    【FAQ】全志D1芯片 如何在tina使用tplayerdemo 进行rtsp拉流说明?
    d1 f133 faq 技术支持
    4781
      make menuconfig 选项rtsp
      Allwinner
       libcedarx....................................... libcedarx  for allwinner (PACKAGE_libcedarx [=y])
        Select cedarx configuration options
         [*] Support rtsp stream
      打上附件的 "support_rtsp.patch"补丁(主要是开启rtsp依赖的模块, 后续会加宏配置好,只选rtsp就好) support_rtsp.patch
      diff --git a/allwinner/tina_multimedia/libcedarx/libcore/parser/Makefile.am b/allwinner/tina_multimedia/libcedarx/libcore/parser/Makefile.am
      index f33af3743..5d1aeaf0c 100755
      --- a/allwinner/tina_multimedia/libcedarx/libcore/parser/Makefile.am
      +++ b/allwinner/tina_multimedia/libcedarx/libcore/parser/Makefile.am
      @@ -72,4 +72,7 @@ if PLS_PARSER_ENABLE
       SUBDIRS += pls
       endif
      -SUBDIRS += base
      \ No newline at end of file
      +SUBDIRS += remux
      +SUBDIRS += base
      diff --git a/allwinner/tina_multimedia/libcedarx/libcore/parser/base/CdxParser.c b/allwinner/tina_multimedia/libcedarx/libcore/parser/base/CdxParser.c
      index 44305f3c6..a24273fbc 100755
      --- a/allwinner/tina_multimedia/libcedarx/libcore/parser/base/CdxParser.c
      +++ b/allwinner/tina_multimedia/libcedarx/libcore/parser/base/CdxParser.c
      @@ -50,7 +50,7 @@ static struct ParserUriKeyInfoS asfKeyInfo =
      -#if 0
      +#if 1
       extern CdxParserCreatorT remuxParserCtor;
       static struct ParserUriKeyInfoS remuxKeyInfo =
      @@ -460,7 +460,7 @@ void AwParserInit(void)
           AwParserRegister(&movParserCtor, CDX_PARSER_MOV, &movKeyInfo);
      -#if 0
      +#if 1
           AwParserRegister(&remuxParserCtor, CDX_PARSER_REMUX, &remuxKeyInfo);
      diff --git a/allwinner/tina_multimedia/libcedarx/libcore/parser/base/Makefile.am b/allwinner/tina_multimedia/libcedarx/libcore/parser/base/Makefile.am
      index 9dbb73590..86174f94e 100755
      --- a/allwinner/tina_multimedia/libcedarx/libcore/parser/base/Makefile.am
      +++ b/allwinner/tina_multimedia/libcedarx/libcore/parser/base/Makefile.am
      @@ -65,6 +65,8 @@ libcdx_parser_la_LIBADD += $(top_srcdir)/libcore/parser/avi/libcdx_avi_parser.la
       libcdx_parser_la_CFLAGS += -DAVI_PARSER_ENABLE
       endif
      +libcdx_parser_la_LIBADD += $(top_srcdir)/libcore/parser/remux/libcdx_remux_parser.la
       if TS_PARSER_ENABLE
       libcdx_parser_la_LIBADD += $(top_srcdir)/libcore/parser/ts/libcdx_ts_parser.la
       libcdx_parser_la_CFLAGS += -DTS_PARSER_ENABLE
      使用ffmpeg 进行推流
      sudo ffmpeg -stream_loop -1 -i 720x480.mp4 -vcodec copy -acodec aac -rtsp_transport tcp -f rtsp rtsp://1.116.32.155/media/test.mp4
      拉流
      4.1 wifi联网
      4.2 tplayerdemo rtsp://1.116.32.155/media/test.mp4
      rtsp 播放效果:
        memory LV 7 最后由 whycan 编辑
        小白请教一下,这个怎么自己搭建呢?
          Zhice.Yang LV 4 最后由 编辑
          root@TinaLinux:/# tplayerdemo rtsp://192.168.42.103
          WARNING: awplayer <cdx_log_set_level:30>: cdx Set log level to 6
          INFO : cedarc CedarPluginVDInit:79: register h264 decoder success!
          INFO : cedarc CedarPluginVDInit:84: register mjpeg decoder success!
          INFO : cedarc CedarPluginVDInit:86: register mpeg2 decoder success!
          INFO : cedarc CedarPluginVDInit:92: register mpeg4dx decoder success!
          INFO : cedarc CedarPluginVDInit:79: register mpeg4H263 decoder success!
          INFO : cedarc CedarPluginVDInit:90: register mpeg4Normal decoder success!
          INFO : cedarc CedarPluginVDInit:74: register vc1 decoder success!
          INFO : cedarc CedarPluginVDInit:85: register h265 decoder success!
          • This program implements a simple player, you can type commands to control the player.
          • To show what commands supported, type 'help'.
          dd: writing '/dev/fb0': No space left on device
          9601+0 records in
          9600+0 records out
          argc = 2
          argv[0] = tplayerdemo
          argv[1] = rtsp://192.168.42.103
          may be is one file:cut down suffix is:.103
          0:can not play this file:tplayerdemo
          destroy all tplayer
          • Quit the program, goodbye!
          貌似都不能识别RTSP地址
          • Q
            quanzhiddd LV 5 最后由 编辑
            • Referenced by  C chenyinchang
