    自制V831小相机适配 i80 LCD 显示屏
      柚木 鉉 LV 9 最后由 YuzukiTsuru 编辑
      V831没有RGB也没有MIPI,正好手上有几片i80 MCU屏幕可以用(320*480 3.5寸的,15块钱一片)
      电路部分
      屏幕部分:
      主控部分:
      没啥好说的,照着Sipeed的抄就行了
      配置设备树
      lcd0: lcd0@01c0c000 {
      			lcd_used            = <1>;
      			lcd_driver_name     = "ili9481";
      			lcd_x               = <320>;
      			lcd_y               = <480>;
      			lcd_width           = <108>;
      			lcd_height          = <64>;
      			lcd_dclk_freq       = <5>;
      			lcd_pwm_used        = <0>;
      			lcd_hbp             = <20>;
      			lcd_ht              = <382>;
      			lcd_hspw            = <2>;
      			lcd_vbp             = <2>; // 320
      			lcd_vt              = <486>; // 320
      			lcd_vspw            = <2>;
      			lcd_if              = <1>;
      			lcd_frm             = <2>;
      			lcd_cpu_mode        = <1>;
      			lcd_cpu_te          = <0>;
      			lcd_cpu_if	        = <14>;
      			lcdgamma4iep        = <22>;
      			lcd_gamma_en        = <0>;
      			lcd_cmap_en         = <0>;
      			lcd_bright_curve_en = <0>;
      			lcd_rb_swap         = <0>;
      			lcd_gpio_0 = <&pio PH 5 1 0 3 0>; /* rst */
      			lcd_gpio_1 = <&pio PD 21 1 0 3 0>; /* cs */
      			lcd_bl_en = <&pio PH 6 1 0 3 1>;
      			pinctrl-0 = <&rgb8_pins_a>;
      			pinctrl-1 = <&rgb8_pins_b>;
      因为这里用的是Kernel刷屏,所以就不配uboot的了
      驱动
      然后找大佬鼠嫖驱动,放到 lichee/linux-4.9/drivers/video/fbdev/sunxi/disp2/disp/lcd/文件夹下。
      编辑 lichee/linux-4.9/drivers/video/fbdev/sunxi/disp2/disp/lcd/panels.c,找一个顺眼的地方加一下配置。
      #ifdef CONFIG_LCD_SUPPORT_ILI9481
      	&ili9481_panel,
      编辑lichee/linux-4.9/drivers/video/fbdev/sunxi/disp2/disp/lcd/panels.h,找一个顺眼的地方加一下配置。
      extern struct __lcd_panel ili9481_panel;
      编辑lichee/linux-4.9/drivers/video/fbdev/sunxi/disp2/disp/lcd/Kconfig,找一个顺眼的地方加一下配置。
      config LCD_SUPPORT_ILI9481
      	bool "LCD support ili9481 panel"
      	default n
      	---help---
      		If you want to support ili9481 panel for display driver, select it.
      编辑 lichee/linux-4.9/drivers/video/fbdev/sunxi/disp2/disp/Makefile,找一个顺眼的地方加一下配置。
      disp-$(CONFIG_LCD_SUPPORT_ILI9481) += lcd/ili9481.o
      再打开 m kernel_menuconfig
      Device Drivers  --->
      	Graphics support  --->
      		Frame buffer Devices  --->
      			Video support for sunxi  --->
      				LCD panels select  --->
      					 [*] LCD support ili9481 panel
      保存,编译kernel打包就好了。
      启动系统
      刷卡,启动系统,可以看到屏幕背光已经亮了。
      测试一下
      echo 1 > sys/class/disp/disp/attr/colorbar
      驱动和配置已经上传Github,自取
        跟着楼主认真学习!
