    T113-S3 的SMHC1连接SD-NAND问题:
    4817
      L13819506056 LV 5 最后由 编辑
      T113-s3的SMHC1接一片SD NAND ,但在读取数据时,传输描述符配置都正确的情况下。iDMA始终报描述符不可用中断。
      status_t sd_mmc_set_dma_table_config(v3x_sd_mmc_t *base,
      sd_mmc_dma_config_t *dma_config,
      sd_mmc_data_t *data_config,
      uint32_t flags)
      base->DMAC = 1;//IMAC 复位
      const uint32_t *start_address;
      uint32_t entries;
      uint32_t i, dma_buffer_len = 0U;
      sd_mmc_dma_descriptor_t *dma_entry_address;
      uint32_t data_bytes = data_config->block_size * data_config->block_count;
      const uint32_t *data = (data_config->rx_data == NULL) ? data_config->tx_data : data_config->rx_data;
      /* check DMA data buffer address align or not */
      if ( ((uint32_t)data & 0x03) != 0U )
          return STA_DMA_DATA_ADDR_NOT_ALIGN;
      * Add non aligned access support ,user need make sure your buffer size is big
      * enough to hold the data,in other words,user need make sure the buffer size
      * is 4 byte aligned
      data_bytes = (data_bytes + 3) & (~3);
      start_address = data;
      base->GCTL |= (SDXC_FIFO_RESET | SDXC_DMA_RESET | SDXC_DMA_ENABLE_BIT);/* reset fifo & dma*/
      /* Check if ADMA descriptor's number is enough. */
      if ((data_bytes % MMC_SD_DMA_DESCRIPTOR_MAX_LENGTH_PER_ENTRY) == 0U)
         entries = data_bytes / MMC_SD_DMA_DESCRIPTOR_MAX_LENGTH_PER_ENTRY;
         entries = ((data_bytes / MMC_SD_DMA_DESCRIPTOR_MAX_LENGTH_PER_ENTRY) + 1U);
      if (entries > ((dma_config->dma_table_words * sizeof(uint32_t)) / sizeof(sd_mmc_dma_descriptor_t)))
         /*如果超过预置(1个)数量,应该支持动态分配描述符表 */
         if( STA_SUCCESS != sd_mmc_malloc_dma_descriptor( dma_config,entries))
            return STA_MEM_ERROR;
      dma_entry_address = (sd_mmc_dma_descriptor_t *)(dma_config->dma_table);
      for (i = 0U; i < entries; i++)
         if (data_bytes > MMC_SD_DMA_DESCRIPTOR_MAX_LENGTH_PER_ENTRY)
           dma_buffer_len = MMC_SD_DMA_DESCRIPTOR_MAX_LENGTH_PER_ENTRY;
           data_bytes -= dma_buffer_len;
            dma_buffer_len = data_bytes;
         dma_entry_address[i].buf_addr_ptr = (uint32_t)start_address;
         dma_entry_address[i].buf_size = dma_buffer_len  ;
         dma_entry_address[i].config   =  SD_MMC_DESCRIPTOR_TC_INT_DIS
                                         | SD_MMC_DESCRIPTOR_CHAIM_MOD
                                         | SD_MMC_DESCRIPTOR_OWN_FLAG;
         dma_entry_address[i].buf_addr_next =  (uint32_t)&dma_entry_address[i + 1];
         start_address += (dma_buffer_len / sizeof(uint32_t));/*32bit 偏移*/
      /* set the end bit */
      dma_entry_address[0].config             =   SD_MMC_DESCRIPTOR_FIRST_FLAG
      uint32_t config = dma_entry_address[i - 1U].config & (~(SD_MMC_DESCRIPTOR_TC_INT_DIS
      dma_entry_address[i - 1U].config = config | SD_MMC_DESCRIPTOR_LAST_FLAG;// \
                                                           // | (1 << 5); /* end of ring */
      dma_entry_address[i - 1U].buf_addr_next = 0;
       base->DMAC = (1 << 1) | (1 << 7);
      /* enable dma interrupt */
      base->IDST = 0x3F; /*清除DMA中断状态 */
      /*config the burst length */
      base->FWLR = (burst_len_16 << 28) | (0x0f << 16) | 240;//0x10;
      /*允许dma中断 */
      if(data_config->rx_data)
        /*DMA 接收利用 DMA传输完毕产生中断*/
        base->IDIE  = (   SDXC_IDMAC_RECEIVE_INTERRUPT
                      | SDXC_IDMAC_FATAL_BUS_ERROR
                      | SDXC_IDMAC_DESTINATION_INVALID
                      | SDXC_IDMAC_CARD_ERROR_SUM);
        base->IMKR &=  ~(1 << 3);
      else if(data_config->tx_data)
        /*DMA 传输利用 MCI传输完毕产生中断*/
        base->IDIE  = (  SDXC_IDMAC_FATAL_BUS_ERROR
                       | SDXC_IDMAC_TRANSMIT_INTERRUPT
        base->IMKR |= (1 << 3);
         base->IDIE = 0;
      base->DLBA = (uint32_t)(dma_config->dma_table);
      /* enable DMA */
      sd_mmc_enable_dma(base);
      /*动态分配的内存 ,需要刷新cache */
      L1C_CleanDataCacheRange(dma_config->dma_table,dma_config->dma_table_words * entries);
      return STA_SUCCESS;
      上面说使用的描述符的内存空间是位于非cache段的内存中。
      从内存数据看配置都是正确的,数据已经从sd nsnd 传输到fifo中了,而 IDMA总是报描述符不可用,致使数据不能从fifo读取到内存中。 大家帮我看看问题可能在哪里。
        原来是这样。总是有意外的惊喜。
        J 1 条回复 最后回复 回复 引用 分享 0
          jordonwu LV 6 @L13819506056 最后由 编辑
          @l13819506056 在 T113-S3 的SMHC1连接SD-NAND问题: 中说:
          总是有意外的惊喜。
          这是什么板子?4个网口?
            L13819506056 LV 5 @jordonwu 最后由 编辑
            @jordonwu 工控板,两个网口,其余两座是CAN +422+IO 口。
              SHVISLCD LV 2 最后由 编辑
              这块板调试成功了吗? CAN接口调通了吗? 这版你们是自用? 还是对外卖?
