    D1s烧写固件失败
    4095
      这样是不是NAND芯片挂了
      [1120]fes begin commit:88480af
      [1123]set pll start
      [1124]fix vccio detect value:0xc0
      [1128]periph0 has been enabled
      [1131]set pll end
      [1132][pmu]: bus read error
      [1135]board init ok
      [1137]beign to init dram
      [1139]ZQ value = 0x2f
      [1141]get_pmu_exist() = -1
      [1144]ddr_efuse_type: 0xa
      [1146]trefi:7.8ms
      [1148][AUTO DEBUG] single rank and full DQ!
      [1152]ddr_efuse_type: 0xa
      [1155]trefi:7.8ms
      [1157][AUTO DEBUG] rank 0 row = 13
      [1160][AUTO DEBUG] rank 0 bank = 4
      [1163][AUTO DEBUG] rank 0 page size = 2 KB
      [1167]DRAM BOOT DRIVE INFO: V0.33
      [1170]DRAM CLK = 528 MHz
      [1172]DRAM Type = 2 (2:DDR2,3:DDR3)
      [1176]DRAMC read ODT  off.
      [1178]DRAM ODT off.
      [1180]ddr_efuse_type: 0xa
      [1183]DRAM SIZE =64 M
      [1185]dram_tpr4:0x0
      [1187]PLL_DDR_CTRL_REG:0xf8002b00
      [1190]DRAM_CLK_REG:0xc0000000
      [1193][TIMING DEBUG] MR2= 0x0
      [1197]DRAM simple test OK.
      [1200]init dram ok
      U-Boot 2018.05-g24521d6-dirty-config-dirty (Mar 18 2022 - 13:42:30 +0800) Allwinner Technology
      [03.913]DRAM:  64 MiB
      [03.918]Relocation Offset is: 01ee7000
      [03.943]secure enable bit: 0
      [03.949]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [03.955]flash init start
      [03.958]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [03.965][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
      [03.975][mmc]: get sdc_type fail and use default host:tm4.
      [04.005][mmc]: Is not Boot mode!
      [04.008][mmc]: SUNXI SDMMC Controller Version:0x50310
      [04.019][mmc]: ************Try SD card 2************
      [04.024][mmc]: mmc 2 cmd timeout 100 status 100
      [04.028][mmc]: smc 2 err, cmd 8,  RTO
      [04.032][mmc]: mmc 2 close bus gating and reset
      [04.037][mmc]: mmc 2 cmd timeout 100 status 100
      [04.041][mmc]: smc 2 err, cmd 55,  RTO
      [04.045][mmc]: mmc 2 close bus gating and reset
      [04.049][mmc]: ************Try MMC card 2************
      [04.058][mmc]: mmc 2 cmd timeout 100 status 100
      [04.062][mmc]: smc 2 err, cmd 1,  RTO
      [04.065][mmc]: mmc 2 close bus gating and reset
      [04.069][mmc]: Card did not respond to voltage select!
      [04.074][mmc]: ************SD/MMC 2 init error!************
      [04.080][mmc]: mmc init product failed
      MMC init failed
      try emmc fail
      [04.096]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
      [04.101]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
      [04.162]sunxi-spinand-phy: request spi0 gpio ok
      [04.166]sunxi-spinand-phy: request general tx dma channel ok!
      [04.171]sunxi-spinand-phy: request general rx dma channel ok!
      [04.177]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [04.181]sunxi-spinand-phy: init spic0 clk ok
      [04.227]sunxi-spinand-phy: not detect any munufacture from id table
      [04.242]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [04.248]sunxi-spinand-phy: get phy info from fdt fail
      [04.252]sunxi-spinand-phy: not detect munufacture from fdt
      [04.258]sunxi-spinand-phy: detect munufacture from id table: Winbond
      [04.264]sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
      [04.269]sunxi-spinand-phy: ========== arch info ==========
      [04.275]sunxi-spinand-phy: Model:               W25N01GVZEIG
      [04.280]sunxi-spinand-phy: Munufacture:         Winbond
      [04.285]sunxi-spinand-phy: DieCntPerChip:       1
      [04.289]sunxi-spinand-phy: BlkCntPerDie:        1024
      [04.294]sunxi-spinand-phy: PageCntPerBlk:       64
      [04.298]sunxi-spinand-phy: SectCntPerPage:      4
      [04.303]sunxi-spinand-phy: OobSizePerPage:      64
      [04.307]sunxi-spinand-phy: BadBlockFlag:        0x0
      [04.312]sunxi-spinand-phy: OperationOpt:        0x7
      [04.317]sunxi-spinand-phy: MaxEraseTimes:       65000
      [04.321]sunxi-spinand-phy: EccFlag:             0x0
      [04.326]sunxi-spinand-phy: EccType:             2
      [04.330]sunxi-spinand-phy: EccProtectedType:    3
      [04.335]sunxi-spinand-phy: ========================================
      [04.341]sunxi-spinand-phy:
      [04.343]sunxi-spinand-phy: ========== physical info ==========
      [04.349]sunxi-spinand-phy: TotalSize:    128 M
      [04.353]sunxi-spinand-phy: SectorSize:   512 B
      [04.357]sunxi-spinand-phy: PageSize:     2 K
      [04.361]sunxi-spinand-phy: BlockSize:    128 K
      [04.365]sunxi-spinand-phy: OOBSize:      64 B
      [04.369]sunxi-spinand-phy: ========================================
      [04.375]sunxi-spinand-phy:
      [04.378]sunxi-spinand-phy: ========== logical info ==========
      [04.383]sunxi-spinand-phy: TotalSize:    128 M
      [04.387]sunxi-spinand-phy: SectorSize:   512 B
      [04.392]sunxi-spinand-phy: PageSize:     4 K
      [04.396]sunxi-spinand-phy: BlockSize:    256 K
      [04.400]sunxi-spinand-phy: OOBSize:      128 B
      [04.404]sunxi-spinand-phy: ========================================
      [04.420]sunxi-spinand-phy: set spic0 clk to 100 Mhz
      [04.424]sunxi-spinand-phy: block lock register: 0x00
      [04.429]sunxi-spinand-phy: feature register: 0x19
      [04.433]sunxi-spinand-phy: sunxi physic nand init end
      [04.443]Loading Environment from SUNXI_FLASH... OK
      [04.456]try to burn key
      [04.460]out of usb burn from boot: not need burn key
      [04.464]Net:   [04.466]No ethernet found.
      sunxi work mode=0x10
      run usb efex
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x1
      set address 0x1 ok
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x12
      origin_erase_flag = 0x1
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      the 0 mbr table is ok
      the 1 mbr table is ok
      the 2 mbr table is ok
      the 3 mbr table is ok
      total mbr part 8
      part[0] classname :DISK
      part[0] addrlo    :0x8000
      part[0] lenlo     :0x1f8
      part[0] user_type :32768
      part[0] keydata   :0
      part[0] ro        :0
      part[1] name      :env
      part[1] classname :DISK
      part[1] addrlo    :0x81f8
      part[1] lenlo     :0x1f8
      part[1] user_type :32768
      part[1] keydata   :0
      part[1] ro        :0
      part[2] name      :env-redund
      part[2] classname :DISK
      part[2] addrlo    :0x83f0
      part[2] lenlo     :0x1f8
      part[2] user_type :32768
      part[2] keydata   :0
      part[2] ro        :0
      part[3] name      :boot
      part[3] classname :DISK
      part[3] addrlo    :0x85e8
      part[3] lenlo     :0x5000
      part[3] user_type :32768
      part[3] keydata   :0
      part[3] ro        :0
      part[4] name      :rootfs
      part[4] classname :DISK
      part[4] addrlo    :0xd5e8
      part[4] lenlo     :0xbe00
      part[4] user_type :32768
      part[4] keydata   :0
      part[4] ro        :0
      part[5] name      :recovery
      part[5] classname :DISK
      part[5] addrlo    :0x193e8
      part[5] lenlo     :0x5780
      part[5] user_type :32768
      part[5] keydata   :0
      part[5] ro        :0
      part[6] classname :DISK
      part[6] addrlo    :0x1eb68
      part[6] lenlo     :0x2800
      part[6] user_type :32768
      part[6] keydata   :0
      part[6] ro        :0
      part[7] name      :UDISK
      part[7] classname :DISK
      part[7] addrlo    :0x21368
      part[7] lenlo     :0x0
      part[7] user_type :0
      part[7] keydata   :0
      part[7] ro        :0
      total part: 9
      mbr 0, 8000, 8000
      boot-resource 1, 1f8, 8000
      env 2, 1f8, 8000
      env-redund 3, 1f8, 8000
      boot 4, 5000, 8000
      rootfs 5, be00, 8000
      recovery 6, 5780, 8000
      rootfs_data 7, 2800, 8000
      UDISK 8, 0, 0
      [07.492]erase blk 0 to blk 32
      need erase flash: 18
      [07.518]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
       #: name		size		offset		mask_flags
       0: boot0               0x00100000	0x00000000	1
       1: uboot               0x00300000	0x00100000	1
       2: secure_storage      0x00100000	0x00400000	1
       3: sys                 0x07b00000	0x00500000	0
      defaults:
      mtdids  : nand0=nand
      [07.578]MTD info (4)
      [07.580]pagesize: 0x1000
      [07.582]blksize: 0x40000
      [07.584]num  offset     bytes      name
      [07.588]0    0x00000000 0x00100000 boot0
      [07.592]1    0x00100000 0x00300000 uboot
      [07.595]2    0x00400000 0x00100000 secure_storage
      [07.600]3    0x00500000 0x07b00000 sys
      [07.603]ubi attach the last part of mtd device: NO.3
      [07.667]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.723]ubi0: attaching mtd4
      [07.726]ubi0 warning: scan_peb: bad ec header at pnum 0, drop this block
      [07.732]ubi0 warning: scan_peb: bad ec header at pnum 1, drop this block
      [07.739]ubi0 warning: scan_peb: bad ec header at pnum 2, drop this block
      [07.746]ubi0 warning: scan_peb: bad ec header at pnum 3, drop this block
      [07.753]ubi0 warning: scan_peb: bad ec header at pnum 4, drop this block
      [07.759]ubi0 warning: scan_peb: bad ec header at pnum 5, drop this block
      [07.766]ubi0 warning: scan_peb: bad ec header at pnum 6, drop this block
      [07.773]ubi0 warning: scan_peb: bad ec header at pnum 7, drop this block
      [07.779]ubi0 warning: scan_peb: bad ec header at pnum 8, drop this block
      [07.786]ubi0 warning: scan_peb: bad ec header at pnum 9, drop this block
      [07.793]ubi0 warning: scan_peb: bad ec header at pnum 10, drop this block
      [07.799]ubi0 warning: scan_peb: bad ec header at pnum 11, drop this block
      [07.806]ubi0 warning: scan_peb: bad ec header at pnum 12, drop this block
      [07.813]ubi0 warning: scan_peb: bad ec header at pnum 13, drop this block
      [07.820]ubi0 warning: scan_peb: bad ec header at pnum 14, drop this block
      [07.826]ubi0 warning: scan_peb: bad ec header at pnum 15, drop this block
      [07.833]ubi0 warning: scan_peb: bad ec header at pnum 16, drop this block
      [07.840]ubi0 warning: scan_peb: bad ec header at pnum 17, drop this block
      [07.847]ubi0 warning: scan_peb: bad ec header at pnum 18, drop this block
      [07.854]ubi0 warning: scan_peb: bad ec header at pnum 19, drop this block
      [07.860]ubi0 warning: scan_peb: bad ec header at pnum 20, drop this block
      [07.867]ubi0 warning: scan_peb: bad ec header at pnum 21, drop this block
      [07.874]ubi0 warning: scan_peb: bad ec header at pnum 22, drop this block
      [07.881]ubi0 warning: scan_peb: bad ec header at pnum 23, drop this block
      [07.887]ubi0 warning: scan_peb: bad ec header at pnum 24, drop this block
      [07.894]ubi0 warning: scan_peb: bad ec header at pnum 25, drop this block
      [07.901]ubi0 warning: scan_peb: bad ec header at pnum 26, drop this block
      [07.908]ubi0 warning: scan_peb: bad ec header at pnum 27, drop this block
      [07.914]ubi0 warning: scan_peb: bad ec header at pnum 28, drop this block
      [07.921]ubi0 warning: scan_peb: bad ec header at pnum 29, drop this block
      [07.928]ubi0 warning: scan_peb: bad ec header at pnum 30, drop this block
      [07.935]ubi0 warning: scan_peb: bad ec header at pnum 31, drop this block
      [07.942]ubi0 warning: scan_peb: bad ec header at pnum 32, drop this block
      [07.948]ubi0 warning: scan_peb: bad ec header at pnum 33, drop this block
      [07.955]ubi0 warning: scan_peb: bad ec header at pnum 34, drop this block
      [07.962]ubi0 warning: scan_peb: bad ec header at pnum 35, drop this block
      [07.969]ubi0 warning: scan_peb: bad ec header at pnum 36, drop this block
      [07.975]ubi0 warning: scan_peb: bad ec header at pnum 37, drop this block
      [07.982]ubi0 warning: scan_peb: bad ec header at pnum 38, drop this block
      [07.989]ubi0 warning: scan_peb: bad ec header at pnum 39, drop this block
      [07.996]ubi0 warning: scan_peb: bad ec header at pnum 40, drop this block
      [08.002]ubi0 warning: scan_peb: bad ec header at pnum 41, drop this block
      [08.009]ubi0 warning: scan_peb: bad ec header at pnum 42, drop this block
      [08.016]ubi0 warning: scan_peb: bad ec header at pnum 43, drop this block
      [08.023]ubi0 warning: scan_peb: bad ec header at pnum 44, drop this block
      [08.030]ubi0 warning: scan_peb: bad ec header at pnum 45, drop this block
      [08.036]ubi0 warning: scan_peb: bad ec header at pnum 46, drop this block
      [08.043]ubi0 warning: scan_peb: bad ec header at pnum 47, drop this block
      [08.050]ubi0 warning: scan_peb: bad ec header at pnum 48, drop this block
      [08.057]ubi0 warning: scan_peb: bad ec header at pnum 49, drop this block
      [08.063]ubi0 warning: scan_peb: bad ec header at pnum 50, drop this block
      [08.070]ubi0 warning: scan_peb: bad ec header at pnum 51, drop this block
      [08.077]ubi0 warning: scan_peb: bad ec header at pnum 52, drop this block
      [08.084]ubi0 warning: scan_peb: bad ec header at pnum 53, drop this block
      [08.090]ubi0 warning: scan_peb: bad ec header at pnum 54, drop this block
      [08.097]ubi0 warning: scan_peb: bad ec header at pnum 55, drop this block
      [08.104]ubi0 warning: scan_peb: bad ec header at pnum 56, drop this block
      [08.111]ubi0 warning: scan_peb: bad ec header at pnum 57, drop this block
      [08.118]ubi0 warning: scan_peb: bad ec header at pnum 58, drop this block
      [08.124]ubi0 warning: scan_peb: bad ec header at pnum 59, drop this block
      [08.131]ubi0 warning: scan_peb: bad ec header at pnum 60, drop this block
      [08.138]ubi0 warning: scan_peb: bad ec header at pnum 61, drop this block
      [08.145]ubi0 warning: scan_peb: bad ec header at pnum 62, drop this block
      [08.151]ubi0 warning: scan_peb: bad ec header at pnum 63, drop this block
      [08.158]ubi0 warning: scan_peb: bad ec header at pnum 64, drop this block
      [08.165]ubi0 warning: scan_peb: bad ec header at pnum 65, drop this block
      [08.172]ubi0 warning: scan_peb: bad ec header at pnum 66, drop this block
      [08.178]ubi0 warning: scan_peb: bad ec header at pnum 67, drop this block
      [08.185]ubi0 warning: scan_peb: bad ec header at pnum 68, drop this block
      [08.192]ubi0 warning: scan_peb: bad ec header at pnum 69, drop this block
      [08.199]ubi0 warning: scan_peb: bad ec header at pnum 70, drop this block
      [08.205]ubi0 warning: scan_peb: bad ec header at pnum 71, drop this block
      [08.212]ubi0 warning: scan_peb: bad ec header at pnum 72, drop this block
      [08.219]ubi0 warning: scan_peb: bad ec header at pnum 73, drop this block
      [08.226]ubi0 warning: scan_peb: bad ec header at pnum 74, drop this block
      [08.233]ubi0 warning: scan_peb: bad ec header at pnum 75, drop this block
      [08.239]ubi0 warning: scan_peb: bad ec header at pnum 76, drop this block
      [08.246]ubi0 warning: scan_peb: bad ec header at pnum 77, drop this block
      [08.253]ubi0 warning: scan_peb: bad ec header at pnum 78, drop this block
      [08.260]ubi0 warning: scan_peb: bad ec header at pnum 79, drop this block
      [08.266]ubi0 warning: scan_peb: bad ec header at pnum 80, drop this block
      [08.273]ubi0 warning: scan_peb: bad ec header at pnum 81, drop this block
      [08.280]ubi0 warning: scan_peb: bad ec header at pnum 82, drop this block
      [08.287]ubi0 warning: scan_peb: bad ec header at pnum 83, drop this block
      [08.293]ubi0 warning: scan_peb: bad ec header at pnum 84, drop this block
      [08.300]ubi0 warning: scan_peb: bad ec header at pnum 85, drop this block
      [08.307]ubi0 warning: scan_peb: bad ec header at pnum 86, drop this block
      [08.314]ubi0 warning: scan_peb: bad ec header at pnum 87, drop this block
      [08.321]ubi0 warning: scan_peb: bad ec header at pnum 88, drop this block
      [08.327]ubi0 warning: scan_peb: bad ec header at pnum 89, drop this block
      [08.334]ubi0 warning: scan_peb: bad ec header at pnum 90, drop this block
      [08.341]ubi0 warning: scan_peb: bad ec header at pnum 91, drop this block
      [08.348]ubi0 warning: scan_peb: bad ec header at pnum 92, drop this block
      [08.354]ubi0 warning: scan_peb: bad ec header at pnum 93, drop this block
      [08.361]ubi0 warning: scan_peb: bad ec header at pnum 94, drop this block
      [08.368]ubi0 warning: scan_peb: bad ec header at pnum 95, drop this block
      [08.375]ubi0 warning: scan_peb: bad ec header at pnum 96, drop this block
      [08.381]ubi0 warning: scan_peb: bad ec header at pnum 97, drop this block
      [08.388]ubi0 warning: scan_peb: bad ec header at pnum 98, drop this block
      [08.395]ubi0 warning: scan_peb: bad ec header at pnum 99, drop this block
      [08.402]ubi0 warning: scan_peb: bad ec header at pnum 100, drop this block
      [08.409]ubi0 warning: scan_peb: bad ec header at pnum 101, drop this block
      [08.415]ubi0 warning: scan_peb: bad ec header at pnum 102, drop this block
      [08.422]ubi0 warning: scan_peb: bad ec header at pnum 103, drop this block
      [08.429]ubi0 warning: scan_peb: bad ec header at pnum 104, drop this block
      [08.436]ubi0 warning: scan_peb: bad ec header at pnum 105, drop this block
      [08.443]ubi0 warning: scan_peb: bad ec header at pnum 106, drop this block
      [08.450]ubi0 warning: scan_peb: bad ec header at pnum 107, drop this block
      [08.457]ubi0 warning: scan_peb: bad ec header at pnum 108, drop this block
      [08.463]ubi0 warning: scan_peb: bad ec header at pnum 109, drop this block
      [08.470]ubi0 warning: scan_peb: bad ec header at pnum 110, drop this block
      [08.477]ubi0 warning: scan_peb: bad ec header at pnum 111, drop this block
      [08.484]ubi0 warning: scan_peb: bad ec header at pnum 112, drop this block
      [08.491]ubi0 warning: scan_peb: bad ec header at pnum 113, drop this block
      [08.498]ubi0 warning: scan_peb: bad ec header at pnum 114, drop this block
      [08.505]ubi0 warning: scan_peb: bad ec header at pnum 115, drop this block
      [08.511]ubi0 warning: scan_peb: bad ec header at pnum 116, drop this block
      [08.518]ubi0 warning: scan_peb: bad ec header at pnum 117, drop this block
      [08.525]ubi0 warning: scan_peb: bad ec header at pnum 118, drop this block
      [08.532]ubi0 warning: scan_peb: bad ec header at pnum 119, drop this block
      [08.539]ubi0 warning: scan_peb: bad ec header at pnum 120, drop this block
      [08.546]ubi0 warning: scan_peb: bad ec header at pnum 121, drop this block
      [08.553]ubi0 warning: scan_peb: bad ec header at pnum 122, drop this block
      [08.559]ubi0 warning: scan_peb: bad ec header at pnum 123, drop this block
      [08.566]ubi0 warning: scan_peb: bad ec header at pnum 124, drop this block
      [08.573]ubi0 warning: scan_peb: bad ec header at pnum 125, drop this block
      [08.580]ubi0 warning: scan_peb: bad ec header at pnum 126, drop this block
      [08.587]ubi0 warning: scan_peb: bad ec header at pnum 127, drop this block
      [08.594]ubi0 warning: scan_peb: bad ec header at pnum 128, drop this block
      [08.601]ubi0 warning: scan_peb: bad ec header at pnum 129, drop this block
      [08.607]ubi0 warning: scan_peb: bad ec header at pnum 130, drop this block
      [08.614]ubi0 warning: scan_peb: bad ec header at pnum 131, drop this block
      [08.621]ubi0 warning: scan_peb: bad ec header at pnum 132, drop this block
      [08.628]ubi0 warning: scan_peb: bad ec header at pnum 133, drop this block
      [08.635]ubi0 warning: scan_peb: bad ec header at pnum 134, drop this block
      [08.642]ubi0 warning: scan_peb: bad ec header at pnum 135, drop this block
      [08.649]ubi0 warning: scan_peb: bad ec header at pnum 136, drop this block
      [08.655]ubi0 warning: scan_peb: bad ec header at pnum 137, drop this block
      [08.662]ubi0 warning: scan_peb: bad ec header at pnum 138, drop this block
      [08.669]ubi0 warning: scan_peb: bad ec header at pnum 139, drop this block
      [08.676]ubi0 warning: scan_peb: bad ec header at pnum 140, drop this block
      [08.683]ubi0 warning: scan_peb: bad ec header at pnum 141, drop this block
      [08.690]ubi0 warning: scan_peb: bad ec header at pnum 142, drop this block
      [08.697]ubi0 warning: scan_peb: bad ec header at pnum 143, drop this block
      [08.703]ubi0 warning: scan_peb: bad ec header at pnum 144, drop this block
      [08.710]ubi0 warning: scan_peb: bad ec header at pnum 145, drop this block
      [08.717]ubi0 warning: scan_peb: bad ec header at pnum 146, drop this block
      [08.724]ubi0 warning: scan_peb: bad ec header at pnum 147, drop this block
      [08.731]ubi0 warning: scan_peb: bad ec header at pnum 148, drop this block
      [08.738]ubi0 warning: scan_peb: bad ec header at pnum 149, drop this block
      [08.745]ubi0 warning: scan_peb: bad ec header at pnum 150, drop this block
      [08.751]ubi0 warning: scan_peb: bad ec header at pnum 151, drop this block
      [08.758]ubi0 warning: scan_peb: bad ec header at pnum 152, drop this block
      [08.765]ubi0 warning: scan_peb: bad ec header at pnum 153, drop this block
      [08.772]ubi0 warning: scan_peb: bad ec header at pnum 154, drop this block
      [08.779]ubi0 warning: scan_peb: bad ec header at pnum 155, drop this block
      [08.786]ubi0 warning: scan_peb: bad ec header at pnum 156, drop this block
      [08.793]ubi0 warning: scan_peb: bad ec header at pnum 157, drop this block
      [08.799]ubi0 warning: scan_peb: bad ec header at pnum 158, drop this block
      [08.806]ubi0 warning: scan_peb: bad ec header at pnum 159, drop this block
      [08.813]ubi0 warning: scan_peb: bad ec header at pnum 160, drop this block
      [08.820]ubi0 warning: scan_peb: bad ec header at pnum 161, drop this block
      [08.827]ubi0 warning: scan_peb: bad ec header at pnum 162, drop this block
      [08.834]ubi0 warning: scan_peb: bad ec header at pnum 163, drop this block
      [08.841]ubi0 warning: scan_peb: bad ec header at pnum 164, drop this block
      [08.847]ubi0 warning: scan_peb: bad ec header at pnum 165, drop this block
      [08.854]ubi0 warning: scan_peb: bad ec header at pnum 166, drop this block
      [08.861]ubi0 warning: scan_peb: bad ec header at pnum 167, drop this block
      [08.868]ubi0 warning: scan_peb: bad ec header at pnum 168, drop this block
      [08.875]ubi0 warning: scan_peb: bad ec header at pnum 169, drop this block
      [08.882]ubi0 warning: scan_peb: bad ec header at pnum 170, drop this block
      [08.889]ubi0 warning: scan_peb: bad ec header at pnum 171, drop this block
      [08.895]ubi0 warning: scan_peb: bad ec header at pnum 172, drop this block
      [08.902]ubi0 warning: scan_peb: bad ec header at pnum 173, drop this block
      [08.909]ubi0 warning: scan_peb: bad ec header at pnum 174, drop this block
      [08.916]ubi0 warning: scan_peb: bad ec header at pnum 175, drop this block
      [08.923]ubi0 warning: scan_peb: bad ec header at pnum 176, drop this block
      [08.930]ubi0 warning: scan_peb: bad ec header at pnum 177, drop this block
      [08.937]ubi0 warning: scan_peb: bad ec header at pnum 178, drop this block
      [08.943]ubi0 warning: scan_peb: bad ec header at pnum 179, drop this block
      [08.950]ubi0 warning: scan_peb: bad ec header at pnum 180, drop this block
      [08.957]ubi0 warning: scan_peb: bad ec header at pnum 181, drop this block
      [08.964]ubi0 warning: scan_peb: bad ec header at pnum 182, drop this block
      [08.971]ubi0 warning: scan_peb: bad ec header at pnum 183, drop this block
      [08.978]ubi0 warning: scan_peb: bad ec header at pnum 184, drop this block
      [08.984]ubi0 warning: scan_peb: bad ec header at pnum 185, drop this block
      [08.991]ubi0 warning: scan_peb: bad ec header at pnum 186, drop this block
      [08.998]ubi0 warning: scan_peb: bad ec header at pnum 187, drop this block
      [09.005]ubi0 warning: scan_peb: bad ec header at pnum 188, drop this block
      [09.012]ubi0 warning: scan_peb: bad ec header at pnum 189, drop this block
      [09.019]ubi0 warning: scan_peb: bad ec header at pnum 190, drop this block
      [09.026]ubi0 warning: scan_peb: bad ec header at pnum 191, drop this block
      [09.032]ubi0 warning: scan_peb: bad ec header at pnum 192, drop this block
      [09.039]ubi0 warning: scan_peb: bad ec header at pnum 193, drop this block
      [09.046]ubi0 warning: scan_peb: bad ec header at pnum 194, drop this block
      [09.053]ubi0 warning: scan_peb: bad ec header at pnum 195, drop this block
      [09.060]ubi0 warning: scan_peb: bad ec header at pnum 196, drop this block
      [09.067]ubi0 warning: scan_peb: bad ec header at pnum 197, drop this block
      [09.074]ubi0 warning: scan_peb: bad ec header at pnum 198, drop this block
      [09.080]ubi0 warning: scan_peb: bad ec header at pnum 199, drop this block
      [09.087]ubi0 warning: scan_peb: bad ec header at pnum 200, drop this block
      [09.094]ubi0 warning: scan_peb: bad ec header at pnum 201, drop this block
      [09.101]ubi0 warning: scan_peb: bad ec header at pnum 202, drop this block
      [09.108]ubi0 warning: scan_peb: bad ec header at pnum 203, drop this block
      [09.115]ubi0 warning: scan_peb: bad ec header at pnum 204, drop this block
      [09.122]ubi0 warning: scan_peb: bad ec header at pnum 205, drop this block
      [09.128]ubi0 warning: scan_peb: bad ec header at pnum 206, drop this block
      [09.135]ubi0 warning: scan_peb: bad ec header at pnum 207, drop this block
      [09.142]ubi0 warning: scan_peb: bad ec header at pnum 208, drop this block
      [09.149]ubi0 warning: scan_peb: bad ec header at pnum 209, drop this block
      [09.156]ubi0 warning: scan_peb: bad ec header at pnum 210, drop this block
      [09.163]ubi0 warning: scan_peb: bad ec header at pnum 211, drop this block
      [09.170]ubi0 warning: scan_peb: bad ec header at pnum 212, drop this block
      [09.176]ubi0 warning: scan_peb: bad ec header at pnum 213, drop this block
      [09.183]ubi0 warning: scan_peb: bad ec header at pnum 214, drop this block
      [09.190]ubi0 warning: scan_peb: bad ec header at pnum 215, drop this block
      [09.197]ubi0 warning: scan_peb: bad ec header at pnum 216, drop this block
      [09.204]ubi0 warning: scan_peb: bad ec header at pnum 217, drop this block
      [09.211]ubi0 warning: scan_peb: bad ec header at pnum 218, drop this block
      [09.218]ubi0 warning: scan_peb: bad ec header at pnum 219, drop this block
      [09.224]ubi0 warning: scan_peb: bad ec header at pnum 220, drop this block
      [09.231]ubi0 warning: scan_peb: bad ec header at pnum 221, drop this block
      [09.238]ubi0 warning: scan_peb: bad ec header at pnum 222, drop this block
      [09.245]ubi0 warning: scan_peb: bad ec header at pnum 223, drop this block
      [09.252]ubi0 warning: scan_peb: bad ec header at pnum 224, drop this block
      [09.259]ubi0 warning: scan_peb: bad ec header at pnum 225, drop this block
      [09.266]ubi0 warning: scan_peb: bad ec header at pnum 226, drop this block
      [09.272]ubi0 warning: scan_peb: bad ec header at pnum 227, drop this block
      [09.279]ubi0 warning: scan_peb: bad ec header at pnum 228, drop this block
      [09.286]ubi0 warning: scan_peb: bad ec header at pnum 229, drop this block
      [09.293]ubi0 warning: scan_peb: bad ec header at pnum 230, drop this block
      [09.300]ubi0 warning: scan_peb: bad ec header at pnum 231, drop this block
      [09.307]ubi0 warning: scan_peb: bad ec header at pnum 232, drop this block
      [09.314]ubi0 warning: scan_peb: bad ec header at pnum 233, drop this block
      [09.320]ubi0 warning: scan_peb: bad ec header at pnum 234, drop this block
      [09.327]ubi0 warning: scan_peb: bad ec header at pnum 235, drop this block
      [09.334]ubi0 warning: scan_peb: bad ec header at pnum 236, drop this block
      [09.341]ubi0 warning: scan_peb: bad ec header at pnum 237, drop this block
      [09.348]ubi0 warning: scan_peb: bad ec header at pnum 238, drop this block
      [09.355]ubi0 warning: scan_peb: bad ec header at pnum 239, drop this block
      [09.362]ubi0 warning: scan_peb: bad ec header at pnum 240, drop this block
      [09.368]ubi0 warning: scan_peb: bad ec header at pnum 241, drop this block
      [09.375]ubi0 warning: scan_peb: bad ec header at pnum 242, drop this block
      [09.382]ubi0 warning: scan_peb: bad ec header at pnum 243, drop this block
      [09.389]ubi0 warning: scan_peb: bad ec header at pnum 244, drop this block
      [09.396]ubi0 warning: scan_peb: bad ec header at pnum 245, drop this block
      [09.403]ubi0 warning: scan_peb: bad ec header at pnum 246, drop this block
      [09.410]ubi0 warning: scan_peb: bad ec header at pnum 247, drop this block
      [09.416]ubi0 warning: scan_peb: bad ec header at pnum 248, drop this block
      [09.423]ubi0 warning: scan_peb: bad ec header at pnum 249, drop this block
      [09.430]ubi0 warning: scan_peb: bad ec header at pnum 250, drop this block
      [09.437]ubi0 warning: scan_peb: bad ec header at pnum 251, drop this block
      [09.444]ubi0 warning: scan_peb: bad ec header at pnum 252, drop this block
      [09.451]ubi0 warning: scan_peb: bad ec header at pnum 253, drop this block
      [09.458]ubi0 warning: scan_peb: bad ec header at pnum 254, drop this block
      [09.464]ubi0 warning: scan_peb: bad ec header at pnum 255, drop this block
      [09.471]ubi0 warning: scan_peb: bad ec header at pnum 256, drop this block
      [09.478]ubi0 warning: scan_peb: bad ec header at pnum 257, drop this block
      [09.485]ubi0 warning: scan_peb: bad ec header at pnum 258, drop this block
      [09.492]ubi0 warning: scan_peb: bad ec header at pnum 260, drop this block
      [09.499]ubi0 warning: scan_peb: bad ec header at pnum 261, drop this block
      [09.506]ubi0 warning: scan_peb: bad ec header at pnum 262, drop this block
      [09.512]ubi0 warning: scan_peb: bad ec header at pnum 263, drop this block
      [09.519]ubi0 warning: scan_peb: bad ec header at pnum 264, drop this block
      [09.526]ubi0 warning: scan_peb: bad ec header at pnum 265, drop this block
      [09.533]ubi0 warning: scan_peb: bad ec header at pnum 266, drop this block
      [09.540]ubi0 warning: scan_peb: bad ec header at pnum 267, drop this block
      [09.547]ubi0 warning: scan_peb: bad ec header at pnum 268, drop this block
      [09.554]ubi0 warning: scan_peb: bad ec header at pnum 269, drop this block
      [09.560]ubi0 warning: scan_peb: bad ec header at pnum 270, drop this block
      [09.567]ubi0 warning: scan_peb: bad ec header at pnum 271, drop this block
      [09.574]ubi0 warning: scan_peb: bad ec header at pnum 272, drop this block
      [09.581]ubi0 warning: scan_peb: bad ec header at pnum 273, drop this block
      [09.588]ubi0 warning: scan_peb: bad ec header at pnum 274, drop this block
      [09.595]ubi0 warning: scan_peb: bad ec header at pnum 275, drop this block
      [09.602]ubi0 warning: scan_peb: bad ec header at pnum 276, drop this block
      [09.608]ubi0 warning: scan_peb: bad ec header at pnum 277, drop this block
      [09.615]ubi0 warning: scan_peb: bad ec header at pnum 278, drop this block
      [09.622]ubi0 warning: scan_peb: bad ec header at pnum 279, drop this block
      [09.629]ubi0 warning: scan_peb: bad ec header at pnum 280, drop this block
      [09.636]ubi0 warning: scan_peb: bad ec header at pnum 281, drop this block
      [09.643]ubi0 warning: scan_peb: bad ec header at pnum 282, drop this block
      [09.649]ubi0 warning: scan_peb: bad ec header at pnum 283, drop this block
      [09.656]ubi0 warning: scan_peb: bad ec header at pnum 284, drop this block
      [09.663]ubi0 warning: scan_peb: bad ec header at pnum 285, drop this block
      [09.670]ubi0 warning: scan_peb: bad ec header at pnum 286, drop this block
      [09.677]ubi0 warning: scan_peb: bad ec header at pnum 287, drop this block
      [09.684]ubi0 warning: scan_peb: bad ec header at pnum 288, drop this block
      [09.691]ubi0 warning: scan_peb: bad ec header at pnum 289, drop this block
      [09.697]ubi0 warning: scan_peb: bad ec header at pnum 290, drop this block
      [09.704]ubi0 warning: scan_peb: bad ec header at pnum 291, drop this block
      [09.711]ubi0 warning: scan_peb: bad ec header at pnum 292, drop this block
      [09.718]ubi0 warning: scan_peb: bad ec header at pnum 293, drop this block
      [09.725]ubi0 warning: scan_peb: bad ec header at pnum 294, drop this block
      [09.732]ubi0 warning: scan_peb: bad ec header at pnum 295, drop this block
      [09.739]ubi0 warning: scan_peb: bad ec header at pnum 296, drop this block
      [09.745]ubi0 warning: scan_peb: bad ec header at pnum 297, drop this block
      [09.752]ubi0 warning: scan_peb: bad ec header at pnum 298, drop this block
      [09.759]ubi0 warning: scan_peb: bad ec header at pnum 299, drop this block
      [09.766]ubi0 warning: scan_peb: bad ec header at pnum 300, drop this block
      [09.773]ubi0 warning: scan_peb: bad ec header at pnum 301, drop this block
      [09.780]ubi0 warning: scan_peb: bad ec header at pnum 302, drop this block
      [09.787]ubi0 warning: scan_peb: bad ec header at pnum 303, drop this block
      [09.793]ubi0 warning: scan_peb: bad ec header at pnum 304, drop this block
      [09.800]ubi0 warning: scan_peb: bad ec header at pnum 305, drop this block
      [09.807]ubi0 warning: scan_peb: bad ec header at pnum 306, drop this block
      [09.814]ubi0 warning: scan_peb: bad ec header at pnum 307, drop this block
      [09.821]ubi0 warning: scan_peb: bad ec header at pnum 308, drop this block
      [09.828]ubi0 warning: scan_peb: bad ec header at pnum 309, drop this block
      [09.835]ubi0 warning: scan_peb: bad ec header at pnum 310, drop this block
      [09.841]ubi0 warning: scan_peb: bad ec header at pnum 311, drop this block
      [09.848]ubi0 warning: scan_peb: bad ec header at pnum 312, drop this block
      [09.855]ubi0 warning: scan_peb: bad ec header at pnum 313, drop this block
      [09.862]ubi0 warning: scan_peb: bad ec header at pnum 314, drop this block
      [09.869]ubi0 warning: scan_peb: bad ec header at pnum 315, drop this block
      [09.876]ubi0 warning: scan_peb: bad ec header at pnum 316, drop this block
      [09.883]ubi0 warning: scan_peb: bad ec header at pnum 317, drop this block
      [09.889]ubi0 warning: scan_peb: bad ec header at pnum 318, drop this block
      [09.896]ubi0 warning: scan_peb: bad ec header at pnum 319, drop this block
      [09.903]ubi0 warning: scan_peb: bad ec header at pnum 320, drop this block
      [09.910]ubi0 warning: scan_peb: bad ec header at pnum 321, drop this block
      [09.917]ubi0 warning: scan_peb: bad ec header at pnum 322, drop this block
      [09.924]ubi0 warning: scan_peb: bad ec header at pnum 323, drop this block
      [09.931]ubi0 warning: scan_peb: bad ec header at pnum 324, drop this block
      [09.937]ubi0 warning: scan_peb: bad ec header at pnum 325, drop this block
      [09.944]ubi0 warning: scan_peb: bad ec header at pnum 326, drop this block
      [09.951]ubi0 warning: scan_peb: bad ec header at pnum 327, drop this block
      [09.958]ubi0 warning: scan_peb: bad ec header at pnum 328, drop this block
      [09.965]ubi0 warning: scan_peb: bad ec header at pnum 329, drop this block
      [09.972]ubi0 warning: scan_peb: bad ec header at pnum 330, drop this block
      [09.979]ubi0 warning: scan_peb: bad ec header at pnum 331, drop this block
      [09.985]ubi0 warning: scan_peb: bad ec header at pnum 332, drop this block
      [09.992]ubi0 warning: scan_peb: bad ec header at pnum 333, drop this block
      [09.999]ubi0 warning: scan_peb: bad ec header at pnum 334, drop this block
      [10.006]ubi0 warning: scan_peb: bad ec header at pnum 335, drop this block
      [10.013]ubi0 warning: scan_peb: bad ec header at pnum 336, drop this block
      [10.020]ubi0 warning: scan_peb: bad ec header at pnum 337, drop this block
      [10.027]ubi0 warning: scan_peb: bad ec header at pnum 338, drop this block
      [10.033]ubi0 warning: scan_peb: bad ec header at pnum 339, drop this block
      [10.040]ubi0 warning: scan_peb: bad ec header at pnum 340, drop this block
      [10.047]ubi0 warning: scan_peb: bad ec header at pnum 341, drop this block
      [10.054]ubi0 warning: scan_peb: bad ec header at pnum 342, drop this block
      [10.061]ubi0 warning: scan_peb: bad ec header at pnum 343, drop this block
      [10.068]ubi0 warning: scan_peb: bad ec header at pnum 344, drop this block
      [10.075]ubi0 warning: scan_peb: bad ec header at pnum 345, drop this block
      [10.081]ubi0 warning: scan_peb: bad ec header at pnum 346, drop this block
      [10.088]ubi0 warning: scan_peb: bad ec header at pnum 347, drop this block
      [10.095]ubi0 warning: scan_peb: bad ec header at pnum 348, drop this block
      [10.102]ubi0 warning: scan_peb: bad ec header at pnum 349, drop this block
      [10.109]ubi0 warning: scan_peb: bad ec header at pnum 350, drop this block
      [10.116]ubi0 warning: scan_peb: bad ec header at pnum 351, drop this block
      [10.123]ubi0 warning: scan_peb: bad ec header at pnum 352, drop this block
      [10.129]ubi0 warning: scan_peb: bad ec header at pnum 353, drop this block
      [10.136]ubi0 warning: scan_peb: bad ec header at pnum 354, drop this block
      [10.143]ubi0 warning: scan_peb: bad ec header at pnum 355, drop this block
      [10.150]ubi0 warning: scan_peb: bad ec header at pnum 356, drop this block
      [10.157]ubi0 warning: scan_peb: bad ec header at pnum 357, drop this block
      [10.164]ubi0 warning: scan_peb: bad ec header at pnum 358, drop this block
      [10.171]ubi0 warning: scan_peb: bad ec header at pnum 359, drop this block
      [10.177]ubi0 warning: scan_peb: bad ec header at pnum 360, drop this block
      [10.184]ubi0 warning: scan_peb: bad ec header at pnum 361, drop this block
      [10.191]ubi0 warning: scan_peb: bad ec header at pnum 362, drop this block
      [10.198]ubi0 warning: scan_peb: bad ec header at pnum 363, drop this block
      [10.205]ubi0 warning: scan_peb: bad ec header at pnum 364, drop this block
      [10.212]ubi0 warning: scan_peb: bad ec header at pnum 365, drop this block
      [10.219]ubi0 warning: scan_peb: bad ec header at pnum 366, drop this block
      [10.225]ubi0 warning: scan_peb: bad ec header at pnum 367, drop this block
      [10.232]ubi0 warning: scan_peb: bad ec header at pnum 368, drop this block
      [10.239]ubi0 warning: scan_peb: bad ec header at pnum 369, drop this block
      [10.246]ubi0 warning: scan_peb: bad ec header at pnum 370, drop this block
      [10.253]ubi0 warning: scan_peb: bad ec header at pnum 371, drop this block
      [10.260]ubi0 warning: scan_peb: bad ec header at pnum 372, drop this block
      [10.267]ubi0 warning: scan_peb: bad ec header at pnum 373, drop this block
      [10.273]ubi0 warning: scan_peb: bad ec header at pnum 374, drop this block
      [10.280]ubi0 warning: scan_peb: bad ec header at pnum 375, drop this block
      [10.287]ubi0 warning: scan_peb: bad ec header at pnum 376, drop this block
      [10.294]ubi0 warning: scan_peb: bad ec header at pnum 377, drop this block
      [10.301]ubi0 warning: scan_peb: bad ec header at pnum 378, drop this block
      [10.308]ubi0 warning: scan_peb: bad ec header at pnum 379, drop this block
      [10.315]ubi0 warning: scan_peb: bad ec header at pnum 380, drop this block
      [10.321]ubi0 warning: scan_peb: bad ec header at pnum 381, drop this block
      [10.328]ubi0 warning: scan_peb: bad ec header at pnum 382, drop this block
      [10.335]ubi0 warning: scan_peb: bad ec header at pnum 383, drop this block
      [10.342]ubi0 warning: scan_peb: bad ec header at pnum 384, drop this block
      [10.349]ubi0 warning: scan_peb: bad ec header at pnum 385, drop this block
      [10.356]ubi0 warning: scan_peb: bad ec header at pnum 386, drop this block
      [10.362]ubi0 warning: scan_peb: bad ec header at pnum 387, drop this block
      [10.369]ubi0 warning: scan_peb: bad ec header at pnum 388, drop this block
      [10.376]ubi0 warning: scan_peb: bad ec header at pnum 389, drop this block
      [10.383]ubi0 warning: scan_peb: bad ec header at pnum 390, drop this block
      [10.390]ubi0 warning: scan_peb: bad ec header at pnum 391, drop this block
      [10.397]ubi0 warning: scan_peb: bad ec header at pnum 392, drop this block
      [10.404]ubi0 warning: scan_peb: bad ec header at pnum 393, drop this block
      [10.410]ubi0 warning: scan_peb: bad ec header at pnum 394, drop this block
      [10.417]ubi0 warning: scan_peb: bad ec header at pnum 395, drop this block
      [10.424]ubi0 warning: scan_peb: bad ec header at pnum 396, drop this block
      [10.431]ubi0 warning: scan_peb: bad ec header at pnum 397, drop this block
      [10.438]ubi0 warning: scan_peb: bad ec header at pnum 398, drop this block
      [10.445]ubi0 warning: scan_peb: bad ec header at pnum 399, drop this block
      [10.452]ubi0 warning: scan_peb: bad ec header at pnum 400, drop this block
      [10.458]ubi0 warning: scan_peb: bad ec header at pnum 401, drop this block
      [10.465]ubi0 warning: scan_peb: bad ec header at pnum 402, drop this block
      [10.472]ubi0 warning: scan_peb: bad ec header at pnum 403, drop this block
      [10.479]ubi0 warning: scan_peb: bad ec header at pnum 404, drop this block
      [10.486]ubi0 warning: scan_peb: bad ec header at pnum 405, drop this block
      [10.493]ubi0 warning: scan_peb: bad ec header at pnum 406, drop this block
      [10.500]ubi0 warning: scan_peb: bad ec header at pnum 407, drop this block
      [10.506]ubi0 warning: scan_peb: bad ec header at pnum 408, drop this block
      [10.513]ubi0 warning: scan_peb: bad ec header at pnum 409, drop this block
      [10.520]ubi0 warning: scan_peb: bad ec header at pnum 410, drop this block
      [10.527]ubi0 warning: scan_peb: bad ec header at pnum 411, drop this block
      [10.534]ubi0 warning: scan_peb: bad ec header at pnum 412, drop this block
      [10.541]ubi0 warning: scan_peb: bad ec header at pnum 413, drop this block
      [10.548]ubi0 warning: scan_peb: bad ec header at pnum 414, drop this block
      [10.554]ubi0 warning: scan_peb: bad ec header at pnum 415, drop this block
      [10.561]ubi0 warning: scan_peb: bad ec header at pnum 416, drop this block
      [10.568]ubi0 warning: scan_peb: bad ec header at pnum 417, drop this block
      [10.575]ubi0 warning: scan_peb: bad ec header at pnum 418, drop this block
      [10.582]ubi0 warning: scan_peb: bad ec header at pnum 419, drop this block
      [10.589]ubi0 warning: scan_peb: bad ec header at pnum 420, drop this block
      [10.596]ubi0 warning: scan_peb: bad ec header at pnum 421, drop this block
      [10.602]ubi0 warning: scan_peb: bad ec header at pnum 422, drop this block
      [10.609]ubi0 warning: scan_peb: bad ec header at pnum 423, drop this block
      [10.616]ubi0 warning: scan_peb: bad ec header at pnum 424, drop this block
      [10.623]ubi0 warning: scan_peb: bad ec header at pnum 425, drop this block
      [10.630]ubi0 warning: scan_peb: bad ec header at pnum 426, drop this block
      [10.637]ubi0 warning: scan_peb: bad ec header at pnum 427, drop this block
      [10.644]ubi0 warning: scan_peb: bad ec header at pnum 428, drop this block
      [10.650]ubi0 warning: scan_peb: bad ec header at pnum 429, drop this block
      [10.657]ubi0 warning: scan_peb: bad ec header at pnum 430, drop this block
      [10.664]ubi0 warning: scan_peb: bad ec header at pnum 431, drop this block
      [10.671]ubi0 warning: scan_peb: bad ec header at pnum 432, drop this block
      [10.678]ubi0 warning: scan_peb: bad ec header at pnum 433, drop this block
      [10.685]ubi0 warning: scan_peb: bad ec header at pnum 434, drop this block
      [10.692]ubi0 warning: scan_peb: bad ec header at pnum 435, drop this block
      [10.698]ubi0 warning: scan_peb: bad ec header at pnum 436, drop this block
      [10.705]ubi0 warning: scan_peb: bad ec header at pnum 437, drop this block
      [10.712]ubi0 warning: scan_peb: bad ec header at pnum 438, drop this block
      [10.719]ubi0 warning: scan_peb: bad ec header at pnum 439, drop this block
      [10.726]ubi0 warning: scan_peb: bad ec header at pnum 440, drop this block
      [10.733]ubi0 warning: scan_peb: bad ec header at pnum 441, drop this block
      [10.740]ubi0 warning: scan_peb: bad ec header at pnum 442, drop this block
      [10.746]ubi0 warning: scan_peb: bad ec header at pnum 443, drop this block
      [10.753]ubi0 warning: scan_peb: bad ec header at pnum 444, drop this block
      [10.760]ubi0 warning: scan_peb: bad ec header at pnum 445, drop this block
      [10.767]ubi0 warning: scan_peb: bad ec header at pnum 446, drop this block
      [10.774]ubi0 warning: scan_peb: bad ec header at pnum 447, drop this block
      [10.781]ubi0 warning: scan_peb: bad ec header at pnum 448, drop this block
      [10.788]ubi0 warning: scan_peb: bad ec header at pnum 449, drop this block
      [10.794]ubi0 warning: scan_peb: bad ec header at pnum 450, drop this block
      [10.801]ubi0 warning: scan_peb: bad ec header at pnum 451, drop this block
      [10.808]ubi0 warning: scan_peb: bad ec header at pnum 452, drop this block
      [10.815]ubi0 warning: scan_peb: bad ec header at pnum 453, drop this block
      [10.822]ubi0 warning: scan_peb: bad ec header at pnum 454, drop this block
      [10.829]ubi0 warning: scan_peb: bad ec header at pnum 455, drop this block
      [10.836]ubi0 warning: scan_peb: bad ec header at pnum 456, drop this block
      [10.842]ubi0 warning: scan_peb: bad ec header at pnum 457, drop this block
      [10.849]ubi0 warning: scan_peb: bad ec header at pnum 458, drop this block
      [10.856]ubi0 warning: scan_peb: bad ec header at pnum 459, drop this block
      [10.863]ubi0 warning: scan_peb: bad ec header at pnum 460, drop this block
      [10.870]ubi0 warning: scan_peb: bad ec header at pnum 461, drop this block
      [10.877]ubi0 warning: scan_peb: bad ec header at pnum 462, drop this block
      [10.884]ubi0 warning: scan_peb: bad ec header at pnum 463, drop this block
      [10.890]ubi0 warning: scan_peb: bad ec header at pnum 464, drop this block
      [10.897]ubi0 warning: scan_peb: bad ec header at pnum 465, drop this block
      [10.904]ubi0 warning: scan_peb: bad ec header at pnum 466, drop this block
      [10.911]ubi0 warning: scan_peb: bad ec header at pnum 467, drop this block
      [10.918]ubi0 warning: scan_peb: bad ec header at pnum 468, drop this block
      [10.925]ubi0 warning: scan_peb: bad ec header at pnum 469, drop this block
      [10.932]ubi0 warning: scan_peb: bad ec header at pnum 470, drop this block
      [10.938]ubi0 warning: scan_peb: bad ec header at pnum 471, drop this block
      [10.945]ubi0 warning: scan_peb: bad ec header at pnum 472, drop this block
      [10.952]ubi0 warning: scan_peb: bad ec header at pnum 473, drop this block
      [10.959]ubi0 warning: scan_peb: bad ec header at pnum 474, drop this block
      [10.966]ubi0 warning: scan_peb: bad ec header at pnum 475, drop this block
      [10.973]ubi0 warning: scan_peb: bad ec header at pnum 476, drop this block
      [10.980]ubi0 warning: scan_peb: bad ec header at pnum 477, drop this block
      [10.986]ubi0 warning: scan_peb: bad ec header at pnum 478, drop this block
      [10.993]ubi0 warning: scan_peb: bad ec header at pnum 479, drop this block
      [11.000]ubi0 warning: scan_peb: bad ec header at pnum 480, drop this block
      [11.007]ubi0 warning: scan_peb: bad ec header at pnum 481, drop this block
      [11.014]ubi0 warning: scan_peb: bad ec header at pnum 482, drop this block
      [11.021]ubi0 warning: scan_peb: bad ec header at pnum 483, drop this block
      [11.028]ubi0 warning: scan_peb: bad ec header at pnum 484, drop this block
      [11.034]ubi0 warning: scan_peb: bad ec header at pnum 485, drop this block
      [11.041]ubi0 warning: scan_peb: bad ec header at pnum 486, drop this block
      [11.048]ubi0 warning: scan_peb: bad ec header at pnum 487, drop this block
      [11.055]ubi0 warning: scan_peb: bad ec header at pnum 488, drop this block
      [11.062]ubi0 warning: scan_peb: bad ec header at pnum 489, drop this block
      [11.069]ubi0 warning: scan_peb: bad ec header at pnum 490, drop this block
      [11.076]ubi0 warning: scan_peb: bad ec header at pnum 491, drop this block
      [11.082]ubi0: scanning is finished
      [11.085]ubi0: empty MTD device detected
      [11.128]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [11.133]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [11.139]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [11.146]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [11.152]ubi0: good PEBs: 491, bad PEBs: 1, corrupted PEBs: 0
      [11.157]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
      [11.164]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
      [11.172]ubi0: available PEBs: 468, total reserved PEBs: 23, PEBs reserved for bad PEB handling: 19
      [12.233]erase blk 0 to blk 32
      [12.253]erase blk 40 to blk 1024
      [12.534]blk 558 is bad, skip to erase
      [12.537]blk 559 is bad, skip to erase
      [12.792]sunxi-spinand: spinand secure storage ok for phy blk 32 and 33
      [12.798]sunxi-spinand: secure storage blks have never used before
      [12.805]sunxi-spinand: secure storage has no valid data on item 0
      [12.811]Item0 (Map) magic is bad
      [12.814]the secure storage map is empty
      [12.975]sunxi-spinand: write secure storage itme 0 ok
      [12.979]erase secure storage: 0 ok
      SUNXI_EFEX_MBR_TAG
      mbr size = 0x10000
      force mbr
      defaults:
      mtdids  : nand0=nand
      [13.033]MTD info (4)
      [13.035]pagesize: 0x1000
      [13.037]blksize: 0x40000
      [13.039]num  offset     bytes      name
      [13.043]0    0x00000000 0x00100000 boot0
      [13.046]1    0x00100000 0x00300000 uboot
      [13.050]2    0x00400000 0x00100000 secure_storage
      [13.055]3    0x00500000 0x07b00000 sys
      [13.058]MBR info (unalign):
      [13.061]partno   addr       sects      type       name
      [13.065]0        0x00000000 0x00008000 0x00000001 mbr
      [13.070]1        0x00008000 0x000001f8 0x00008000 boot-resource
      [13.076]2        0x000081f8 0x000001f8 0x00008000 env
      [13.081]3        0x000083f0 0x000001f8 0x00008000 env-redund
      [13.086]4        0x000085e8 0x00005000 0x00008000 boot
      [13.091]5        0x0000d5e8 0x0000be00 0x00008000 rootfs
      [13.096]6        0x000193e8 0x00005780 0x00008000 recovery
      [13.101]7        0x0001eb68 0x00002800 0x00008000 rootfs_data
      [13.106]8        0x00021368 0x00000000 0x00000000 UDISK
      [13.111]ubi attach the last part of mtd device: NO.3
      [13.116]MBR info (align):
      [13.118]partno   addr       sects      type       name
      [13.123]0        0x00002800 0x000081f0 0x00000001 mbr
      [13.128]1        0x0000a9f0 0x000001f8 0x00008000 boot-resource
      [13.134]2        0x0000abe8 0x000001f8 0x00008000 env
      [13.138]3        0x0000ade0 0x000001f8 0x00008000 env-redund
      [13.144]4        0x0000afd8 0x000050b8 0x00008000 boot
      [13.149]5        0x00010090 0x0000bef8 0x00008000 rootfs
      [13.154]6        0x0001bf88 0x00005898 0x00008000 recovery
      [13.159]7        0x00021820 0x00002958 0x00008000 rootfs_data
      [13.164]8        0x00024178 0x00000000 0x00000000 UDISK
      [13.169]ubi attach the last part of mtd device: NO.3
      [13.174]ubi attatch mtd, name: sys
      [13.177]ubi0: detaching mtd4
      [13.182]ubi0: mtd4 is detached
      [13.185]ubi0: attaching mtd4
      [13.283]ubi0: scanning is finished
      [13.286]ubi0: empty MTD device detected
      [13.329]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [13.334]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [13.340]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [13.347]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [13.353]ubi0: good PEBs: 491, bad PEBs: 1, corrupted PEBs: 0
      [13.358]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
      [13.365]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
      [13.373]ubi0: available PEBs: 468, total reserved PEBs: 23, PEBs reserved for bad PEB handling: 19
      Creating dynamic volume boot-resource of size 258048
      Creating dynamic volume boot of size 10579968
      Creating dynamic volume rootfs of size 25030656
      Creating dynamic volume recovery of size 11612160
      set address 0x1
      set address 0x1 ok
      Creating dynamic volume rootfs_data of size 5419008
      No size specified -> Using max size (50319360)
      [14.726]reset last volume size to 0x17fe8
      Creating dynamic volume UDISK of size 50319360
      [14.819]fill gap start: volume mbr sects 0x7f80
      [25.968]ubi0 warning: ubi_io_read_vid_hdr: bad magic number at PEB 149: 55464d65 instead of 55424921
      [25.977]Volume identifier header dump:
      [25.981]	magic     55464d65
      [25.983]	version   69
      [25.985]	vol_type  70
      [25.987]	copy_flag 68
      [25.989]	compat    68
      [25.991]	vol_id    1145324612
      [25.994]	lnum      1145324612
      [25.997]	data_size 1145566276
      [25.999]	used_ebs  1145324614
      [26.002]	data_pad  1145324612
      [26.005]	sqnum     4919131752989213783
      [26.008]	hdr_crc   754dfc4c
      [26.011]Volume identifier header hexdump:
      [26.014]ubi0 warning: ubi_eba_read_leb: corrupted VID header at PEB 149, LEB 0:0
      [26.022]ubi0 warning: ubi_volume_continue_write: volume 0 on UBI device 0 is corrupt
      [26.029]fill gap end: volume mbr
      [26.033]update partition map
      [26.035]logical area info: 468 258048 last_lba: 235871
      read from corrupted volume 0[26.051]mbr magic error: woftwtuu wanted softw411
      *** ERROR: Can't read MBR header ***
      read from corrupted volume 0[26.073]mbr magic error: woftwtuu wanted softw411
        wxgd2017 LV 5 最后由 编辑
        是的,怎么解?换flash?
          但是我没接串口0,看不到打印信息
            柚木 鉉 LV 9 @wxgd2017 最后由 编辑
            @wxgd2017 没有解决,后面没弄这个了
            • Moved from 代码下载问题专区 by  xiaowenge xiaowenge
