    分析Tina打包流程,并在buildroot上来实现打包生成tina镜像,支持PhoenixSuit烧写。
    6
    7
    9007
    • baiwen
      100ask LV 6 最后由 编辑
      • 镜像文件 tina_d1-h-nezha_uart0.img 欢迎烧写体验。
      步骤简述
      首先记录下官方 tina-sdk 打包的log输出。
      book@virtual-machine:~/D1s-Core/tina-d1-h$ pack
      PACK_CHIP         sun20iw1p1
      PACK_PLATFORM     tina
      PACK_BOARD        d1-h-nezha
      PACK_KERN
      PACK_DEBUG        uart0
      PACK_SIG          none
      PACK_SECURE       none
      PACK_MODE         normal
      PACK_FUNC         android
      PACK_PROGRAMMER   none
      PACK_TAR_IMAGE    none
      PACK_TOPDIR       /home/book/D1s-Core/tina-d1-h
      No kernel param, parse it from d1-h
      copying tools file
      copying configs file
      storage_type value is 5
      rm /home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/sys_partition_nor.fex
      rm /home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/image_nor.cfg
      copying boot resource
      LZMA 4.65 : Igor Pavlov : Public domain : 2009-02-03
      copying boot file
      make user resource for : /home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/sys_partition.fex
      handle partition user-res
      no user resource partitions
      APP_PART_DOWNLOAD_FILE = /home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/app.fex
      Need size of filesystem
      no data resource partitions
      don't build dtbo ...
      create sys_partiton.fex +++++++++++++++++++++++++++++++++++++++++++++++++++++4
      argc = 2
      input name sys_partition.fex
      Script 1 source file Path=/home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/sys_partition.fex
      Script 1 bin file Path=/home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/sys_partition.bin
      update_fdt: num 1752 randto1k
      parser 1 file ok
      create sys_partiton.fex+++++++++++++++++++++++++++++++++++++++++++++++++++++5
      update_chip
      pack boot package
      content_count=3
      packing for tina linux
      normal
      update mbr use 4++++++++++++++++++++++
      mbr count = 4
      partitation file Path=/home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/sys_partition.bin
      mbr_name file Path=/home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/sunxi_mbr.fex
      download_name file Path=/home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/dlinfo.fex
      mbr size = 252
      mbr magic softw411
      disk name=boot-resource
      disk name=env
      disk name=env-redund
      disk name=boot
      disk name=rootfs
      disk name=dsp0
      disk name=recovery
      this is not a partition key
      update_for_part_info 0
      crc 0 = 4c7bc2df
      crc 1 = d9c69382
      crc 2 = bc706624
      crc 3 = 29cd3779
      gpt_head->header_crc32 = 0x892c53ba
      GPT----part num 8---
      gpt_entry: 128
      gpt_header: 92
      GPT:boot-resource: a1f8          c177
      GPT:env         : c178          c36f
      GPT:env-redund  : c370          c567
      GPT:boot        : c568          1161f
      GPT:rootfs      : 11620         1b597
      GPT:dsp0        : 1b598         1b987
      GPT:recovery    : 1b988         227c7
      GPT:UDISK       : 227c8         ffffffde
      update gpt file ok
      update mbr file ok
      temp = 20
      mbr count = 4 total_sectors = 15269888 logic_offset = 40960
      mbr size = 252
      mbr magic softw411
      disk name=env
      disk name=boot
      disk name=rootfs
      disk name=dsp0
      disk name=recovery
      crc 0 = 4c7bc2df
      crc 1 = d9c69382
      crc 2 = bc706624
      crc 3 = 29cd3779
      gpt_head->header_crc32 = 0x1328fa28
      gpt_entry: 128
      gpt_header: 92
      GPT:env         : c178          c36f
      GPT:UDISK       : 227c8         e8ffde
      update gpt file ok
      update mbr file ok
      cp sys parttion.fex  for dragon.fex ++++++++++++++++++++++++++++
        [mbr]
        mbr_size  : 252 Kbyte
        partition_name  : boot-resource
        partition_size  : 8064
        boot-resource.fex size : 3.0M byte
        partition_name  : env
        partition_size  : 504
        downloadfile  : env.fex
        env.fex size : 128K byte
        partition_name  : env-redund
        partition_size  : 20664
        downloadfile  : boot.fex
        boot.fex -> /home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/boot.img
        boot.img size : 5.0M byte
        partition_name  : rootfs
        partition_size  : 40824
        downloadfile  : rootfs.fex
        rootfs.fex -> /home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/rootfs.img
        rootfs.img size : 5.9M byte
        partition_name  : dsp0
        partition_size  : 1008
        downloadfile  : dsp0.fex
        dsp0.fex size : 249K byte
        partition_name  : recovery
        partition_size  : 28224
      /home/book/D1s-Core/tina-d1-h/out/host/bin/
      Begin Parse sys_partion.fex
      FilePath: boot-resource.fex
      FileLength=2f8c00Add partion env.fex ENV_FEX000000000
      FilePath: env.fex
      FileLength=20000Add partion env.fex ENV_FEX000000000
      FilePath: env.fex
      FilePath: boot.fex
      FileLength=4f4000Add partion rootfs.fex ROOTFS_FEX000000
      FilePath: rootfs.fex
      FileLength=5e0000Add partion dsp0.fex DSP0_FEX00000000
      Add partion very dsp0.fex DSP0_FEX00000000
      FilePath: dsp0.fex
      FileLength=3e38cBuildImg 0
      ----------image is for nand/emmc----------
      /home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/tina_d1-h-nezha_uart0.img
      pack finish
      分析打包过程
      从上述log可以看出整个打包过程大致分为这么几个步骤
      1. 指定一些比较环境变量,比如镜像输出目录 镜像的一些配置信息。
      2. 之后将镜像拷贝到需要打包的目录下,开始进行统一处理
      3. 根据文件系统分区信息,将其转换成 适合后续程序使用的格式。
      4. 转换分区信息为 专门的GPT/MBR分区头部。
      5. 使用dragon打包,将所有配置文件里指定的文件,进行汇总,打包输出。
      使用命令操作 主要分为4步
      busybox unix2dos sys_partition.fex
      tina-d1-h/tools/pack-bintools/src/script  sys_partition.fex
      tina-d1-h/tools/pack-bintools/src/update_mbr  sys_partition.bin 4
      tina-d1-h/tools/pack-bintools/src/dragon  image.cfg sys_partition.fex
      dragon分析
      这里面 最关键的就是 sys_partition.fex 文件,它定义了分区的信息 以及大小等。
      可以进入 编译后的 tina-d1-h/out/d1-h-nezha/image 目录下查看。
      我们可以直接cat sys_partition.fex文件
      book@virtual-machine:~/D1s-Core/tina-d1-h/out/d1-h-nezha/image$ cat sys_partition_for_dragon.fex
      ;    mbr的大小, 以Kbyte为单位
      [mbr]
      size = 252
      ;  partition 定义范例:
      ; 注:1、name唯一, 不允许同名
      ;     2、name最大12个字符
      ;     4、align to logical block size(504 sectors), leb size = 2*(1 nand phy block size - 1 phy page size)
      [partition_start]
      [partition]
          name         = boot-resource
          size         = 8064
          user_type    = 0x8000
      [partition]
          name         = env
          size         = 504
          downloadfile = "env.fex"
          user_type    = 0x8000
      [partition]
          name         = env-redund
          size         = 504
          user_type    = 0x8000
      [partition]
          name         = boot
          size         = 20664
          downloadfile = "boot.fex"
          user_type    = 0x8000
      [partition]
          name         = rootfs
          size         = 40824
          downloadfile = "rootfs.fex"
          user_type    = 0x8000
      [partition]
          name         = dsp0
          size         = 1008
          downloadfile = "dsp0.fex"
          user_type    = 0x8000
      [partition]
          name         = recovery
          size         = 28224
          ;downloadfile = "recovery.fex"
          user_type    = 0x8000
      这里面所有的 downloadfile文件 都是我们编译出来要烧写的文件。所以只需要把相应的文件放到这个目录下,就可以进行打包操作了。
      如果你在不改变 文件大小的前提下,可以直接执行tina-d1-h/tools/pack-bintools/src/dragon image.cfg sys_partition.fex 命令,你会发现它生成了一个 tina_d1-h-nezha_uart0.img,镜像,这个镜像是和使用pack命令打包生成的一样。
      那么这里面还有一个 img.cfg文件。这个文件里面包含了很多 fex二进制文件,目前我认为这些文件都是和全志官方的烧写工具绑定死的,所以不用管它,只要制作的时候 当前目录下有这些工具即可。
      有了这两个文件以后,就可以直接使用 dragon打包生成可以用 凤凰烧写器 烧写的系统镜像啦。
      sys_partiton分析
      如果你的系统镜像格式 一直保持大小不变,那么上面这个命令 就可以一直用,但是这个时候 我想自己编译内核 增加 驱动模块,编译文件系统 增加组件 导致系统镜像变大了 这要怎么办?
      简单点,直接修改 sys_partition.fex为 文件大小不就可以了吗?
      但是你会发现 这样做不行,他会提示错误。
      这个时候 我们就要继续分析 log日志输出了,会发现,我们执行 dragon打包 只有下面这些输出信息,没有上面的 GPT/MBR分区信息。
      /home/book/D1s-Core/tina-d1-h/tools/pack-bintools/src/
      FilePath: env.fex
      FilePath: env.fex
      FilePath: boot.fex
      FilePath: dsp0.fex
      那么这个时候 就需要往回找,这个文件是哪里来的 怎么生成的?
      通过 搜索 分析 发现是 来自于 sys_partiton.bin 文件,但是这个文件又是一个 二进制文件,而且也是后面打包生成的,那么还是要继续往回找 sys_partition.bin文件又是怎么生成的。
      同样是结合log 加打印
      找到了 如下这两个命令。
      一开始以为这个 script 是ubuntu的某一个包,后来发现也是一个全志自家提供的工具。
      既然 工具都找全了 那我们可以修改试试看。
      修改 sys_partition.fex 把它的大小 调整为 70824
      之后保存退出,从头执行如下命令 来确认猜想是否正确。
      book@virtual-machine:~/D1s-Core/tina-d1-h/out/d1-h-nezha/image$ busybox unix2dos sys_partition.fex
      book@virtual-machine:~/D1s-Core/tina-d1-h/out/d1-h-nezha/image$ ~/D1s-Core/tina-d1-h/tools/pack-bintools/src/script  sys_partition.fex
      argc = 2
      parser 1 file ok
      book@virtual-machine:~/D1s-Core/tina-d1-h/out/d1-h-nezha/image$ ~/D1s-Core/tina-d1-h/tools/pack-bintools/src/update_mbr  sys_partition.bin 4
      mbr count = 4
      mbr size = 252
      mbr magic softw411
      disk name=env
      disk name=boot
      disk name=rootfs
      disk name=dsp0
      disk name=recovery
      crc 0 = ea84dacc
      crc 1 = 7f398b91
      crc 2 = 1a8f7e37
      crc 3 = 8f322f6a
      gpt_head->header_crc32 = 0x53fc3a66
      gpt_entry: 128
      gpt_header: 92
      GPT:env         : c178          c36f
      GPT:rootfs      : 11620         22ac7
      GPT:dsp0        : 22ac8         22eb7
      GPT:recovery    : 22eb8         29cf7
      GPT:UDISK       : 29cf8         ffffffde
      update gpt file ok
      update mbr file ok
      book@virtual-machine:~/D1s-Core/tina-d1-h/out/d1-h-nezha/image$ ~/D1s-Core/tina-d1-h/tools/pack-bintools/src/dragon  image.cfg sys_partition.fex
      FilePath: env.fex
      FilePath: env.fex
      FilePath: boot.fex
      FilePath: dsp0.fex
      最后在当前目录下 生成了一个 名为 tina_d1-h-nezha_uart0.img 文件,把它用 凤凰烧录 工具烧录进去。
      你会发现你可以把你增加过文件的分区 烧进去 并启动啦。
      那么这个时候,还存在一个问题,就是D1使用的都是 squashfs 类型的文件系统,这个时候,你也需要分析一下 他们的这个文件系统 生产方式,这个就可以借助 grep 命令了,参考如下。
      分析文件系统生成方式
      最后得到 这个
      rootfs.squashfs -noappend -processors 9 -nopad -noappend -root-owned -comp xz -b 256k -p '''/dev d 755 0 0''' -p '''/dev/console c 600 0 0 5 1''' -processors 4\n' >> /home/book/buildroot_dshannezhastu/buildroot-awol/output/build/buildroot-fs/squashfs/fakeroot
      然后 把它 扔进 buildroot 就可以制作出 可以供 D1内核使用的系统,
      注意 tina的环境变量里面的 init 进程位置和buildroot 不一样 需要修改。
      最后 给大家放上,我们已经支持过 NEZHA D1的buildroot完整系统镜像源码
      https://github.com/DongshanPI/buildroot_dshannezhastu
      clone下来后,需要更新git 子模块 执行如下命令来拉取子模块的源码。
      git submodule update --init --recursive
      git submodule update --recursive --remote
      git pull --recurse-submodules
      之后进入 buildroot-awol 目录下,稍等一会 就可以生成 供spi nand 烧写的flash镜像了。 当然,也可以烧到tf卡启动。。
      buildroot_dshannezhastu/buildroot-awol$ make BR2_DL_DIR=../Download BR2_EXTERNAL=../br2nezhastu/ dshannezhastu_spinand_core_defconfig
      编译完成后的输出信息。
      镜像输出在 output/images/目录下
      baiwen D 2 条回复 最后回复 回复 引用 分享 4
      • baiwen
        100ask LV 6 @baiwen 最后由 编辑
        @allwinnertech 知道了这些以后,后面就可以 直接抛开 任何的 自动构建系统,来从零自己撸Linux系统了。前面已经告诉了 大家怎么 兼容buildroot 编译各个部分。。
        J 1 条回复 最后回复 回复 引用 分享 1
          Juggernaut LV 5 @baiwen 最后由 编辑
          @allwinnertech 大佬牛逼
          • E
            elliott LV 4 最后由 编辑
            好帖。自定义制作镜像很有帮助。
              dream LV 6 @baiwen 最后由 编辑
              @allwinnertech 好贴,感谢分享。
              • Referenced by  baiwen baiwen
                yuwei LV 6 最后由 编辑
                好帖子 。。。。。。。。。。。。
                  dsxiang LV 3 最后由 xiaowenge 编辑
                  刷机时会提示错误
