    ubuntu 20.04 编译MQ-Dual Longan SDK
      lyphotoes LV 4 最后由 编辑
      安装编译需要的依赖软件包
      除了 gcc,ncurse,bison,autoconf,wget,patch,texinfo,zlib,dos2unix 之外需要安装如下:
      sudo apt-get install git
      sudo apt-get install gnupg
      sudo apt-get install flex
      sudo apt-get install bison
      sudo apt-get install gperf
      sudo apt-get install build-essential
      sudo apt-get install zip
      sudo apt-get install curl
      sudo apt-get install libc6-dev
      sudo apt-get install libncurses5-dev:i386
      sudo apt-get install x11proto-core-dev
      sudo apt-get install libx11-dev:i386
      sudo apt-get install libreadline6-dev:i386
      sudo apt-get install libgl1-mesa-glx:i386
      sudo apt-get install libgl1-mesa-dev
      sudo apt-get install g++-multilib
      sudo apt-get install mingw32
      sudo apt-get install tofrodos
      sudo apt-get install python-markdown
      sudo apt-get install libxml2-utils
      sudo apt-get install xsltproc
      sudo apt-get install zlib1g-dev:i386
      sudo apt-get install gawk
      sudo dpkg-reconfigure dash 选择no
      sudo apt-get install libgl1-mesa-dev:i386
      sudo apt install u-boot-tools
      参照官方文档《T113_Longan_Linux_SDK开发环境配置手册.pdf》进行编译主要差异如下
      1. 增加这一句 sudo apt-get install libgl1-mesa-dev:i386 同时,最后有一条ln -s 没有照做。
      2. 编译过程遇到报错,具体看下面的参考文档一节
      3. "mkimage" command not found - U-Boot images will not be built ---> sudo apt install u-boot-tools
      编译过程如下:
      source ./build/envsetup.sh
      ./build.sh
      media/qotone/Dev/SW/sdk/t113-longan/platform/framework/auto/kernel/xr829/Makefile:19: CROSS_COMPILE: arm-linux-gnueabi-
        Building modules, stage 2.
        MODPOST 1 modules
        CC [M]  /media/qotone/Dev/SW/sdk/t113-longan/platform/framework/auto/kernel/xr829/xr829.mod.o
        LD [M]  /media/qotone/Dev/SW/sdk/t113-longan/platform/framework/auto/kernel/xr829/xr829.ko
      make[1]: Leaving directory '/media/qotone/Dev/SW/sdk/t113-longan/out/kernel/build'
      '/media/qotone/Dev/SW/sdk/t113-longan/platform/framework/auto/kernel/xr829/xr829.ko' -> '/media/qotone/Dev/SW/sdk/t113-longan/platform/../out/t113/evb1_auto/longan/buildroot/target/lib/modules/5.4.61/xr829.ko'
      PARTITION_FEX=/media/qotone/Dev/SW/sdk/t113-longan/device/config/chips/t113/configs/evb1_auto/longan/sys_partition.fex
      ROOTFS_FEX_LINE=64
      ROOTFS_FEX_STR=    size         = 2097152
      ROOTFS_FEX_SIZE= 2097152
      EXT4_SIZE=1073741824(1073741824/1024/1024)
      /media/qotone/Dev/SW/sdk/t113-longan/device/config/chips/t113/configs/evb1_auto/longan/sys_partition.fex rootfs.fex size is  2097152
      EXT4_SIZE= 2097152*512=1073741824
      Creating filesystem with parameters:
          Block size: 4096
          Blocks per group: 32768
          Inodes per group: 8192
          Inode size: 256
          Journal blocks: 4096
          Label:
          Blocks: 262144
          Block groups: 8
          Reserved blocks: 0
          Reserved block group size: 63
      Created filesystem with 7384/65536 inodes and 54559/262144 blocks
      /media/qotone/Dev/SW/sdk/t113-longan/build/bin/make_ext4fs -s -l 1073741824 /media/qotone/Dev/SW/sdk/t113-longan/out/t113/evb1_auto/longan/rootfs.ext4  /media/qotone/Dev/SW/sdk/t113-longan/out/t113/evb1_auto/longan/buildroot/target
      INFO: pack rootfs ok ...
      INFO: build lichee OK.
      /build.sh pack
      ACTION List: mkpack ;========
      Execute command: mkpack
      INFO: packing firmware ...
      INFO: Use BIN_PATH: /media/qotone/Dev/SW/sdk/t113-longan/device/config/chips/t113/bin
      copying tools file
      copying configs file
      copying product configs file
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/aultls32.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/aultools.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/boot_package.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/boot_package.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/boot_package_nor.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/cardscript.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/cardscript_secure.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/cardtool.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/diskfs.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/dragon_toc.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/env-recovery.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/env.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/env_ab.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/env_burn.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/env_dragon.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/env_nor.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/esm.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/image.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/image_crashdump.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/image_linux.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/image_nor.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/parameter.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/split_xxxx.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/sunxi.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/sw-subimgs-ab-rdiff.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/sw-subimgs-ab.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/sw-subimgs-recovery.cfg
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/sys_config.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/sys_partition-recovery.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/sys_partition.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/sys_partition_ab.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/sys_partition_dump.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/sys_partition_nor.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/sys_partition_private.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/sysrecovery.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/toc0.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/toc1.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/usbtool.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/usbtool_crash.fex
      /media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/usbtool_test.fex
      copying boot resource
      copying boot file
      '/media/qotone/Dev/SW/sdk/t113-longan/device/config/chips/t113/bin/boot0_nand_sun8iw20p1.bin' -> '/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/boot0_nand.fex'
      '/media/qotone/Dev/SW/sdk/t113-longan/device/config/chips/t113/bin/boot0_sdcard_sun8iw20p1.bin' -> '/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/boot0_sdcard.fex'
      '/media/qotone/Dev/SW/sdk/t113-longan/device/config/chips/t113/bin/boot0_spinor_sun8iw20p1.bin' -> '/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/boot0_spinor.fex'
      '/media/qotone/Dev/SW/sdk/t113-longan/device/config/chips/t113/bin/fes1_sun8iw20p1.bin' -> '/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/fes1.fex'
      '/media/qotone/Dev/SW/sdk/t113-longan/device/config/chips/t113/bin/u-boot-sun8iw20p1.bin' -> '/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/u-boot.fex'
      '/media/qotone/Dev/SW/sdk/t113-longan/device/config/chips/t113/bin/dsp0.bin' -> '/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/dsp0.fex'
      '/media/qotone/Dev/SW/sdk/t113-longan/device/config/chips/t113/bin/optee_sun8iw20p1.bin' -> '/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/optee.fex'
      '/media/qotone/Dev/SW/sdk/t113-longan/device/config/chips/t113//bin/dsp0.bin' -> '/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/dsp0.fex'
      copying boot file 2.0
      '/media/qotone/Dev/SW/sdk/t113-longan/out/t113/evb1_auto/longan/boot0_nand_sun8iw20p1.bin' -> '/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/boot0_nand.fex'
      '/media/qotone/Dev/SW/sdk/t113-longan/out/t113/evb1_auto/longan/boot0_sdcard_sun8iw20p1.bin' -> '/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/boot0_sdcard.fex'
      '/media/qotone/Dev/SW/sdk/t113-longan/out/t113/evb1_auto/longan/boot0_spinor_sun8iw20p1.bin' -> '/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/boot0_spinor.fex'
      '/media/qotone/Dev/SW/sdk/t113-longan/out/t113/evb1_auto/longan/fes1_sun8iw20p1.bin' -> '/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/fes1.fex'
      '/media/qotone/Dev/SW/sdk/t113-longan/out/t113/evb1_auto/longan/sboot_sun8iw20p1.bin' -> '/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/sboot.bin'
      '/media/qotone/Dev/SW/sdk/t113-longan/out/t113/evb1_auto/longan/u-boot-sun8iw20p1.bin' -> '/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/u-boot.fex'
      copying additional files
      /media/qotone/Dev/SW/sdk/t113-longan/out/t113/evb1_auto/longan/.sunxi.dts: Warning (alias_paths): /aliases: aliases property name must include only lowercase and '-'
      dbg1 pack
      /media/qotone/Dev/SW/sdk/t113-longan/out/t113/evb1_auto/longan/dtc  -W no-unit_address_vs_reg -W no-simple_bus_reg -W no-unique_unit_address -W no-cooling_device_property -W no-unit_address_format -I dtb -O dts -o /media/qotone/Dev/SW/sdk/t113-longan/out/t113/evb1_auto/longan/.sunxi.dts /media/qotone/Dev/SW/sdk/t113-longan/out/t113/evb1_auto/longan/sunxi.dtbs
      update optee
      sboot file Path=/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/sboot.bin
      script file Path=/media/qotone/Dev/SW/sdk/t113-longan/out/pack_out/sys_config.bin
      extd_head.select_mode:0
      magic:$�� ��
      script update sboot ok
      pack boot package
      content_count=3
      --redundant env data size 0x20000---
      packing for linux
      normal
      this is not a partition key
      gpt_head->header_crc32 = 0x3e898e5f
      GPT----part num 8---
      gpt_entry: 128
      gpt_header: 92
      GPT:boot-resource: 8000          10685
      GPT:env         : 10686         10e85
      GPT:env-redund  : 10e86         11685
      GPT:boot        : 11686         1a005
      GPT:rootfs      : 1a006         21a005
      GPT:dsp0        : 21a006        21a805
      GPT:private     : 21a806        222805
      GPT:UDISK       : 222806        222815
      update gpt file ok
      update mbr file ok
      /media/qotone/Dev/SW/sdk/t113-longan/tools/pack/pctools/linux/eDragonEx/
      Begin Parse sys_partion.fex
      FilePath: boot-resource.fex
      FileLength=dad400Add partion env.fex ENV_FEX000000000
      FilePath: env.fex
      FileLength=20000Add partion env.fex ENV_FEX000000000
      FilePath: env.fex
      FilePath: boot.fex
      FileLength=10db000Add partion rootfs.fex ROOTFS_FEX000000
      FilePath: rootfs.fex
      FileLength=c636270Add partion dsp0.fex DSP0_FEX00000000
      Add partion very dsp0.fex DSP0_FEX00000000
      FilePath: dsp0.fex
      FileLength=3fc78sys_config.fex Len: 0x2355
      board.fex Len: 0x400
      config.fex Len: 0x1400
      split_xxxx.fex Len: 0x200
      sys_partition.fex Len: 0xc21
      sunxi.fex Len: 0xe800
      boot0_nand.fex Len: 0xc000
      boot0_sdcard.fex Len: 0xc000
      u-boot.fex Len: 0xec000
      u-boot-crash.fex Len: 0x25
      toc1.fex Len: 0x8
      toc0.fex Len: 0x8
      fes1.fex Len: 0x4bc0
      boot_package.fex Len: 0x140000
      usbtool.fex Len: 0x2d200
      usbtool_crash.fex Len: 0x1ec00
      aultools.fex Len: 0x288b7
      aultls32.fex Len: 0x2511f
      cardtool.fex Len: 0x11e00
      cardscript.fex Len: 0x6de
      sunxi_gpt.fex Len: 0x2000
      sunxi_mbr.fex Len: 0x10000
      dlinfo.fex Len: 0x4000
      arisc.fex Len: 0x6
      vmlinux.fex Len: 0x36ba88b
      boot-resource.fex Len: 0xdad400
      Vboot-resource.fex Len: 0x4
      env.fex Len: 0x20000
      Venv.fex Len: 0x4
      Venv.fex Len: 0x4
      boot.fex Len: 0x10db000
      Vboot.fex Len: 0x4
      rootfs.fex Len: 0xc636270
      Vrootfs.fex Len: 0x4
      dsp0.fex Len: 0x3fc78
      Vdsp0.fex Len: 0x4
      BuildImg 0
      size:288M  /media/qotone/Dev/SW/sdk/t113-longan/out/t113_linux_evb1_auto_uart0.img
      pack finish
      使用过程中遇到的问题
      1. 使用官方windows烧录工具烧写tf卡默认是选择的量产卡,应该选择启动卡
      参考文档
      • gdbusauth.c:1302:11: error: ‘%s’ directive argument is null
      • gawk编译ibgpg-error-1.33出错 具体修改位置还是最好看gnu官方的: 比较
