    pack 时 ERROR: unable to open file boot-resource.fex
    7
    10
    12989
      hikaruhg LV 2 最后由 xiaowenge 编辑
      请问我在 pack 时出现下列讯息
      update_for_part_info -1
      ERROR: update mbr file fail
      ERROR: update_mbr failed
      这要怎么解决?
      谢谢
        没有生成 boot-resource.fex
        C 3 条回复 最后回复 回复 引用 分享 0
          chunzhang LV 4 @whycan 最后由 编辑
          @whycan 你好。这个 boot-resource.fex 未生成是在编译 boot-resource 的时间出错了还是别的什么情况呀?能提供个解决的思路吗?我这边编译完了也没报错,pack 的时间也出现了这个问题。谢谢
            chunzhang LV 4 @whycan 最后由 xiaowenge 编辑
            @whycan 这是 pack 之后的log
            $ pack
            PACK_CHIP         sun20iw1p1
            PACK_PLATFORM     tina
            PACK_BOARD        d1s-nezha
            PACK_KERN
            PACK_DEBUG        uart0
            PACK_SIG          none
            PACK_SECURE       none
            PACK_MODE         normal
            PACK_FUNC         android
            PACK_PROGRAMMER   none
            PACK_TAR_IMAGE    none
            PACK_TOPDIR       /home/zc/tina-d1-h
            No kernel param, parse it from d1s
            copying tools file
            copying configs file
            storage_type value is 5
            rm /home/zc/tina-d1-h/out/d1s-nezha/image/sys_partition_nor.fex
            rm /home/zc/tina-d1-h/out/d1s-nezha/image/image_nor.cfg
            copying boot resource
            LZMA 4.65 : Igor Pavlov : Public domain : 2009-02-03
            copying boot file
            make user resource for : /home/zc/tina-d1-h/out/d1s-nezha/image/sys_partition.fex
            handle partition user-res
            no user resource partitions
            APP_PART_DOWNLOAD_FILE = /home/zc/tina-d1-h/out/d1s-nezha/image/app.fex
            Need size of filesystem
            no data resource partitions
            don't build dtbo ...
            update_chip
            /home/zc/tina-d1-h/scripts/pack_img.sh: line 1354: /home/zc/tina-d1-h/out/host/bin/fsbuild: cannot execute binary file: Exec format error
            pack boot package
            content_count=3
            packing for tina linux
            normal
            mbr count = 4
            partitation file Path=/home/zc/tina-d1-h/out/d1s-nezha/image/sys_partition.bin
            mbr_name file Path=/home/zc/tina-d1-h/out/d1s-nezha/image/sunxi_mbr.fex
            download_name file Path=/home/zc/tina-d1-h/out/d1s-nezha/image/dlinfo.fex
            mbr size = 16384
            mbr magic softw411
            disk name=boot-resource
            aldfaaa 1 条回复 最后回复 回复 引用 分享 0
              @whycan 你好,单独编译 boot-resource 的命令是什么呀?
              Z 1 条回复 最后回复 回复 引用 分享 0
              • aldfaaa
                whycan矿工-小叶 LV 7 @chunzhang 最后由 编辑
                @chunzhang
                查询./scripts/pack_img.sh发现./tools/pack-bintools/src/fsbuild这个程序是32位的, 所以安装以下组件可解决问题:
                apt-get install lib32z1 lib32z1-dev
                Z H S 3 条回复 最后回复 回复 引用 分享 4
                  ZhangJun LV 3 @chunzhang 最后由 编辑
                  @chunzhang 你好,问题解决了吗,我也遇到这个问题,采取这几位老哥给的方法没有解决,可以回复一下吗
                    ZhangJun LV 3 @aldfaaa 最后由 编辑
                    @aldfaaa 采取了还是那样的问题,还有其他解决方法吗
                      hoshino1989 LV 3 @aldfaaa 最后由 编辑
                      @aldfaaa 感谢你的建议,对我很有用
                        shywkylh LV 2 @aldfaaa 最后由 编辑
                        • Referenced by  J Jingyan
