    请教T113运行主频的设置问题
      L13819506056 LV 5 最后由 YuzukiTsuru 编辑
      使用芒果派小麻雀板的T113做测试,CPU运行主频高于800MHz,切换时就跑飞。测试代码如下,请求大佬们支招:
      #define CPU_RUN_FREQ           1200000000
      #define SYS_XTOSC_CLK            24000000
      static void set_pll_cpux_axi(void)
      		uint32_t val;
        int n =  (CPU_RUN_FREQ / SYS_XTOSC_CLK -1 ) & 0xFF;
      	/* Switch to PLL_PERI(1X) clock while changing cpu pll (600MHz) */
      	CCU_CPU_AXI_CFG  =  (4<<24)  ;
        sdelay(10000);
      	/*  cpu pll rate = 24000000 * n      */
        val = PLL_CPU_CTRL_REG & (~((0xff << 8) | (1 << 27)));
       	val |= (n << 8);
      	PLL_CPU_CTRL_REG  = val;
      	PLL_CPU_CTRL_REG &= ~(1 << 29);
        sdelay(5);
        PLL_CPU_CTRL_REG |= (1 << 29);
        sdelay(1000);
        while( (PLL_CPU_CTRL_REG &(1 << 28)) == 0 );  /* wait for pll lock */
        PLL_CPU_CTRL_REG |= (1 << 27);                 /* open pll out gate */
        sdelay(10000);
      /* Switch clock source */
      	CCU_CPU_AXI_CFG  =    (3 << 24);
        sdelay(10000);
      这一句CCU_CPU_AXI_CFG = (3 << 24)一执行,CPU就跑飞了.
      请求支援。期待中。
