请问 D1 启动出现 GPT 错误是什么问题呢?
[ 2.018580] [SNDCODEC][sunxi_card_init][583]:card init finished [ 2.026426] GPT:Primary header thinks Alt. header is not at the end of the disk. [ 2.035192] mmc1: new high speed SDIO card at address 0001 [ 2.041967] GPT:92680 != 61980671 [ 2.045718] GPT:Alternate GPT header not at the end of the disk. [ 2.052414] GPT:92680 != 61980671 [ 2.056125] GPT: Use GNU Parted to correct GPT errors. [ 2.061914] mmcblk0: p1 p2 p3 p4 p5 [ 2.070879] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok [ 2.082390] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0 [ 2.094644] [SNDCODEC][sunxi_card_dev_probe][832]:register card finished [ 2.103046] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: id:sunxi,dsp-msgbox new channel: 0x202 -> 0x102! [ 2.114656] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: rpmsg hifi[0] client driver is probed [ 2.126800] NET: Registered protocol family 10 [ 2.133373] Segment Routing with IPv6 [ 2.137653] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 2.145279] NET: Registered protocol family 17 [ 2.150318] can: controller area network core (rev 20170425 abi 9) [ 2.157424] NET: Registered protocol family 29 [ 2.162391] can: raw protocol (rev 20170425) [ 2.167197] can: broadcast manager protocol (rev 20170425 t) [ 2.173545] can: netlink gateway (rev 20190810) max_hops=1 [ 2.180032] Bluetooth: RFCOMM TTY layer initialized [ 2.185614] Bluetooth: RFCOMM socket layer initialized [ 2.191377] Bluetooth: RFCOMM ver 1.11 [ 2.196901] Loading compiled-in X.509 certificates [ 2.205052] HDMI 2.0 driver init start! [ 2.209361] boot_hdmi=false [ 2.212522] ERROR: can not get hdmi_cts_compatibility [ 2.218247] ERROR: can not get hdmi_cec_support node [ 2.223835] ERROR: can not get hdmi_cec_super_standby node [ 2.229951] ERROR: can not get hdmi_hdcp_enable [ 2.235065] ERROR: pinctrl_get for HDMI2.0 DDC fail [ 2.240505] ERROR: can not get ddc_en_io_ctrl [ 2.245447] ERROR: can not get hdmi_power_cnt [ 2.251866] HDMI2.0 module init end [ 2.290357] twi twi2: twi2 supply twi not found, using dummy regulator [ 2.304124] sunxi_i2c_probe()2262 - [i2c2] probe success [ 2.312633] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator [ 2.327320] get ehci0-controller wakeup-source is fail. [ 2.333354] sunxi ehci0-controller don't init wakeup source [ 2.339578] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe000904a40, 0x:ffffffd004bd0000, irq_no:2e [ 2.353116] [sunxi-ehci0]: Not init ehci0 [ 2.358143] get ohci0-controller wakeup-source is fail. [ 2.364174] sunxi ohci0-controller don't init wakeup source [ 2.370396] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe000905580 [ 2.380838] [sunxi-ohci0]: Not init ohci0 [ 2.385894] get ehci1-controller wakeup-source is fail. [ 2.391838] sunxi ehci1-controller don't init wakeup source [ 2.398140] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe000904e00, 0x:ffffffd004bd9000, irq_no:31 [ 2.413146] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller [ 2.420369] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1 [ 2.430304] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000 [ 2.462878] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00 [ 2.471730] hub 1-0:1.0: USB hub found [ 2.476075] hub 1-0:1.0: 1 port detected [ 2.481616] get ohci1-controller wakeup-source is fail. [ 2.487671] sunxi ohci1-controller don't init wakeup source [ 2.493979] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe000905940 [ 2.504797] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller [ 2.512019] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2 [ 2.521926] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400 [ 2.597957] hub 2-0:1.0: USB hub found [ 2.602201] hub 2-0:1.0: 1 port detected [ 2.612183] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 2.624802] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 2.632268] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 2.642106] clk: Not disabling unused clocks [ 2.646972] cfg80211: failed to load regulatory.db [ 2.652407] ALSA device list: [ 2.655879] #0: audiocodec [ 2.659105] alloc_fd: slot 0 not NULL! [ 2.669590] List of all partitions: [ 2.673610] b300 30990336 mmcblk0 [ 2.673616] driver: mmcblk [ 2.681193] b301 4032 mmcblk0p1 2a9f222d-b95d-43e1-8766-95ce27872abf [ 2.681196] [ 2.691298] b302 252 mmcblk0p2 99f5f2b1-95b3-427c-bec3-6782f4fc2b53 [ 2.691303] [ 2.701493] b303 252 mmcblk0p3 c3e465de-6a1f-4006-b61c-d481a9e22861 [ 2.701498] [ 2.711539] b304 10332 mmcblk0p4 f5405084-d4ba-4a81-89c5-84e256e62667 [ 2.711543] [ 2.721745] b305 14112 mmcblk0p5 cb03eac2-ded4-4fb0-8023-bca6e652fc41 [ 2.721749] [ 2.731797] No filesystem could mount root, tried: [ 2.731802] ext3 [ 2.737285] ext2 [ 2.739428] ext4 [ 2.741567] squashfs [ 2.743730] vfat [ 2.746258] [ 2.750054] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5) [ 2.759466] CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.61 #224 [ 2.766060] Call Trace: [ 2.768800] [<ffffffe0000333ce>] walk_stackframe+0x0/0xa0 [ 2.774820] [<ffffffe0000335b0>] show_stack+0x2a/0x34 [ 2.780454] [<ffffffe00060c3d2>] dump_stack+0x20/0x28 [ 2.786087] [<ffffffe000038376>] panic+0xee/0x2b6 [ 2.791333] [<ffffffe000000f5a>] mount_block_root+0x26e/0x28a [ 2.797738] [<ffffffe000000ffc>] mount_root+0x86/0x90 [ 2.803368] [<ffffffe000001116>] prepare_namespace+0x110/0x152 [ 2.809870] [<ffffffe000000b78>] kernel_init_freeable+0x17e/0x19a [ 2.816670] [<ffffffe00061fce2>] kernel_init+0x12/0xee [ 2.822398] [<ffffffe000032018>] ret_from_exception+0x0/0xc [ 2.828613] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5) ]---
找到问题了,后面那三个分区全是 rootfs, 无脑复制粘贴引起的。
