auto-boot is enabled!
                    [    2.300141] sunxi-rproc 43030000.e907_rproc: is_using_kernel_fw: 0
                    [    2.307290] remoteproc remoteproc0: e907_rproc is available
                    [    2.313790] sunxi-rproc 43030000.e907_rproc: sunxi rproc driver probe ok
                    [    2.322256] sunxi-rpbuf-controller rpbuf_controller0@0: assigned reserved memory node e907_rpbuf@81646000
                    [    2.334074] [ADDR_MGT] addr_mgt_probe: module version: v1.0.13
                    [    2.341603] [ADDR_MGT] addr_mgt_probe: success.
                    [    2.347172] sunxi:sunxi_startup_info-startup_info:[INFO]: startup source record: cold_boot
                    [    2.356939] NET: Registered protocol family 17
                    [    2.362057] NET: Registered protocol family 15
                    [    2.367265] Key type dns_resolver registered
                    [    2.395290] ubi0: attaching mtd3
                    [    2.414519] sunxi:ccu-ng-4a000000.prcm_ccu:[ERR]: enable extern 32k error
                    [    2.422354] sunxi:ccu-ng-4a000000.prcm_ccu:[WARN]: enable extern 32k error, change rccal
                    [    3.042557] random: crng init done
                    [    3.602697] ubi0: scanning is finished
                    [    3.620458] ubi0 warning: ubi_eba_init: cannot reserve enough PEBs for bad PEB handling, reserved 16, need 36
                    [    3.635294] ubi0: attached mtd3 (name "sys", size 123 MiB)
                    [    3.641574] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
                    [    3.649362] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
                    [    3.657062] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
                    [    3.664936] ubi0: good PEBs: 980, bad PEBs: 4, corrupted PEBs: 0
                    [    3.671735] ubi0: user volume: 10, internal volumes: 1, max. volumes count: 128
                    [    3.679999] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
                    [    3.689437] ubi0: available PEBs: 0, total reserved PEBs: 980, PEBs reserved for bad PEB handling: 16
                    [    3.699868] ubi0: background thread "ubi_bgt0d" started, PID 45
                    [    3.709256] block ubiblock0_7: created from ubi0:7(rootfs)
                    [    3.715596] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
                    [    3.727065] sunxi-rtc 4a000c00.rtc: setting system clock to 1970-01-01T00:00:08 UTC (8)
                    [    3.737914] sunxi:sound-common:[WARN]: 326 pacfg_level_trig_init(): pa-pin-msleep1-0 get failed, default 0
                    [    3.750718] sunxi:sound-i2s:[WARN]: 2206 snd_sunxi_dts_params_init(): clk-en-post-delay missing
                    [    3.760600] sunxi:sound-i2s:[WARN]: 2214 snd_sunxi_dts_params_init(): clk-keep missing
                    [    3.770356] sunxi:sound-mach:[WARN]: 372 asoc_simple_parse_ucfmt(): set data late to default
                    [    3.780423] debugfs: Directory 'soc@2002000:codec_plat' with parent 'audiocodec' already present!
                    [    3.790778] sunxi-snd-mach soc@2002000:codec_mach: 42030000.codec <-> soc@2002000:codec_plat mapping ok
                    [    3.803000] sunxi:sound-mach:[WARN]: 372 asoc_simple_parse_ucfmt(): set data late to default
                    [    3.812660] sunxi-snd-mach soc@2002000:i2s0_mach: No 'sound-dai' property
                    [    3.820722] debugfs: Directory '42032000.i2s0_plat' with parent 'sndi2s0' already present!
                    [    3.830363] sunxi-snd-mach soc@2002000:i2s0_mach: snd-soc-dummy-dai <-> 42032000.i2s0_plat mapping ok
                    [    4.023782] ALSA device list:
                    [    4.027257]   #0: audiocodec
                    [    4.030547]   #1: sndi2s0
                    [    4.033762] sunxi:uart-ng-uart-ng0:[INFO]: uart0, select set 0, baud 115200, uartclk 192000000 beyond rance[24000000, 120000000]
                    [    4.052878] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
                    [    4.067067] devtmpfs: mounted
                    [    4.070705] Freeing unused kernel memory: 172K
                    [    4.075775] This architecture does not have kernel memory protection.
                    [    4.083069] Run /init as init process
                    mount: mounting none on /dev failed: Resource busy
                    [    4.626213] UBIFS (ubi0:8): Mounting in unauthenticated mode
                    [    4.633237] UBIFS (ubi0:8): background thread "ubifs_bgt0_8" started, PID 83
                    [    4.701713] UBIFS (ubi0:8): recovery needed
                    [    4.804595] UBIFS (ubi0:8): recovery completed
                    [    4.810397] UBIFS (ubi0:8): UBIFS: mounted UBI device 0, volume 8, name "rootfs_data"
                    [    4.819351] UBIFS (ubi0:8): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
                    [    4.830657] UBIFS (ubi0:8): FS size: 4063232 bytes (3 MiB, 32 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
                    [    4.842176] UBIFS (ubi0:8): reserved for root: 191915 bytes (187 KiB)
                    [    4.849495] UBIFS (ubi0:8): media format: w5/r0 (latest is w5/r0), UUID 424C0888-89F6-4FAB-9AD1-5CDE86100932, small LPT model
                    Cannot get MTD information for /dev/by-name/env
                    Cannot get MTD information for /dev/by-name/env-redund
                    [    4.891360] overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off.
                    init started: BusyBox v1.33.2 (2025-07-09 02:10:56 UTC)
                    starting pid 99, tty '': '/etc/init.d/rcS boot'
                    [    4.985831] UBIFS (ubi0:9): Mounting in unauthenticated mode
                    [    4.992663] UBIFS (ubi0:9): background thread "ubifs_bgt0_9" started, PID 104
                    [    5.038705] sunxi_usb_udc 44100000.udc-controller: 44100000.udc-controller supply udc not found, using dummy regulator
                    [    5.073903] UBIFS (ubi0:9): recovery needed
                    [    5.120995] UBIFS (ubi0:9): recovery completed
                    [    5.126773] UBIFS (ubi0:9): UBIFS: mounted UBI device 0, volume 9, name "UDISK"
                    [    5.135252] UBIFS (ubi0:9): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
                    [    5.146495] UBIFS (ubi0:9): FS size: 53202944 bytes (50 MiB, 419 LEBs), journal size 2666496 bytes (2 MiB, 21 LEBs)
                    [    5.158282] UBIFS (ubi0:9): reserved for root: 2512906 bytes (2454 KiB)
                    [    5.165791] UBIFS (ubi0:9): media format: w5/r0 (latest is w5/r0), UUID 6883688F-2146-4B9E-A8A4-C73BDED33919, small LPT model
                    ------run rc.final file-----
                    Load mpp modules
                    [    5.401512] sunxi:vin:[WARN]: sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
                    [    5.425962] sunxi:vin:[WARN]: sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
                    [    5.445572] sunxi:vin:[WARN]: sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
                    [    5.465086] sunxi:vin:[WARN]: sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
                    sh: write error: Invalid argument
                    [    5.540911] file system registered
                    [    5.590915] udc 44100000.udc-controller: failed to start g1: -19
                    sh: write error: No such device
                    sh: 0000000000000000000: unknown operand
                    [    5.694148] read descriptors
                    [    5.697669] read strings
                    [    5.991427] sunxi:vin:[WARN]: get csi isp clk fail
                    [    5.996962] sunxi:vin:[WARN]: get csi isp src clk fail
                    [    6.004206] sunxi:vin:[INFO]: [gc1084_mipi]PWR_ON!
                    [    6.011447] sunxi:twi-42502000.twi0:[ERR]: drv-mode: Timeout when sending 9th SCL clk
                    [    6.020281] sunxi:twi-42502000.twi0:[ERR]: drv mode: TWI BUS error state is drv:0x1 eng:0x20
                    [    6.029914] sunxi:twi-42502000.twi0:[ERR]: drv-mode: xfer failed (dev addr:0x37)
                    [    6.038442] sunxi:twi-42502000.twi0:[ERR]: drv-mode: Timeout when sending 9th SCL clk
                    [    6.047267] sunxi:twi-42502000.twi0:[ERR]: drv mode: TWI BUS error state is drv:0x1 eng:0x20
                    [    6.056852] sunxi:twi-42502000.twi0:[ERR]: drv-mode: xfer failed (dev addr:0x37)
                    [    6.065320] sunxi:twi-42502000.twi0:[ERR]: drv-mode: Timeout when sending 9th SCL clk
                    [    6.074142] sunxi:twi-42502000.twi0:[ERR]: drv mode: TWI BUS error state is drv:0x1 eng:0x20
                    [    6.083741] sunxi:twi-42502000.twi0:[ERR]: drv-mode: xfer failed (dev addr:0x37)
                    [    6.092194] sunxi:vin:[INFO]: [VIN_DEV_I2C]gc1084_mipi read retry 3, read addr is 0x3f0
                    [    6.304889] configfs-gadget gadget: high-speed config #1: c
                    [    6.320554] sunxi:twi-42502000.twi0:[ERR]: drv-mode: Timeout when sending 9th SCL clk
                    [    6.329383] sunxi:twi-42502000.twi0:[ERR]: drv mode: TWI BUS error state is drv:0x1 eng:0x20
                    [    6.338934] sunxi:twi-42502000.twi0:[ERR]: drv-mode: xfer failed (dev addr:0x37)
                    [    6.347407] sunxi:twi-42502000.twi0:[ERR]: drv-mode: Timeout when sending 9th SCL clk
                    [    6.356254] sunxi:twi-42502000.twi0:[ERR]: drv mode: TWI BUS error state is drv:0x1 eng:0x20
                    [    6.365802] sunxi:twi-42502000.twi0:[ERR]: drv-mode: xfer failed (dev addr:0x37)
                    [    6.374258] sunxi:twi-42502000.twi0:[ERR]: drv-mode: Timeout when sending 9th SCL clk
                    [    6.383103] sunxi:twi-42502000.twi0:[ERR]: drv mode: TWI BUS error state is drv:0x1 eng:0x20
                    [    6.392646] sunxi:twi-42502000.twi0:[ERR]: drv-mode: xfer failed (dev addr:0x37)
                    [    6.401032] sunxi:vin:[INFO]: [VIN_DEV_I2C]gc1084_mipi read retry 3, read addr is 0x3f0
                    [    6.629528] sunxi:twi-42502000.twi0:[ERR]: drv-mode: Timeout when sending 9th SCL clk
                    [    6.638352] sunxi:twi-42502000.twi0:[ERR]: drv mode: TWI BUS error state is drv:0x1 eng:0x20
                    [    6.647893] sunxi:twi-42502000.twi0:[ERR]: drv-mode: xfer failed (dev addr:0x37)
                    [    6.656324] sunxi:twi-42502000.twi0:[ERR]: drv-mode: Timeout when sending 9th SCL clk
                    [    6.665147] sunxi:twi-42502000.twi0:[ERR]: drv mode: TWI BUS error state is drv:0x1 eng:0x20
                    [    6.674716] sunxi:twi-42502000.twi0:[ERR]: drv-mode: xfer failed (dev addr:0x37)
                    [    6.683172] sunxi:twi-42502000.twi0:[ERR]: drv-mode: Timeout when sending 9th SCL clk
                    [    6.691995] sunxi:twi-42502000.twi0:[ERR]: drv mode: TWI BUS error state is drv:0x1 eng:0x20
                    [    6.701562] sunxi:twi-42502000.twi0:[ERR]: drv-mode: xfer failed (dev addr:0x37)
                    [    6.709948] sunxi:vin:[INFO]: [VIN_DEV_I2C]gc1084_mipi read retry 3, read addr is 0x3f0
                    [    6.938532] sunxi:twi-42502000.twi0:[ERR]: drv-mode: Timeout when sending 9th SCL clk
                    [    6.947355] sunxi:twi-42502000.twi0:[ERR]: drv mode: TWI BUS error state is drv:0x1 eng:0x20
                    [    6.956897] sunxi:twi-42502000.twi0:[ERR]: drv-mode: xfer failed (dev addr:0x37)
                    [    6.965330] sunxi:twi-42502000.twi0:[ERR]: drv-mode: Timeout when sending 9th SCL clk
                    [    6.974152] sunxi:twi-42502000.twi0:[ERR]: drv mode: TWI BUS error state is drv:0x1 eng:0x20
                    [    6.983693] sunxi:twi-42502000.twi0:[ERR]: drv-mode: xfer failed (dev addr:0x37)
                    [    6.992125] sunxi:twi-42502000.twi0:[ERR]: drv-mode: Timeout when sending 9th SCL clk
                    [    7.000959] sunxi:twi-42502000.twi0:[ERR]: drv mode: TWI BUS error state is drv:0x1 eng:0x20
                    [    7.010499] sunxi:twi-42502000.twi0:[ERR]: drv-mode: xfer failed (dev addr:0x37)
                    [    7.018903] sunxi:vin:[INFO]: [VIN_DEV_I2C]gc1084_mipi read retry 3, read addr is 0x3f0
                    [    7.027950] sunxi:vin:[ERR]: [gc1084_mipi]chip found is not an target chip.
                    [    7.035824] sunxi:vin:[INFO]: [gc1084_mipi]PWR_OFF!
                    [    7.044241] sunxi:vin:[ERR]: registering gc1084_mipi, No such device!
                    [    7.051630] sunxi:vin:[INFO]: vinc1 is null
                    [    7.056488] sunxi:vin:[INFO]: vinc5 is null
                    [    7.103033] sunxi:VE:[INFO]: 2238 sunxi_cedar_init(): sunxi cedar version 1.1
                    [    7.111654] sunxi:VE:[INFO]: 2160 sunxi_cedar_probe(): probe ve
                    [    7.118788] sunxi-cedar 41c0e000.ve: 41c0e000.ve supply ve not found, using dummy regulator
                    [    7.134896] remoteproc remoteproc0: powering up e907_rproc
                    [    7.141252] remoteproc remoteproc0: using internal firmware, skip checking here
                    [    7.440622] remoteproc remoteproc0: loading fw from partition riscv0
                    [    7.448248] sunxi-rproc 43030000.e907_rproc: handle vendor resource, type: 129
                    [    7.456517] sunxi-rproc 43030000.e907_rproc: add trace mem 'aw_trace_log', da: 0x8112ef00, len: 4096
                    [    7.466980] remoteproc remoteproc0: Physical address cast in 32bit to fit resource table format
                    [    7.476867] remoteproc remoteproc0: firmware version: UTS - Tue, 12 Aug 2025 15:29:39 +0800
                    [    7.476867] Compile Time - 15:29:39
                    [    7.494044] sunxi-rproc 43030000.e907_rproc: boot address: 0x81001c00
                    [    7.501579]  remoteproc0#vdev0buffer: assigned reserved memory node vdev0buffer@81200000
                    [    7.512111] virtio_rpmsg_bus virtio0: rpmsg host is online
                    [    7.518523]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
                    [    7.525426] remoteproc remoteproc0: remote processor e907_rproc is now up
                    Load usb modules
                    Load wifi modules
                    [    7.624077] [xradio_mod_init,690][XRADIO_ALWY] xradio wlan version:XR_V1.0.0.250218
                    [    7.632781] [xradio_core_init,543][XRADIO_ALWY] xradio core init
                    [    7.678924] virtio_rpmsg_bus virtio0: creating channel sunxi,rpmsg_ctrl addr 0x400
                    [    7.703298] virtio_rpmsg_bus virtio0: creating channel rpbuf-service addr 0x401
                    [    7.711867] rpbuf_service_rpmsg virtio0.rpbuf-service.-1.1025: rpmsg device parent 0: virtio0
                    [    7.721558] rpbuf_service_rpmsg virtio0.rpbuf-service.-1.1025: rpmsg device parent 1: remoteproc0#vdev0buffer
                    [    7.732769] rpbuf_service_rpmsg virtio0.rpbuf-service.-1.1025: rpmsg device parent 2: remoteproc0
                    [    7.742798] rpbuf_service_rpmsg virtio0.rpbuf-service.-1.1025: rpmsg device parent 3: 43030000.e907_rproc
                    [    7.764082] sunxi-rpbuf-controller rpbuf_controller0@0: buffer "xradio_mtx": NULL -> remote_dummy_buffers
                    [    7.774976] sunxi-rpbuf-controller rpbuf_controller0@0: buffer "xradio_mrx": NULL -> remote_dummy_buffers
                    [    7.785842] virtio_rpmsg_bus virtio0: creating channel xrlink_rpmsg addr 0x402
                    [    7.794276] [xradio_rpmsg_init,191][IO] xrlink rpmsg creat succeed
                    [    7.805452] sunxi-rpbuf-controller rpbuf_controller0@0: "xradio_mrx" allocate payload memory: va 0x099423c5, pa 0x0000000083c08000, len 20480
                    [    7.820444] sunxi-rpbuf-controller rpbuf_controller0@0: buffer "xradio_mrx" (id:1): remote_dummy_buffers -> buffers
                    [    7.838613] sunxi-rpbuf-controller rpbuf_controller0@0: "xradio_mtx" allocate payload memory: va 0x54b08cbd, pa 0x0000000083c10000, len 12288
                    [    7.860998] sunxi-rpbuf-controller rpbuf_controller0@0: buffer "xradio_mtx" (id:0): remote_dummy_buffers -> buffers
                    [    7.873515] [xradio_rpbuf_init,555][IO] xrlink master rpbuf creat succeed
                    [    7.881313] [xradio_platform_init,84][PLAT] xradio_platform_init sucess 0xc1e55200
                    [    7.890015] [xradio_core_init,550][XRADIO_ALWY] xradio_plat c1e55200
                    [    7.897273] [xradio_core_init,553][XRADIO_ALWY] xradio add_net_dev
                    [    7.905778] [xradio_core_init,560][XRADIO_ALWY] xradio debug com init
                    [    7.913252] [xradio_core_init,564][XRADIO_ALWY] xradio queue init
                    [    7.920200] [xradio_core_init,569][XRADIO_ALWY] xradio platform on
                    [    7.927205] [xradio_core_init,574][XRADIO_ALWY] register tx and rx task
                    [    7.935177] [xradio_core_init,579][XRADIO_ALWY] up cmd init
                    [    7.941625] [xradio_core_init,584][XRADIO_ALWY] low cmd init
                    [    7.948061] [xradio_core_init,589][XRADIO_ALWY] hand way
                    [    7.955170] [xraido_low_cmd_dev_hand_way,129][CMD] Host hand way dev success.
                    [    7.963276] [xradio_core_init,594][XRADIO_ALWY] xradio core init Suceess
                    [    7.971517] [xradio_set_kernel_macaddr,454][XRADIO_ALWY] MACADDR=94:0a:31:b7:1e:e8
                    [    7.980326] [xradio_core_init,610][XRADIO_ALWY] AP_ADDR=94:0a:31:b7:9e:e9
                    [    7.988024] [xradio_core_init,617][XRADIO_ALWY] wlan device is opening...
                    [    8.147806] [xradio_core_init,622][XRADIO_ALWY] wlan device is ready
                    [    8.155096] ======== XRADIO WIFI OPEN ========
                    Starting wifi_deamon....: WINF: wifimanger verion:2.0.8.5 20250812-07:18:33 c3e9e83
                    WINF: **************************************
                    WINF: * Copyright (c) 2019-2025 Allwinner Technology Co., Ltd. ALL rights reserved
                    WINF: * version: 2.0.8.5 20250812-07:18:33 c3e9e83
                    WINF: * module name: UNKNOWN (D)
                    WINF: * wifimg support mode:(sta | ap | --- | --- | ------ | -------)
                    WINF: * module support mode:(sta | ap | --- | --- | ------ | -------)
                    WINF: * actual support mode:(sta | ap | --- | --- | ------ | -------)
                    WINF: wifi mode sta on success
                    WINF: wifi on sta success
                    WINF: wifi set auto reconnect enable success
                    mount: mounting /dev/mmcblk0p1 on /mnt/extsd failed: No such file or directory
                    starting pid 204, tty '/dev/console': '-/bin/sh'
                    BusyBox v1.33.2 (2025-07-09 02:10:56 UTC) built-in shell (ash)
                     _____  _              __     _
                    |_   _||_| ___  _ _   |  |   |_| ___  _ _  _ _
                      | |   _ |   ||   |  |  |__ | ||   || | ||_'_|
                      | |  | || | || _ |  |_____||_||_|_||___||_,_|
                      |_|  |_||_|_||_|_|  Tina is Based on OpenWrt!
                     Tina Linux (5.0, r16776-9575252c49)
                    root@(none):/#
                    root@(none):/#
                    Q 2 条回复 最后回复 回复 引用 分享 0
                      @awwwwa 是用quick_config配置编译的吗? 你的SDK是哪个版本是1.2吗? 能否 发我一份
                        @awwwwa 我这个SDK应该部是最新的,造成的, 我看这颗物料的更新是7月30日,而我的SDK是6月份的, 应该是SDK的问题了, 能发我一份SDK吗?
                          awwwwa LV 8 @QY157 最后由 编辑
                          @qy157 我的也是1.2 SDK
                          我的SPI驱动
                          你的 SPI 驱动
                          可以看到,你的日志里连 AW SPINand MTD Layer Version: 2.7 20240110 都没加载,所以SPI NAND 无法挂载
                          Q 1 条回复 最后回复 回复 引用 分享 0
                            QY157 LV 4 @awwwwa 最后由 awwwwa 编辑
                            @awwwwa 能把你的board.dts 发出来吗? 你除了使用quick_config配置之外还有别的改动吗?我看了下dts 好像不太对劲, spi0好像都没有nand的节点,
                             &spi0 {
                            	pinctrl-0 = <&spi0_pins_default &spi0_pins_cs>;
                            	pinctrl-1 = <&spi0_pins_sleep>;
                            	sunxi,spi-bus-mode = <SUNXI_SPI_BUS_NOR>;
                            	sunxi,spi-cs-mode = <SUNXI_SPI_CS_SOFT>;
                            	status = "okay";
                            	dmas;
                            	dma-names;
                            	spi_board0 {
                            		device_type = "spi_board0";
                            		compatible = "spi-nor";
                            		spi-max-frequency = <100000000>;
                            		m25p,fast-read = <1>;
                            		/*individual_lock;*/
                            		reg = <0x0>;
                            		spi-rx-bus-width = <4>;
                            		spi-tx-bus-width = <4>;
                            		status = "disabled";
                              awwwwa LV 8 最后由 编辑
                              &spi0 {
                              	status = "okay";
                              	spi_board0 {
                              		reg = <0x0>;
                              	spi-nand@0 {
                              		compatible = "spi-nand";
                              		spi-max-frequency=<100000000>;
                              		reg = <0x0>;
                              		spi-rx-bus-width=<0x04>;
                              		spi-tx-bus-width=<0x04>;
                              		status = "okay";
                                awwwwa LV 8 最后由 编辑
                                你在IPC板级切nand了,ipc板级优化设备树大小把不用的都删了
                                  @awwwwa 你用的哪个版型 编译的?
                                    @qy157 perf2
                                    Q 3 条回复 最后回复 回复 引用 分享 0
                                      @awwwwa 好的 我试试先
                                        @awwwwa de29abdf-9630-4c39-ae8d-479fc43b7c0a-cd171663-a1c8-4c51-93b5-dab71e7e8a3e.png 1aa7bd61-ac8b-4b68-a8e6-28aebe163d44-2c162759-0502-449c-a0de-b569918bb19c.png ubuntu20.04,按照上面的方法进行编译,编译成功后 输出的居然还是nor的镜像14407fc4-d449-4d77-81cb-45c78849ac87-7a81ff97-4da0-47b9-99b6-633ed166a70d.png 这是怎么回事啊?
                                          QY157 LV 4 @awwwwa 最后由 QY157 编辑
                                          @awwwwa 问题解决了, 非常感谢
                                            zjkj_hsq LV 2 @QY157 最后由 编辑
                                            @qy157 我也遇到这个问题了 想请问你最后是怎么解决的啊? 是上面提到的设备树问题导致的么?
