    YuzukiXR32 调试日记:SD卡驱动调试
      首先,SDK抄一下EVB的相关文件
      然后把 __PRJ_CONFIG_BOARD 修改到 __PRJ_CONFIG_BOARD := YuzukiXR32
      试试能不能编译编译
      cd XR32SDK/project/example/sd/gcc
      make build
      编译通过~
          "section" :[
              {"id": "0xa5ff5a00", "bin": "boot.bin",       "cert": "null", "flash_offs": "0K",    "sram_offs": "0x00067000", "ep": "0x00067101", "attr": "0x1"},
              {"id": "0xa5fe5a01", "bin": "app.bin",        "cert": "null", "flash_offs": "32K",   "sram_offs": "0x00010000", "ep": "0x00010101", "attr": "0x1"},
              {"id": "0xa5f75a08", "bin": "app_ext.bin",    "cert": "null", "flash_offs": "332K",  "sram_offs": "0x60000000", "ep": "0xffffffff", "attr": "0x1"}
      generate image: xr_system.img
      刷写程序
      运行一下试试看
      sd demo started
      SDC source:24 MHz clock=400 kHz,src:0, n:1, m:14
      __mci_irq_handler,535 raw_int:100 err!
      SDC err, cmd 8,  RTO
      sdc 387 abnormal status: RespErr
      int err 100
      SDC err, cmd 55,  RTO
      int err 100
      int err 100
      int err 100
      int err 100
      sd scan error
      不出所料,用不了,应该是引脚绑定不同,打开板级文件看看
      __xip_rodata
      static const GPIO_PinMuxParam g_pinmux_sd0[BOARD_SD0_DATA_BITS + 2] = {
      	{ GPIO_PORT_A, GPIO_PIN_0,  { GPIOA_P0_F3_SD_CMD,     GPIO_DRIVING_LEVEL_2, GPIO_PULL_UP } },	/* CMD */
      	{ GPIO_PORT_A, GPIO_PIN_2,  { GPIOA_P2_F3_SD_CLK,     GPIO_DRIVING_LEVEL_2, GPIO_PULL_UP } },	/* CLK */
      	{ GPIO_PORT_A, GPIO_PIN_1,  { GPIOA_P1_F3_SD_DATA0,   GPIO_DRIVING_LEVEL_2, GPIO_PULL_UP } },	/* D0 */
      //	{ GPIO_PORT_A, GPIO_PIN_3,  { GPIOA_P3_F3_SD_DATA1,   GPIO_DRIVING_LEVEL_2, GPIO_PULL_UP } },	/* D1 */
      //	{ GPIO_PORT_A, GPIO_PIN_4,  { GPIOA_P4_F3_SD_DATA2,   GPIO_DRIVING_LEVEL_2, GPIO_PULL_UP } },	/* D2 */
      //	{ GPIO_PORT_A, GPIO_PIN_5,  { GPIOA_P5_F3_SD_DATA3,   GPIO_DRIVING_LEVEL_2, GPIO_PULL_UP } },	/* D3 */
      果然,绑定的脚是PA的SD脚位,参照YuzukiXR32的电路图,应该是使用PB驱动SDIO才对。
      那就修改一下
      __xip_rodata
      	{ GPIO_PORT_B, GPIO_PIN_4,  { GPIOB_P4_F3_SD_CMD, GPIO_DRIVING_LEVEL_2, GPIO_PULL_UP } },	/* CMD */
      	{ GPIO_PORT_B, GPIO_PIN_7,  { GPIOB_P7_F3_SD_CLK,  GPIO_DRIVING_LEVEL_2, GPIO_PULL_UP } },	/* CLK */
      	{ GPIO_PORT_B, GPIO_PIN_5,  { GPIOB_P5_F3_SD_DATA0, GPIO_DRIVING_LEVEL_2, GPIO_PULL_UP } },	/* D0 */
      成功运行
      sd demo started
      SDC source:192 MHz clock=48000 kHz,src:1000000, n:0, m:1
      write "hello word!" to sd card
      read data: hello word!
      sd demo over
      • Moved from 爱搞机专区 by  xiaowenge xiaowenge
