    D1 哪吒开发板 XR829 softap_up 热点没跑起来
    d1 哪吒 热点 wifi xr829
    • U
      uuuuid LV 6 最后由 编辑
      root@TinaLinux:/# softap_up  test 123456789
      Start hostapd test!
      wpa2-psk!
      Start to set softap!
      Message is: OK
      Set softap finished!
      [10155.452495] [STA_WRN] !!! xradio_remove_interface: vif_id=0
      [10157.507181] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=70:f4:4d:76:31:86
      [10157.532142] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=70:f4:4d:76:31:86
      [10157.556032] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
      [10157.590682] netlink: 'hostapd': attribute type 213 has an invalid length.
      Start to start softap!
      SoftAP started successfullyHaving catch sig_chld!
      Message is: OK
      Start softap finished!
      [10158.652122] [STA_WRN] xradio_change_interface: new type=3(2), p2p=0(0)
      [10158.669674] [STA_WRN] !!! xradio_remove_interface: vif_id=0
      [10158.680143] [STA] !!!xradio_vif_setup: id=0, type=3, p2p=0, addr=70:f4:4d:76:31:86
      iptables v1.4.21: can't initialize iptables table `nat': Table does not exist (do you need to insmod?)
      Perhaps iptables or your kernel needs to be upgraded.
      enable data forward failed!
      root@TinaLinux:/#
        看上去是没有iptable?
