    D1s Tina SDK 2.0中tplayer问题
    6
    10
    9418
    • F
      fengshulin LV 3 最后由 编辑
      1.使用的板子是芒果派MQ-R
      2.刷入的镜像是基于Tina SDK 2.0构建,并打了Tina_d1x_append补丁。
      3.使用tplayerdemo /root/test.mp4指令,可以播放视频,播放完成后,直接卡死。输入指令quit,也无效。
      部分打印logo如下:
      root@TinaLinux:/usr/bin# tplayerdemo /root/test.mp4
      WARNING: awplayer <cdx_log_set_level:30>: cdx Set log level to 6
      INFO   : cedarc <CedarPluginVDInit:79>: register h264 decoder success!
      INFO   : cedarc <CedarPluginVDInit:84>: register mjpeg decoder success!
      INFO   : cedarc <CedarPluginVDInit:86>: register mpeg2 decoder success!
      INFO   : cedarc <CedarPluginVDInit:92>: register mpeg4dx decoder success!
      INFO   : cedarc <CedarPluginVDInit:79>: register mpeg4H263 decoder success!
      INFO   : cedarc <CedarPluginVDInit:90>: register mpeg4Normal decoder success!
      INFO   : cedarc <CedarPluginVDInit:74>: register vc1 decoder success!
      INFO   : cedarc <CedarPluginVDInit:85>: register h265 decoder success!
      INFO   : cedarc <CedarPluginVDInit:70>: register vp6Soft decoder success!
      INFO   : cedarc <CedarPluginVDInit:88>: register Wmv12Soft decoder success!
      * This program implements a simple player, you can type commands to control the player.
      * To show what commands supported, type 'help'.
      dd: writing '/dev/fb0': No space left on device
      6001+0 records in
      6000+0 records out
      argc = 2
      argv[0] = tplayerdemo
      argv[1] = /root/test.mp4
      may be is one file:cut down suffix is:.mp4
      find the matched type:.mp4
      create player:0
      tag   : tina3.5
      branch: tina-dev[SNDCODEC][sunxi_card_hw_params][620]:stream_flag: 0
      xplayer:process message XPLAYER_COMMAND_SET_AUDVE: enable hw clock
      IOSINK.
      xplayer:process messageenable_cedar_hw_clk,552
       XPLAYER_COMMAND_SET_SURFACE.
      xplayer:process message XPLAYER_CVE: VE real_freq=576000000
      OMMAND_SET_SUBCTRL.
      xplayer:process message XPLAYER_COMMAND_SET_DI.
      create player[0]:0xfec29d0
      screen width:800,screen height:480
      1:playVideo:0
      before TPlayerSetDataSource,94712:/root/test.mp4
      xplayer:process message XPLAYER_COMMAND_SET_SOURCE.
      xplayer:process message XPLAYER_COMMAND_PREPARE.
      INFO   : cedarc <log_set_level:43>: Set log level to 5 from /vendor/etc/cedarc.conf
      ERROR  : cedarc <DebugCheckConfig:301>: now cedarc log level:5
      setDataSource end
      *****tplayer:video width = 640,height = 480
      warning: unknown callback from Tinaplayer.
      TPLAYER_NOTIFY_PREPARED,has prepared.
      TPlayerPrepare end
      TPlayerSetHoldLastPicture()
      xplayer:process message XPLAYER_COMMAND_START.
      (Allwinner Audio Middle Layer),line(971) : Create Decoder!!=====
      (Allwinner Audio Middle Layer),line(603) : AudioDec_Installaudiolib ok
      (Allwinner Audio Middle Layer),line(606) : audio decoder init start ...
      (AllwinnerAlibs),line(50) :
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Audio <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      tag   : audiocodec-v1.2
      branch: new
      commit: 3ba65962c01cbf1280ddda19d843009b6ef8ce85
      date  : Tue Jan 8 16:25:27 2019 +0800
      (AllwinnerAlibs),line(700) : ----Loading so success!
      (AllwinnerAlibs),line(902) : *************pAudioStreamInfo start******************
      (AllwinnerAlibs),line(903) : eCodecFormat         :id(4), name(aac low-complexy)
      (AllwinnerAlibs),line(904) : eSubCodecFormat      :0
      (AllwinnerAlibs),line(905) : nChannelNum          :2
      (AllwinnerAlibs),line(906) : nBitsPerSample       :16
      (AllwinnerAlibs),line(907) : nSampleRate          :44100
      (AllwinnerAlibs),line(908) : nAvgBitrate          :128135
      (AllwinnerAlibs),line(909) : nMaxBitRate          :128135
      (AllwinnerAlibs),line(910) : nFileSize            :0
      (AllwinnerAlibs),line(911) : eAudioBitstreamSource:0
      (AllwinnerAlibs),line(912) : eDataEncodeType      :0
      (AllwinnerAlibs),line(913) : nCodecSpecificDataLen:2
      (AllwinnerAlibs),line(914) : pCodecSpecificData   :0x3fe8064dc0
      (AllwinnerAlibs),line(915) : nFlags               :0
      (AllwinnerAlibs),line(916) : nBlockAlign          :0
      (AllwinnerAlibs),line(917) : *************pAudioStreamInfo end  ******************
      (AAC Decoder),line(36) : init successs...
      (Allwinner Audio Middle Layer),line(614) : AUDIO DECODE INIT OK...0
      started.
      ERROR  : awplayer <__LayerQueueBuffer:969>: *** picNode is full when queue buffer
      *****tplayer:video decoded width = 640,height = 480
      *****tplayerdemo:video decoded width = 640,height = 480real set to display rect:w = 640,h = 480
      ****player(0xfec4db0): first video pts = 66733*****
      ERROR  : fbm.c <FbmReturnPicture:1043>: invalid frame status, a picture being returned,                 but bUsedByRender=0, bInValidPictureQueue=1, bAlreadyDisplayed=0.
      ERROR  : fbm.c <FbmReturnPicture:1044>: **picture[0x3fe4001f08],id[8]
      WARNING: cedarc <ReturnPicture:1698>: FbmReturnPicture return fail,            it means the picture being returned it not one of this FBM.
      tplayerdemo#
      tplayerdemo#
      tplayerdemo#
      tplayerdemo#
      tplayerdemo# quit
      tplayerdemo# COMMAND_QUIT
      xplayer:process message XPLAYER_COMMAND_RESET.
      ^CGot signal 2, exiting ...
      • Q
        quanzhiddd LV 5 最后由 编辑
        请问这个问题现在解决了吗,我也遇到了这个问题
          YterAA LV 7 最后由 编辑
          播放之前建立音频通路、或者关闭音频输出播放
          Q 1 条回复 最后回复 回复 引用 分享 0
          • Q
            quanzhiddd LV 5 @YterAA 最后由 编辑
            @yteraa 感谢大佬,提前打开音频通路后解决了
            L S 2 条回复 最后回复 回复 引用 分享 0
              lyzzhdj LV 2 @quanzhiddd 最后由 编辑
              @quanzhiddd 请教:如何打开音频通道?
              多谢
                soso90 LV 7 @quanzhiddd 最后由 编辑
                @quanzhiddd 同问,如何打开音频通路~~
                T 1 条回复 最后回复 回复 引用 分享 0
                • T
                  TEVET LV 7 @soso90 最后由 编辑
                  @soso90
                  我有点好奇,这个不是要配上asound.conf 就行了嘛。
                  make menuconfig -> Allwinner -> alsa-conf-aw
                  勾上,舒服一下
                  L 1 条回复 最后回复 回复 引用 分享 2
                    lyzzhdj LV 2 @TEVET 最后由 编辑
                    @tevet 你好,我的这个选项是配置着的,现象和楼主一样
                    • Q
                      quanzhiddd LV 5 @lyzzhdj 最后由 编辑
                      @lyzzhdj 需要用到tinymix组件,在menuconfig中搜索,然后打开。以打开LINEOUT双通道喇叭为例,依次在终端中输入
                      tinymix set 15 31
                      tinymix set 17 1
                      tinymix set 18 1
                      tinymix set 31 1
                        lyzzhdj LV 2 最后由 编辑
                        我根据 quanzhiddd的提示,用TEVET 提到的ALSA组件中的amixer实现了,具体命令是
                        amixer -Dhw:audiocodec cset name='LINEOUT Switch' 1
                        刚接触linux对系统不熟悉,多谢2位的帮助
