    请问 PhoenixCard 烧卡软件的 【量产卡】与 【启动卡】菜单有什么区别呢?
    phoenixcard
    9938
    • tigger
      tigger LV 7 最后由 编辑
        DOT小文哥 LV 8 最后由 编辑
        这个应该是以前平板时代留下来的产物。
        总所周知,全志以前是做平板起家的。
        做平板的时候,因为板子上本来就有emmc,量产卡就是把卡插进去,固件会自己烧到emmc上,然后再把量产卡拔出来,再启动的时候就用emmc上的固件启动,这张“量产卡”就可以用来烧下一台设备了。
        启动卡就是插进去不动了,不会把固件移到emmc上,一直用这张启动卡启动,要是卡被拔出来了,就相当于 是板子没有系统了,就是一块砖头。
          memory LV 7 最后由 编辑
          试了一下,选择量产卡烧录,启动日志:
          [32]HELLO! BOOT0 is starting!
          [35]BOOT0 commit : 27369ab-dirty
          [38]set pll start
          [40]periph0 has been enabled
          [43]set pll end
          [44][pmu]: bus read error
          [47]board init ok
          [48]ZQ value = 0x32***********
          [51]get_pmu_exist() = -1
          [54]ddr_efuse_type: 0xa
          [57][AUTO DEBUG] single rank and full DQ!
          [60]ddr_efuse_type: 0xa
          [63][AUTO DEBUG] rank 0 row = 13
          [66][AUTO DEBUG] rank 0 bank = 4
          [69][AUTO DEBUG] rank 0 page size = 2 KB
          [73]DRAM BOOT DRIVE INFO: V0.24
          [76]DRAM CLK = 528 MHz
          [78]DRAM Type = 2 (2:DDR2,3:DDR3)
          [81]DRAMC read ODT  off.
          [84]DRAM ODT off.
          [85]ddr_efuse_type: 0xa
          [88]DRAM SIZE =64 M
          [92]DRAM simple test OK.
          [94]dram size =64
          [96]card no is 0
          [97]sdcard 0 line count 4
          [100][mmc]: mmc driver ver 2021-04-2 16:45
          [109][mmc]: Wrong media type 0x0
          [112][mmc]: ***Try SD card 0***
          [122][mmc]: DS26/SDR12 4 bit
          [125][mmc]: 25000000 Hz
          [127][mmc]: 30264 MB
          [129][mmc]: ***SD/MMC 0 init OK!!!***
          [214]Loading boot-pkg Succeed(index=0).
          [218]Entry_name        = opensbi
          [221]Entry_name        = u-boot
          [225]Entry_name        = dtb
          [227]mmc not para
          [229]Jump to second Boot.
          OpenSBI v0.6
                  |_|
          Platform Max HARTs     : 1
          Current Hart           : 0
          Runtime SBI Version    : 0.2
          MIDELEG : 0x0000000000000222
          MEDELEG : 0x000000000000b1ff
          PMP3    : 0x0000000000020000-0x0000000000027fff (A,_H?H????с2018.05-g0a88ac9-dirty-config-dirty (Feb 08 2022 - 22:32:34 +0800) Allwinner Technology
          [00.313]DRAM:  64 MiB
          [00.315]Relocation Offset is: 01f02000
          [00.320]secure enable bit: 0
          [00.322]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
          [00.329]flash init start
          [00.331]workmode = 17,storage type = 1
          try card 2
          set card number 2
          get card number 2
          [00.339][mmc]: mmc driver ver uboot2018:2021-04-16 14:23:00-1
          [00.344][mmc]: get sdc_type fail and use default host:tm4.
          [00.351][mmc]: Is not Boot mode!
          [00.353][mmc]: SUNXI SDMMC Controller Version:0x50310
          [00.364][mmc]: ************Try SD card 2************
          [00.369][mmc]: mmc 2 cmd timeout 2 status 2
          [00.373][mmc]: smc 2 err, cmd 8,  RE
          [00.376][mmc]: mmc 2 close bus gating and reset
          [00.381][mmc]: Current spd_md 0 freq_id 0 sdly 255
          [00.385][mmc]: Get next samply point 193 at spd_md 0 freq_id 0
          [00.391][mmc]: need retry next clk 400000
          [00.401][mmc]: ************Try SD card 2************
          [00.406][mmc]: mmc 2 cmd timeout 2 status 2
          [00.409][mmc]: smc 2 err, cmd 8,  RE
          [00.413][mmc]: mmc 2 close bus gating and reset
          [00.417][mmc]: Current spd_md 0 freq_id 0 sdly 193
          [00.421][mmc]: Get next samply point 131 at spd_md 0 freq_id 0
          [00.427][mmc]: need retry next clk 400000
          [00.437][mmc]: ************Try SD card 2************
          [00.442][mmc]: mmc 2 cmd timeout 2 status 2
          [00.446][mmc]: smc 2 err, cmd 8,  RE
          [00.449][mmc]: mmc 2 close bus gating and reset
          [00.453][mmc]: Current spd_md 0 freq_id 0 sdly 131
          [00.458][mmc]: Get next samply point 69 at spd_md 0 freq_id 0
          [00.463][mmc]: need retry next clk 400000
          [00.473][mmc]: ************Try SD card 2************
          [00.478][mmc]: mmc 2 cmd timeout 2 status 2
          [00.482][mmc]: smc 2 err, cmd 8,  RE
          [00.485][mmc]: mmc 2 close bus gating and reset
          [00.489][mmc]: Current spd_md 0 freq_id 0 sdly 69
          [00.494][mmc]: Get next samply point 7 at spd_md 0 freq_id 0
          [00.499][mmc]: need retry next clk 400000
          [00.509][mmc]: ************Try SD card 2************
          [00.514][mmc]: mmc 2 cmd timeout 2 status 2
          [00.518][mmc]: smc 2 err, cmd 8,  RE
          [00.521][mmc]: mmc 2 close bus gating and reset
          [00.525][mmc]: Current spd_md 0 freq_id 0 sdly 7
          [00.530][mmc]: Get next samply point 9 at spd_md 0 freq_id 0
          [00.535][mmc]: need retry next clk 400000
          [00.545][mmc]: ************Try SD card 2************
          [00.550][mmc]: mmc 2 cmd timeout 2 status 2
          [00.554][mmc]: smc 2 err, cmd 8,  RE
          [00.557][mmc]: mmc 2 close bus gating and reset
          [00.561][mmc]: Current spd_md 0 freq_id 0 sdly 9
          [00.565][mmc]: Get next samply point 11 at spd_md 0 freq_id 0
          [00.571][mmc]: need retry next clk 400000
          [00.581][mmc]: ************Try SD card 2************
          [00.586][mmc]: mmc 2 cmd timeout 2 status 2
          [00.590][mmc]: smc 2 err, cmd 8,  RE
          [00.593][mmc]: mmc 2 close bus gating and reset
          [00.597][mmc]: Current spd_md 0 freq_id 0 sdly 11
          [00.602][mmc]: Get next samply point 13 at spd_md 0 freq_id 0
          [00.607][mmc]: need retry next clk 400000
          [00.617][mmc]: ************Try SD card 2************
          [00.622][mmc]: mmc 2 cmd timeout 2 status 2
          [00.626][mmc]: smc 2 err, cmd 8,  RE
          [00.629][mmc]: mmc 2 close bus gating and reset
          [00.633][mmc]: Current spd_md 0 freq_id 0 sdly 13
          [00.638][mmc]: Get next samply point 15 at spd_md 0 freq_id 0
          [00.643][mmc]: need retry next clk 400000
          [00.653][mmc]: ************Try SD card 2************
          [00.658][mmc]: mmc 2 cmd timeout 2 status 2
          [00.662][mmc]: smc 2 err, cmd 8,  RE
          [00.665][mmc]: mmc 2 close bus gating and reset
          [00.669][mmc]: Current spd_md 0 freq_id 0 sdly 15
          [00.674][mmc]: Get next samply point 17 at spd_md 0 freq_id 0
          [00.679][mmc]: need retry next clk 400000
          [00.689][mmc]: ************Try SD card 2************
          [00.694][mmc]: mmc 2 cmd timeout 2 status 2
          [00.698][mmc]: smc 2 err, cmd 8,  RE
          [00.701][mmc]: mmc 2 close bus gating and reset
          [00.705][mmc]: Current spd_md 0 freq_id 0 sdly 17
          [00.710][mmc]: Get next samply point 19 at spd_md 0 freq_id 0
          [00.715][mmc]: need retry next clk 400000
          [00.725][mmc]: ************Try SD card 2************
          [00.730][mmc]: mmc 2 cmd timeout 2 status 2
          [00.734][mmc]: smc 2 err, cmd 8,  RE
          [00.737][mmc]: mmc 2 close bus gating and reset
          [00.742][mmc]: Current spd_md 0 freq_id 0 sdly 19
          [00.746][mmc]: Get next samply point 21 at spd_md 0 freq_id 0
          [00.751][mmc]: need retry next clk 400000
          [00.762][mmc]: ************Try SD card 2************
          [00.766][mmc]: mmc 2 cmd timeout 2 status 2
          [00.770][mmc]: smc 2 err, cmd 8,  RE
          [00.773][mmc]: mmc 2 close bus gating and reset
          [00.778][mmc]: Current spd_md 0 freq_id 0 sdly 21
          [00.782][mmc]: Get next samply point 23 at spd_md 0 freq_id 0
          [00.787][mmc]: need retry next clk 400000
          [00.798][mmc]: ************Try SD card 2************
          [00.802][mmc]: mmc 2 cmd timeout 2 status 2
          [00.806][mmc]: smc 2 err, cmd 8,  RE
          [00.809][mmc]: mmc 2 close bus gating and reset
          [00.814][mmc]: Current spd_md 0 freq_id 0 sdly 23
          [00.818][mmc]: Get next samply point 25 at spd_md 0 freq_id 0
          [00.824][mmc]: need retry next clk 400000
          [00.834][mmc]: ************Try SD card 2************
          [00.838][mmc]: mmc 2 cmd timeout 42 status 42
          [00.842][mmc]: smc 2 err, cmd 8,  RE RCE
          [00.846][mmc]: mmc 2 close bus gating and reset
          [00.850][mmc]: Current spd_md 0 freq_id 0 sdly 25
          [00.855][mmc]: Get next samply point 27 at spd_md 0 freq_id 0
          [00.860][mmc]: need retry next clk 400000
          [00.870][mmc]: ************Try SD card 2************
          [00.875][mmc]: mmc 2 cmd timeout 42 status 42
          [00.879][mmc]: smc 2 err, cmd 8,  RE RCE
          [00.883][mmc]: mmc 2 close bus gating and reset
          [00.887][mmc]: Current spd_md 0 freq_id 0 sdly 27
          [00.891][mmc]: Get next samply point 29 at spd_md 0 freq_id 0
          [00.897][mmc]: need retry next clk 400000
          [00.907][mmc]: ************Try SD card 2************
          [00.912][mmc]: mmc 2 cmd timeout 100 status 100
          [00.916][mmc]: smc 2 err, cmd 8,  RTO
          [00.920][mmc]: mmc 2 close bus gating and reset
          [00.925][mmc]: mmc 2 cmd timeout 100 status 100
          [00.929][mmc]: smc 2 err, cmd 55,  RTO
          [00.932][mmc]: mmc 2 close bus gating and reset
          [00.937][mmc]: ************Try MMC card 2************
          [00.945][mmc]: mmc 2 cmd timeout 100 status 100
          [00.950][mmc]: smc 2 err, cmd 1,  RTO
          [00.953][mmc]: mmc 2 close bus gating and reset
          [00.957][mmc]: Card did not respond to voltage select!
          [00.962][mmc]: ************SD/MMC 2 init error!************
          [00.967][mmc]: mmc init product failed
          MMC init failed
          try emmc fail
          [00.974]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
          [00.980]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
          [00.988]sunxi-spinand-phy: request spi0 gpio ok
          [00.992]sunxi-spinand-phy: request general tx dma channel ok!
          [00.998]sunxi-spinand-phy: request general rx dma channel ok!
          [01.003]sunxi-spinand-phy: set spic0 clk to 20 Mhz
          [01.008]sunxi-spinand-phy: init spic0 clk ok
          [01.032]sunxi-spinand-phy: read id failed : -110
          try nand fail
          [01.040]unrecognized JEDEC id bytes: ff, ff, ff
          try spinor fail
          initcall sequence 0000000043f9a2e0 failed at call 000000004200d70e (err=-1)
          会依次查找 emmc / spi nand / spi nor,都没有就出错退出了。
            memory LV 7 最后由 编辑
            [35]BOOT0 commit : 553a5eb
            [38]set pll start
            [39]periph0 has been enabled
            [42]set pll end
            [46]board init ok
            [48]ZQ value = 0x2f
            [50]get_pmu_exist() = -1
            [52]ddr_efuse_type: 0xa
            [54]mark_id: 0x5c
            [56]trefi:7.8ms
            [58][AUTO DEBUG] single rank and full DQ!
            [62]ddr_efuse_type: 0xa
            [64]mark_id: 0x5c
            [66]trefi:7.8ms
            [68][AUTO DEBUG] rank 0 row = 13
            [71][AUTO DEBUG] rank 0 bank = 4
            [74][AUTO DEBUG] rank 0 page size = 2 KB
            [78]DRAM BOOT DRIVE INFO: V0.32
            [81]DRAM CLK = 408 MHz
            [83]DRAM Type = 2 (2:DDR2,3:DDR3)
            [86]DRAMC read ODT  off.
            [89]DRAM ODT off.
            [90]ddr_efuse_type: 0xa
            [93]mark_id: 0x5c
            [95]DRAM SIZE =64 M
            [97]PLL_DDR_CTRL_REG:0xf9002100
            [100]DRAM_CLK_REG:0xc0000000
            [102][TIMING DEBUG] MR2= 0x0
            [107]DRAM simple test OK.
            [109]dram size =64
            [111]card no is 0
            [113]sdcard 0 line count 4
            [115][mmc]: mmc driver ver 2021-04-2 16:45
            [125][mmc]: Wrong media type 0x0
            [127][mmc]: ***Try SD card 0***
            [137][mmc]: HSSDR52/SDR25 4 bit
            [140][mmc]: 50000000 Hz
            [143][mmc]: 30264 MB
            [145][mmc]: ***SD/MMC 0 init OK!!!***
            [195]Loading boot-pkg Succeed(index=0).
            [199]Entry_name        = opensbi
            [202]Entry_name        = u-boot
            [206]Entry_name        = dtb
            [208]mmc not para
            [210]Jump to second Boot.
            OpenSBI auto-t113-linux-V0.1-1-ge15c4f7
                    |_|
            Current Hart           : 0
            PMP3    : 0x0000000000020000-0x0000000000027fff (A,?H?H????с2018.05-00019-gc7a7584e23 (Sep 26 2021 - 11:44:52 +0000) Allwinner Technology
            [00.296]DRAM:  64 MiB
            [00.298]Relocation Offset is: 01ee1000
            [00.303]secure enable bit: 0
            [00.306]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
            [00.312]flash init start
            [00.314]workmode = 17,storage type = 1
            try card 0
            set card number 0
            get card number 0
            [00.322][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
            [00.327][mmc]: get sdc_type fail and use default host:tm1.
            [00.339][mmc]: get card0 default pin fail
            [00.343][mmc]: can't find node "mmc0",will add new node
            [00.348][mmc]: fdt err returned <no error>
            [00.352][mmc]: Using default timing para
            [00.355][mmc]: sunxi mmc pin set failed!
            [00.359]error card no error
            [00.362][mmc]: MMC Device -1 not found
            MMC init failed
            try card0 fail
            try card 1
            set card number 1
            get card number 1
            [00.372][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
            [00.378][mmc]: get sdc_type fail and use default host:tm1.
            [00.383][mmc]: mmc_get_para_from_fex: input sdc_no error: 1
            [00.388][mmc]: Using default timing para
            [00.392][mmc]: sunxi mmc pin set failed!
            [00.395]error,card no error
            [00.398][mmc]: MMC Device -1 not found
            MMC init failed
            try card1 fail
            try card 2
            set card number 2
            get card number 2
            [00.409][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
            [00.414][mmc]: get sdc_type fail and use default host:tm4.
            [00.420][mmc]: Is not Boot mode!
            [00.423][mmc]: SUNXI SDMMC Controller Version:0x50310
            [00.434][mmc]: ************Try SD card 2************
            [00.440][mmc]: mmc 2 cmd timeout 100 status 100
            [00.444][mmc]: smc 2 err, cmd 8,  RTO
            [00.447][mmc]: mmc 2 close bus gating and reset
            [00.452][mmc]: mmc 2 cmd timeout 100 status 100
            [00.456][mmc]: smc 2 err, cmd 55,  RTO
            [00.460][mmc]: mmc 2 close bus gating and reset
            [00.464][mmc]: ************Try MMC card 2************
            [00.473][mmc]: mmc 2 cmd timeout 100 status 100
            [00.477][mmc]: smc 2 err, cmd 1,  RTO
            [00.480][mmc]: mmc 2 close bus gating and reset
            [00.485][mmc]: Card did not respond to voltage select!
            [00.489][mmc]: ************SD/MMC 2 init error!************
            [00.495][mmc]: mmc init product failed
            MMC init failed
            try card2 fail
            try emmc fail
            [00.503]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
            [00.509]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
            [00.517]sunxi-spinand-phy: request spi0 gpio ok
            [00.521]sunxi-spinand-phy: request general tx dma channel ok!
            [00.527]sunxi-spinand-phy: request general rx dma channel ok!
            [00.532]sunxi-spinand-phy: set spic0 clk to 20 Mhz
            [00.537]sunxi-spinand-phy: init spic0 clk ok
            [00.582]sunxi-spinand-phy: not detect any munufacture from id table
            [00.589]sunxi-spinand-phy: get spi-nand Model from fdt fail
            [00.594]sunxi-spinand-phy: get phy info from fdt fail
            [00.598]sunxi-spinand-phy: not detect munufacture from fdt
            [00.604]sunxi-spinand-phy: detect munufacture from id table: GD
            [00.609]sunxi-spinand-phy: detect spinand id: ffff51c8 ffffffff
            [00.615]sunxi-spinand-phy: ========== arch info ==========
            [00.620]sunxi-spinand-phy: Model:               GD5F1GQ5UEYIG
            [00.626]sunxi-spinand-phy: Munufacture:         GD
            [00.630]sunxi-spinand-phy: DieCntPerChip:       1
            [00.634]sunxi-spinand-phy: BlkCntPerDie:        1024
            [00.639]sunxi-spinand-phy: PageCntPerBlk:       64
            [00.644]sunxi-spinand-phy: SectCntPerPage:      4
            [00.648]sunxi-spinand-phy: OobSizePerPage:      64
            [00.653]sunxi-spinand-phy: BadBlockFlag:        0x0
            [00.657]sunxi-spinand-phy: OperationOpt:        0x7
            [00.662]sunxi-spinand-phy: MaxEraseTimes:       50000
            [00.667]sunxi-spinand-phy: EccFlag:             0x1
            [00.671]sunxi-spinand-phy: EccType:             7
            [00.676]sunxi-spinand-phy: EccProtectedType:    2
            [00.680]sunxi-spinand-phy: ========================================
            [00.686]sunxi-spinand-phy:
            [00.688]sunxi-spinand-phy: ========== physical info ==========
            [00.694]sunxi-spinand-phy: TotalSize:    128 M
            [00.698]sunxi-spinand-phy: SectorSize:   512 B
            [00.702]sunxi-spinand-phy: PageSize:     2 K
            [00.706]sunxi-spinand-phy: BlockSize:    128 K
            [00.710]sunxi-spinand-phy: OOBSize:      64 B
            [00.715]sunxi-spinand-phy: ========================================
            [00.721]sunxi-spinand-phy:
            [00.723]sunxi-spinand-phy: ========== logical info ==========
            [00.729]sunxi-spinand-phy: TotalSize:    128 M
            [00.733]sunxi-spinand-phy: SectorSize:   512 B
            [00.737]sunxi-spinand-phy: PageSize:     4 K
            [00.741]sunxi-spinand-phy: BlockSize:    256 K
            [00.745]sunxi-spinand-phy: OOBSize:      128 B
            [00.749]sunxi-spinand-phy: ========================================
            [00.756]sunxi-spinand-phy: GD5F1GQ5UEYIG reset rx bit width to 1
            [00.761]sunxi-spinand-phy: GD5F1GQ5UEYIG reset tx bit width to 1
            [00.767]sunxi-spinand-phy: set spic0 clk to 100 Mhz
            [00.771]sunxi-spinand-phy: block lock register: 0x00
            [00.776]sunxi-spinand-phy: feature register: 0x11
            [00.781]sunxi-spinand-phy: sunxi physic nand init end
            [00.785][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
            [00.791][mmc]: get sdc_type fail and use default host:tm1.
            [00.803][mmc]: get card0 default pin fail
            [00.807][mmc]: can't find node "mmc0",will add new node
            [00.812][mmc]: fdt err returned <no error>
            [00.815][mmc]: Using default timing para
            [00.819][mmc]: sunxi mmc pin set failed!
            [00.823]error card no error
            [00.825][mmc]: MMC Device -1 not found
            fail to find one useful mmc card
            initcall sequence 0000000043f8fb20 failed at call 000000004200e81a (err=-1)
            焊上 spi nand 之后,出现了 找不到 mmc0,可能是 uboot-board.dts TF 卡的配置有问题?
              memory LV 7 最后由 编辑
              输入 part list sunxi_flash 0 发现可以显示 TF卡分区:
              => part list sunxi_flash 0
              Partition Map for UNKNOWN device 0  --   Partition Type: EFI
              Part    Start LBA       End LBA         Name
                      Attributes
                      Type GUID
                      Partition GUID
                1     0x00008780      0x0000a6ff      "boot-resource"
                      attrs:  0x0000000000000000
                      type:   0fc63daf-8483-4772-8e79-3d69d8477de4
                      guid:   d4c8f1d5-757a-475a-b9a8-0074ff65dd1b
                2     0x0000a700      0x0000a8f7      "env"
                      guid:   fc2fd674-e9a9-4a44-89a2-cc5798413979
                3     0x0000a8f8      0x0000aaef      "env-redund"
                      guid:   b33c1ff3-5666-4b5c-9a3d-cac68f400ad0
                4     0x0000aaf0      0x0000fba7      "boot"
                      guid:   ef8068de-d87b-4265-8af3-5285368efc49
                5     0x0000fba8      0x0002fba7      "rootfs"
                      guid:   1846d402-1afd-4ecd-bf3a-29286953d7e0
                6     0x0002fba8      0x0002ff97      "dsp0"
                      guid:   94d209b1-385c-4a02-8d82-61e8a059b33e
                7     0x0002ff98      0x00036dd7      "recovery"
                      guid:   27263635-cf03-4add-82f9-af10d477c79d
              但是 mmc 命令根本木得反应:
              => mmc dev 0
              No MMC device available
              => mmc dev 2
              => mmc info
              感觉是 mmc 命令不响应的问题造成的。
                memory LV 7 最后由 编辑
                再次确认,官方的哪吒SDK + 哪吒开发板 uboot 也不能运行 mmc info 和 mmc dev 0 这些命令,看来这个量产卡功能在D1 平台应该不能正常测试。
                  memory LV 7 最后由 编辑
                  既然 D1 哪吒不行,那试一试 A100:
                  插入TF卡上电开始自动烧录:
                  串口日志:
                  [88]HELLO! BOOT0 is starting!
                  [91]BOOT0 commit : dc54be6
                  [94]set pll start
                  [95]periph0 has been enabled
                  [99]set pll end
                  [100][pmu]: bus read error
                  [103][pmu]: bus read error
                  [111]vaild para:1  select dram para0
                  [114]board init ok
                  [116]DRAM BOOT DRIVE INFO: V0.19
                  [120]the chip id is 0x2400
                  [122]the chip id is 0x2400
                  [125]the chip id is 0x2400
                  [128]the chip id is 0x2400
                  [130]the chip id is 0x2400
                  [133]chip id check OK
                  [135]DRAM_VCC set to 1100 mv
                  [168]DRAM retraining ten
                  [174][AUTO DEBUG]32bit,1 ranks training success!
                  [185]DRAM CLK =792 MHZ
                  [187]DRAM Type =8 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
                  [195]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6063
                  [207]DRAM simple test OK.
                  [210]dram size =1024
                  [212]chipid = 53002400
                  [214]nsi init ok 2020-4-7
                  [217]card no is 0
                  [219]sdcard 0 line count 4
                  [222][mmc]: mmc driver ver 2020-05-25 09:40
                  [232][mmc]: Wrong media type 0x0
                  [235][mmc]: ***Try SD card 0***
                  [255]mmc_read_info 748:region magic is not right, retry more time 0
                  [273]mmc_read_info 748:region magic is not right, retry more time 0
                  [290]mmc_read_info 748:region magic is not right, retry more time 0
                  [308]mmc_read_info 748:region magic is not right, go err 0
                  [314]dump info registers:[316]
                  0x29b7c : [318]0 [318]0 [319]0 [320]0 [320]
                  0x29b8c : [322]0 [323]0 [323]0 [324]0 [325]
                  0x29b9c : [326]0 [327]0 [327]0 [328]0 [329]
                  0x29bac : [330]0 [331]0 [332]0 [332]0 [333]
                  0x29bbc : [335]0 [335]0 [336]0 [337]0 [337]
                  0x29bcc : [339]0 [340]0 [340]0 [341]0 [342]
                  0x29bdc : [343]0 [344]0 [345]0 [345]0 [346]
                  0x29bec : [348]0 [348]0 [349]0 [350]0 [350]
                  0x29bfc : [352]0 [353]0 [353]0 [354]0 [355]
                  0x29c0c : [356]0 [357]0 [358]0 [358]0 [359]
                  0x29c1c : [360]0 [361]0 [362]0 [362]0 [363]
                  0x29c2c : [365]0 [365]0 [366]0 [367]0 [367]
                  0x29c3c : [369]0 [370]0 [370]0 [371]0 [372]
                  0x29c4c : [373]0 [374]0 [375]0 [375]0 [376]
                  0x29c5c : [378]0 [378]0 [379]0 [380]0 [380]
                  0x29c6c : [382]0 [383]0 [383]0 [384]0 [385]
                  0x29c7c : [386]0 [387]0 [388]0 [388]0 [389]
                  0x29c8c : [390]0 [391]0 [392]0 [392]0 [393]
                  0x29c9c : [395]0 [395]0 [396]0 [397]0 [397]
                  0x29cac : [399]0 [400]0 [400]0 [401]0 [402]
                  0x29cbc : [403]0 [404]0 [405]0 [405]0 [406]
                  0x29ccc : [408]0 [408]0 [409]0 [410]0 [410]
                  0x29cdc : [412]0 [413]0 [413]0 [414]0 [415]
                  0x29cec : [416]0 [417]0 [418]0 [418]0 [419]
                  0x29cfc : [421]0 [421]0 [422]0 [423]0 [423]
                  0x29d0c : [425]0 [425]0 [426]0 [427]0 [427]
                  0x29d1c : [429]0 [430]0 [430]0 [431]0 [432]
                  0x29d2c : [433]0 [434]0 [435]0 [435]0 [436]
                  0x29d3c : [438]0 [438]0 [439]0 [440]0 [440]
                  0x29d4c : [442]0 [443]0 [443]0 [444]0 [445]
                  0x29d5c : [446]0 [447]0 [448]0 [448]0 [449]
                  0x29d6c : [451]0 [451]0 [452]0 [453]0 [453]
                  [454][mmc]: RMCA FAIL!
                  [456][mmc]: mmc read timing info fail
                  [460][mmc]: sdc0 spd mode error, 2
                  [463][mmc]: mmc 0 bias 0
                  [468][mmc]: HSSDR52/SDR25 4 bit
                  [471][mmc]: 50000000 Hz
                  [473][mmc]: 30264 MB
                  [475][mmc]: ***SD/MMC 0 init OK!!!***
                  [550]Loading boot-pkg Succeed(index=0).
                  [554]Entry_name        = u-boot
                  [561]Entry_name        = monitor
                  [564]Entry_name        = scp
                  [573]set arisc reset to de-assert state
                  [576]Entry_name        = dtb
                  [580]Jump to second Boot.
                  NOTICE:  BL3-1: v1.0(debug):cc1f5d7
                  NOTICE:  BL3-1: Built : 10:23:25, 2020-04-08
                  NOTICE:  BL3-1 commit: 8
                  ERROR:   Error initializing runtime service tspd_fast
                  NOTICE:  BL3-1: Preparing for EL3 exit to normal world
                  NOTICE:  BL3-1: Next image address = 0x4a000000
                  ▒OTICE:  BL3-1: Next image spsr = 0x1d3
                  U-Boot 2018.05 (Feb 07 2022 - 22:08:09 +0800) Allwinner Technology
                  [00.621]CPU:   Allwinner Family
                  [00.624]Model: sun50iw10
                  I2C:   ready
                  [00.874]DRAM:  1 GiB
                  [00.877]Relocation Offset is: 35f17000
                  [00.906]secure enable bit: 0
                  [00.910][ARISC] :arisc initialize
                  [00.915][ARISC ERROR] :get [allwinner,sunxi-hwspinlock] device node error
                  CACHE: Misaligned operation at range [7ffa72a0, 7ffa75b8]
                  [00.926][ARISC] :arisc para ok
                  [SCP] :sunxi-arisc driver begin startup 2
                  [SCP] :0x1
                  [SCP] :arisc version: []
                  [SCP] :arisc startup ready
                  [SCP] :arisc startup notify message feedback
                  [SCP] :send hard sync feedback message: 0x900200
                  [SCP] :sunxi-arisc driver v1.10 is starting
                  [00.953][ARISC] :sunxi-arisc driver startup succeeded
                  [00.958]pmu_axp81X_probe pmic_bus_read fail
                  [00.962]pmu_axp858_probe pmic_bus_read fail
                  [00.966]PMU: no found
                  [00.968]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
                  [00.975]init_clocks:finish
                  [00.977]drv_disp_init
                  request pwm success, pwm8:pwm8:0x300a000.
                  pwm_request: err:this pwm has been requested!
                  [01.013]drv_disp_init finish
                  [01.021]gic: sec monitor mode
                  [01.023]boot_gui_init:start
                  [01.028]set disp.dev2_output_type fail. using defval=0
                  [01.033]disp 1, clk: pll(490000000),clk(490000000),dclk(70000000) dsi_rate(490000000)
                       clk real:pll(492000000),clk(492000000),dclk(70285714) dsi_rate(0)
                  [01.050]switch device: sel=1, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
                  [01.057]boot_gui_init:finish
                  [01.059]flash init start
                  [01.062]workmode = 17,storage type = 1
                  try card 2
                  set card number 2
                  get card number 2
                  [01.069][mmc]: mmc driver ver uboot2018:2020-5-25 9:26:00-20201021190
                  [01.083][mmc]: Is not Boot mode!
                  [01.086][mmc]: SUNXI SDMMC Controller Version:0x50300
                  [01.097][mmc]: ************Try SD card 2************
                  [01.102][mmc]: mmc 2 cmd timeout 100 status 100
                  [01.106][mmc]: smc 2 err, cmd 8,  RTO
                  [01.110][mmc]: mmc 2 close bus gating and reset
                  [01.115][mmc]: mmc 2 cmd timeout 100 status 100
                  [01.119][mmc]: smc 2 err, cmd 55,  RTO
                  [01.122][mmc]: mmc 2 close bus gating and reset
                  [01.127][mmc]: ************Try MMC card[01.130]soc ic_ver:0x0, qa_val:0x0, markid:0x53002400 dclk[0-9999]
                   2************
                  [01.203][mmc]: mmc 2 cmd timeout 100 status 100
                  [01.207][mmc]: smc 2 err, cmd 8,  RTO
                  [01.210][mmc]: mmc 2 close bus gating and reset
                  [01.215][mmc]: mmc 2 cmd timeout 100 status 100
                  [01.219][mmc]: smc 2 err, cmd 55,  RTO
                  [01.223][mmc]: mmc 2 close bus gating and reset
                  [01.239]LCD open finish
                  [01.267][mmc]: gen_tuning_blk_bus8: total blk 10
                  [01.271][mmc]: gen_tuning_blk_bus4: total blk 6
                  [01.275][mmc]: Using 8 bit tuning now
                  [01.281][mmc]: write_tuning_try_freq: write ok
                  [01.285][mmc]: Pattern compare ok
                  [01.288][mmc]: Write tuning pattern ok
                  [01.292][mmc]: ================== HSSDR52_SDR25...
                  [01.296][mmc]: skip freq 400000
                  [01.299][mmc]: skip freq 25000000
                  [01.302][mmc]: freq: 2-50000000-64-4
                  [01.513][mmc]: [0-48|49] [61-63|3]
                  [01.516][mmc]: ================== HSDDR52_DDR50...
                  [01.521][mmc]: skip freq 400000
                  [01.524][mmc]: freq: 1-25000000-64-4
                  [01.746][mmc]: freq: 2-50000000-64-4
                  [01.971][mmc]: [0-39|40] [47-49|3] [52-63|12]
                  [01.975][mmc]: [0-24|25] [26-39|14] [47-63|17]
                  [01.979][mmc]: DS26/SDR12: 0xffffffff 0xffffffff
                  [01.983][mmc]: HSSDR52/SDR25: 0xff18ffff 0xffffffff
                  [01.988][mmc]: HSDDR52/DDR50: 0xff0c14ff 0xffffffff
                  [01.992][mmc]: HS200/SDR104: 0xffffffff 0xffffffff
                  [01.997][mmc]: HS400: 0xffffffff 0xffffffff
                  [02.001][mmc]: HS400: 0xffffffff 0xffffffff
                  [02.005][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
                  [02.011][mmc]: mmc driver ver uboot2018:2020-5-25 9:26:00-20201021190
                  [02.018][mmc]: get sdc_type fail and use default host:tm1.
                  [02.029][mmc]: Using default timing para
                  [02.033][mmc]: SUNXI SDMMC Controller Version:0x50300
                  [02.050][mmc]: card_caps:0x30000002
                  [02.053][mmc]: host_caps:0x3000003f
                  [02.059]Loading Environment from SUNXI_FLASH... OK
                  [02.063]try to burn key
                  [02.066]out of usb burn from boot: not need burn key
                  sunxi work mode=0x11
                  run card sprite
                  [02.083]try sprite_led_gpio config
                  [02.087]sprite_led_gpio start
                  [02.090]sunxi sprite begin
                  screen_width = 1280
                  screen_height = 800
                  bar x1: 320 y1: 360
                  bar x2: 960 y2: 440
                  357443 bytes read in 32 ms (10.7 MiB/s)
                  [SFTE_Set_Pixel_Sizes_i] 394 buf_size is 2304
                  cur_pixel_size 32 pixel_size 32
                  firmware name <NULL>
                  img start = 0x18000
                  try to read mmc start 98304
                  read mmc ok
                  [02.167]firmware probe ok
                  [02.169]fetch download map
                  *************DOWNLOAD MAP DUMP************
                  total download part 9
                  download part[0] name          :bootloader
                  download part[0] download file :BOOT-RESOURCE_FE
                  download part[0] verify file   :VBOOT-RESOURCE_F
                  download part[0] lenlo         :0x10000
                  download part[0] addrlo        :0x8000
                  download part[0] encrypt       :0x0
                  download part[0] verify        :0x1
                  download part[1] name          :env
                  download part[1] download file :ENV_FEX000000000
                  download part[1] verify file   :VENV_FEX00000000
                  download part[1] lenlo         :0x8000
                  download part[1] addrlo        :0x18000
                  download part[1] encrypt       :0x0
                  download part[1] verify        :0x1
                  download part[2] name          :boot
                  download part[2] download file :BOOT_FEX00000000
                  download part[2] verify file   :VBOOT_FEX0000000
                  download part[2] lenlo         :0x10000
                  download part[2] addrlo        :0x20000
                  download part[2] encrypt       :0x0
                  download part[2] verify        :0x1
                  download part[3] name          :super
                  download part[3] download file :SUPER_FEX0000000
                  download part[3] verify file   :VSUPER_FEX000000
                  download part[3] lenlo         :0x700000
                  download part[3] addrlo        :0x30000
                  download part[3] encrypt       :0x0
                  download part[3] verify        :0x1
                  download part[4] name          :recovery
                  download part[4] download file :RECOVERY_FEX0000
                  download part[4] verify file   :VRECOVERY_FEX000
                  download part[4] lenlo         :0x10000
                  download part[4] addrlo        :0x738000
                  download part[4] encrypt       :0x0
                  download part[4] verify        :0x1
                  download part[5] name          :vbmeta
                  download part[5] download file :VBMETA_FEX000000
                  download part[5] verify file   :VVBMETA_FEX00000
                  download part[5] lenlo         :0x8000
                  download part[5] addrlo        :0x888000
                  download part[5] encrypt       :0x0
                  download part[5] verify        :0x1
                  download part[6] name          :vbmeta_system
                  download part[6] download file :VBMETA_SYSTEM_FE
                  download part[6] verify file   :VVBMETA_SYSTEM_F
                  download part[6] lenlo         :0x8000
                  download part[6] addrlo        :0x890000
                  download part[6] encrypt       :0x0
                  download part[6] verify        :0x1
                  download part[7] name          :vbmeta_vendor
                  download part[7] download file :VBMETA_VENDOR_FE
                  download part[7] verify file   :VVBMETA_VENDOR_F
                  download part[7] lenlo         :0x8000
                  download part[7] addrlo        :0x898000
                  download part[7] encrypt       :0x0
                  download part[7] verify        :0x1
                  download part[8] name          :dtbo
                  download part[8] download file :DTBO_FEX00000000
                  download part[8] verify file   :VDTBO_FEX0000000
                  download part[8] lenlo         :0x1000
                  download part[8] addrlo        :0x8b8000
                  download part[8] encrypt       :0x0
                  download part[8] verify        :0x1
                  [02.413]fetch mbr
                  the 0 mbr table is ok
                  the 1 mbr table is ok
                  the 2 mbr table is ok
                  the 3 mbr table is ok
                  total mbr part 17
                  part[0] classname :DISK
                  part[0] user_type :32768
                  part[0] keydata   :0
                  part[0] ro        :0
                  part[1] name      :env
                  part[1] classname :DISK
                  part[1] user_type :32768
                  part[1] keydata   :0
                  part[1] ro        :0
                  part[2] name      :boot
                  part[2] classname :DISK
                  part[2] user_type :32768
                  part[2] keydata   :0
                  part[2] ro        :0
                  part[3] name      :super
                  part[3] classname :DISK
                  part[3] user_type :32768
                  part[3] keydata   :0
                  part[3] ro        :0
                  part[4] name      :misc
                  part[4] classname :DISK
                  part[4] addrlo    :0x730000
                  part[4] lenlo     :0x8000
                  part[4] user_type :32768
                  part[4] keydata   :0
                  part[4] ro        :0
                  part[5] name      :recovery
                  part[5] classname :DISK
                  part[5] addrlo    :0x738000
                  part[5] lenlo     :0x10000
                  part[5] user_type :32768
                  part[5] keydata   :0
                  part[5] ro        :0
                  part[6] name      :cache
                  part[6] classname :DISK
                  part[6] addrlo    :0x748000
                  part[6] lenlo     :0x140000
                  part[6] user_type :32768
                  part[6] keydata   :0
                  part[6] ro        :0
                  part[7] classname :DISK
                  part[7] addrlo    :0x888000
                  part[7] user_type :32768
                  part[7] keydata   :0
                  part[7] ro        :0
                  part[8] name      :vbmeta_system
                  part[8] classname :DISK
                  part[8] addrlo    :0x890000
                  part[8] lenlo     :0x8000
                  part[8] user_type :32768
                  part[8] keydata   :0
                  part[8] ro        :0
                  part[9] name      :vbmeta_vendor
                  part[9] classname :DISK
                  part[9] addrlo    :0x898000
                  part[9] lenlo     :0x8000
                  part[9] user_type :32768
                  part[9] keydata   :0
                  part[9] ro        :0
                  part[10] name      :metadata
                  part[10] classname :DISK
                  part[10] addrlo    :0x8a0000
                  part[10] lenlo     :0x8000
                  part[10] user_type :32768
                  part[10] keydata   :0
                  part[10] ro        :0
                  part[11] name      :private
                  part[11] classname :DISK
                  part[11] addrlo    :0x8a8000
                  part[11] lenlo     :0x8000
                  part[11] user_type :32768
                  part[11] keydata   :0
                  part[11] ro        :0
                  part[12] name      :frp
                  part[12] classname :DISK
                  part[12] addrlo    :0x8b0000
                  part[12] lenlo     :0x400
                  part[12] user_type :32768
                  part[12] keydata   :32768
                  part[12] ro        :0
                  part[13] name      :empty
                  part[13] classname :DISK
                  part[13] addrlo    :0x8b0400
                  part[13] lenlo     :0x7c00
                  part[13] user_type :32768
                  part[13] keydata   :0
                  part[13] ro        :0
                  part[14] name      :dtbo
                  part[14] classname :DISK
                  part[14] addrlo    :0x8b8000
                  part[14] lenlo     :0x1000
                  part[14] user_type :32768
                  part[14] keydata   :0
                  part[14] ro        :0
                  part[15] name      :media_data
                  part[15] classname :DISK
                  part[15] addrlo    :0x8b9000
                  part[15] lenlo     :0x8000
                  part[15] user_type :32768
                  part[15] keydata   :0
                  part[15] ro        :0
                  part[16] name      :UDISK
                  part[16] classname :DISK
                  part[16] addrlo    :0x8c1000
                  part[16] lenlo     :0x0
                  part[16] user_type :33024
                  part[16] keydata   :0
                  part[16] ro        :0
                  total mbr part 17
                  part[0] user_type :0x8000
                  part[0] keydata   :0x0
                  part[0] ro        :0x0
                  part[1] name      :env
                  part[1] user_type :0x8000
                  part[1] keydata   :0x0
                  part[1] ro        :0x0
                  part[2] name      :boot
                  part[2] user_type :0x8000
                  part[2] keydata   :0x0
                  part[2] ro        :0x0
                  part[3] name      :super
                  part[3] user_type :0x8000
                  part[3] keydata   :0x0
                  part[3] ro        :0x0
                  part[4] name      :misc
                  part[4] user_type :0x8000
                  part[4] keydata   :0x0
                  part[4] ro        :0x0
                  part[5] user_type :0x8000
                  part[5] keydata   :0x0
                  part[5] ro        :0x0
                  part[6] name      :cache
                  part[6] user_type :0x8000
                  part[6] keydata   :0x0
                  part[6] ro        :0x0
                  part[7] user_type :0x8000
                  part[7] keydata   :0x0
                  part[7] ro        :0x0
                  part[8] user_type :0x8000
                  part[8] keydata   :0x0
                  part[8] ro        :0x0
                  part[9] user_type :0x8000
                  part[9] keydata   :0x0
                  part[9] ro        :0x0
                  part[10] user_type :0x8000
                  part[10] keydata   :0x0
                  part[10] ro        :0x0
                  part[11] user_type :0x8000
                  part[11] keydata   :0x0
                  part[11] ro        :0x0
                  part[12] name      :frp
                  part[12] user_type :0x8000
                  part[12] keydata   :0x8000
                  part[12] ro        :0x0
                  part[13] user_type :0x8000
                  part[13] keydata   :0x0
                  part[13] ro        :0x0
                  part[14] name      :dtbo
                  part[14] user_type :0x8000
                  part[14] keydata   :0x0
                  part[14] ro        :0x0
                  part[15] user_type :0x8000
                  part[15] keydata   :0x0
                  part[15] ro        :0x0
                  part[16] lenlo     :0x0
                  part[16] user_type :0x8100
                  part[16] keydata   :0x0
                  part[16] ro        :0x0
                  [02.987]begin to erase flash
                  total part: 18
                  mbr 0, 8000, 8000
                  bootloader 1, 10000, 8000
                  env 2, 8000, 8000
                  boot 3, 10000, 8000
                  super 4, 700000, 8000
                  misc 5, 8000, 8000
                  recovery 6, 10000, 8000
                  cache 7, 140000, 8000
                  vbmeta 8, 8000, 8000
                  vbmeta_system 9, 8000, 8000
                  vbmeta_vendor 10, 8000, 8000
                  metadata 11, 8000, 8000
                  private 12, 8000, 8000
                  frp 13, 400, 8000
                  empty 14, 7c00, 8000
                  dtbo 15, 1000, 8000
                  media_data 16, 8000, 8000
                  UDISK 17, 0, 8100
                  [03.027]erase all part start
                  need erase flash: 1
                  ******Has init
                  private part exist
                  GPT:bootloader  : 12000         21fff
                  GPT:env         : 22000         29fff
                  GPT:boot        : 2a000         39fff
                  GPT:super       : 3a000         739fff
                  GPT:misc        : 73a000        741fff
                  GPT:recovery    : 742000        751fff
                  GPT:cache       : 752000        891fff
                  GPT:vbmeta      : 892000        899fff
                  GPT:vbmeta_system: 89a000        8a1fff
                  GPT:vbmeta_vendor: 8a2000        8a9fff
                  GPT:metadata    : 8aa000        8b1fff
                  GPT:private     : 8b2000        8b9fff
                  GPT:frp         : 8ba000        8ba3ff
                  GPT:empty       : 8ba400        8c1fff
                  GPT:dtbo        : 8c2000        8c2fff
                  GPT:media_data  : 8c3000        8cafff
                  GPT:UDISK       : 8cb000        e8ffde
                  begin to store data
                  part 0 name bootloader
                  keydata = 0x0
                  part 1 name env
                  keydata = 0x0
                  part 2 name boot
                  keydata = 0x0
                  part 3 name super
                  keydata = 0x0
                  part 4 name misc
                  keydata = 0x0
                  part 5 name recovery
                  keydata = 0x0
                  part 6 name cache
                  keydata = 0x0
                  part 7 name vbmeta
                  keydata = 0x0
                  part 8 name vbmeta_system
                  keydata = 0x0
                  part 9 name vbmeta_vendor
                  keydata = 0x0
                  part 10 name metadata
                  keydata = 0x0
                  part 11 name private
                  keydata = 0x0
                  find keypart private
                  keypart read start: 0x8a8000, sectors 0x8000
                  keypart part private read  0x8a8000, sectors 0x8000
                  part 12 name frp
                  keydata = 0x1
                  find keypart frp
                  keypart read start: 0x8b0000, sectors 0x400
                  keypart part frp read  0x8b0000, sectors 0x400
                  part 13 name empty
                  keydata = 0x0
                  part 14 name dtbo
                  keydata = 0x0
                  part 15 name media_data
                  keydata = 0x0
                  part 16 name UDISK
                  keydata = 0x0
                  begin to erase
                  [03.380]erase all part start
                  card2 erase boot0
                  erase env part
                  [03.394][mmc]: erase from: 139264, to: 172031, cnt: 32768, erase_group: 1024
                  [03.411][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0xa ms
                  erase boot part
                  [03.419][mmc]: erase from: 172032, to: 237567, cnt: 65536, erase_group: 1024
                  [03.452][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x1b ms
                  erase super part
                  [03.460][mmc]: erase from: 237568, to: 7577599, cnt: 7340032, erase_group: 1024
                  [05.564][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x831 ms
                  erase misc part
                  [05.572][mmc]: erase from: 7577600, to: 7610367, cnt: 32768, erase_group: 1024
                  [05.589][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0xa ms
                  erase recovery part
                  [05.597][mmc]: erase from: 7610368, to: 7675903, cnt: 65536, erase_group: 1024
                  [05.631][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x1b ms
                  erase cache part
                  [05.639][mmc]: erase from: 7675904, to: 8986623, cnt: 1310720, erase_group: 1024
                  [05.989][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x157 ms
                  erase vbmeta part
                  [05.997][mmc]: erase from: 8986624, to: 9019391, cnt: 32768, erase_group: 1024
                  [06.014][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0xa ms
                  erase vbmeta_system part
                  [06.023][mmc]: erase from: 9019392, to: 9052159, cnt: 32768, erase_group: 1024
                  [06.040][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0xa ms
                  erase vbmeta_vendor part
                  [06.048][mmc]: erase from: 9052160, to: 9084927, cnt: 32768, erase_group: 1024
                  [06.065][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0xa ms
                  erase metadata part
                  [06.074][mmc]: erase from: 9084928, to: 9117695, cnt: 32768, erase_group: 1024
                  [06.092][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0xb ms
                  erase private part
                  [06.100][mmc]: erase from: 9117696, to: 9150463, cnt: 32768, erase_group: 1024
                  [06.121][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0xe ms
                  erase frp part
                  [06.129][mmc]: erase from: 9150464, to: 9151487, cnt: 1024, erase_group: 1024
                  [06.138][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x2 ms
                  erase empty part
                  [06.146][mmc]: erase from: 9151488, to: 9183231, cnt: 31744, erase_group: 1024
                  [06.162][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x9 ms
                  erase dtbo part
                  [06.170][mmc]: erase from: 9183232, to: 9187327, cnt: 4096, erase_group: 1024
                  [06.180][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x3 ms
                  erase media_data part
                  [06.188][mmc]: erase from: 9187328, to: 9220095, cnt: 32768, erase_group: 1024
                  [06.206][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0xb ms
                  erase UDISK part
                  sunxi_sprite_mmc_phyerase: @nr is 0, erase from @from to end
                  [06.219][mmc]: erase from: 9220096, to: 15268863, cnt: 6048768, erase_group: 1024
                  [07.790][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x61c ms
                  [07.797][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
                  [07.802][mmc]: --0: from15268864  nr1023
                  card erase all
                  finish erase
                  ******Has init
                  rewrite
                  ******Has init
                  write primary GPT success
                  write Backup GPT success
                  keypart write start: 0x8a8000, sectors 0x8000
                  keypart write start: 0x8b0000, sectors 0x400
                  flash exit
                  [08.242]successed in erasing flash
                  ******Has init
                  [08.254]begin to download part
                  [08.256]begin to download part bootloader
                  partdata hi 0x0
                  partdata lo 0x91ac00
                  sparse: bad magic
                  [09.282]successed in writting part bootloader
                  origin_verify value = efcdf783, active_verify value = efcdf783
                  [09.419]successed in verify part bootloader
                  [09.423]successed in download part bootloader
                  [09.427]begin to download part env
                  partdata hi 0x0
                  partdata lo 0x20000
                  sparse: bad magic
                  [09.449]successed in writting part env
                  origin_verify value = abb98d91, active_verify value = abb98d91
                  [09.462]successed in verify part env
                  [09.465]successed in download part env
                  [09.469]begin to download part boot
                  partdata hi 0x0
                  partdata lo 0x2000000
                  sparse: bad magic
                  [13.037]successed in writting part boot
                  origin_verify value = 97897dde, active_verify value = 97897dde
                  [13.484]successed in verify part boot
                  [13.487]successed in download part boot
                  [13.491]begin to download part super
                  partdata hi 0x0
                  partdata lo 0x35808280
                  chunk 0(2385)
                  chunk 1(2385)
                  chunk 2(2385)
                  chunk 3(2385)
                  chunk 4(2385)
                  chunk 5(2385)
                  chunk 6(2385)
                  chunk 7(2385)
                  chunk 8(2385)
                  chunk 9(2385)
                  chunk 10(2385)
                  chunk 11(2385)
                  chunk 12(2385)
                  chunk 13(2385)
                  chunk 2378(2385)
                  chunk 2379(2385)
                  chunk 2380(2385)
                  chunk 2381(2385)
                  chunk 2382(2385)
                  chunk 2383(2385)
                  chunk 2384(2385)
                  [232.228]successed in writting part super
                  origin_verify value = 2c17b45a, active_verify value = 2c17b45a
                  [232.237]successed in verify part super
                  [232.241]successed in download part super
                  [232.244]begin to download part recovery
                  partdata hi 0x0
                  sparse: bad magic
                  [239.134]successed in writting part recovery
                  origin_verify value = c9c11f80, active_verify value = c9c11f80
                  [239.583]successed in verify part recovery
                  [239.587]successed in download part recovery
                  [239.591]begin to download part vbmeta
                  partdata hi 0x0
                  partdata lo 0x2000
                  sparse: bad magic
                  [239.601]successed in writting part vbmeta
                  origin_verify value = 4074c1f1, active_verify value = 4074c1f1
                  [239.614]successed in verify part vbmeta
                  [239.617]successed in download part vbmeta
                  [239.621]begin to download part vbmeta_system
                  partdata hi 0x0
                  partdata lo 0x1000
                  sparse: bad magic
                  [239.631]successed in writting part vbmeta_system
                  origin_verify value = 53be81d4, active_verify value = 53be81d4
                  [239.644]successed in verify part vbmeta_system
                  [239.648]successed in download part vbmeta_system
                  [239.653]begin to download part vbmeta_vendor
                  partdata hi 0x0
                  partdata lo 0x1000
                  sparse: bad magic
                  [239.663]successed in writting part vbmeta_vendor
                  origin_verify value = 3e1679d9, active_verify value = 3e1679d9
                  [239.676]successed in verify part vbmeta_vendor
                  [239.680]successed in download part vbmeta_vendor
                  [239.684]begin to download part dtbo
                  partdata hi 0x0
                  sparse: bad magic
                  [240.112]successed in writting part dtbo
                  origin_verify value = c2511571, active_verify value = c2511571
                  [240.151]successed in verify part dtbo
                  [240.154]successed in download part dtbo
                  [240.163]successed in downloading part
                  uboot size = 0xec000
                  storage type = 2
                  sunxi_sprite_deal_uboot ok
                  [240.342]successed in downloading uboot
                  [240.431][mmc]: write mmc 2 info ok
                  dram para[0] = 318
                  dram para[1] = 8
                  dram para[2] = c0c0c0c
                  dram para[3] = d0d0d0d
                  dram para[4] = e0e
                  dram para[5] = f0e0c0e
                  dram para[6] = 30fa
                  dram para[7] = 4000000
                  dram para[8] = 0
                  dram para[9] = 34
                  dram para[10] = 1b
                  dram para[11] = 33
                  dram para[12] = 3
                  dram para[13] = 0
                  dram para[14] = 0
                  dram para[15] = 4
                  dram para[16] = 72
                  dram para[17] = 0
                  dram para[18] = 7
                  dram para[19] = 0
                  dram para[20] = 0
                  dram para[21] = 24
                  dram para[22] = 0
                  dram para[23] = 80000000
                  dram para[24] = 0
                  dram para[25] = 0
                  dram para[26] = 31010101
                  dram para[27] = 2e0000
                  dram para[28] = 24222122
                  dram para[29] = f0f0e0f
                  dram para[30] = 6063
                  dram para[31] = 1d1d1b1c
                  storage type = 2
                  [240.563]successed in downloading boot0
                  CARD OK
                  [240.567]sprite success
                  sprite_next_work=3
                  next work 3
                  SUNXI_UPDATE_NEXT_ACTION_SHUTDOWN
                  [243.575][mmc]: mmc exit start
                  [243.647][mmc]: mmc 2 exit ok
                  烧录完成
                    memory LV 7 最后由 编辑
                    刷完重启, Android正常,初步判断就是哪吒 u-boot 的 mmc 命令未实现导致量产卡失败?
