    A133 BOARD_HAS_SECURE_OS
    11
    10911
    • G
      gworld LV 3 最后由 编辑
      BOARD_HAS_SECURE_OS ?= true时从开机到安卓启动画面时间很长,大概需要1分钟;
      BOARD_HAS_SECURE_OS ?= false时在安卓启动画面很快,但是一共卡在安卓启动画面,报错 vdc: Failed: Status(-8, EX_SERVICE_SPECIFIC): '0: '望大神指点。
      • tigger
        tigger LV 7 最后由 编辑
        我的A133 35秒启动到桌面
        G T 2 条回复 最后回复 回复 引用 分享 0
        • G
          gworld LV 3 @tigger 最后由 编辑
          @tigger 你这个BOARD_HAS_SECURE_OS ? =false吗?
          • tigger
            tigger LV 7 最后由 编辑
            • tigger
              tigger LV 7 最后由 编辑
              [123]HELLO! BOOT0 is starting!
              [126]BOOT0 commit : dc54be6
              [128]set pll start
              [130]periph0 has been enabled
              [134]set pll end
              [135][pmu]: bus read error
              [138][pmu]: bus read error
              [146]vaild para:1  select dram para0
              [149]board init ok
              [151]DRAM BOOT DRIVE INFO: V0.19
              [155]the chip id is 0x2400
              [157]the chip id is 0x2400
              [160]the chip id is 0x2400
              [163]the chip id is 0x2400
              [165]the chip id is 0x2400
              [168]chip id check OK
              [170]DRAM_VCC set to 1100 mv
              [173]DRAM CLK =792 MHZ
              [175]DRAM Type =8 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
              [183]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6063
              [196]DRAM simple test OK.
              [198]dram size =1024
              [200]chipid = 53002400
              [203]nsi init ok 2020-4-7
              [206]card no is 2
              [208]sdcard 2 line count 8
              [210][mmc]: mmc driver ver 2020-05-25 09:40
              [220][mmc]: Wrong media type 0x0
              [223][mmc]: ***Try SD card 2***
              [227][mmc]: mmc 2 cmd 8 timeout, err 100
              [231][mmc]: mmc 2 cmd 8 err 100
              [234][mmc]: mmc 2 send if cond failed
              [239][mmc]: mmc 2 cmd 55 timeout, err 100
              [243][mmc]: mmc 2 cmd 55 err 100
              [246][mmc]: mmc 2 send app cmd failed
              [250][mmc]: ***Try MMC card 2***
              [307][mmc]: RMCA OK!
              [309][mmc]: mmc 2 bias 4
              [313][mmc]: MMC 5.0
              [315][mmc]: HSSDR52/SDR25 8 bit
              [318][mmc]: 50000000 Hz
              [320][mmc]: 7456 MB
              [322][mmc]: ***SD/MMC 2 init OK!!!***
              [377]Loading boot-pkg Succeed(index=0).
              [381]Entry_name        = u-boot
              [388]Entry_name        = monitor
              [391]Entry_name        = scp
              [399]set arisc reset to de-assert state
              [403]Entry_name        = dtb
              [407]tunning data addr:0x4a0003e8
              [410]Jump to second Boot.
              NOTICE:  BL3-1: v1.0(debug):cc1f5d7
              NOTICE:  BL3-1: Built : 10:23:25, 2020-04-08
              NOTICE:  BL3-1 commit: 8
              ERROR:   Error initializing runtime service tspd_fast
              NOTICE:  BL3-1: Preparing for EL3 exit to normal world
              NOTICE:  BL3-1: Next image address = 0x4a000000
              NOTICE:  BL3-1: Next image spsr = 0x1d3
              U-Boot 2018.05 (Feb 14 2022 - 13:42:55 +0800) Allwinner Technology
              [00.489]CPU:   Allwinner Family
              [00.492]Model: sun50iw10
              I2C:   ready
              [00.736]DRAM:  1 GiB
              [00.739]Relocation Offset is: 35f17000
              [00.769]secure enable bit: 0
              [00.771][ARISC] :arisc initialize
              [00.776][ARISC ERROR] :get [allwinner,sunxi-hwspinlock] device node error
              CACHE: Misaligned operation at range [7ffa72a0, 7ffa75b8]
              [00.788][ARISC] :arisc para ok
              [SCP] :sunxi-arisc driver begin startup 2
              [SCP] :0x1
              [SCP] :arisc version: []
              [SCP] :arisc startup ready
              [SCP] :arisc startup notify message feedback
              [SCP] :send hard sync feedback message: 0x900200
              [SCP] :sunxi-arisc driver v1.10 is starting
              [00.815][ARISC] :sunxi-arisc driver startup succeeded
              [00.820]pmu_axp81X_probe pmic_bus_read fail
              [00.824]pmu_axp858_probe pmic_bus_read fail
              [00.828]PMU: no found
              [00.830]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
              [00.837]init_clocks:finish
              [00.839]not need merged sunxi overlay
              [00.843]drv_disp_init
              request pwm success, pwm8:pwm8:0x300a000.
              pwm_request: err:this pwm has been requested!
              [00.878]drv_disp_init finish
              [00.886]gic: sec monitor mode
              [00.889]flash init start
              [00.891]workmode = 0,storage type = 2
              [00.894][mmc]: mmc driver ver uboot2018:2020-5-25 9:26:00-20201021190
              [00.908][mmc]: SUNXI SDMMC Controller Version:0x50300
              [00.983][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
              [00.990]sunxi flash init ok
              [00.993]Loading Environment from SUNXI_FLASH... OK
              [01.002]no secure os for keybox operation
              [01.006]try to burn key
              [01.009]out of usb burn from boot: not need burn key
              [01.014]boot_gui_init:start
              [01.018]set disp.dev2_output_type fail. using defval=0
              [01.023]disp 1, clk: pll(490000000),clk(490000000),dclk(70000000) dsi_rate(490000000)
                   clk real:pll(492000000),clk(492000000),dclk(70285714) dsi_rate(0)
              [01.040]switch device: sel=1, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
              [01.047]boot_gui_init:finish
              2764854 bytes read in 33 ms (79.9 MiB/s)
              [01.102]read item0 copy0
              [01.114]Item0 (Map) magic is bad
              [01.117]the secure storage item0 copy[01.120]soc ic_ver:0x0, qa_val:0x0, markid:0x53002400 dclk[0-9999]
              0 magic is bad
              [01.137]Item0 (Map) magic is bad
              [01.140]the secure storage item0 copy1 magic is bad
              [01.145]Item0 (Map) magic is bad
              [01.148]the secure storage map is empty
              [01.151]no item name device_unlock in the map
              [01.155]no item name fastboot_status_flag in the map
              [01.160]sunxi secure storage has no flag
              [01.166][mmc]: delete mmc-hs400-1_8v from dtb
              [01.169][mmc]: delete mmc-hs200-1_8v from dtb
              [01.175](weak)update dtb dram start
              [01.179]update dtb dram  end
              [01.182]update dts
              [01.184]no item name snum in the map
              [01.197]load file(ULI/factory/snum.txt) error.
              [01.201]no item name mac in the map
              [01.215]load file(ULI/factory/mac.txt) error.
              [01.219]no item name wifi_mac in the map
              [01.229]LCD open finish
              [01.239]load file(ULI/factory/wifi_mac.txt) error.
              [01.243]no item name bt_mac in the map
              [01.257]load file(ULI/factory/bt_mac.txt) error.
              [01.262]no item name specialstr in the map
              [01.276]load file(ULI/factory/specialstr.txt) error.
              [01.289]update part info
              [01.292]key 0
              [01.296]misc partition found
              [01.398]update bootcmd
              [01.399]serial num is: 0c001415a0c0876220d
              [03.414]partinfo: name boot, start 0x2a000, size 0x10000
              [03.707]read data in addr ret = 1
              [03.709]magic = AVB0
              [03.712]major version = 1  minor version = 0
              [03.716]authentication_data_block_size = 240
              [03.720]auxiliary_data_block_size = d40
              [03.723]vbmeta_size = 4224
              [03.726]algorithm_type = 0
              [03.728]flag = 1
              [03.730]release tool = avbtool 1.1.0
              [03.747]read data in addr ret = 1
              [03.750]magic = AVB0
              [03.752]major version = 1  minor version = 0
              [03.756]authentication_data_block_size = 140
              [03.760]auxiliary_data_block_size = 3c0
              [03.764]vbmeta_size = 1536
              [03.766]algorithm_type = 0
              [03.769]flag = 0
              [03.770]release tool = avbtool 1.1.0
              [03.788]read data in addr ret = 1
              [03.791]magic = AVB0
              [03.793]major version = 1  minor version = 0
              [03.797]authentication_data_block_size = 140
              [03.801]auxiliary_data_block_size = 340
              [03.805]vbmeta_size = 1408
              [03.807]algorithm_type = 0
              [03.810]flag = 0
              [03.811]release tool = avbtool 1.1.0
              [03.815]total_size = 7168
              [03.817]alloc block = 17
              [03.861]vbmeta hash is 5639a0abfa80d7a29b777a9fc9dea4a1fb40797ec8ad6fd229bd60db8c6d52c1[03.870]in boot normal mode,pass normal para to cmdline
              [03.876]android.hardware = sun50iw10p1
              [03.879]line:56 dtbo_idx= 0
              [03.882]dtbo_idx= 64
              [03.962]partinfo: name dtbo, start 0x8c2000, size 0x1000
              [04.016]Starting kernel ...
              [04.018][mmc]: mmc exit start
              [04.106][mmc]: mmc 2 exit ok
              [    0.000000] Linux version 4.9.170 (tigger@ubuntu) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #6 SMP PREEMPT Mon Feb 14 19:34:12 CST 2022
              [    0.000000] Boot CPU: AArch64 Processor [410fd034]
              [    0.000000] bootconsole [earlycon0] enabled
              [    0.000000] disp reserve base 0x7bf65080 ,size 0x3e8000
              [    0.000000] cma: Reserved 8 MiB at 0x000000007f800000
              [    0.000000] On node 0 totalpages: 262144
              [    0.000000]   DMA zone: 4096 pages used for memmap
              [    0.000000]   DMA zone: 0 pages reserved
              [    0.000000]   DMA zone: 262144 pages, LIFO batch:31
              [    0.000000] psci: Trusted OS migration not required
              [    0.000000] percpu: Embedded 23 pages/cpu @ffffffc03f704000 s53376 r8192 d32640 u94208
              [    0.000000] pcpu-alloc: s53376 r8192 d32640 u94208 alloc=23*4096
              [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
              [    0.000000] Detected VIPT I-cache on CPU0
              [    0.000000] CPU features: enabling workaround for ARM erratum 845719
              [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258048
              [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4 init=/init partitions=bootloader@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:super@mmcblk0p4:misc@mmcblk0p5:recovery@mmcblk0p6:cache@mmcblk0p7:vbmeta@mmcblk0p8:vbmeta_system@mmcblk0p9:vbmeta_vendor@mmcblk0p10:metadata@mmcblk0p11:private@mmcblk0p12:frp@mmcblk0p13:empty@mmcblk0p14:dtbo@mmcblk0p15:media_data@mmcblk0p16:UDISK@mmcblk0p17 cma=8M snum=0c001415a0c0876220d mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.vbmeta.avb_version=2.0 androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=7168 androidboot.vbmeta.digest=5639a0abfa80d7a29b777a9fc9dea4a1fb40797ec8ad6fd229bd60db8c6d52c1 androidboot.vbmeta.device_state=locked androidboot.mode=normal androidboot.serialno=0c001415a0c0876220d androidboot.hardware=sun50iw10p1 boot_type=2 androidboot.boot_type=2 androidboot.secure_os_exist=0 androidboot.trustchain=false gpt=1 uboot_message=2018.05(02/14/2[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
              [    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
              [    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
              [    0.000000] Memory: 977428K/1048576K available (11390K kernel code, 2192K rwdata, 4040K rodata, 4416K init, 600K bss, 62956K reserved, 8192K cma-reserved)
              [    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
              [    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
              [    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008ba0000   ( 11392 KB)
              [    0.000000]     .rodata : 0xffffff8008ba0000 - 0xffffff8008fa0000   (  4096 KB)
              [    0.000000]       .init : 0xffffff8008fa0000 - 0xffffff80093f0000   (  4416 KB)
              [    0.000000]       .data : 0xffffff80093f0000 - 0xffffff8009614008   (  2193 KB)
              [    0.000000]        .bss : 0xffffff8009614008 - 0xffffff80096aa018   (   601 KB)
              [    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
              [    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
              [    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
              [    0.000000]               0xffffffbf00000000 - 0xffffffbf01000000   (    16 MB actual)
              [    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc040000000   (  1024 MB)
              [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
              [    0.000000]  Build-time adjustment of leaf fanout to 64.
              [    0.000000] NR_IRQS:64 nr_irqs:64 0
              [    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
              [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
              [    0.008146] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
              [    0.018200] pid_max: default: 32768 minimum: 301
              [    0.023030] Security Framework initialized
              [    0.026879] SELinux:  Initializing.
              [    0.030474] SELinux:  Starting in permissive mode
              [    0.035135] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
              [    0.041697] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
              [    0.049576] ftrace: allocating 34487 entries in 135 pages
              [    0.133178] sched-energy: CPU device node has no sched-energy-costs
              [    0.133820] Invalid sched_group_energy for CPU0
              [    0.138357] CPU0: update cpu_capacity 1024
              [    0.152464] ASID allocator initialised with 32768 entries
              [    0.171401] BOOTEVENT:       171.390957: ON
              [    0.199434] Detected VIPT I-cache on CPU1
              [    0.199486] Invalid sched_group_energy for CPU1
              [    0.199488] CPU1: update cpu_capacity 1024
              [    0.199491] CPU1: Booted secondary processor [410fd034]
              [    0.222806] Detected VIPT I-cache on CPU2
              [    0.222832] Invalid sched_group_energy for CPU2
              [    0.222835] CPU2: update cpu_capacity 1024
              [    0.222837] CPU2: Booted secondary processor [410fd034]
              [    0.246220] Detected VIPT I-cache on CPU3
              [    0.246245] Invalid sched_group_energy for CPU3
              [    0.246248] CPU3: update cpu_capacity 1024
              [    0.246250] CPU3: Booted secondary processor [410fd034]
              [    0.246334] Brought up 4 CPUs
              [    0.296969] SMP: Total of 4 processors activated.
              [    0.301660] CPU features: detected feature: 32-bit EL0 Support
              [    0.307466] CPU features: detected feature: Kernel page table isolation (KPTI)
              [    0.318493] CPU: All CPU(s) started at EL1
              [    0.318737] alternatives: patching kernel code
              [    0.323346] Invalid sched_group_energy for CPU3
              [    0.327663] CPU3: update max cpu_capacity 1024
              [    0.332079] Invalid sched_group_energy for Cluster3
              [    0.336932] Invalid sched_group_energy for CPU2
              [    0.341439] Invalid sched_group_energy for Cluster2
              [    0.346291] Invalid sched_group_energy for CPU1
              [    0.350799] Invalid sched_group_energy for Cluster1
              [    0.355651] Invalid sched_group_energy for CPU0
              [    0.360159] Invalid sched_group_energy for Cluster0
              [    0.365541] CPU1: update max cpu_capacity 1024
              [    0.370156] devtmpfs: initialized
              [    0.412316] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
              [    0.416457] futex hash table entries: 1024 (order: 5, 131072 bytes)
              [    0.423259] atomic64_test: passed
              [    0.425951] pinctrl core: initialized pinctrl subsystem
              [    0.433244] NET: Registered protocol family 16
              [    0.436992] dump_class_init,861, success
              [    0.456219] cpuidle: using governor menu
              [    0.457555] sunxi iommu: irq = 9
              [    0.458517] vdso: 2 pages (1 code @ ffffff8008ba8000, 1 data @ ffffff80093f4000)
              [    0.465121] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
              [    0.473295] DMA: preallocated 256 KiB pool for atomic allocations
              [    0.481138] sun50iw10p1-r-pinctrl r_pio: initialized sunXi PIO driver
              [    0.501695] sun50iw10p1-pinctrl pio: initialized sunXi PIO driver
              [    0.506244] iommu: Adding device 1c0e000.ve to group 0
              [    0.514561] iommu: Adding device 6000000.disp to group 0
              [    0.515414] iommu: Adding device 6480000.g2d to group 0
              [    0.523478] iommu: Adding device csi0 to group 0
              [    0.524467] iommu: Adding device csi1 to group 0
              [    0.529717] iommu: Adding device 2108000.tdm to group 0
              [    0.534293] iommu: Adding device 2100000.isp to group 0
              [    0.539474] iommu: Adding device 2102000.isp to group 0
              [    0.544523] iommu: Adding device 2110000.scaler to group 0
              [    0.549978] iommu: Adding device 2110400.scaler to group 0
              [    0.555432] iommu: Adding device 2110800.scaler to group 0
              [    0.560900] iommu: Adding device 2110c00.scaler to group 0
              [    0.601407] pwm module init!
              [    0.606625] sunxi-pm debug v3.10
              [    0.608113] SCSI subsystem initialized
              [    0.608885] usbcore: registered new interface driver usbfs
              [    0.613566] usbcore: registered new interface driver hub
              [    0.618833] usbcore: registered new device driver usb
              [    0.623993] sunxi_i2c_adap_init()2541 - init
              [    0.628560] sunxi_i2c_probe()2289 - [i2c0] twi_drv_used = 0
              [    0.633552] sunxi_i2c_probe()2293 - [i2c0] twi_pkt_interval = 0
              [    0.639442] twi0 supply twi not found, using dummy regulator
              [    0.645141] twi_request_gpio()453 - [i2c0] init name: twi0
              [    0.651253] sunxi_i2c_probe()2289 - [i2c1] twi_drv_used = 0
              [    0.656070] sunxi_i2c_probe()2293 - [i2c1] twi_pkt_interval = 0
              [    0.661985] twi1 supply twi not found, using dummy regulator
              [    0.667666] twi_request_gpio()453 - [i2c1] init name: twi1
              [    0.673896] sunxi_i2c_probe()2289 - [i2c2] twi_drv_used = 0
              [    0.678606] sunxi_i2c_probe()2293 - [i2c2] twi_pkt_interval = 0
              [    0.684505] twi2 supply twi not found, using dummy regulator
              [    0.690198] twi_request_gpio()453 - [i2c2] init name: twi2
              [    0.696176] sunxi_i2c_probe()2289 - [i2c3] twi_drv_used = 0
              [    0.701135] sunxi_i2c_probe()2293 - [i2c3] twi_pkt_interval = 0
              [    0.707037] twi3 supply twi not found, using dummy regulator
              [    0.712748] twi_request_gpio()453 - [i2c3] init name: twi3
              [    0.718700] media: Linux media interface: v0.10
              [    0.722685] Linux video capture interface: v2.00
              [    0.728248] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
              [    0.734297] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
              [    0.740665] ion_parse_dt_heap_common: id 6 type 6 name secure align 1000
              [    0.747474] drm config service not available: FFFFFFFF
              [    0.752543] Advanced Linux Sound Architecture Driver Initialized.
              [    0.759054] Bluetooth: Core ver 2.22
              [    0.761946] NET: Registered protocol family 31
              [    0.766304] Bluetooth: HCI device and connection manager initialized
              [    0.772645] Bluetooth: HCI socket layer initialized
              [    0.777490] Bluetooth: L2CAP socket layer initialized
              [    0.782557] Bluetooth: SCO socket layer initialized
              [    0.788150] ncs8801s init:*************************
              [    0.792378] script_ncs8801s_gpio_init: ncs8801s is not used
              [    0.798430] clocksource: Switched to clocksource arch_sys_counter
              [    0.880819] VFS: Disk quotas dquot_6.6.0
              [    0.880960] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
              [    0.888742] udc_init,0
              [    0.889952] NET: Registered protocol family 2
              [    0.905297] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
              [    0.906769] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
              [    0.913354] TCP: Hash tables configured (established 8192 bind 8192)
              [    0.919621] UDP hash table entries: 512 (order: 2, 16384 bytes)
              [    0.925464] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
              [    0.932113] NET: Registered protocol family 1
              [    0.936399] Trying to unpack rootfs image as initramfs...
              [    0.969166] Freeing initrd memory: 752K
              [    0.970710] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
              [    0.977696] audit: initializing netlink subsys (disabled)
              [    0.980560] audit: type=2000 audit(0.806:1): initialized
              [    0.986820] workingset: timestamp_bits=45 max_order=18 bucket_order=0
              [    1.003938] Registering sdcardfs 0.1
              [    1.004520] ntfs: driver 2.1.32 [Flags: R/W].
              [    1.006779] fuse init (API version 7.26)
              [    1.012420] SELinux:  Registering netfilter hooks
              [    1.019334] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
              [    1.022237] io scheduler noop registered
              [    1.026079] io scheduler deadline registered
              [    1.030636] io scheduler cfq registered (default)
              [    1.036606] [DISP]disp_module_init
              [    1.039578] [DISP] disp_init,line:2260:
              [    1.042041] smooth display screen:1 type:1 mode:4
              [    1.130480] [DISP] lcd_clk_config,line:665:
              ;▒▒▒▒J"ͥ}Ʌѕ▒490000000)
              [    1.130527]      clk real:pll(492000000),clk(492000000),dclk(70285714) dsi_rate(0)
              [    1.132303] [DISP]disp_module_init finish
              [    1.134375] uart uart0: get regulator failed
              [    1.134390] uart0 supply uart not found, using dummy regulator
              [    1.134676] uart0: ttyS0 at MMIO 0x5000000 (irq = 349, base_baud = 1500000) is a SUNXI
              [    1.134695] sw_console_setup()1731 - console setup baud 115200 parity n bits 8, flow n
              [    1.168933] console [ttyS0] enabled
              [    1.178463] bootconsole [earlycon0] disabled
              [    1.187529] uart uart1: get regulator failed
              [    1.195757] uart1 supply uart not found, using dummy regulator
              [    1.202592] uart1: ttyS1 at MMIO 0x5000400 (irq = 350, base_baud = 1500000) is a SUNXI
              [    1.212515] misc dump reg init
              [    1.217055] G2D: Module initialized.major:246
              [    1.223260] [drm] Initialized
              [    1.226792] Unable to detect cache hierarchy for CPU 0
              [    1.246250] brd: module loaded
              [    1.265453] loop: module loaded
              [    1.269941] zram: Added device: zram0
              [    1.274272] [NAND][NE] Not found valid nand node on dts
              [    1.281243] sunxi-wlan soc@03000000:wlan@0: wlan_busnum (1)
              [    1.287559] sunxi-wlan soc@03000000:wlan@0: Missing wlan_power.
              [    1.294289] sunxi-wlan soc@03000000:wlan@0: wlan_power_name ((null))
              [    1.301464] sunxi-wlan soc@03000000:wlan@0: Missing wlan_io_regulator.
              [    1.308823] sunxi-wlan soc@03000000:wlan@0: io_regulator_name ((null))
              [    1.316237] sunxi-wlan soc@03000000:wlan@0: wlan_regon gpio=357  mul-sel=1  pull=-1  drv_level=-1  data=0
              [    1.327044] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
              [    1.334119] sunxi-wlan soc@03000000:wlan@0: get gpio power_en failed
              [    1.341297] sunxi-wlan soc@03000000:wlan@0: wlan_hostwake gpio=358  mul-sel=1  pull=-1  drv_level=-1  data=0
              [    1.352456] sunxi-wlan soc@03000000:wlan@0: clk not config
              [    1.358643] sunxi-wlan soc@03000000:wlan@0: dcxo not config
              [    1.364952] sunxi-wlan soc@03000000:wlan@0: pinctrl_lookup_state(default) failed! return ffffffffffffffed
              [    1.376818] [ADDR_MGT] addr_mgt_probe: success.
              [    1.383990] it6612_init-<629>:it6612 init:*************************
              [    1.391805] it6612_probe-<497>:it6612 probe:*************************
              [    1.403256] twi_stop()514 - [i2c0] STOP can't sendout!
              [    1.409031] sunxi_i2c_core_process()1751 - [i2c0] STOP failed!
              [    1.415619] sunxi_i2c_do_xfer()1946 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
              [    1.425232] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
              [    1.434870] sunxi_i2c_do_xfer()1946 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x4c)
              [    1.444505] sunxi_i2c_do_xfer()1946 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x4c)
              [    1.454626] libphy: Fixed MDIO Bus: probed
              [    1.459261] tun: Universal TUN/TAP device driver, 1.6
              [    1.464964] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
              [    1.473710] gmac-power0: NULL
              [    1.477072] gmac-power1: NULL
              [    1.480442] gmac-power2: NULL
              [    1.484692] PPP generic driver version 2.4.2
              [    1.489784] PPP BSD Compression module registered
              [    1.495126] PPP Deflate Compression module registered
              [    1.500846] PPP MPPE Compression module registered
              [    1.506254] NET: Registered protocol family 24
              [    1.511261] PPTP driver version 0.8.5
              [    1.515777] usbcore: registered new interface driver rtl8150
              [    1.522231] usbcore: registered new interface driver r8152
              [    1.528502] usbcore: registered new interface driver asix
              [    1.534654] usbcore: registered new interface driver ax88179_178a
              [    1.541580] usbcore: registered new interface driver cdc_ether
              [    1.548237] usbcore: registered new interface driver smsc75xx
              [    1.554791] usbcore: registered new interface driver smsc95xx
              [    1.561321] usbcore: registered new interface driver net1080
              [    1.567766] usbcore: registered new interface driver cdc_subset
              [    1.574492] usbcore: registered new interface driver zaurus
              [    1.580842] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
              [    1.589251] usbcore: registered new interface driver cdc_ncm
              [    1.595640] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
              [    1.603353] get ehci0-controller, regulator_io is no nocare
              [    1.609641] get ehci0-controller wakeup-source is fail.
              [    1.615769] sunxi ehci0-controller don't init wakeup source
              [    1.622051] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff8009695ac0, 0x:ffffff80097c4000, irq_no:164
              [    1.635769] [sunxi-ehci0]: Not init ehci0
              [    1.640417] get ehci1-controller, regulator_io is no nocare
              [    1.646888] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff8009695e48, 0x:ffffff80097ce000, irq_no:166
              [    1.660625] 5200000.ehci1-controller supply drvvbus not found, using dummy regulator
              [    1.669495] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
              [    1.679722] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
              [    1.689927] sunxi-ehci 5200000.ehci1-controller: irq 358, io mem 0xffffffc03da84810
              [    1.711785] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
              [    1.720729] hub 1-0:1.0: USB hub found
              [    1.724997] hub 1-0:1.0: 1 port detected
              [    1.730378] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
              [    1.737700] get ohci0-controller, regulator_io is no nocare
              [    1.743988] get ohci0-controller wakeup-source is fail.
              [    1.750092] sunxi ohci0-controller don't init wakeup source
              [    1.756490] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff8009696558
              [    1.766972] [sunxi-ohci0]: Not init ohci0
              [    1.771605] get ohci1-controller, regulator_io is no nocare
              [    1.778166] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff80096968e0
              [    1.788671] 5200000.ohci1-controller supply drvvbus not found, using dummy regulator
              [    1.797511] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
              [    1.807331] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 2
              [    1.817104] sunxi-ohci 5200000.ohci1-controller: irq 359, io mem 0xffffffc03da84c00
              [    1.886797] hub 2-0:1.0: USB hub found
              [    1.891061] hub 2-0:1.0: 1 port detected
              [    1.896595] usbcore: registered new interface driver uas
              [    1.902715] usbcore: registered new interface driver usb-storage
              [    1.909545] usbcore: registered new interface driver ums-alauda
              [    1.916269] usbcore: registered new interface driver ums-cypress
              [    1.923094] usbcore: registered new interface driver ums-datafab
              [    1.929915] usbcore: registered new interface driver ums_eneub6250
              [    1.936935] usbcore: registered new interface driver ums-freecom
              [    1.943755] usbcore: registered new interface driver ums-isd200
              [    1.950482] usbcore: registered new interface driver ums-jumpshot
              [    1.957403] usbcore: registered new interface driver ums-karma
              [    1.964032] usbcore: registered new interface driver ums-onetouch
              [    1.970968] usbcore: registered new interface driver ums-realtek
              [    1.977793] usbcore: registered new interface driver ums-sddr09
              [    1.984517] usbcore: registered new interface driver ums-sddr55
              [    1.991244] usbcore: registered new interface driver ums-usbat
              [    1.997949] usbcore: registered new interface driver usbserial
              [    2.004721] usbcore: registered new interface driver option
              [    2.011051] usbserial: USB Serial support registered for GSM modem (1-port)
              [    2.019158] usb_serial_number:20080411
              [    2.024150] sunxikbd_key_init: key0 vol= 210 code= 115
              [    2.029956] sunxikbd_key_init: key1 vol= 410 code= 114
              [    2.035748] sunxikbd_key_init: key2 vol= 590 code= 139
              [    2.041544] sunxikbd_key_init: key3 vol= 750 code= 28
              [    2.047237] sunxikbd_key_init: key4 vol= 880 code= 102
              [    2.053366] input: sunxi-keyboard as /devices/virtual/input/input0
              [    2.062417] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
              [    2.069350] sunxi-rtc rtc: RTC enabled
              [    2.073890] i2c /dev entries driver
              [    2.078809] sunxi cedar version 0.1
              [    2.082884] VE: install start!!!
              [    2.082884]
              [    2.088327] cedar_ve: cedar-ve the get irq is 347
              [    2.094042] VE: get debugfs_mpp_root is NULL, please check mpp
              [    2.094042]
              [    2.102285] VE: sunxi ve debug register driver failed!
              [    2.102285]
              [    2.111997] device-mapper: uevent: version 1.0.3
              [    2.117718] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
              [    2.127413] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
              [    2.136638] Bluetooth: HCI UART driver ver 2.3
              [    2.141659] Bluetooth: HCI UART protocol H4 registered
              [    2.147450] Bluetooth: HCI UART protocol LL registered
              [    2.153243] Bluetooth: HCI UART protocol Three-wire (H5) registered
              [    2.164483] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
              [    2.174628] sunxi-mmc sdc2: No vmmc regulator found
              [    2.180137] sunxi-mmc sdc2: No vqmmc regulator found
              [    2.185732] sunxi-mmc sdc2: No vdmmc regulator found
              [    2.191331] sunxi-mmc sdc2: No vd33sw regulator found
              [    2.197024] sunxi-mmc sdc2: No vd18sw regulator found
              [    2.202721] sunxi-mmc sdc2: No vq33sw regulator found
              [    2.208412] sunxi-mmc sdc2: No vq18sw regulator found
              [    2.214668] sunxi-mmc sdc2: set host busy
              [    2.219269] mmc:failed to get gpios
              [    2.223475] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.248454] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.275133] sunxi-mmc sdc2: detmode:alway in(non removable)
              [    2.275155] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.283528] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.284597] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.295450] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.295517] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.308365] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.352884] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
              [    2.362321] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
              [    2.371734] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.382624] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
              [    2.392065] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
              [    2.401474] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
              [    2.410908] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
              [    2.420645] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
              [    2.430742] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
              [    2.436053] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
              [    2.446913] sunxi-mmc sdc2: sdc set ios:clk 20000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
              [    2.458168] sunxi-mmc sdc2: sdc set ios:clk 20000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
              [    2.469152] sunxi-mmc sdc0: No vmmc regulator found
              [    2.469156] sunxi-mmc sdc0: No vqmmc regulator found
              [    2.469161] sunxi-mmc sdc0: No vdmmc regulator found
              [    2.469165] sunxi-mmc sdc0: No vd33sw regulator found
              [    2.469169] sunxi-mmc sdc0: No vd18sw regulator found
              [    2.469173] sunxi-mmc sdc0: No vq33sw regulator found
              [    2.469177] sunxi-mmc sdc0: No vq18sw regulator found
              [    2.474983] sunxi-mmc sdc0: set host busy
              [    2.475048] sunxi-mmc sdc0: Got CD GPIO
              [    2.475425] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.475451] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
              [    2.491795] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.508727] sunxi-mmc sdc0: detmode:gpio irq
              [    2.509248] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
              [    2.509326] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
              [    2.509379] sunxi-mmc sdc1: No vmmc regulator found
              [    2.509383] sunxi-mmc sdc1: No vqmmc regulator found
              [    2.509388] sunxi-mmc sdc1: No vdmmc regulator found
              [    2.509392] sunxi-mmc sdc1: No vd33sw regulator found
              [    2.509396] sunxi-mmc sdc1: No vd18sw regulator found
              [    2.509400] sunxi-mmc sdc1: No vq33sw regulator found
              [    2.509404] sunxi-mmc sdc1: No vq18sw regulator found
              [    2.509990] sunxi-mmc sdc1: set host busy
              [    2.510065] mmc:failed to get gpios
              [    2.510090] sunxi-mmc sdc1: min-frequency:400000
              [    2.510326] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.510351] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
              [    2.525177] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.541845] sunxi-mmc sdc1: detmode:manually by software
              [    2.542684] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
              [    2.543176] hidraw: raw HID events driver (C) Jiri Kosina
              [    2.543515] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
              [    2.543540] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.546025] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.547928] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
              [    2.548758] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
              [    2.549597] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
              [    2.549972] usbcore: registered new interface driver usbhid
              [    2.549975] usbhid: USB HID core driver
              [    2.550393] ashmem: initialized
              [    2.550428] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
              [    2.550459] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
              [    2.551975] optee: probing for conduit method from DT.
              [    2.551983] optee: api uid mismatch
              [    2.552406] usbcore: registered new interface driver snd-usb-audio
              [    2.554107] u32 classifier
              [    2.554109]     Actions configured
              [    2.554119] Netfilter messages via NETLINK v0.30.
              [    2.554136] nfnl_acct: registering with nfnetlink.
              [    2.554456] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
              [    2.554684] ctnetlink v0.93: registering with nfnetlink.
              [    2.555236] xt_time: kernel timezone is -0000
              [    2.555336] ipip: IPv4 and MPLS over IPv4 tunneling driver
              [    2.556050] gre: GRE over IPv4 demultiplexor driver
              [    2.556053] ip_gre: GRE over IPv4 tunneling driver
              [    2.557314] IPv4 over IPsec tunneling driver
              [    2.560370] ip_tables: (C) 2000-2006 Netfilter Core Team
              [    2.560621] arp_tables: arp_tables: (C) 2002 David S. Miller
              [    2.565633] Initializing XFRM netlink socket
              [    2.565668] IPsec XFRM device driver
              [    2.566468] NET: Registered protocol family 10
              [    2.568294] mip6: Mobile IPv6
              [    2.568326] ip6_tables: (C) 2000-2006 Netfilter Core Team
              [    2.583435] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
              [    2.584944] NET: Registered protocol family 17
              [    2.584986] NET: Registered protocol family 15
              [    2.585019] l2tp_core: L2TP core driver, V2.0
              [    2.585034] l2tp_ppp: PPPoL2TP kernel driver, V2.0
              [    2.588002] Registered cp15_barrier emulation handler
              [    2.588017] Registered setend emulation handler
              [    2.588975] registered taskstats version 1
              [    2.603835] get usb_detect_mode is fail, 22
              [    2.605130] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:06 UTC (6)
              [    2.606169] usb1-vbus: disabling
              [    2.606174] ALSA device list:
              [    2.606176]   No soundcards found.
              [    2.711876] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
              [    2.926451] sunxi-mmc sdc2: sdc set ios:clk 20000000Hz bm PP pm ON vdd 21 width 8 timing MMC-DDR52 dt B
              [    2.928750] Freeing unused kernel memory: 4416K
              [    2.928844] Kernel init done
              [    2.937487] init: init first stage started!
              [    2.938800] init: [libfs_mgr]ReadFstabFromDt(): failed to read fstab from dt
              [    2.941333] init: Using Android DT directory /proc/device-tree/firmware/android/
              [    2.966966] mmc0: new DDR MMC card at address 0001
              [    2.973315] mmcblk0: mmc0:0001 8WPD3R 7.28 GiB
              [    2.982229] mmcblk0boot0: mmc0:0001 8WPD3R partition 1 4.00 MiB
              [    2.992683] mmcblk0boot1: mmc0:0001 8WPD3R partition 2 4.00 MiB
              [    3.003136] mmcblk0rpmb: mmc0:0001 8WPD3R partition 3 512 KiB
              [    3.012332]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
              [    3.039402] init: [libfs_mgr]Created logical partition system on device /dev/block/dm-0
              [    3.050369] init: [libfs_mgr]Created logical partition vendor on device /dev/block/dm-1
              [    3.061334] init: [libfs_mgr]Created logical partition product on device /dev/block/dm-2
              [    3.071638] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
              [    3.081230] init: [libfs_mgr]Filesystem on /dev/block/by-name/metadata was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x46
              [    3.096340] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/metadata,/metadata,ext4)=-1: No such file or directory
              [    3.108807] init: [libfs_mgr]Not running /system/bin/e2fsck on /dev/block/mmcblk0p11 (executable not in system image)
              [    3.445765] EXT4-fs (mmcblk0p11): recovery complete
              [    3.530584] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: errors=panic
              [    3.547152] EXT4-fs (dm-0): mounted filesystem without journal. Opts: barrier=1
              [    3.570951] random: fast init done
              [    3.578691] EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1
              [    3.592385] EXT4-fs (dm-2): mounted filesystem without journal. Opts: barrier=1
              [    3.624642] init: 12 output lines suppressed due to ratelimiting
              [    3.647512] random: init: uninitialized urandom read (40 bytes read)
              [    3.881880] random: init: uninitialized urandom read (40 bytes read)
              [    3.917758] init: Loading SELinux policy
              [    3.949307] SELinux: 8192 avtab hash slots, 22205 rules.
              [    3.972399] SELinux: 8192 avtab hash slots, 22205 rules.
              [    3.978431] SELinux:  1 users, 4 roles, 1369 types, 0 bools, 1 sens, 1024 cats
              [    3.986593] SELinux:  97 classes, 22205 rules
              [    3.996115] SELinux:  Completing initialization.
              [    4.001339] SELinux:  Setting up existing superblocks.
              [    4.142735] audit: type=1403 audit(8.036:2): policy loaded auid=4294967295 ses=4294967295
              [    4.152279] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
              [    4.152279]
              [    4.173026] selinux: SELinux:  Skipping /product/etc/selinux/product_file_contexts:  empty file
              [    4.173026]
              [    4.184824] selinux: SELinux: Loaded file_contexts
              [    4.184824]
              [    4.200678] random: init: uninitialized urandom read (40 bytes read)
              [    4.266645] init: init second stage started!
              [    4.322473] init: Using Android DT directory /proc/device-tree/firmware/android/
              [    4.339654] selinux: SELinux:  Skipping /product/etc/selinux/product_file_contexts:  empty file
              [    4.339654]
              [    4.351401] selinux: SELinux: Loaded file_contexts
              [    4.351401]
              [    4.358523] init: Running restorecon...
              [    4.385011] init: Overriding previous 'ro.' property 'pm.dexopt.shared':'speed' with new value 'quicken'
              [    4.396081] init: Overriding previous 'ro.' property 'ro.kernel.android.checkjni':'0' with new value '1'
              [    4.411061] selinux: avc:  denied  { set } for  scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
              [    4.411061]
              [    4.428893] selinux: avc:  denied  { set } for  scontext=u:r:vendor_init:s0 tcontext=u:object_r:dalvik_prop:s0 tclass=property_service permissive=1
              [    4.428893]
              [    4.445755] init: Overriding previous 'ro.' property 'dalvik.vm.heapsize':'256m' with new value '512m'
              [    4.683683] urandom_read: 6 callbacks suppressed
              [    4.683690] random: ueventd: uninitialized urandom read (40 bytes read)
              [    4.702005] ueventd: ueventd started!
              [    4.712674] selinux: SELinux:  Skipping /product/etc/selinux/product_file_contexts:  empty file
              [    4.712674]
              [    4.724525] selinux: SELinux: Loaded file_contexts
              [    4.724525]
              [    4.731981] ueventd: Parsing file /ueventd.rc...
              [    4.738936] ueventd: Parsing file /vendor/ueventd.rc...
              [    4.744527] apexd: Bootstrap subcommand detected
              [    4.751255] ueventd: Parsing file /odm/ueventd.rc...
              [    4.757025] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
              [    4.757160] apexd: Scanning /system/apex for embedded keys
              [    4.759325] apexd: Scanning /product/apex for embedded keys
              [    4.759545] apexd: ... does not exist. Skipping
              [    4.759753] apexd: Scanning /system/apex looking for APEX packages.
              [    4.760121] apexd: Found /system/apex/com.android.conscrypt
              [    4.760584] apexd: Skipped when bootstrapping
              [    4.760798] apexd: Found /system/apex/com.android.media
              [    4.761254] apexd: Skipped when bootstrapping
              [    4.761468] apexd: Found /system/apex/com.android.tzdata
              [    4.768364] apexd: 9 output lines suppressed due to ratelimiting
              [    4.827644] ueventd: Parsing file /ueventd.sun50iw10p1.rc...
              [    4.834120] ueventd: Unable to read config file '/ueventd.sun50iw10p1.rc': open() failed: No such file or directory
              [    5.118634] ueventd: Coldboot took 0.27 seconds
              [    5.161721] Registered swp emulation handler
              [    5.229387] init: wait for '/dev/block/by-name/media_data' took 0ms
              [    5.243102] FAT-fs (mmcblk0p16): bogus number of reserved sectors
              [    5.250257] FAT-fs (mmcblk0p16): Can't find a valid FAT filesystem
              [    5.428493] fsck.f2fs: Info: Fix the reported corruption.
              [    5.428493]
              [    5.436352] fsck.f2fs:       Info: No support kernel version!
              [    5.436352]
              [    5.445489] fsck.f2fs: Info: Segments per section = 1
              [    5.445489]
              [    5.446312] logd.auditd: start
              [    5.456559] fsck.f2fs: Info: Sections per zone = 1
              [    5.456559]
              [    5.463735] fsck.f2fs: Info: sector size = 512
              [    5.463735]
              [    5.470548] fsck.f2fs: Info: total sectors = 6049759 (2953 MB)
              [    5.470548]
              [    5.478903] fsck.f2fs: Info: MKFS version
              [    5.478903]
              [    5.485197] fsck.f2fs:   "4.9.170 #6 SMP PREEMPT Mon Feb 14 19:34:12 CST 2022"
              [    5.485197]
              [    5.495108] fsck.f2fs: Info: FSCK version
              [    5.495108]
              [    5.501484] fsck.f2fs:   from "4.9.170 #6 SMP PREEMPT Mon Feb 14 19:34:12 CST 2022"
              [    5.501484]
              [    5.780594] F2FS-fs (mmcblk0p17): recover_inode: ino = 26a, name = primary.prof, inline = 3
              [    5.790093] F2FS-fs (mmcblk0p17): recover_data: ino = 26a (i_size: recover) recovered = 0, err = 0
              [    5.800201] F2FS-fs (mmcblk0p17): recover_inode: ino = 261, name = primary.prof, inline = 3
              [    5.809628] F2FS-fs (mmcblk0p17): recover_data: ino = 261 (i_size: recover) recovered = 0, err = 0
              [    5.819733] F2FS-fs (mmcblk0p17): recover_inode: ino = 402, name = primary.prof, inline = 3
              [    5.829157] F2FS-fs (mmcblk0p17): recover_data: ino = 402 (i_size: recover) recovered = 0, err = 0
              [    5.839260] F2FS-fs (mmcblk0p17): recover_inode: ino = 34b, name = primary.prof, inline = 3
              [    5.848686] F2FS-fs (mmcblk0p17): recover_data: ino = 34b (i_size: recover) recovered = 0, err = 0
              [    5.858784] F2FS-fs (mmcblk0p17): recover_inode: ino = 36a, name = primary.prof, inline = 3
              [    5.868208] F2FS-fs (mmcblk0p17): recover_data: ino = 36a (i_size: recover) recovered = 0, err = 0
              [    5.878306] F2FS-fs (mmcblk0p17): recover_inode: ino = 735, name = sanity.xml, inline = b
              [    5.888064] F2FS-fs (mmcblk0p17): recover_dentry: ino = 735, name = sanity.xml, dir = 6cb, err = 0
              [    5.898188] F2FS-fs (mmcblk0p17): recover_data: ino = 735 (i_size: recover) recovered = 0, err = 0
              [    5.908287] F2FS-fs (mmcblk0p17): recover_inode: ino = 470, name = primary.prof, inline = 3
              [    5.917711] F2FS-fs (mmcblk0p17): recover_data: ino = 470 (i_size: recover) recovered = 0, err = 0
              [    5.927808] F2FS-fs (mmcblk0p17): recover_inode: ino = 6d2, name = app_icons.db, inline = 1
              [    5.937316] F2FS-fs (mmcblk0p17): recover_data: ino = 6d2 (i_size: recover) recovered = 7, err = 0
              [    5.947419] F2FS-fs (mmcblk0p17): recover_inode: ino = 6d2, name = app_icons.db, inline = 1
              [    5.956876] F2FS-fs (mmcblk0p17): recover_data: ino = 6d2 (i_size: recover) recovered = 4, err = 0
              [    5.966980] F2FS-fs (mmcblk0p17): recover_inode: ino = 6c2, name = launcher.db, inline = 1
              [    5.976342] F2FS-fs (mmcblk0p17): recover_data: ino = 6c2 (i_size: recover) recovered = 2, err = 0
              [    5.986445] F2FS-fs (mmcblk0p17): recover_inode: ino = 6c2, name = launcher.db, inline = 1
              [    5.995799] F2FS-fs (mmcblk0p17): recover_data: ino = 6c2 (i_size: recover) recovered = 2, err = 0
              [    6.005900] F2FS-fs (mmcblk0p17): recover_inode: ino = 6d2, name = app_icons.db, inline = 1
              [    6.015379] F2FS-fs (mmcblk0p17): recover_data: ino = 6d2 (i_size: recover) recovered = 9, err = 0
              [    6.025478] F2FS-fs (mmcblk0p17): recover_inode: ino = 736, name = android.accounts.AccountAuthenticator.xml, inline = b
              [    6.038849] F2FS-fs (mmcblk0p17): recover_dentry: ino = 736, name = android.accounts.AccountAuthenticator.xml, dir = 5af, err = 0
              [    6.052014] F2FS-fs (mmcblk0p17): recover_data: ino = 736 (i_size: recover) recovered = 0, err = 0
              [    6.062115] F2FS-fs (mmcblk0p17): recover_inode: ino = 6d2, name = app_icons.db, inline = 1
              [    6.071595] F2FS-fs (mmcblk0p17): recover_data: ino = 6d2 (i_size: recover) recovered = 5, err = 0
              [    6.081701] F2FS-fs (mmcblk0p17): recover_inode: ino = 6d2, name = app_icons.db, inline = 1
              [    6.091187] F2FS-fs (mmcblk0p17): recover_data: ino = 6d2 (i_size: recover) recovered = 12, err = 0
              [    6.101388] F2FS-fs (mmcblk0p17): recover_inode: ino = 6d2, name = app_icons.db, inline = 1
              [    6.110880] F2FS-fs (mmcblk0p17): recover_data: ino = 6d2 (i_size: recover) recovered = 5, err = 0
              [    6.120977] F2FS-fs (mmcblk0p17): recover_inode: ino = 6c2, name = launcher.db, inline = 1
              [    6.130337] F2FS-fs (mmcblk0p17): recover_data: ino = 6c2 (i_size: recover) recovered = 2, err = 0
              [    6.140433] F2FS-fs (mmcblk0p17): recover_inode: ino = 6d2, name = app_icons.db, inline = 1
              [    6.149902] F2FS-fs (mmcblk0p17): recover_data: ino = 6d2 (i_size: recover) recovered = 7, err = 0
              [    6.159999] F2FS-fs (mmcblk0p17): recover_inode: ino = 6d2, name = app_icons.db, inline = 1
              [    6.169484] F2FS-fs (mmcblk0p17): recover_data: ino = 6d2 (i_size: recover) recovered = 10, err = 0
              [    6.179692] F2FS-fs (mmcblk0p17): recover_inode: ino = 737, name = appwidgets.xml, inline = b
              [    6.191212] F2FS-fs (mmcblk0p17): recover_dentry: ino = 737, name = appwidgets.xml, dir = 68, err = 0
              [    6.201666] F2FS-fs (mmcblk0p17): recover_data: ino = 737 (i_size: recover) recovered = 0, err = 0
              [    6.211780] F2FS-fs (mmcblk0p17): recover_inode: ino = 738, name = appwidgets.xml, inline = b
              [    6.221415] F2FS-fs (mmcblk0p17): recover_dentry: ino = 738, name = appwidgets.xml, dir = 68, err = 0
              [    6.231866] F2FS-fs (mmcblk0p17): recover_data: ino = 738 (i_size: recover) recovered = 0, err = 0
              [    6.241975] F2FS-fs (mmcblk0p17): recover_inode: ino = 739, name = appwidgets.xml, inline = b
              [    6.251598] F2FS-fs (mmcblk0p17): recover_dentry: ino = 739, name = appwidgets.xml, dir = 68, err = 0
              [    6.262002] F2FS-fs (mmcblk0p17): recover_data: ino = 739 (i_size: recover) recovered = 0, err = 0
              [    6.272099] F2FS-fs (mmcblk0p17): recover_inode: ino = 6d2, name = app_icons.db, inline = 1
              [    6.281573] F2FS-fs (mmcblk0p17): recover_data: ino = 6d2 (i_size: recover) recovered = 4, err = 0
              [    6.291668] F2FS-fs (mmcblk0p17): recover_inode: ino = 6d2, name = app_icons.db, inline = 1
              [    6.301142] F2FS-fs (mmcblk0p17): recover_data: ino = 6d2 (i_size: recover) recovered = 10, err = 0
              [    6.311337] F2FS-fs (mmcblk0p17): recover_inode: ino = 6d2, name = app_icons.db, inline = 1
              [    6.320803] F2FS-fs (mmcblk0p17): recover_data: ino = 6d2 (i_size: recover) recovered = 4, err = 0
              [    6.330903] F2FS-fs (mmcblk0p17): recover_inode: ino = 73a, name = settings_secure.xml, inline = 1
              [    6.341841] F2FS-fs (mmcblk0p17): recover_dentry: ino = 73a, name = settings_secure.xml, dir = 68, err = 0
              [    6.352791] F2FS-fs (mmcblk0p17): recover_data: ino = 73a (i_size: recover) recovered = 3, err = 0
              [    6.362937] F2FS-fs (mmcblk0p17): recover_inode: ino = 73b, name = roles.xml, inline = b
              [    6.372714] F2FS-fs (mmcblk0p17): recover_dentry: ino = 73b, name = roles.xml, dir = 68, err = 0
              [    6.382636] F2FS-fs (mmcblk0p17): recover_data: ino = 73b (i_size: recover) recovered = 0, err = 0
              [    6.392741] F2FS-fs (mmcblk0p17): recover_inode: ino = 73c, name = settings_global.xml, inline = 1
              [    6.403533] F2FS-fs (mmcblk0p17): recover_dentry: ino = 73c, name = settings_global.xml, dir = 68, err = 0
              [    6.414475] F2FS-fs (mmcblk0p17): recover_data: ino = 73c (i_size: recover) recovered = 3, err = 0
              [    6.424580] F2FS-fs (mmcblk0p17): recover_inode: ino = 73d, name = settings_system.xml, inline = 1
              [    6.435368] F2FS-fs (mmcblk0p17): recover_dentry: ino = 73d, name = settings_system.xml, dir = 68, err = 0
              [    6.446315] F2FS-fs (mmcblk0p17): recover_data: ino = 73d (i_size: recover) recovered = 2, err = 0
              [    6.456416] F2FS-fs (mmcblk0p17): recover_inode: ino = 73e, name = package-restrictions.xml, inline = 1
              [    6.467707] F2FS-fs (mmcblk0p17): recover_dentry: ino = 73e, name = package-restrictions.xml, dir = 68, err = 0
              [    6.479140] F2FS-fs (mmcblk0p17): recover_data: ino = 73e (i_size: recover) recovered = 3, err = 0
              [    6.489283] F2FS-fs (mmcblk0p17): recover_inode: ino = 73f, name = shortcuts.xml, inline = 1
              [    6.500018] F2FS-fs (mmcblk0p17): recover_dentry: ino = 73f, name = shortcuts.xml, dir = 733, err = 0
              [    6.510466] F2FS-fs (mmcblk0p17): recover_data: ino = 73f (i_size: recover) recovered = 2, err = 0
              [    6.520563] F2FS-fs (mmcblk0p17): recover_inode: ino = 337, name = primary.prof, inline = 3
              [    6.529986] F2FS-fs (mmcblk0p17): recover_data: ino = 337 (i_size: recover) recovered = 0, err = 0
              [    6.626954] F2FS-fs (mmcblk0p17): checkpoint: version = 3eed3eb4
              [    6.634013] F2FS-fs (mmcblk0p17): Mounted with checkpoint version = 3eed3eb4
              [    6.645433] EXT4-fs (mmcblk0p7): Ignoring removed nomblk_io_submit option
              [    6.666852] EXT4-fs (mmcblk0p7): recovery complete
              [    6.672859] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
              [    6.822816] EXT4-fs (mmcblk0p7): Ignoring removed nomblk_io_submit option
              [    6.833106] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: barrier=1,data=ordered,nomblk_io_submit,noauto_da_alloc,errors=panic
              [    6.876866] init: 14 output lines suppressed due to ratelimiting
              [    6.891155] zram0: detected capacity change from 0 to 760922112
              [    6.938931] mkswap: Swapspace size: 743084k, UUID=13ec065f-06ab-4190-aa10-9ee9de850d6b
              [    6.948999] Adding 743084k swap on /dev/block/zram0.  Priority:-1 extents:1 across:743084k SS
              console:/ $ [    7.543825] usbcore: registered new interface driver uvcvideo
              [    7.550354] USB Video Class driver (1.1.1)
              [    7.785820] apexd: Marking APEXd as starting
              [    7.792705] apexd: Scanning /system/apex for embedded keys
              [    7.801662] apexd: Scanning /product/apex for embedded keys
              [    7.808136] apexd: ... does not exist. Skipping
              [    7.813425] apexd: Populating APEX database from mounts...
              [    7.820276] apexd: Failed to walk /product/apex : Can't open /product/apex for reading : No such file or directory
              [    7.832947] apexd: Found "/apex/com.android.tzdata@290000000"
              [    7.839613] apexd: Found "/apex/com.android.runtime@1"
              [    7.845739] apexd: 2 packages restored.
              [    7.850210] apexd: Scanning /data/apex/sessions looking for sessions to be activated.
              [    7.907029] vdc: Waited 0ms for vold
              [    8.015232] type=1400 audit(11.906:3): avc: denied { setattr } for comm="init" name="audio_d" dev="mmcblk0p17" ino=118 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
              [    8.242336] logd.daemon: reinit
              [    8.688406] file system registered
              [    8.711134] using random self ethernet address
              [    8.716324] using random host ethernet address
              [    8.998681] treadahead: /data/vendor/treadahead/readahead_file_offset not exist;
              [    9.007664] treadahead: go to open trace
              [    9.023060] healthd: No battery devices found
              [    9.043346] healthd: battery none chg=
              [    9.051835]
              [    9.051835] insmod_device_driver
              [    9.051835]
              [    9.131513] type=1400 audit(11.906:3): avc: denied { setattr } for comm="init" name="audio_d" dev="mmcblk0p17" ino=118 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
              [    9.147178] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.06
              [    9.161265] type=1400 audit(13.023:4): avc: denied { create } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
              [    9.180372] type=1400 audit(13.023:4): avc: denied { create } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
              [    9.199253] type=1400 audit(13.023:5): avc: denied { setopt } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
              [    9.218463] type=1400 audit(13.023:5): avc: denied { setopt } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
              [    9.237354] type=1400 audit(13.023:6): avc: denied { bind } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
              [    9.256308] type=1400 audit(13.023:6): avc: denied { bind } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
              [    9.278929] init: Command 'insmod /vendor/modules/xradio_btlpm.ko' action=persist.vendor.bluetooth_vendor=xradio (/vendor/etc/init/init.wireless.bluetooth.rc:25) took 471ms and failed: finit_module for "/vendor/modules/xradio_btlpm.ko" failed: No such device
              [    9.305894] init: Service 'treadahead_process' (pid 1785) exited with status 0
              [    9.314220] init: Sending signal 9 to service 'treadahead_process' (pid 1785) process group...
              [    9.324663] libprocessgroup: Successfully killed process cgroup uid 0 pid 1785 in 0ms
              [    9.335076] init: Service 'preloaddata' (pid 1832) exited with status 0
              [    9.342732] init: Sending signal 9 to service 'preloaddata' (pid 1832) process group...
              [    9.352418] libprocessgroup: Successfully killed process cgroup uid 0 pid 1832 in 0ms
              [    9.362739] init: processing action (persist.vendor.bluetooth_vendor=xradio && vold.post_fs_data_done=1) from (/vendor/etc/init/init.wireless.bluetooth.rc:56)
              [    9.396776] init: processing action (nonencrypted) from (/init.rc:760)
              [    9.404551] init: Could not start service 'flash_recovery' as part of class 'main': Cannot find '/system/bin/install-recovery.sh': No such file or directory
              [    9.426868] read descriptors
              [    9.430259] read strings
              [   11.951275] sunxi_set_cur_vol_work()403 WARN: get power supply failed
              [   12.041706] android_work: sent uevent USB_STATE=CONNECTED
              [   12.048129] sunxi_set_cur_vol_work()403 WARN: get power supply failed
              [   12.174851] configfs-gadget gadget: high-speed config #1: b
              [   12.181520] android_work: sent uevent USB_STATE=CONFIGURED
              [   12.833440] pvrsrvkm: loading out-of-tree module taints kernel.
              [   12.939251] pvrsrvkm gpu: set gpu core rate:504000000 freq:504000000-950000uV dfs:0x00000001
              [   12.949233] pvrsrvkm gpu: set gpu core rate:504000000 freq:472500000-950000uV dfs:0x00000002
              [   12.958876] pvrsrvkm gpu: set gpu core rate:504000000 freq:441000000-950000uV dfs:0x00000004
              [   12.968558] pvrsrvkm gpu: set gpu core rate:252000000 freq:252000000-950000uV dfs:0x00000001
              [   12.978797] pvrsrvkm gpu: idle:0 dvfs:0 power:0 No mode:1 volt:0 core:504000000
              [   12.987244] PVR_K:  1805: Read BVNC 22.102.54.38 from HW device registers
              [   12.994979] PVR_K:  1805: RGX Device registered with BVNC 22.102.54.38
              [   13.003480] pvrsrvkm gpu: opp[1/4]: (252000000 Hz, 950000 uV)
              [   13.010029] pvrsrvkm gpu: opp[2/4]: (441000000 Hz, 950000 uV)
              [   13.016532] pvrsrvkm gpu: opp[3/4]: (472500000 Hz, 950000 uV)
              [   13.023051] pvrsrvkm gpu: opp[4/4]: (504000000 Hz, 950000 uV)
              [   13.030368] pvrsrvkm gpu: Cooling: power ops not registered, not enabling cooling
              [   13.043205] [drm] Initialized pvr 1.11.5516664 20170530 on minor 0
              [   13.053539] type=1400 audit(13.933:9): avc: denied { write } for comm="radio_monitor" name="uevent" dev="sysfs" ino=17793 scontext=u:r:radio_monitor:s0 tcontext=u:object_r:sysfs_usb:s0 tclass=file permissive=1
              [   13.077228] type=1400 audit(16.946:10): avc: denied { read } for comm="pvrsrvctl" name="modules" dev="proc" ino=4026532037 scontext=u:r:pvr:s0 tcontext=u:object_r:proc_modules:s0 tclass=file permissive=1
              [   13.097908] type=1400 audit(16.946:10): avc: denied { read } for comm="pvrsrvctl" name="modules" dev="proc" ino=4026532037 scontext=u:r:pvr:s0 tcontext=u:object_r:proc_modules:s0 tclass=file permissive=1
              [   13.118406] type=1400 audit(16.950:11): avc: denied { open } for comm="pvrsrvctl" path="/proc/modules" dev="proc" ino=4026532037 scontext=u:r:pvr:s0 tcontext=u:object_r:proc_modules:s0 tclass=file permissive=1
              [   13.139694] type=1400 audit(16.950:11): avc: denied { open } for comm="pvrsrvctl" path="/proc/modules" dev="proc" ino=4026532037 scontext=u:r:pvr:s0 tcontext=u:object_r:proc_modules:s0 tclass=file permissive=1
              [   13.160934] type=1400 audit(16.950:12): avc: denied { getattr } for comm="pvrsrvctl" path="/proc/modules" dev="proc" ino=4026532037 scontext=u:r:pvr:s0 tcontext=u:object_r:proc_modules:s0 tclass=file permissive=1
              [   13.188174] PVR_K:  1796: RGX Firmware image 'rgx.fw.22.102.54.38' loaded
              [   13.224495] logd: logdr: UID=1036 GID=1023 PID=1923 b tail=0 logMask=19 pid=0 start=0ns timeout=0ns
              [   15.116961] init: Service 'bootanim' (pid 2016) exited with status 0
              [   15.124225] init: Sending signal 9 to service 'bootanim' (pid 2016) process group...
              [   15.133414] libprocessgroup: Successfully killed process cgroup uid 1003 pid 2016 in 0ms
              [   17.978867] healthd: battery none chg=
              [   19.414084] random: crng init done
              [   21.895625] binder: undelivered transaction 3466, process died.
              [   21.904003] init: Service 'vendor.camera-provider-2-4' (pid 1932) exited with status 0
              [   21.913391] init: Sending signal 9 to service 'vendor.camera-provider-2-4' (pid 1932) process group...
              [   21.924724] libprocessgroup: Successfully killed process cgroup uid 1047 pid 1932 in 0ms
              [   22.676161] healthd: battery none chg=
              [   22.686301] healthd: battery none chg=
              [   23.286174] type=1400 audit(16.950:12): avc: denied { getattr } for comm="pvrsrvctl" path="/proc/modules" dev="proc" ino=4026532037 scontext=u:r:pvr:s0 tcontext=u:object_r:proc_modules:s0 tclass=file permissive=1
              [   23.312589] type=1400 audit(1644899277.263:13): avc: denied { read } for comm="android.ui" name="state" dev="sysfs" ino=17497 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
              [   23.336158] type=1400 audit(1644899277.263:13): avc: denied { read } for comm="android.ui" name="state" dev="sysfs" ino=17497 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
              [   23.355814] init: processing action (sys.sysctl.extra_free_kbytes=*) from (/init.rc:806)
              [   23.367602] type=1400 audit(1644899277.263:14): avc: denied { open } for comm="android.ui" path="/sys/devices/platform/ite66121/extcon/hdmi/state" dev="sysfs" ino=17497 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
              [   23.397743] type=1400 audit(1644899277.263:14): avc: denied { open } for comm="android.ui" path="/sys/devices/platform/ite66121/extcon/hdmi/state" dev="sysfs" ino=17497 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
              [   23.425374] type=1400 audit(1644899277.263:15): avc: denied { getattr } for comm="android.ui" path="/sys/devices/platform/ite66121/extcon/hdmi/state" dev="sysfs" ino=17497 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
              [   24.571628] acc_open
              [   24.574153] acc_release
              [   24.968766] init: Received control message 'interface_start' for 'android.hardware.wifi@1.0::IWifi/default' from pid: 1626 (/system/bin/hwservicemanager)
              [   24.985790] init: starting service 'vendor.wifi_hal_legacy'...
              [   24.996997] init: Received control message 'interface_start' for 'android.hardware.wifi@1.0::IWifi/default' from pid: 1626 (/system/bin/hwservicemanager)
              [   25.316647] libphy: gmac0: probed
              [   25.395552] sunxi-gmac gmac0 eth0: eth0: Type(7) PHY ID 001cc916 at 0 IRQ poll (gmac0-0:00)
              [   32.518795] sunxi-gmac gmac0 eth0: Link is Up - 100Mbps/Full - flow control off
              [   34.130237] init: processing action (sys.sysctl.tcp_def_init_rwnd=*) from (/init.rc:810)
              [   34.437899] init: processing action (sys.boot_completed=1) from (/init.rc:800)
              [   34.455563] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.device.rc:44)
              [   34.514037] get ctp_power is fail, -22
              [   34.523106] sunxi_ctp_startup: ctp_power_io is invalid.
              [   34.539084] get ctp_gesture_wakeup fail, no gesture wakeup
              [   34.555190] 1-005d supply ctp not found, using dummy regulator
              [   34.564047] sdcardfs version 2.0
              [   34.564054] sdcardfs: dev_name -> /data/media
              [   34.564057] sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,derive_gid,default_normal,unshared_obb,mask=6,userid=0,gid=1015
              [   34.564063] sdcardfs: mnt -> ffffffc0158c9520
              [   34.564174] sdcardfs: mounted on top of /data/media type f2fs
              [   34.566347] Remount options were mask=23,gid=9997 for vfsmnt ffffffc017078560.
              [   34.566397] sdcardfs : options - debug:1
              [   34.566401] sdcardfs : options - gid:9997
              [   34.566404] sdcardfs : options - mask:23
              [   34.567539] Remount options were mask=7,gid=9997 for vfsmnt ffffffc017079520.
              [   34.567576] sdcardfs : options - debug:1
              [   34.567582] sdcardfs : options - gid:9997
              [   34.567585] sdcardfs : options - mask:7
              [   34.568849] Remount options were mask=7,gid=9997 for vfsmnt ffffffc01707a3a0.
              [   34.568885] sdcardfs : options - debug:1
              [   34.568893] sdcardfs : options - gid:9997
              [   34.568895] sdcardfs : options - mask:7
              [   34.859589] input: gt9xxnew_ts as /devices/virtual/input/input1
              [   34.872499] init: Command 'insmod /vendor/modules/gt9xxnew_ts.ko' action=sys.boot_completed=1 (/vendor/etc/init/hw/init.device.rc:46) took 404ms and succeeded
              [   34.962294] init: Command 'insmod /vendor/modules/gt9xxnewdup_ts.ko' action=sys.boot_completed=1 (/vendor/etc/init/hw/init.device.rc:47) took 69ms and failed: finit_module for "/vendor/modules/gt9xxnewdup_ts.ko" failed: Operation not permitted
              [   35.126238] init: processing action (sys.boot_completed=1) from (/system/etc/init/aw_thermal.rc:10)
              [   35.131191] selinux: SELinux: Skipping restorecon on directory(/data/system_ce/0)
              [   35.131191]
              [   35.147206] init: starting service 'aw_thermal'...
              [   35.156990] init: processing action (sys.boot_completed=1 && sys.logbootcomplete=1) from (/system/etc/init/bootstat.rc:78)
              [   35.179784] init: starting service 'exec 11 (/system/bin/bootstat --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l)'...
              [   35.478920] treadahead: /data/vendor/treadahead/readahead_file_offset not exist;
              [   35.487506] treadahead: go to read trace
              [   35.558501] [DISP] de_enhance_set_mode,line:474:
              [   35.563949] para excess! mode = 0, enhance_mode = 0, format=255
              [   35.570912] [DISP] de_enhance_set_mode,line:474:
              [   35.575968] para excess! mode = 0, enhance_mode = 0, format=255
              [   35.583448] [DISP] de_enhance_set_mode,line:474:
              [   35.588553] para excess! mode = 0, enhance_mode = 0, format=255
              [   35.595474] [DISP] de_enhance_set_mode,line:474:
              [   35.600779] para excess! mode = 0, enhance_mode = 1, format=255
              [   35.607768] [DISP] de_enhance_set_mode,line:474:
              [   35.615244] para excess! mode = 0, enhance_mode = 0, format=255
              [   35.622589] [DISP] de_enhance_set_mode,line:474:
              [   35.627682] para excess! mode = 0, enhance_mode = 0, format=255
              [   35.634708] [DISP] de_enhance_set_mode,line:474:
              [   35.639873] para excess! mode = 0, enhance_mode = 1, format=255
              [   35.646873] [DISP] de_enhance_set_mode,line:474:
              [   35.652206] para excess! mode = 0, enhance_mode = 0, format=255
              [   35.659612] [DISP] de_enhance_set_mode,line:474:
              [   35.664671] para excess! mode = 0, enhance_mode = 0, format=255
              [   35.671615] [DISP] de_enhance_set_mode,line:474:
              [   35.676666] para excess! mode = 0, enhance_mode = 1, format=255
              [   35.683603] [DISP] de_enhance_set_mode,line:474:
              [   35.688663] para excess! mode = 0, enhance_mode = 0, format=255
              [   39.282513] BOOTEVENT:     39282.498474: OFF
              [   42.619131] apexd: Can't open /product/apex for reading : No such file or directory
              [   43.413170] init: Received control message 'start' for 'gsid' from pid: 2076 (system_server)
              [   43.428864] init: starting service 'gsid'...
              [   43.896744] init: Received control message 'stop' for 'gsid' from pid: 2076 (system_server)
              [   43.907949] init: Sending signal 9 to service 'gsid' (pid 3864) process group...
              [   43.933988] libprocessgroup: Successfully killed process cgroup uid 0 pid 3864 in 11ms
              [   43.947602] init: Service 'gsid' (pid 3864) received signal 9
              [   44.022976] type=1400 audit(1644899277.263:15): avc: denied { getattr } for comm="android.ui" path="/sys/devices/platform/ite66121/extcon/hdmi/state" dev="sysfs" ino=17497 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
              [   44.095599] type=1400 audit(1645110582.574:16): avc: granted { read } for comm="main" name="u:object_r:net_dns_prop:s0" dev="tmpfs" ino=9595 scontext=u:r:untrusted_app_25:s0:c512,c768 tcontext=u:object_r:net_dns_prop:s0 tclass=file app=com.android.email
              [   45.189057] type=1400 audit(1645110582.574:16): avc: granted { read } for comm="main" name="u:object_r:net_dns_prop:s0" dev="tmpfs" ino=9595 scontext=u:r:untrusted_app_25:s0:c512,c768 tcontext=u:object_r:net_dns_prop:s0 tclass=file app=com.android.email
              [   45.214939] type=1400 audit(1645110583.740:17): avc: denied { dac_override } for comm="irqbalance" capability=1 scontext=u:r:shell:s0 tcontext=u:r:shell:s0 tclass=capability permissive=1
              [   52.557212] type=1400 audit(1645110583.740:17): avc: denied { dac_override } for comm="irqbalance" capability=1 scontext=u:r:shell:s0 tcontext=u:r:shell:s0 tclass=capability permissive=1
              [   52.562828] treadahead: read trace end
              [   52.580709] type=1400 audit(1645110591.110:18): avc: denied { ptrace } for comm="crash_dump32" scontext=u:r:crash_dump:s0 tcontext=u:r:vendor_init:s0 tclass=process permissive=1
              [   52.726960] logd: logdr: UID=0 GID=0 PID=4034 n tail=50 logMask=8 pid=3477 start=0ns timeout=0ns
              [   52.739258] logd: logdr: UID=0 GID=0 PID=4034 n tail=50 logMask=1 pid=3477 start=0ns timeout=0ns
              [   52.754669] logd: logdr: UID=0 GID=0 PID=4034 n tail=0 logMask=8 pid=3477 start=0ns timeout=0ns
              [   52.766251] logd: logdr: UID=0 GID=0 PID=4034 n tail=0 logMask=1 pid=3477 start=0ns timeout=0ns
              [   52.784004] init: Untracked pid 4034 exited with status 0
              [   52.791447] init: Untracked pid 4036 exited with status 0
              [   52.849100] treadahead: parser trace end
              [   52.888372] init: Service 'treadahead_trace' (pid 3477) exited with status 0
              [   52.896422] init: Sending signal 9 to service 'treadahead_trace' (pid 3477) process group...
              [   52.906716] libprocessgroup: Successfully killed process cgroup uid 0 pid 3477 in 0ms
              [   55.186537] type=1400 audit(1645110591.110:18): avc: denied { ptrace } for comm="crash_dump32" scontext=u:r:crash_dump:s0 tcontext=u:r:vendor_init:s0 tclass=process permissive=1
              [   55.204450] type=1400 audit(1645110593.740:19): avc: denied { dac_override } for comm="irqbalance" capability=1 scontext=u:r:shell:s0 tcontext=u:r:shell:s0 tclass=capability permissive=1
              这是我的启动日志,你对比看看。
              G 1 条回复 最后回复 回复 引用 分享 0
              • G
                gworld LV 3 @tigger 最后由 编辑
                @tigger 非常感谢,你这个屏用的不是edp屏吧
                tigger 1 条回复 最后回复 回复 引用 分享 0
                • tigger
                  tigger LV 7 @gworld 最后由 编辑
                  @gworld
                  和 LCD 没有关系, 我试过 LVDS 和 HV RGB 都是可以用的:
                  • G
                    @tigger 你用的sdk是2.2的不
                    • T
                      TEVET LV 7 @tigger 最后由 编辑
                      @tigger
                      大佬,请教下这个 BOARD_HAS_SECURE_OS 若是false 是否就磁盘内容无法保护。
                      需要加密要走 A133 的 SECURE OS 开发手册?
                      • tigger
                        tigger LV 7 @TEVET 最后由 编辑
                        @tevet SECURE OS 还没玩过
                        @gworld 不知道怎么看版本
                        Z 1 条回复 最后回复 回复 引用 分享 0
                          ZZZZ_ LV 4 @tigger 最后由 编辑
                          @tigger 怎么开机的 为啥我开不了机
