    t113 i2c 总线时钟调节不起作用
    8618
    • E
      efancier LV 6 最后由 YuzukiTsuru 编辑
      mangopi dual 的板子,调试触摸屏的时候发现tw2 i2c 调节不生效,无论输入400K还是100K,实际都以1.2M左右运行,查看 /sys目录下和 /proc 目录下i2c 节点的频率都已经是修改过的频率了,请问是否是i2c总线驱动的问题? 使用的是buidlroot
      设备树:
      &twi2 {
      clock-frequency = <400000>;
      pinctrl-0 = <&twi2_pins_a>;
      pinctrl-1 = <&twi2_pins_b>;
      twi_drv_used = <1>;
      dmas = <&dma 45>, <&dma 45>;
      dma-names = "tx", "rx";
      ctp@14 {
      compatible = "allwinner,goodix,gt911";
      device_type = "ctp";
      reg = <0x14>;
      status = "disabled";
      ctp_name = "gt9xxnew_ts";
      ctp_twi_id = <0x2>;
      ctp_twi_addr = <0x14>;
      ctp_screen_max_x = <0x320>;
      ctp_screen_max_y = <0x1e0>;
      ctp_revert_x_flag = <0x0>;
      ctp_revert_y_flag = <0x0>;
      ctp_int_port = <&pio PB 2 GPIO_ACTIVE_HIGH>;
      ctp_wakeup = <&pio PB 3 GPIO_ACTIVE_HIGH>;
      /ctp-supply = <&reg_aldo2>;/
      /ctp_power_ldo = <&reg_aldo2>;/
      /ctp_power_ldo_vol = <3300>;/
      • E
        追踪到驱动程序里面的寄存器读写了,发现这句话
        writel(reg_val, i2c->base_addr + reg_clk);
        无论往寄存器里面写什么值,i2c 输出时钟频率都不变,可能是写入的值需要符合一定的组合,或者寄存器地址根本就不对?还是硬件有Bug? 原厂的技术工程师能否帮忙看一下
        static void sunxi_i2c_clk_write_reg(struct sunxi_i2c *i2c, unsigned int reg_clk,
        		unsigned int sclk_freq,
        		unsigned char clk_m, unsigned char clk_n,
        		unsigned int mask_clk_m, unsigned int mask_clk_n)
        	unsigned int reg_val = readl(i2c->base_addr + reg_clk);
        #if IS_ENABLED(CONFIG_ARCH_SUN50IW10)
        	unsigned int duty;
        	dev_dbg(i2c->dev, "reg_clk = 0x%x, clk_m = %u, clk_n = %u,"
        		"mask_clk_m = %x, mask_clk_n = %x\n",
        		reg_clk, clk_m, clk_n, mask_clk_m, mask_clk_n);
        	if (reg_clk == TWI_DRIVER_BUSC) {
        		reg_val &= ~(mask_clk_m | mask_clk_n);
        		reg_val |= ((clk_m | (clk_n << 4)) << 8);
        		duty = TWI_DRV_CLK_DUTY;
        		if (sclk_freq > STANDDARD_FREQ)
        			reg_val |= duty;
        			reg_val &= ~duty;
        		dev_dbg(i2c->dev, "reg: 0x%x value: 0x%x\n",
        			reg_clk, readl(i2c->base_addr + reg_clk));
        		printk("\n clk reg val:%d - reg:%d, m -n %d-%d",reg_val,i2c->base_addr + reg_clk, clk_m, clk_n);
        	} else {
        		reg_val |= ((clk_m  << 3) | clk_n);
        		duty = TWI_CLK_DUTY;
        			reg_val |= duty;
        			reg_val &= ~duty;
        D 1 条回复 最后回复 回复 引用 分享 0
          duowei1987 LV 3 @efancier 最后由 编辑
          @efancier 在longan下确实是这种情况,而在tina下i2c就是正常的,我也不清楚原因
          S 1 条回复 最后回复 回复 引用 分享 0
            Vogelweide LV 6 @duowei1987 最后由 编辑
            @duowei1987 longan sdk是不是有问题,我用PD20 PD21都调不出来I2C。。。。
            E 1 条回复 最后回复 回复 引用 分享 0
            • E
              efancier LV 6 @suitjune 最后由 编辑
              @duowei1987, 多谢确认这个问题,这个坑也太大了,我试试Tina的 I2c 总线驱动看能不能解决这个问题,现在的方案是用GPIO模拟,速度能到100K左右,暂时对付着驱动GT触摸屏
                Vogelweide LV 6 最后由 编辑
                我又试了试,可以400K I2C频率啊,longan sdk.
                • E
                  @suitjune ,是buildroot编译的吗?
                    Vogelweide LV 6 @efancier 最后由 编辑
                    @efancier 啥意思?longan sdk不都有自己的SDK的内核?你是指内核是buildroot编译出来的?
                    • E
                      @suitjune , 用的这个构建的:
                      https://github.com/YuzukiHD/Buildroot-YuzukiSBC
                        @efancier 将longan的i2c-sunxi.c和i2c-sunxi.h更换为tina linux的文件就可以了,测试过i2c正常
                        E 1 条回复 最后回复 回复 引用 分享 1
                        • E
                          efancier LV 6 @duowei1987 最后由 编辑
                          @duowei1987 ,谢谢!我对比下看看这两个版本的文件有什么不一样。
