    哪吒D1 wifi无法使用
    6
    3950
      junchao82 LV 2 最后由 编辑
      环境
      • 硬件:淘宝官方店,哪吒D1开发板,标准套餐
      • 软件:出厂系统
      问题
      刚拿到手的板子
      插上带有出厂系统的sd卡,启动进入系统后ifcofnig -a 看不见wlan0
      root@sipeed:~# ifconfig -a
      eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
              ether da:76:5d:c1:dc:73  txqueuelen 1000  (Ethernet)
              RX packets 0  bytes 0 (0.0 B)
              RX errors 0  dropped 0  overruns 0  frame 0
              TX packets 0  bytes 0 (0.0 B)
              TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
              device interrupt 62
      lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
              inet 127.0.0.1  netmask 255.0.0.0
              inet6 ::1  prefixlen 128  scopeid 0x10<host>
              loop  txqueuelen 1000  (Local Loopback)
              RX packets 8  bytes 400 (400.0 B)
              TX packets 8  bytes 400 (400.0 B)
      sit0: flags=128<NOARP>  mtu 1480
              sit  txqueuelen 1000  (IPv6-in-IPv4)
      使用dmesg查看信息发现有错误
      [  OK  ] Found device /dev/ttyS0.
      [  OK  ] Started Network Time Synchronization.
      [  OK  ] Reached target System Time Set.
      [  OK  ] Reached target System Time Synchronized.
      [   12.752874] systemd-journald[97]: Failed to read journal file /var/log/journal/d6cf2e6523464ceab62681de06d93957/user-1000.journal for rotation, trying to move it out of the way: Text file busy
      [  OK  ] Reached target Hardware activated USB gadget.
      [   14.208719] ======== XRADIO WIFI OPEN ========
      [   14.257684] ieee80211_init failed (-12)!
      [   14.527369] usbcore: registered new interface driver uvcvideo
      [   14.655469] USB Video Class driver (1.1.1)
      [   14.844483] xt_time: kernel timezone is -0000
      [FAILED] Failed to start Load Kernel Modules.
      See 'systemctl status systemd-modules-load.service' for details.
      [  OK  ] Finished Helper to synchronize boot up for ifupdown.
      [  OK  ] Listening on Load/Save RF ??itch Status /dev/rfkill Watch.
               Starting Load Kernel Modules...
               Starting Load/Save RF Kill Switch Status...
      [   15.753880] sunxi-rfkill soc@3000000:rfkill@0: block state already is 1
      [  OK  ] Started Load/Save RF Kill Switch Status.
      [   16.964979] ======== XRADIO WIFI OPEN ========
      [   16.969944] ieee80211_init failed (-12)!
      [   17.054932] Error: Driver 'gt9xxnew_ts' is already registered, aborting...
               Starting Apply Kernel Variables...
      [  OK  ] Finished Apply Kernel Variables.
      [  OK  ] Reached target System Initialization.
      [  OK  ] Started Daily apt download activities.
      [  OK  ] Started Daily apt upgrade and clean activities.
      [  OK  ] Started Periodic ext4 Onli??ata Check for All Filesystems.
      [  OK  ] Started Discard unused blocks once a week.
      [  OK  ] Started Daily rotation of log files.
      [  OK  ] Started Daily man-db regeneration.
      [  OK  ] Started Daily Cleanup of Temporary Directories.
      [  OK  ] Reached target Timers.
      [  OK  ] Listening on D-Bus System Message Bus Socket.
      [  OK  ] Reached target Sockets.
      [  OK  ] Reached target Basic System.
               Starting Save/Restore Sound Card State...
      [  OK  ] Started Regular background program processing daemon.
      [  OK  ] Started D-Bus System Message Bus.
               Starting Connection service...
      兄弟们帮忙看看,是不是硬件有问题
      • tigger
        tigger LV 7 最后由 编辑
        D1_Tina_Linux_Wi-Fi_开发指南.pdf
        J 1 条回复 最后回复 回复 引用 分享 0
          DOT小文哥 LV 8 最后由 编辑
          出厂的板子没有SD卡,你的卡是怎么来的
            junchao82 LV 2 @xiaowenge 最后由 编辑
            @xiaowenge 是Debian by Sipeed 的系统,sipeed淘宝店买的,买的套餐里带的系统
              junchao82 LV 2 @tigger 最后由 编辑
              @tigger 谢了兄弟,但常见问题里我看见我这种问题,我尝试手动加载驱动
              root@sipeed:~# modprobe xradio_wlan
              [ 6650.755577] ======== XRADIO WIFI OPEN ========
              [ 6650.760569] ieee80211_init failed (-12)!
              modprobe: ERROR: could not insert 'xr829': Cannot allocate memory
              [ 6652.046927] ======== XRADIO WIFI OPEN ========
              [ 6652.051987] ieee80211_init failed (-12)!
              root@sipeed:~# modprobe xr829
              [ 6672.194738] ======== XRADIO WIFI OPEN ========
              [ 6672.199701] ieee80211_init failed (-12)!
              root@sipeed:~#
              root@sipeed:~# free -h
                             total        used        free      shared  buff/cache   available
              Mem:           992Mi       129Mi       692Mi       4.0Mi       171Mi       842Mi
              Swap:             0B          0B          0B
              root@sipeed:~# lsmod
              Module                  Size  Used by
              xt_time                 3611  0
              xt_multiport            2532  0
              xt_mark                 1574  0
              xt_mac                  1439  0
              xt_limit                2828  0
              xt_comment              1261  0
              xt_TCPMSS               4100  0
              xt_LOG                  1740  0
              uvcvideo              128608  0
              videobuf2_vmalloc       7487  1 uvcvideo
              videobuf2_memops        1796  1 videobuf2_vmalloc
              iptable_filter          1804  0
              ipt_REJECT              2687  0
              fuse                  152485  1
                HonestQiao LV 2 最后由 编辑
                参考安装网址:https://d1.docs.aw-ol.com/d1_dev/
                安装的是:Debian by Sipeed
                出现完全一样的wlan无法驱动问题
