    V831 的 Tina 启动没有 Uboot 与 Linux 日志输出,dmesg有输出
      printk的等级已经设置7了
      [302]HELLO! BOOT0 is starting!
      [305]BOOT0 commit : e3b2a9e
      [307]board init start
      [310]set pll start
      [312]set pll end
      [314][pmu]: bus read error
      [316][pmu]: bus read error
      [319]board init ok
      [321]chip id check OK
      [323]DRAM BOOT DRIVE INFO: V0.41
      [326]DRAM CLK = 528 MHz
      [328]DRAM Type = 2 (2:DDR2,3:DDR3)
      [332]DRAMC read ODT  off.
      [334]DRAM ODT off.
      [337]DRAM SIZE =64 M
      [343]DRAM simple test OK.
      [345]rtc standby flag is 0x0, super standby flag is 0x0
      [350]dram size =64
      MESSAGE: [0x0] TEE-CORE: OP-TEE version: sun8iw19p1_v0.6.0-14-gf6954e7 #1 2019年 11月 21日 星期四 01:34:42 UTC arm
      ERROR:   [0x0] TEE-CORE:platform_standby_fdt_parse:126: no pmu node
      ERROR:   [0x0] TEE-CORE:sunxi_twi_parse_from_dt:84: no pmu node
      mount: mounting pstore on /sys/fs/pstore failed: No such file or directory
      mount: mounting /dev/by-name/rootfs_data on /overlay failed: No such file or directory
      Mount Failed: formating /dev/by-name/rootfs_data to ext4 ...
      mke2fs 1.42.12 (29-Aug-2014)
      The file /dev/by-name/rootfs_data does not exist and no size was specified.
      can't run '/bin/mkdir': Read-only file system
      mount: mounting devpts on /dev/pts failed: No such file or directory
      ------run rc.final file-----
      Load mpp modules
      read-only file system detected...done
      Starting network...
      ifconfig: SIOCGIFFLAGS: No such device
      udhcpc: SIOCGIFINDEX: No such device
      Starting telnetd: OK
      enable android usb
      sh: write error: Resource busy
      ------run profile file-----
      root@TinaLinux:/# cat /proc/sys/kernel/printk
       7       7       1       7
        柚木 鉉 LV 9 最后由 YuzukiTsuru 编辑
        使用量产卡刷入Uboot有输出,使用启动卡就不行了
        [303]HELLO! BOOT0 is starting!
        [306]BOOT0 commit : e3b2a9e
        [309]board init start
        [311]set pll start
        [314]set pll end
        [315][pmu]: bus read error
        [318][pmu]: bus read error
        [321]board init ok
        [322]chip id check OK
        [325]DRAM BOOT DRIVE INFO: V0.41
        [328]DRAM CLK = 528 MHz
        [330]DRAM Type = 2 (2:DDR2,3:DDR3)
        [333]DRAMC read ODT  off.
        [336]DRAM ODT off.
        [338]DRAM SIZE =64 M
        [344]DRAM simple test OK.
        [347]rtc standby flag is 0x0, super standby flag is 0x0
        [352]dram size =64
        MESSAGE: [0x0] TEE-CORE: OP-TEE version: sun8iw19p1_v0.6.0-14-gf6954e7 #1 2019. 11. 21. .... 01:34:42 UTC arm
        U-Boot 2018.05-00008-g384031a (Jan 16 2020 - 14:12:41 +0800) Allwinner Technology
        [00.467]CPU:   Allwinner Family
        [00.470]Model: sun8iw19
        I2C:   ready
        [00.474]DRAM:  64 MiB
        [00.477]Relocation Offset is: f9f46000
        [00.498]secure enable bit: 0
        [00.502]pmu_axp152_probe pmic_bus_read fail
        [00.505]pmu_axp2101_probe pmic_bus_read fail
        [00.509]PMU: no found
        [00.511]bmu_axp152_probe pmic_bus_read fail
        [00.515]bmu_axp2101_probe pmic_bus_read fail
        [00.519]BMU: no found
        [00.521]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=132Mhz
        [00.528]gic: sec monitor mode
        [00.530]flash init start
        [00.533]workmode = 17,storage type = 1
        try card 2
        set card number 2
        get card number 2
        [00.540]mmc driver ver uboot2018:2019-12-13 9:48:00
        [00.545]get mem for descripter OK !
        [00.549]get gpio bias fail
        [00.551]get gpio_bias: pc_bias fail
        [00.555]get card2_boot_para:sdc_io_1v8 fail
        [00.561]get card2 disable pin fail
        [00.564]get card2_boot_para:sdc_ex_dly_used fail
        [00.568]get sdc_ex_dly_used -1090671915, use auto tuning sdly
        [00.574]get sdc2 sdc_boot0_sup_1v8 fail.
        [00.578]get card-pwr-gpios faild
        [00.581]get card2_boot_para:time_pwroff_ms:use default time_pwroff:200
        [00.587]Using default timing para
        [00.590]init mmc 2 clock and io
        [00.593]devnum 2, prv 43fb6590, bdesc 42b664ec
        [00.597]SUNXI SD/MMC: 2
        [00.599]==================== work mode: 17 0, sample_mode:0
        [00.605]=============== start mmc_init_boot...
        [00.623]Card did not respond to voltage select!
        [00.627]mmc_init: -95, time 28
        [00.630]mmc_init: mmc init fail, err -95
        MMC init failed
        try emmc fail
        [00.636]NB1 : enter phy init
        [00.639][NI]enter rawnand hardward init..
        [00.643]nand0: get node offset error
        [00.646][NE]init nctri NAND PIORequest error!
        [00.650][NE]rawnand_channel_init channel@0 init nctri fail
        [00.656][NI]rawnand hardward init fail
        [00.659][NI]---rawnand_dump_clock start---
        [00.663][NI]---rawnand_dump_clock end---
        [00.667][NI]---rawnand_dump_gpio_nand start---
        [00.671][NI]---rawnand_dump_gpio_nand end---
        [00.675][NE]nand_physic_init error -1
        [00.678]NB1 : nand phy init fail
        [00.681]Failed to probe nand flash
        try nand fail
        [00.691]unrecognized JEDEC id bytes: ff, ff, ff
        try spinor fail
        initcall sequence 43fab5dc failed at call 4a00a301 (err=-1)
        [310]set pll start
        [312]set pll end
        [319]board init ok
        [334]DRAM ODT off.
        [350]dram size =64
        Load mpp modules
        Starting network...
        Starting telnetd: udhcpc: SIOCGIFINDEX: No such device
        OK
        enable android usb
          修复叻,手残打开了Boot Time Optimization
          # Boot Time Optimization
          # CONFIG_BOOT_TIME_OPTIMIZATION is not set
