    boot0启动的时候一直按 2 或者按 d,就能进入FEL烧录模式的原因
      memory LV 7 最后由 编辑
      void main(void)
              int dram_size;
              int status;
              phys_addr_t  uboot_base = 0, optee_base = 0, monitor_base = 0, \
                                      rtos_base = 0, opensbi_base = 0;
              u16 pmu_type = 0, key_input = 0; /* TODO: set real value */
              sunxi_serial_init(BT0_head.prvt_head.uart_port, (void *)BT0_head.prvt_head.uart_ctrl, 6);
              printf("HELLO! BOOT0 is starting!\n");
              printf("BOOT0 commit : %s\n", BT0_head.hash);
              sunxi_set_printf_debug_mode(BT0_head.prvt_head.debug_mode);
              status = sunxi_board_init();
              if(status)
                      goto _BOOT_ERROR;
              if (rtc_probe_fel_flag()) {
                      rtc_clear_fel_flag();
                      goto _BOOT_ERROR;
      #ifdef CFG_SUNXI_PHY_KEY
              } else if (check_update_key(&key_input)) {
                      goto _BOOT_ERROR;
              } else if (BT0_head.prvt_head.enable_jtag) {
                      printf("enable_jtag\n");
                      boot_set_gpio((normal_gpio_cfg *)BT0_head.prvt_head.jtag_gpio, 5, 1);
      #ifdef FPGA_PLATFORM
              dram_size = mctl_init((void *)BT0_head.prvt_head.dram_para);
      #else
      #ifdef CFG_DDR_SOFT_TRAIN
              if (BT0_head.prvt_head.dram_para[30] & (1 << 11))
                      neon_enable();
              dram_size = init_DRAM(0, (void *)BT0_head.prvt_head.dram_para);
              if(!dram_size)
                      goto _BOOT_ERROR;
              else {
                      printf("dram size =%d\n", dram_size);
              char uart_input_value = get_uart_input();
              if (uart_input_value == '2') {
                      sunxi_set_printf_debug_mode(3);
                      printf("detected user input 2\n");
                      goto _BOOT_ERROR;
              } else if (uart_input_value == 'd') {
                      sunxi_set_printf_debug_mode(8);
                      printf("detected user input d\n");
              mmu_enable(dram_size);
              malloc_init(CONFIG_HEAP_BASE, CONFIG_HEAP_SIZE);
      lichee/brandy-2.0/spl/nboot/main/boot0_main.c
